See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1266/changes
Changes:
[arneke] GWC - Pegging to 1.1.3 release and minor fixes (catalog seems to have improved) in case a release is made while I am on vacation
[...truncated 3190 lines...]
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor132.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.Socket.connect(Socket.java:520)
at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
at sun.net.www.http.HttpClient.New(HttpClient.java:304)
at sun.net.www.http.HttpClient.New(HttpClient.java:321)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:813)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:765)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:690)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:934)
at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:67)
at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:684)
at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:347)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1147)
... 33 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.729 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.179 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
22 Jun 08:38:48 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:108)
at org.geoserver.wms.kvp.WMSKvpRequestReaderAdapter.createRequest(WMSKvpRequestReaderAdapter.java:72)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1089)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1057)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1024)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:471)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:452)
at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:193)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:132)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.665 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
22 Jun 08:38:50 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:630)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:726)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.569 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.265 sec
Results :
Tests run: 157, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
Downloading: http://repo.opengeo.org//org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.pom
Downloading: http://download.osgeo.org/webdav/geotools//org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.pom
Downloading: http://maven.restlet.org/org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.pom
Downloading: http://repo1.maven.org/maven2/org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.pom
Downloading: http://repo.opengeo.org//org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.jar
Downloading: http://download.osgeo.org/webdav/geotools//org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.jar
Downloading: http://maven.restlet.org/org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.jar
Downloading: http://repo1.maven.org/maven2/org/opengeo/geowebcache/1.1.3/geowebcache-1.1.3.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.opengeo:geowebcache:jar:1.1.3
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.opengeo -DartifactId=geowebcache -Dversion=1.1.3 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.opengeo -DartifactId=geowebcache -Dversion=1.1.3 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver:gwc:jar:2.0-SNAPSHOT
2) org.opengeo:geowebcache:jar:1.1.3
1 required artifact is missing.
for artifact:
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/)
[INFO] Total time: 2 minutes 58 seconds
[INFO] Finished at: Mon Jun 22 08:38:54 EDT 2009
[INFO] Final Memory: 37M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
