See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/144/changes
Changes:
[arneke] GEOS-2185 Added bbox. Easy once you're working on the right KML reflector class ![]()
[...truncated 9603 lines...]
at org.geoserver.catalog.util.LegacyCatalogImporter.importDataStores(LegacyCatalogImporter.java:311)
at org.geoserver.catalog.util.LegacyCatalogImporter.importCatalog(LegacyCatalogImporter.java:256)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:136)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:109)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:73)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:164)
at org.geoserver.wfsv.WFSVTestSupport.oneTimeSetUp(WFSVTestSupport.java:35)
at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:19)
at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
29 Aug 06:43:22 ERROR [data.postgis] - Could not version enable: roads
java.io.IOException: This feature type (roads) is associated to an unsupported fid mapper: class org.geotools.data.jdbc.fidmapper.NullFIDMapper
The supported fid mapper classes are: [class org.geotools.data.jdbc.fidmapper.BasicFIDMapper, class org.geotools.data.jdbc.fidmapper.MultiColumnFIDMapper, class org.geotools.data.postgis.fidmapper.PostGISAutoIncrementFIDMapper]
at org.geotools.data.postgis.VersionedPostgisDataStore.enableVersioning(VersionedPostgisDataStore.java:1011)
at org.geotools.data.postgis.VersionedPostgisDataStore.setVersioned(VersionedPostgisDataStore.java:382)
at org.geotools.data.postgis.VersionedPostgisDataStoreFactory.createDataStore(VersionedPostgisDataStoreFactory.java:155)
at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:75)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:155)
at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:29)
29 Aug 06:43:22 INFO [geoserver.catalog] - Processed data store 'spearfish', enabled
29 Aug 06:43:22 INFO [geoserver.catalog] - Processed coverage store 'dem', enabled
29 Aug 06:43:23 INFO [geoserver.catalog] - Loaded feature type 'topp:changesets'
29 Aug 06:43:23 INFO [geoserver.catalog] - Loaded feature type 'topp:roads'
29 Aug 06:43:23 INFO [geoserver.catalog] - Loaded feature type 'topp:restricted'
29 Aug 06:43:23 INFO [geoserver.catalog] - Loaded feature type 'topp:archsites'
29 Aug 06:43:23 INFO [geoserver.confg] - Loading service 'wfs'
29 Aug 06:43:26 WARN [geotools.xml] - cvc-complex-type.3.1: Value 'WFSV' of attribute 'service' of element 'wfs:Transaction' is not valid with respect to the corresponding attribute use. Attribute 'service' has a fixed value of 'WFS'.
29 Aug 06:43:26 WARN [geotools.xml] - cvc-complex-type.2.4.a: Invalid content was found starting with element 'topp:archsites'. One of '{"http://www.opengis.net/gml":\_Feature\}' is expected.
29 Aug 06:43:27 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp\}archsites is read-only
at org.geoserver.wfs.Transaction.execute(Transaction.java:272)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
at org.geoserver.wfsv.DefaultVersioningWebFeatureService.transaction(DefaultVersioningWebFeatureService.java:181)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy11.transaction(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:528)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:194)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:936)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:903)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:567)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:542)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:701)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:684)
at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:54)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 71.128 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.768 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.135 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.202 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 1, Errors: 4, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 54 seconds
[INFO] Finished at: Fri Aug 29 06:43:29 EDT 2008
[INFO] Final Memory: 32M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
