[Geoserver-devel] Branching GeoFence 2.2.x -- Re: geofence geoserver integration
Hi Niels,
ok, some changes in the geofence branches and versions:
- Current master has been branched to "2.2.x",
- The user-role refactoring branch is going to be merged into master, which
will be bumped to version 3.0. This major version change is due to the changes
in the base model that will make the previous version uncompatible.
For the GeoFence community module in GeoServer 2.7 we'll have to use the
GeoFence 2.2.x branch, in order to have the DTOs matching, while GeoServer
master (2.8) will use GeoFence master (3.0).
   Emanuele
Alle 16:33:31 di Monday 6 April 2015, Niels Charlier ha scritto:
I made a pull request for the changes on geoserver:
https://github.com/geoserver/geoserver/pull/1005
I've put it there already mainly to get commenting and reviewing going.
But I do hope we can sort out how to get these changes in the official
branches of geofence and geoserver soon!
Let me know what you think.
Regards
Niels
On 06-04-15 11:55, Niels Charlier wrote:
> Hi Emanuele,
> Are the geofence refactoring commits going to be pulled in the master
> branch in the official repo?
> Because I almost have a pull ready for gs-geofence-server but it
> depends on those changes being there.
> Also, I have found a work-around for my eclipse issue. While you can't
> manipulate the dependency order of included projects from the GUI,
> there is an order inside the config file behind it (.classpath file in
> the project dir). The order of the pom doesn't seem to be respected,
> but I can manually do it. After running maven eclipse:eclipse, I
> manually edit the .classpath file and move the model-internal
> dependency above the gs-geofence dependency. That is the best solution
> for now, but still a bit annoying. There is another really annoying
> thing in eclipse, there is an application-context.xml in test and it
> reads it of course.
> Regards
> Niels
> On 02-04-15 13:01, Emanuele Tajariol wrote:
>> Hi Niels,
>>> * Let gs-geofence also use model-internal, but it is probably not
>>> desire
>>> to have all that unnecessary hibernate stuff loaded.
>> Exactly: the split model was created only because gs-geofence did
>> import too
>> much hibernate stuff inside geoserver.
>>> * Make them different classes (or in different packages) but use
>>> interfaces instead for compatibility? Probably would require lots of
>>> refactoring inside geofence.
>>> * Can we somehow force geofence-server to use the classes from
>>> geofence-model-internal even if both are on the classpath? It seems
>>> that
>>> java will always use the _first_ on the classpath, but eclipse doesn't
>>> recognise an order in project dependencies
>> These solutions are quite complex, and would be a workaround for a
>> workaround
>> (the split model).
>> I guess the simpler way would be to only have a single model module,
>> and to
>> remove the hibernate annotations using the hbm files instead.
>> I tried to use the hibernate tools for automatically creating the hbm
>> files out
>> of the annotations, but they seemed quite bugged. Do you have any
>> experience
>> with them?
>> Cheers,
>> Emanuele
>> Alle 12:17:37 di Thursday 2 April 2015, Niels Charlier ha scritto:
>>> Hi,
>>> I have a practical problem regarding the difference between
>>> geofence-model and geofence-model-internal.
>>> They both contain the same classes, but geofence-model removes the
>>> hibernate annotations from the build.
>>> gs-geofence uses geofence-model while gs-geofence-server needs
>>> gs-geofence-model-internal. I solved this earlier by putting an
>>> exclusion in the geofence-server profile of the web-app pom. The
>>> problem
>>> is however eclipse. When you do mvn eclipse:eclipse inside web-app,
>>> this
>>> works fine. However, eclipse doesn't add any of the geoserver
>>> modules as
>>> "required projects" in the build path, but rather as regular external
>>> jar files, so you miss the relationship between the code and this
>>> brings
>>> inconveniences while programming and debugging.
>>> To solve that you have to do eclipse:eclipse from the geoserver source
>>> root. But then eclipse doesn't recognise the exclusion... and keeps
>>> loading the classes from model. And geofence-server doesn't work
>>> without
>>> the hibernate annotations.
>>> So, do you guys have any ideas for solutions?
>>> desire
>>> that
>>> Any suggestions?
>>> Regards
>>> Niels
>>> On 27-03-15 17:16, Emanuele Tajariol wrote:
>>>> Hi Niels,
>>>>> What does this setting do: "Use GeoServer roles to get
>>>>> authorizations"?
