[Geoserver-devel] Bugs on GetFeature by POST method with GML2-GZIP
Hi, I have a problem with GML2-GZIP output.
When i call GetFeature with GML2-GZIP outputFormat by GET Method. it
runs well. but when I call by POST Method it returns a corrupted Gzip
format...
I know Get&Post on GetFeature get results from FeatureReponse.. Is
the problem here is the transfer data by POST method...
Could you give an advise to solve the problem..
thanks
format...
thanks
Hmmm... I really don't understand this, since get and post really should
handle things in exactly the same way, and digging into the code I
couldn't find a difference. What are you using to test post? If you're
just using the GeoServer TestWfsPost then it _could_ be a problem with
that. But if you submit this as a bug to our JIRA task tracker
(http://jira.codehaus.org/secure/BrowseProject.jspa?id=10311) we'll do our
best to fix it. I looked into it for about 15 minutes this morning,
hoping it would be an easy fix, but wasn't able to figure it out. Any
idea Gabriel?
Chris
