See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/208/changes>
Changes:
[jdeolive] fixing bounding box
[jdeolive] updated wms 1.1 data directory to 2.0 style, and tweaked configured of bridge layer to contain non empty bounding box
[aaime] [GEOS-3962] Centralize reset/reload utilities, reset image and font caches
[...truncated 450 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target>
[INFO] [resources:resources]
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/src/main/resources>
[INFO] [compiler:compile]
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/classes>
[INFO] [resources:testResources]
[INFO] Copying 0 resource
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/test-classes>
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target>
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset"> does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt> . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java"> does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj>
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj> . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/resources>
[INFO] Compiling 53 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/classes>
[INFO] Copying 1 resource
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-tests.jar>
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target>
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/src/main/resources>
[INFO] Compiling 170 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/classes>
[INFO] Copying 14 resources
[INFO] Compiling 44 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/target>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/src/main/resources>
[INFO] snapshot org.geotools:gt-render:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-svg:2.6-SNAPSHOT: checking for updates from osgeo
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.FileProfileActivator@anonymised.com
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wfs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 151 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/src/main/java/org/geoserver/wms/WMSLifecycleHandler.java>:\[30,25\] cannot find symbol
symbol : method resetCache()
location: class org.geotools.renderer.style.SVGGraphicFactory
[INFO] Total time: 1 minute 5 seconds
[INFO] Finished at: Sat May 22 16:48:39 EDT 2010
[INFO] Final Memory: 49M/144M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-05-22-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