>>>> GeofencePage.useRolesToFilter=Use GeoServer roles to get
>>>> authorizations
>>>> it's related to this proposal:
>>>> https://github.com/geosolutions-it/geofence/wiki/Proposal-%233:-GeoSer
>>>> ver
>>>> - Roles-to-GeoFence-groups-mapping#configuration
>>>> It makes the AccessManager query geofence the authorization not for
>>>> the
>>>> accessing user, but by the role the user is assigned in GeoServer
>>>> See also method setRuleFilterUserOrRole.
>>>> If the roles in geoserver are exactly the same as in geofence (as the
>>>> current integration work aims to) it should not matter, since the
>>>> resulting auths will be the same.
>>>> I mean: if the useRolesToFilter is set to true, the user-role matching
>>>> will be done in setRuleFilterUserOrRole. If it's set to false, such
>>>> matching will be performed inside geofence, using the metod
>>>> UserResolver::getRoles
>>>> Cheers,
>>>> Emanuele
>>>> Alle 16:50:58 di Friday 27 March 2015, Niels Charlier ha scritto:
>>>>> Hi Emanuele,
>>>>> Excellent. What does this setting do: "Use GeoServer roles to get
>>>>> authorizations"?
>>>>> Regards
>>>>> Niels
>>>>> On 27-03-15 14:49, Emanuele Tajariol wrote:
>>>>>> Hi Niels,
>>>>>>> The user/group integration work is that ready or does it still need
>>>>>>> work?
>>>>>> It's ready. The rule engine needs info about the user, the role and
>>>>>> their association. You can provide these info by implementing this
>>>>>> interface
>>>>>> https://github.com/etj/geofence/blob/201503_user_role_refact/src/ser
>>>>>> vic
>>>>>> es /core/services-
>>>>>> api/src/main/java/org/geoserver/geofence/spi/UserResolver.java
>>>>>> and aliasing this spring bean with the new implementation
>>>>>> vic
>>>>>> es /core/services-
>>>>>> impl/src/main/resources/applicationContext.xml#L24
>>>>>> The default UserResolver uses the DAO toward the geofence DB
>>>>>> vic
>>>>>> es /core/services-
>>>>>> impl/src/main/java/org/geoserver/geofence/services/DefaultUserResolv
>>>>>> er.
>>>>>> j ava
>>>>>> but I guess you'll have to return the users and roles actually
>>>>>> used in
>>>>>> GeoServer.
>>>>>> Cheers,
>>>>>> Emanuele
>>>>>> Alle 21:23:40 di Thursday 26 March 2015, Niels Charlier ha scritto:
>>>>>>> On 26-03-15 16:49, Andrea Aime wrote:
>>>>>>>> Speaking of hibernate, wondering what might happens if geofence
>>>>>>>> and
>>>>>>>> the monitoring hibernate extension are both loaded in GeoServer.
>>>>>>> Yeah I haven't tested with the hibernate extension yet. That could
>>>>>>> indeed cause more trouble
>>>>>>>> What if the GEOSERVER_DATA_DIR system variable is not defined?
>>>>>>>> It's
>>>>>>>> not mandatory.
>>>>>>>> I guess you could create a subclass of PropertyOverrideConfigurer
>>>>>>>> depending on GeoServerResourceLoader and
>>>>>>>> get the base directory there.
>>>>>>> think
>>>>>>> You are right. Something similar has been done in the geofence
>>>>>>> module
>>>>>>> for the PropertyPlaceholderConfigurer, will use the same principle.
>>>>>>> Consider the current version kind of a proof of concept, will still
>>>>>>> need to fine-tune it.
>>>>>>>> The other thing that bother me a bit, but it's GeoFence own fault,
>>>>>>>> it's this business of setting up the data source
>>>>>>>> inside the Spring context instead of creating it programmatically,
>>>>>>>> allowing the data source to be read from some
>>>>>>>> config file, and allow its re-configuration at runtime.
>>>>>>>> In the long run it would be best if the integrated GeoFence could
>>>>>>>> start off H2, but allowed configuration
>>>>>>>> to store the rules somewhere else at runtime, without need for
>>>>>>>> restarts.
>>>>>>> Yeah some of the client settings also require a restart for the
>>>>>>> same
>>>>>>> reason. The server URL anyway, but that doesn't apply with the
>>>>>>> internal server.
