See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/174/changes>
Changes:
[jdeolive] GEOS-3609, enabling resources from UI, linking layer.setEnabled() to resource.setEnabled()
[jdeolive] GEOS-3713, flushing of feature type schema cache on reload of feature type, added listeners to resource pool
[groldan] backport fix for GEOS-3616
[RiniAngreani] GEOS-3553: app-schema describeFeatureType output is schema invalid
[bencaradocdavies] Fix for GEOS-3709 (build failure in path with spaces)
[aaime] GEOS-3568, New web UI does not control which workspace is the default workspace
[aaime] GEOS-3715, GeoServerAbstractTestSupport should reset the referencing subsystem on startup
A SCM change trigger started this job
Updating https://svn.codehaus.org/geoserver/branches/2.0.x/src
U main/src/test/java/org/geoserver/test/GeoServerAbstractTestSupport.java
U main/src/test/java/org/geoserver/catalog/impl/CatalogImplTest.java
U main/src/main/java/org/geoserver/config/GeoServerLoader.java
U main/src/main/java/org/geoserver/config/util/XStreamPersister.java
U main/src/main/java/org/geoserver/catalog/impl/LayerInfoImpl.java
U main/src/main/java/org/geoserver/catalog/ResourcePool.java
U wfs/src/main/java/org/geoserver/wfs/xml/v1_0_0/WFSConfiguration.java
U wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java
U wfs/src/main/java/org/geoserver/wfs/xml/FeatureTypeSchemaBuilder.java
U wms/src/test/java/org/geoserver/wms/kvp/GetMapKvpRequestReaderTest.java
U extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java
AU web/demo/src/test/java/org/geoserver/web/demo/DemoRequestsPageTest.java
A web/demo/src/test/resources
A web/demo/src/test/resources/org
A web/demo/src/test/resources/org/geoserver
A web/demo/src/test/resources/org/geoserver/web
A web/demo/src/test/resources/org/geoserver/web/demo
A web/demo/src/test/resources/org/geoserver/web/demo/test-data
A web/demo/src/test/resources/org/geoserver/web/demo/test-data/demo-requests
A web/demo/src/test/resources/org/geoserver/web/demo/test-data/demo-requests/WMS_describeLayer.url
AU web/demo/src/test/resources/org/geoserver/web/demo/test-data/demo-requests/WFS_getFeature-1.1.xml
U web/demo/src/main/java/GeoServerApplication.properties
U web/demo/src/main/java/org/geoserver/web/demo/DemoRequestsPage.html
U web/demo/src/main/java/org/geoserver/web/demo/DemoRequestResponse.java
U web/demo/src/main/java/org/geoserver/web/demo/DemoRequestsPage.java
U web/demo/pom.xml
U web/core/src/main/java/org/geoserver/web/data/workspace/WorkspaceProvider.java
U web/core/src/main/java/org/geoserver/web/data/workspace/WorkspacePage.java
A web/core/src/main/java/org/geoserver/web/wicket/Icon.html
A web/core/src/main/java/org/geoserver/web/wicket/Icon.java
Fetching 'http://svn.osgeo.org/geotools/branches/2.6.x/modules/unsupported/app-schema/app-schema/src/test/resources/test-data’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/src/test/resources/test-data’>
At revision 34660
Fetching 'https://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/minimal’>
At revision 13800
Fetching 'https://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/legacy/web/minimal’>
At revision 13800
Fetching 'https://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/css’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/src/test/java/org/geoserver/wicket/test/css’>
At revision 13800
Fetching 'https://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/img’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/src/test/java/org/geoserver/wicket/test/img’>
At revision 13800
At revision 13800
no change for http://svn.osgeo.org/geotools/branches/2.6.x/modules/unsupported/app-schema/app-schema/src/test/resources/test-data since the previous build
no change for https://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal since the previous build
no change for https://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/css since the previous build
no change for https://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/img since the previous build
[geoserver-2.0.x] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver.web:web-demo
POM Location: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/pom.xml>
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geotools:gt-sample-data
Reason: Failed to validate POM for project org.geoserver.web:web-demo at <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/pom.xml>
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver.web:web-demo at <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/pom.xml>
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:378)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:292)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver.web:web-demo at <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/pom.xml>
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1108)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:878)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:506)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:198)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:583)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:461)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:534)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
... 11 more
[INFO] Total time: 10 seconds
[INFO] Finished at: Sat Dec 12 22:39:09 EST 2009
[INFO] Final Memory: 6M/82M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to RiniAngreani because no e-mail address is known, and no default e-mail domain is configured
