[Geoserver-devel] Build failed in Hudson: geoserver-trunk #154
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/154/changes
Changes:
[aaime] Moving wcs 1.1.1 and associated modules up
[...truncated 1202 lines...]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] [clean:clean]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://maven2.mirrors.skynet.be/pub/maven2/javax/mail/mail/1.4/mail-1.4.pom
993/993b
993b downloaded
Downloading: http://maven2.mirrors.skynet.be/pub/maven2/javax/activation/activation/1.1/activation-1.1.pom
1/1K
1K downloaded
Downloading: http://maven2.mirrors.skynet.be/pub/maven2/javax/activation/activation/1.1/activation-1.1.jar
1/61K
4/61K
5/61K
8/61K
9/61K
12/61K
16/61K
20/61K
21/61K
24/61K
26/61K
29/61K
33/61K
37/61K
41/61K
43/61K
45/61K
49/61K
50/61K
53/61K
57/61K
61/61K
61K downloaded
Downloading: http://maven2.mirrors.skynet.be/pub/maven2/javax/mail/mail/1.4/mail-1.4.jar
4/379K
8/379K
10/379K
12/379K
13/379K
16/379K
20/379K
24/379K
28/379K
32/379K
33/379K
36/379K
39/379K
43/379K
47/379K
51/379K
55/379K
59/379K
63/379K
67/379K
68/379K
72/379K
76/379K
77/379K
80/379K
84/379K
88/379K
92/379K
96/379K
100/379K
104/379K
108/379K
109/379K
112/379K
115/379K
119/379K
123/379K
127/379K
131/379K
135/379K
139/379K
143/379K
147/379K
151/379K
155/379K
159/379K
163/379K
167/379K
169/379K
173/379K
173/379K
176/379K
180/379K
184/379K
188/379K
192/379K
196/379K
200/379K
204/379K
208/379K
212/379K
216/379K
220/379K
224/379K
228/379K
232/379K
236/379K
240/379K
244/379K
248/379K
248/379K
251/379K
252/379K
255/379K
258/379K
262/379K
264/379K
265/379K
269/379K
273/379K
277/379K
281/379K
285/379K
289/379K
293/379K
297/379K
301/379K
305/379K
309/379K
313/379K
313/379K
316/379K
320/379K
324/379K
328/379K
332/379K
336/379K
340/379K
341/379K
344/379K
348/379K
348/379K
351/379K
355/379K
359/379K
363/379K
367/379K
371/379K
375/379K
379/379K
379K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 49 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:main:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:testCompile]
[INFO] Compiling 11 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports
T E S T S
Running org.geoserver.wcs.DescribeCoverageTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 1.764 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 0.112 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Running org.geoserver.wcs.GetCoverageTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 0.148 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.852 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.605 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.04 sec <<< FAILURE!
Running org.geoserver.wcs.GetCoverageEncodingTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.032 sec <<< FAILURE!
Results :
Tests in error:
  testDescribeNoIdentifiers(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeUnknownCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeUnknownCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeDemCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeDemCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeRotatedCoverage(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeImageCoverage(org.geoserver.wcs.DescribeCoverageTest)
  testMissingParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testUnknownCoverageParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testBasic(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testStoreUnsupported(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testUnsupportedCRS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridTypes(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridCS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridOrigin(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridOffsets(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testRangeSubset(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageTest)
  testWrongFormatParams(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testInvalidRangeSubset(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
  testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testBasic(org.geoserver.wcs.xml.GetCoverageXmlParserTest)
  testRangeSubsetKeys(org.geoserver.wcs.xml.GetCoverageXmlParserTest)
  testGridCRS(org.geoserver.wcs.xml.GetCoverageXmlParserTest)
  testGetBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testPostBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageEncodingTest)
  testTiffOutput(org.geoserver.wcs.GetCoverageEncodingTest)
  testPngOutput(org.geoserver.wcs.GetCoverageEncodingTest)
  testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageEncodingTest)
Tests run: 56, Failures: 0, Errors: 40, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Wed Jan 23 07:33:31 EST 2008
[INFO] Final Memory: 30M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/155/changes
[...truncated 583 lines...]
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:599)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:318)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:419)
  at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:59)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:334)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:980)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
  at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
  ... 33 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
  at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:146)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
  ... 35 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.492 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.096 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at java.security.AccessController.doPrivileged(Native Method)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
  at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
  at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:613)
  at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:208)
  at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:313)
  at org.geoserver.wcs.GetCoverageTest.executeGetCoverageKvp(GetCoverageTest.java:297)
  at org.geoserver.wcs.GetCoverageTest.testKvpBasic(GetCoverageTest.java:64)
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.608 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.46 sec
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.32 sec <<< FAILURE!
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.136 sec
23 Jan 09:14:02 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find any matching version
  at org.geoserver.ows.util.RequestUtils.getVersionOws11(RequestUtils.java:220)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCapabilities(DefaultWebCoverageService111.java:91)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.getCapabilities(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:402)
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionPost(GetCapabilitiesTest.java:39)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:277)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:258)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:352)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:334)
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:46)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.132 sec
Coverages part: <?xml version="1.0" encoding="UTF-8"?><wcs:Coverages xmlns:wcs="http://www.opengis.net/wcs/1.1.1&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wcs/1.1.1 schemas/wcs/1.1.1/wcsCoverages.xsd"><wcs:Coverage><ows:Title>BlueMarble</ows:Title><ows:Abstract>BlueMarble description</ows:Abstract><ows:Identifier>wcs:BlueMarble</ows:Identifier><ows:Reference xlink:href="cid:theCoverage"/></wcs:Coverage></wcs:Coverages>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.82 sec
Results :
Tests in error:
Tests run: 56, Failures: 0, Errors: 4, Skipped: 0
[INFO] Total time: 1 minute 6 seconds
[INFO] Finished at: Wed Jan 23 09:14:04 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/156/changes
  ... 33 more
  ... 35 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.421 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.072 sec
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.596 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.448 sec
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.304 sec <<< FAILURE!
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.124 sec
23 Jan 09:48:47 ERROR [geoserver.ows] -
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.12 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.752 sec
Results :
Tests in error:
[INFO] Total time: 1 minute 4 seconds
[INFO] Finished at: Wed Jan 23 09:48:49 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/157/changes
  ... 33 more
  ... 35 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.321 sec
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.624 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.128 sec
23 Jan 09:53:24 ERROR [geoserver.ows] -
23 Jan 09:53:25 ERROR [geoserver.ows] -
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.136 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.76 sec
Results :
Tests in error:
[INFO] Total time: 1 minute 2 seconds
[INFO] Finished at: Wed Jan 23 09:53:27 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/158/changes