>>>>>>> work?
>>>>>>> Regards
>>>>>>> Niels
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hello Emanuele,
That sounds good. When the geofence 3.0 branch is there I will update the versions in the geoserver modules.
Thanks! Let me know if you need anything else from me.
Regards
Niels
On 07-04-15 12:40, Emanuele Tajariol wrote:
Hi Niels,
    Emanuele
Regards
Niels
Hi Emanuele,
reads it of course.
Regards
Niels
Hi Niels,
desire
import too
that
workaround
(the split model).
and to
files out
experience
with them?
     Emanuele
problem
this
modules as
brings
without
desire
that
Any suggestions?
Regards
Niels
Hi Niels,
authorizations"?
      authorizations
ver
the
      Emanuele
Hi Emanuele,
authorizations"?
Regards
Niels
Hi Niels,
work?
interface
vic
es /core/services-
vic
es /core/services-
vic
es /core/services-
er.
j ava
used in
GeoServer.
       Emanuele
and
It's
not mandatory.
think
module
restarts.
same
internal server.
work?
Regards
Niels
Hi Niels,
On master branch the version has been updated to 3.0-SNAPSHOT:
   https://github.com/geoserver/geofence/blob/master/src/pom.xml#L15
The refactor branch has already been merged into master.
   Emanuele
Alle 12:55:36 di Wednesday 8 April 2015, Niels Charlier ha scritto:
Hello Emanuele,
Regards
Niels
> Hi Niels,
> which will be bumped to version 3.0. This major version change is due to
> the changes in the base model that will make the previous version
> uncompatible.
> GeoServer master (2.8) will use GeoFence master (3.0).
> Cheers,
> Emanuele
>> Regards
>> Niels
>>> Hi Emanuele,
>>> reads it of course.
>>> Regards
>>> Niels
>>>> Hi Niels,
>>>>> desire
>>>> import too
>>>>> that
>>>>> doesn't recognise an order in project dependencies
>>>> workaround
>>>> (the split model).
>>>> and to
>>>> files out
>>>> experience
>>>> with them?
>>>> Cheers,
>>>> Emanuele
>>>>> Hi,
>>>>> problem
>>>>> this
>>>>> modules as
>>>>> brings
>>>>> source root. But then eclipse doesn't recognise the exclusion... and
>>>>> keeps loading the classes from model. And geofence-server doesn't
>>>>> work without
>>>>> desire
>>>>> that
>>>>> Any suggestions?
>>>>> Regards
>>>>> Niels
>>>>>> Hi Niels,
>>>>>>> authorizations"?
>>>>>> authorizations
>>>>>> er ver
>>>>>> the
>>>>>> the current integration work aims to) it should not matter, since
>>>>>> the resulting auths will be the same.
>>>>>> matching will be done in setRuleFilterUserOrRole. If it's set to
>>>>>> false, such matching will be performed inside geofence, using the
>>>>>> metod UserResolver::getRoles
>>>>>> Cheers,
>>>>>> Emanuele
>>>>>>> Hi Emanuele,
>>>>>>> authorizations"?
>>>>>>> Regards
>>>>>>> Niels
>>>>>>>> Hi Niels,
>>>>>>>>> need work?
>>>>>>>> and their association. You can provide these info by implementing
>>>>>>>> this interface
>>>>>>>> er vic
>>>>>>>> es /core/services-
>>>>>>>> er vic
>>>>>>>> es /core/services-
>>>>>>>> er vic
>>>>>>>> es /core/services-
>>>>>>>> lv er.
>>>>>>>> j ava
>>>>>>>> used in
>>>>>>>> GeoServer.
>>>>>>>> Cheers,
>>>>>>>> Emanuele
>>>>>>>>>> and
>>>>>>>>> could indeed cause more trouble
>>>>>>>>>> It's
>>>>>>>>>> not mandatory.
>>>>>>>>>> PropertyOverrideConfigurer depending on GeoServerResourceLoader
>>>>>>>>>> and
>>>>>>>>> think
>>>>>>>>> module
>>>>>>>>> principle. Consider the current version kind of a proof of
>>>>>>>>> concept, will still need to fine-tune it.
>>>>>>>>>> fault, it's this business of setting up the data source
>>>>>>>>>> programmatically, allowing the data source to be read from some
>>>>>>>>>> could start off H2, but allowed configuration
>>>>>>>>>> restarts.
