[Geoserver-devel] Build failed in Hudson: geoserver-2.1.x #390
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/390/changes&gt;
Changes:
[aaime] [GEOS-4733] Querylayer module won't work properly in WFS 1.1 spatial queries over geographic data
[...truncated 39364 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock5121076977645909050data&gt;
23 Aug 13:31:25 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock1823138088456462440data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock6397614317863081524data&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.725 sec
Running org.geoserver.wps.gs.RangeLookupTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock3790510960574681096data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.18 sec
Results :
Tests run: 118, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wcs/2.7-SNAPSHOT/net.opengis.wcs-2.7-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service GUI
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/src/main/resources&gt;
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/2.7-SNAPSHOT/net.opengis.wps-2.7-SNAPSHOT.jar
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.web.WPSExecuteTransformerTest
Aug 23, 2011 1:31:34 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
[Fatal Error] :2:1: Content is not allowed in prolog.
Aug 23, 2011 1:31:36 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.691 sec
Running org.geoserver.wps.web.WPSRequestBuilderTest
23 Aug 13:31:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock3021761801022126213data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.161 sec
Running org.geoserver.wps.web.WPSAdminPageTest
23 Aug 13:31:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock608581067966748393data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.748 sec
Results :
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.1-SNAPSHOT/web-wps-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.1-SNAPSHOT/web-wps-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.1-SNAPSHOT/web-wps-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/target/web-wps-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.1-SNAPSHOT/web-wps-2.1-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Layer Querying filter functions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/querylayer/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/querylayer&gt;
[INFO] Copying 2 resources
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/querylayer/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/querylayer/src/main/java/org/geoserver/filter/function/QueryFunction.java&gt;:\[159,9\] method does not override a method from its superclass
[INFO] Total time: 12 minutes 57 seconds
[INFO] Finished at: Tue Aug 23 13:31:47 UTC 2011
[INFO] Final Memory: 81M/300M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/391/changes&gt;
Changes:
[groldan] GEOS-4736: Cache not truncated for layer groups upon feature edits
[...truncated 39350 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock7152428280457188311data&gt;
23 Aug 20:50:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock7780915461680486123data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock1458798709042806317data&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.907 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock6591447529384298682data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.424 sec
Results :
T E S T S
Aug 23, 2011 8:51:02 PM org.geoserver.platform.GeoServerExtensions checkContext
Aug 23, 2011 8:51:04 PM org.geoserver.platform.GeoServerExtensions checkContext
Aug 23, 2011 8:51:05 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.617 sec
23 Aug 20:51:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock8693363173578889574data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.078 sec
23 Aug 20:51:10 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock4468893112604940868data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.96 sec
Results :
[INFO] Total time: 13 minutes 58 seconds
[INFO] Finished at: Tue Aug 23 20:51:13 UTC 2011
[INFO] Final Memory: 80M/286M
Hudson blames my commit but the failure seems to be in " GeoServer
Layer Querying filter functions" :
Didn't have time to look into it though.
[INFO] inspecting
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/392/changes&gt;
Changes:
[groldan] GEOS-4737: avoid failure of tile encoding for embedded raster layers
[...truncated 39351 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock4560287689182159561data&gt;
24 Aug 00:48:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock2962048833840977829data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock8982837281087729112data&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.024 sec
24 Aug 00:48:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/./target/mock9140623545088333747data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.017 sec
Results :
T E S T S
Aug 24, 2011 12:48:56 AM org.geoserver.platform.GeoServerExtensions checkContext
Aug 24, 2011 12:48:58 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.625 sec
24 Aug 00:48:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock1891337121347142580data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.65 sec
24 Aug 00:49:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/web-wps/./target/mock4860576421214026969data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.301 sec
Results :
[INFO] Total time: 12 minutes 31 seconds
[INFO] Finished at: Wed Aug 24 00:49:06 UTC 2011
[INFO] Final Memory: 81M/277M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/393/changes&gt;
On Wed, Aug 24, 2011 at 1:57 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
Sorry, my bad, an @Override that is fine on java 6 (trunk) breaks the
compilation
on java 5 (2.1.x)
Fixed
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
