See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/713/changes
Changes:
[arneke] geosearch, redirecting WFS links to gwcs WFS cache
[...truncated 673 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.template.FeatureWrapperTest
Feb 25, 2009 2:45:36 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
Feb 25, 2009 2:45:36 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Feb 25, 2009 2:45:37 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Feb 25, 2009 2:45:37 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cdf'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.622 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.159 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 98, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-arcgrid:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 36 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.3-SNAPSHOT/wcs-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.3-SNAPSHOT/wcs-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/wcs-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.3-SNAPSHOT/wcs-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset" does not exist. Creating the directory.
Reading from file http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java" does not exist. Will create one.
File "http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java" does not exist. Will create one.
Annotated grammar generated successfully in http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/classes
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.geotools.ogc:net.opengis.ows:jar:2.5-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools),
refractions (http://lists.refractions.net/m2/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
Path to dependency:
1) org.geoserver:wcs1_1:jar:1.7.3-SNAPSHOT
2) org.geotools.ogc:net.opengis.wcs:jar:2.5-SNAPSHOT
3) org.geotools.ogc:net.opengis.ows:jar:2.5-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.ows/2.5-SNAPSHOT/net.opengis.ows-2.5-SNAPSHOT.jar
[INFO] Total time: 1 minute 16 seconds
[INFO] Finished at: Wed Feb 25 02:45:59 EST 2009
[INFO] Final Memory: 36M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
