[Geoserver-devel] Build failed in Hudson: geoserver-2.1.x #122
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/122/changes&gt;
Changes:
[jdeolive] GEOS-4424, making GML attribute overriding configurable
[...truncated 35565 lines...]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/h2/target/h2-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-test-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/src/test/java&gt;
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/oracle/target/oracle-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-test-sources.jar
[INFO] Building MySQL DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/mysql/target/mysql-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wfsv/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wfsv&gt;
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wfsv/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 55 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wfsv/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/VersionedSchemaBuilder.java&gt;:\[12,7\] org.geoserver.wfsv.response.v1_1_0.VersionedSchemaBuilder is not abstract and does not override abstract method getGMLConfig(org.geoserver.wfs.WFSInfo) in org.geoserver.wfs.xml.FeatureTypeSchemaBuilder
[INFO] Total time: 14 minutes 13 seconds
[INFO] Finished at: Thu Mar 17 06:46:02 UTC 2011
[INFO] Final Memory: 76M/277M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/123/changes&gt;