>>>>>>>>> same
>>>>>>>>> internal server.
>>>>>>>>> need work?
>>>>>>>>> Regards
>>>>>>>>> Niels
Technical Lead
Emanuele,
Thanks! I have added the version updates to my pull request.
Something else, I need to also make a REST API available on the integrated geofence. Of course I only need the Rules API.
Do you have any recommendations on how to do that? You reckon I should make a new one in geoserver and copy-paste or could I depend on a module and configure to publish it? What are your thoughts?
Regards
Niels
On 08-04-15 13:47, Emanuele Tajariol wrote:
Hi Niels,
    Emanuele
Hello Emanuele,
Regards
Niels
Hi Niels,
uncompatible.
     Emanuele
Regards
Niels
Hi Emanuele,
reads it of course.
Regards
Niels
Hi Niels,
desire
import too
that
workaround
(the split model).
and to
files out
experience
with them?
      Emanuele
problem
this
modules as
brings
work without
desire
that
Any suggestions?
Regards
Niels
Hi Niels,
authorizations"?
       authorizations
er ver
the
       Emanuele
Hi Emanuele,
authorizations"?
Regards
Niels
Hi Niels,
need work?
this interface
er vic
es /core/services-
er vic
es /core/services-
er vic
es /core/services-
lv er.
j ava
used in
GeoServer.
        Emanuele
and
It's
not mandatory.
and
think
module
restarts.
same
internal server.
need work?
Regards
Niels
Hi Niels,
GeoFence used to provide a REST interface,
   https://github.com/geoserver/geofence/tree/master/src/services/modules/rest
but, after the last improvements and refactoring, it needs some review and
fixing.
You can find the (old) related doc here:
    http://goo.gl/NjkvGn
(it was partially ported into github wiki pages, but the paragraph formatting
is awful there).
REST services are implemented using CXF, so it is also to be seen if CXF (and
its transitive deps) will not present any conflict when running inside
GeoServer.
It's also to be checked/decided if the GeoServer dispatcher could/should be
used to route such REST calls.
I guess Andrea could give some hints about how to publish the API.
   Emanuele
Alle 14:48:11 di Wednesday 8 April 2015, Niels Charlier ha scritto:
Emanuele,
Regards
Niels
> Hi Niels,
> Cheers,
> Emanuele
>> Hello Emanuele,
>> Regards
>> Niels
>>> Hi Niels,
>>> to the changes in the base model that will make the previous version
>>> uncompatible.
>>> the GeoFence 2.2.x branch, in order to have the DTOs matching, while
>>> Cheers,
>>> Emanuele
>>>> going. But I do hope we can sort out how to get these changes in the
>>>> official branches of geofence and geoserver soon!
>>>> Regards
>>>> Niels
>>>>> Hi Emanuele,
>>>>> can't manipulate the dependency order of included projects from the
>>>>> GUI, there is an order inside the config file behind it (.classpath
>>>>> file in the project dir). The order of the pom doesn't seem to be
>>>>> respected, but I can manually do it. After running maven
>>>>> eclipse:eclipse, I manually edit the .classpath file and move the
>>>>> model-internal dependency above the gs-geofence dependency. That is
>>>>> the best solution for now, but still a bit annoying. There is
>>>>> another really annoying thing in eclipse, there is an
>>>>> application-context.xml in test and it reads it of course.
>>>>> Regards
>>>>> Niels
>>>>>> Hi Niels,
>>>>>>> desire
>>>>>> import too
>>>>>>> of refactoring inside geofence.
>>>>>>> that
>>>>>> workaround
>>>>>> (the split model).
>>>>>> and to
>>>>>> hbm files out
>>>>>> experience
>>>>>> with them?
>>>>>> Cheers,
>>>>>> Emanuele
>>>>>>> Hi,
>>>>>>> problem
>>>>>>> this
>>>>>>> modules as
>>>>>>> external jar files, so you miss the relationship between the code
>>>>>>> and this brings
>>>>>>> and keeps loading the classes from model. And geofence-server
>>>>>>> doesn't work without
>>>>>>> desire
>>>>>>> that
>>>>>>> Any suggestions?
>>>>>>> Regards
>>>>>>> Niels
>>>>>>>> Hi Niels,
>>>>>>>>> authorizations"?
