[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #622
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/622/changes&gt;
Changes:
[riniangreani] Update SRSWfsTest with GEOT-2707: SRS name isn't updated after CRS reprojection
[...truncated 22566 lines...]
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-08-02T07:41:47.021Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:test="http://test"
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock6465112141848447985data/featureTypes/test_PointFeature/GeometrylessTest.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <test:PointFeature gml:id="mf1">
            <test:loc/>
        </test:PointFeature>
    </gml:featureMember>
    <gml:featureMember>
        <test:PointFeature gml:id="mf2">
            <test:loc/>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Running org.geoserver.test.SRSWfsTest
Aug 2, 2010 7:41:47 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-08-02T07:41:47.229Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock7577014268945018034data/featureTypes/ex_geomContainer/NestedGeometry.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <ex:geomContainer gml:id="1">
            <ex:geom>
                <gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.2">
                    <ex:geom>
                        <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
                            <gml:pos>42.58 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
    <gml:featureMember>
        <ex:geomContainer gml:id="2">
            <ex:geom>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.1">
                    <ex:geom>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Aug 2, 2010 7:41:47 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-08-02T07:41:47.611Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <ex:geom>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                            <gml:pos>42.58000004047607 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
    <gml:featureMember>
            <ex:geom>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Aug 2, 2010 7:41:47 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-02T07:41:47.645Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <ex:geom>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.59 sec <<< FAILURE!
Running org.geoserver.test.PropertyEncodingOrderTest
Aug 2, 2010 7:41:52 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_PlanarOrientation
INFO: WFS GetFeature&er:MineralOccurrence:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-02T07:41:52.503Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="urn:cgi:xmlns:GGIC:EarthResource:1.1 http://www.earthresourceml.org/earthresourceml/1.1/xsd/earthResource.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <er:MineralOccurrence gml:id="er.mineraloccurrence.S0032895">
            <gml:name>Robinson Range - Deposit D</gml:name>
            <er:planarOrientation>
                <gsml:CGI_PlanarOrientation>
                    <gsml:azimuth>
                        <gsml:CGI_NumericValue>
                            <gsml:principalValue uom="urn:ogc:def:uom:UCUM::deg">50.0</gsml:principalValue>
                        </gsml:CGI_NumericValue>
                    </gsml:azimuth>
                    <gsml:convention>strike dip right hand rule</gsml:convention>
                    <gsml:dip>
                        <gsml:CGI_TermValue>
                            <gsml:value codeSpace="http://www.dmp.wa.gov.au/371.aspx&quot;&gt;60\-80&lt;/gsml:value&gt;
                        </gsml:CGI_TermValue>
                    </gsml:dip>
                    <gsml:polarity>not applicable</gsml:polarity>
                </gsml:CGI_PlanarOrientation>
            </er:planarOrientation>
        </er:MineralOccurrence>
Aug 2, 2010 7:41:56 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeoLogicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-02T07:41:56.829Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.cgi-iugs.org/xml/GeoSciML/2 http://schemas.opengis.net/GeoSciML/geosciml.xsd&quot;&gt;
    <gml:featureMember>
        <gsml:GeologicUnit gml:id="gu.25699">
            <gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
            <gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
            <gml:name>-Py</gml:name>
            <gsml:occurence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
            <gsml:exposureColor>
                    <gsml:value codeSpace="some:uri">Blue</gsml:value>
            </gsml:exposureColor>
            <gsml:outcropCharacter>
                    <gsml:value codeSpace="some:uri">x</gsml:value>
            </gsml:outcropCharacter>
            <gsml:composition>
                <gsml:CompositionPart>
                    <gsml:proportion>
                            <gsml:value codeSpace="some:uri">significant</gsml:value>
                    </gsml:proportion>
                    <gsml:role>interbedded component</gsml:role>
                </gsml:CompositionPart>
            </gsml:composition>
        </gsml:GeologicUnit>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.242 sec
Results :
Failed tests:
  testReproject(org.geoserver.test.SRSWfsTest)
Tests run: 45, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 5 minutes 53 seconds
[INFO] Finished at: Mon Aug 02 07:41:57 UTC 2010
[INFO] Final Memory: 62M/231M
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/623/&gt;
