I would like to backport the WMS optional flags to remove root Layer in Capabilities documents.
When the flags are not set the default is to use the old behaviour (always add a root Layer), so it should be safe to backport.
Any concern?
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
