See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/604/>
[...truncated 13188 lines...]
29 Jan 11:50:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3272012531968123547data>
29 Jan 11:50:55 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: Streams.
Strict WFS protocol conformance is being applied.
Make sure the type name is correctly qualified
at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:138)
at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:97)
at sun.reflect.GeneratedMethodAccessor223.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy14.describeFeatureType(Unknown Source)
at sun.reflect.GeneratedMethodAccessor222.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1185)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1204)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1139)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:555)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:538)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:523)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:808)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:772)
at org.geoserver.wfs.v1_1.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:196)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
at sun.reflect.GeneratedMethodAccessor183.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
29 Jan 11:50:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6846022751256756007data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2498438817268553211data>
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.931 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock9182120843444353050data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2044750637625342585data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.27 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8285728400457777182data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.114 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
29 Jan 11:50:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7982676689221786125data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5560611185216476022data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.279 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock993341462083645142data>
Feature type cite:InvalidTypeName unknown
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2361295752769849600data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6816142082955420186data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1867635737848131973data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8302146894881805269data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3539335660423224221data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock910017715014154421data>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.82 sec
Running org.geoserver.wfs.response.ShapeZipTest
29 Jan 11:50:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3409674849790685033data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6565228921291121891data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6089343886329166690data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1434529804005483249data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3251549454147973282data>
29 Jan 11:50:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4681915078475292694data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock342651702313874834data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7070272940281400564data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6650854497158691098data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1378576845141737328data>
29 Jan 11:50:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4746200648127611124data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4707853291249519794data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3518172253735763638data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1117770709681828050data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4815786971972401302data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2030752148908086446data>
29 Jan 11:51:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4553207675235672725data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2751424741483386024data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4968052564334519389data>
29 Jan 11:51:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5805998988425569800data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1705309839354333640data>
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.863 sec
Running org.geoserver.wfs.GetCapabilitiesTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1300703914436424546data>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.389 sec
Results :
Failed tests:
testWithGmlObjectId(org.geoserver.wfs.v1_1.GetFeatureTest)
Tests run: 274, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 53 seconds
[INFO] Finished at: Sun Jan 29 11:51:02 UTC 2012
[INFO] Final Memory: 57M/272M
