See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/3/>
Started by user tomcat
[workspace] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -DskipTests -P allExtensions deploy
[INFO] Scanning for projects...
[INFO] Building Maven Default Project
[INFO] task-segment: [deploy]
[ERROR] BUILD ERROR
[INFO] Cannot execute mojo: resources. It requires a project with an existing pom.xml, but the build is not using one.
[INFO] Total time: 1 second
[INFO] Finished at: Thu Nov 12 13:20:21 EST 2009
[INFO] Final Memory: 4M/68M