>>>>>>>> authorizations
>>>>>>>> oS er ver
>>>>>>>> for the
>>>>>>>> Cheers,
>>>>>>>> Emanuele
>>>>>>>>> Hi Emanuele,
>>>>>>>>> authorizations"?
>>>>>>>>> Regards
>>>>>>>>> Niels
>>>>>>>>>> Hi Niels,
>>>>>>>>>>> need work?
>>>>>>>>>> implementing this interface
>>>>>>>>>> /s er vic
>>>>>>>>>> es /core/services-
>>>>>>>>>> /s er vic
>>>>>>>>>> es /core/services-
>>>>>>>>>> /s er vic
>>>>>>>>>> es /core/services-
>>>>>>>>>> so lv er.
>>>>>>>>>> j ava
>>>>>>>>>> used in
>>>>>>>>>> GeoServer.
>>>>>>>>>> Cheers,
>>>>>>>>>> Emanuele
scritto:
>>>>>>>>>>>> geofence and
>>>>>>>>>>>> GeoServer.
>>>>>>>>>>>> It's
>>>>>>>>>>>> not mandatory.
>>>>>>>>>>> think
>>>>>>>>>>> module
>>>>>>>>>>>> some config file, and allow its re-configuration at runtime.
>>>>>>>>>>>> restarts.
>>>>>>>>>>> same
>>>>>>>>>>> internal server.
>>>>>>>>>>> need work?
>>>>>>>>>>> Regards
>>>>>>>>>>> Niels
Technical Lead
On Wed, Apr 8, 2015 at 3:40 PM, Emanuele Tajariol <etj@anonymised.com>
wrote:
Hi Niels,
fixing.
formatting
is awful there).
(and
GeoServer.
I guess it depends on where you want to expose the REST api.
If we are talking about adding it below the geoserver/rest endpoint, then
I'm afraid you will have to re-code the geofence rest api using restlet.
If however it's ok to have them under geoserver/geofence/rest (a parallel
to geoserver/gwc/... urls) then there is a chance it can be done without
too much
effort, assuming CXF and its dependencies can be mixed in the GeoServer
classpath without problems.
The GeoWebCache own dispatcher is a Spring AbstractController, it's declared
as a bean in the GeoServer app context and then mapped to its own
url subset as follows:
<bean id="gwcUrlMapping"
class="org.springframework.web.servlet.handler.SimpleUrlHandlerMapping">
    <property name="alwaysUseFullPath" value="true"/>
    <property name="mappings">
      <props>
        <!-- prop key="/gwc/service/**">geowebcacheDispatcher</prop-->
        <prop key="/gwc/demo/**">geowebcacheDispatcher</prop>
    <prop key="/gwc/proxy/**">gwcProxyDispatcher</prop>
    <prop key="/gwc/**">geowebcacheDispatcher</prop>
      </props>
    </property>
  </bean>
Now, in GeoFence CXF is enabled using this declaration in web.xml:
<servlet-mapping>
<servlet-name>CXFServlet</servlet-name>
<url-pattern>/rest/*</url-pattern>
</servlet-mapping>
Spring provides a particular AbstractController subclass
called ServletForwardingController
that can forward to a servlet... it's not exactly what we need, but should
be close enough.
So, I guess one could create a special AbstractController wrapping the
CXFServlet, and
then binding it to /geofence/rest
That is hopefully going to do the trick
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Andrea,
Thanks for this suggestion. I can't really find a straight-forward solution to call CXF without the use of a servlet that must be defined in web.xml. And there is only one of those, in web-app where I can't place it because geofence-server is only an extension and you can't force cxf dependencies on web/app. I'm sure there must be a way, but I'm leaning atm towards giving up on that idea, for other reasons as well. We only need the rule service, not any of the other services. CXF seems to always be configured globally over the whole webapp, so even if I did find a way to attach CXF to the /geofence/rest URL, no other libraries could ever use CXF in geoserver because all of it would be linked to that url. I am under the impression CXF is intended as a choice you make for your whole webapp, and in that scenario of course optional modules could add optional services.
So I'm thinking now I'm just going to copy-paste the bare code but reconfigure it with Restlet, or even using spring rest api would be possible, I think.
