recently a colleague of mine tapped a hole in the management of URL checks: the checks could be managed by GUI, but had no REST API for automatic configuration:
https://github.com/geoserver/geoserver/pull/7582
As a new functionality, formally we have to wait a month before backporting to stable.
On the other hand, the functionality is 99% self contained, and should not break anything if not used (I invite you to double check in the PR).
So, I’d like to propose backporting it to 2.25.x without further wait.
And then.. What about 2.24.x? Do you think a backport there would be a good thing too?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
