See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/237/changes>
Changes:
[jdeolive] GEOS-4540, adding config parameter to set log buffer size for post
requests, patch submitted by Rudi Hochmeister
[...truncated 12298 lines...]
SEVERE: Extension lookup occured, but ApplicationContext is unset.
May 17, 2011 4:39:18 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.928 sec
Running org.vfny.geoserver.util.SLDValidatorTest
May 17, 2011 4:39:18 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock5161527096715658641data>
May 17, 2011 4:39:19 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5177'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5175'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5174'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5176'
May 17, 2011 4:39:19 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock1109943262086437533data>
cvc-complex-type.2.4.a: Invalid content starting with element 'Font'. One of '{"http://www.opengis.net/sld":Stroke\}' is expected.
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-511f'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-511d'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-511c'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-511e'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.462 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock3637301780397441829data>
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-50c7'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-50c5'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-50c6'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-50c4'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock6869728967414175525data>
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-506e'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-506c'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-506d'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-506b'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock3604288738685444954data>
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5015'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5013'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5014'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-5012'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock4516904812245959855data>
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-4fbc'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-4fba'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-4fbb'
INFO: Disposing datastore 'DataStoreInfoImpl--1408635a:12ffed30a5f:-4fb9'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.459 sec
Results :
Failed tests:
testGlobal(org.geoserver.config.util.XStreamPersisterTest)
testGobalContactDefault(org.geoserver.config.util.XStreamPersisterTest)
Tests run: 271, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 1 minute 18 seconds
[INFO] Finished at: Tue May 17 16:39:19 UTC 2011
[INFO] Final Memory: 54M/213M