Regards
Niels
On 08-04-15 15:58, Andrea Aime wrote:
On Wed, Apr 8, 2015 at 3:40 PM, Emanuele Tajariol <etj@anonymised.com <mailto:etj@anonymised.com>> wrote:
    Hi Niels,
    review and
    fixing.
    formatting
    is awful there).
    if CXF (and
    GeoServer.
    could/should be
to geoserver/gwc/... urls) then there is a chance it can be done without too much
<bean id="gwcUrlMapping" class="org.springframework.web.servlet.handler.SimpleUrlHandlerMapping">
      <props>
      </props>
    </property>
  </bean>
<servlet-mapping>
</servlet-mapping>
Spring provides a particular AbstractController subclass called ServletForwardingController
that can forward to a servlet... it's not exactly what we need, but should be close enough.
So, I guess one could create a special AbstractController wrapping the CXFServlet, and
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Apr 9, 2015 at 10:26 PM, Niels Charlier <niels@anonymised.com> wrote:
Andrea,
web.xml.
What are the challenges? The path I suggested ends up instantiating the
servlet anyways, the servlet context should be available via the
app-context (which is a web application context).
I don't know CXF, so I cannot comment on this one. Emanuele?
possible, I think.
Both should be feasible, yep... it's just a shame to have to rewrite all
that code.
Ing. Andrea Aime
@geowolf
Technical Lead
> Andrea,
> web.xml.
What about using WebApplicationInitializer to programatically
instantiate the CXFServlet?
http://docs.spring.io/spring/docs/current/javadoc-
api/org/springframework/web/WebApplicationInitializer.html
> services.
Dunno: I never used two CXF servlet instances that expose different sets of
endpoints. I can't find any doc about such configuration.
Anyway, should we have different extensions that uses CXF and a single CXF
servlet instance, I guess this could be solved by choosing proper paths for
the calling URLs (e.g.: rest/cxf/geofence, rest/cxf/ext2, ...)
> possible, I think.
that code.
If we'll find that CXF can not be used, you could anyway write a wrapper that
receives calls from the geoserver dispatcher, and delegates to methods in
RESTRuleServiceImpl, without the need to duplicate any code.
   Emanuele
Technical Lead
Hello Emanuele,
This is something new in servlet-api-3.0 which is still in alpha version.
So, yes, indeed, the challenge I was talking about Andrea is to initialize the servlet context programmatically. I do not see this possible in the current latest stable version of servlet-api. We would need to have the whole of geoserver dependant on CXF.
Regards
Niels
  Andrea,
web.xml.
services.
possible, I think.
that code.
    Emanuele
On Sun, Apr 12, 2015 at 9:57 PM, Niels Charlier <niels@anonymised.com> wrote:
Hello Emanuele,
Did you check the possibility of making your wrapper a application context
aware, grab the app context,
which should be a WebApplicationContext, and call getServletContext on it ?
Ing. Andrea Aime
@geowolf
Technical Lead
On 12-04-15 22:03, Andrea Aime wrote:
Did you check the possibility of making your wrapper a application context aware, grab the app context,
How does that help you add a web servlet programmatically? That helps you retrieve existing servlets?
Regards
Niels
Hi Niels,
we can give a deeper look into instancing the CXF servlet programmatically
starting next week.
Is the pull req ready for building the whole stuff, apart from the REST
interface?
   Emanuele
> it ?
Regards
Niels
Technical Lead
Hello Emanuele,
I have decided for other reasons as well the best way forward is to make a new REST for geoserver and I've already been working on it.
I can still copy-paste some of the implementation. Spring API can be very easily plugged in, does not require any additional dependencies and it doesn't differ that much from the CXF system (it is also annotation based). It is less work than restlet. Thanks for your assistence though.
As far as the geofence-server module with GUI, it is ready for review. Everything works for me, I'm keen to have someone else test it. There should only be a warning that it doesn't work when running geoserver from eclipse unless you manipulate the .classpath file (because of the model/model-internal conflict).
Thanks!
Regards
Niels
On 14-04-15 14:23, Emanuele Tajariol wrote:
Hi Niels,
starting next week.
interface?
    Emanuele
it ?
Regards
Niels
since GeoFence 2.2.x has been branched, I guess we need a new directory 2.2.x/
on
    http://ares.boundlessgeo.com/geofence/
where builds for this branch will be put.
Can anybody take care of this?
   Emanuele
Alle 12:40:42 di Tuesday 7 April 2015, Emanuele Tajariol ha scritto:
Hi Niels,
uncompatible.
   Emanuele
Technical Lead
