[Geoserver-devel] Backporting H2 classpath changes to GeoServer 2.23.x
I’m writing to request a backport of the H2 removal from core modules.
It amounts to removing a direct H2 dependency in GWC disk quota, and the same for KML superoverlay support, replacing the database using HSQL.
In both cases, the database is not migrated, but rebuilt, as it only contains information that can be rebuilt from the data available (tiles and features).
The pull requests involved are the following:
The work was carried out so that transparent switch happens without any user intervention, but there is documentation for the one use case where some intervention is needed:
https://docs.geoserver.org/latest/en/user/installation/upgrade.html#disk-quota-hsql-db-usage-geoserver-2-24-and-newer
Opinions?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Seems reasonable to me. +1
Ian
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
+1 here as well, this has been bothering us for a while now…
Simone Giannecchini
Online training classes for GeoNode, GeoServer and MapStore from the experts!
Visit https://www.geosolutionsgroup.com/professional-training/ for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director GeoSolutions Italy
President GeoSolutions USA
mob: +39 333 8128928
US: +1 (845) 547-7905
http://www.geosolutionsgroup.com
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
+1 the upgrade path sounds reasonable to me
Simone Giannecchini
@simogeo
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
+1
Torben
Simone Giannecchini
@simogeo
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
Nuno Oliveira
@nmcoliveira
GeoSolutions Group
