See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/135/changes
Changes:
[aaime] Dependency cleanup
[aaime] Allow data layer deletion
[aaime] Return URLs for layers that have just been created
[aaime] Upload and configure csv file in geoserver, full version (working!)
[...truncated 894 lines...]
1205/236K
1206/236K
1208/236K
1209/236K
1210/236K
1212/236K
1213/236K
1215/236K
1216/236K
1217/236K
1219/236K
1220/236K
1222/236K
1223/236K
1225/236K
1226/236K
1227/236K
1229/236K
1230/236K
1232/236K
1233/236K
1234/236K
1236/236K
1237/236K
1239/236K
1240/236K
1241/236K
1243/236K
1244/236K
1246/236K
1247/236K
1249/236K
1250/236K
1251/236K
1253/236K
1254/236K
1256/236K
1257/236K
1258/236K
1260/236K
1261/236K
1263/236K
1264/236K
1266/236K
1270/236K
1274/236K
1275/236K
1277/236K
1278/236K
1280/236K
1281/236K
1282/236K
1284/236K
1285/236K
1287/236K
1288/236K
1290/236K
1291/236K
1294/236K
1295/236K
1297/236K
1298/236K
1302/236K
1306/236K
1310/236K
1314/236K
1318/236K
1319/236K
1323/236K
1327/236K
1331/236K
1335/236K
1338/236K
236K downloaded
1339/152K
1340/152K
1342/152K
1343/152K
1345/152K
1346/152K
1349/152K
1352/152K
1353/152K
1356/152K
1359/152K
1362/152K
1365/152K
1369/152K
1372/152K
1373/152K
1376/152K
1379/152K
1380/152K
1381/152K
1383/152K
1384/152K
1388/152K
1392/152K
1394/152K
1397/152K
1401/152K
1404/152K
1408/152K
1408/152K
1410/152K
1411/152K
1413/152K
1417/152K
1417/152K
1421/152K
1425/152K
1429/152K
1433/152K
1437/152K
1441/152K
1441/152K
1442/152K
1446/152K
1448/152K
1449/152K
1452/152K
1456/152K
1458/152K
1459/152K
1461/152K
1463/152K
1465/152K
1466/152K
1470/152K
1474/152K
1478/152K
1482/152K
1483/152K
1487/152K
1491/152K
152K downloaded
1493/24K
1496/24K
1498/24K
1502/24K
1502/24K
1505/24K
1506/24K
1508/24K
1509/24K
1510/24K
1512/24K
1513/24K
1515/24K
24K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.044 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target
[INFO] [resources:resources]
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/classes
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[102,15] cannot find symbol
symbol : method setIndenting(boolean)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[103,15] cannot find symbol
symbol : method setIndentSize(int)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[104,15] cannot find symbol
symbol : method setLineWidth(int)
[INFO] Total time: 44 seconds
[INFO] Finished at: Tue Apr 01 12:03:25 EDT 2008
[INFO] Final Memory: 24M/47M
