[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1691
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1691/changes
Changes:
[simboss] GEOS-3193 and other minor clean-ups for coverage
[...truncated 348 lines...]
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 225 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:ows:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:ows:2.0-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:testCompile]
[INFO] Compiling 47 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.639 sec
Running org.geoserver.catalog.impl.CascadeDeleteVisitorTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.879 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.684 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.267 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Sep 3, 2009 5:22:44 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.313 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
03 Sep 05:22:44 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Sep 03 05:22:44 EDT 2009]; root of context hierarchy
03 Sep 05:22:44 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
03 Sep 05:22:44 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
03 Sep 05:22:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock27833data
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
03 Sep 05:22:44 INFO [geoserver.catalog] - Default namespace: 'gs'
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded style 'Default'
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded style 'Buildings'
03 Sep 05:22:44 INFO [geoserver.catalog] - Processed data store 'cite', enabled
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
03 Sep 05:22:44 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
03 Sep 05:22:44 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Sep 03 05:22:44 EDT 2009]; root of context hierarchy
03 Sep 05:22:44 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-6cdda585:1237f36647b:-74fa'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.067 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Sep 3, 2009 5:22:44 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.config.util.XStreamPersisterTest
03 Sep 05:22:44 INFO [org.geoserver] - Loaded store 'bar', disabled
03 Sep 05:22:45 INFO [org.geoserver] - Loading workspace 'foo'
03 Sep 05:22:45 INFO [org.geoserver] - Loading namespace 'acme'
03 Sep 05:22:45 INFO [org.geoserver] - Loaded store 'foo', disabled
03 Sep 05:22:45 INFO [org.geoserver] - Loaded store 'bar', disabled
03 Sep 05:22:45 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.geoserver.template.FeatureWrapperTest
Sep 3, 2009 5:22:45 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.*.r=*
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.w=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.bases.r=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
03 Sep 05:22:45 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.w=WRITER
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.w=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Layer nurc is unknown in rule + nurc.arc\.grid.w=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.states.r=READER
03 Sep 05:22:45 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.states.r=READER
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.r=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Layer nurc is unknown in rule + nurc.arc\.grid.r=MILITARY
03 Sep 05:22:45 WARN [geoserver.securit] - Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
03 Sep 05:22:45 WARN [geoserver.securit] - Layer topp is unknown in rule + topp.landmarks.w=WRITER
03 Sep 05:22:45 WARN [geoserver.securit] - Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.12 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.753 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.114 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
03 Sep 05:22:49 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
03 Sep 05:22:49 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
03 Sep 05:22:49 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.815 sec
Running org.geoserver.security.SecureCatalogImplTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.207 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.193 sec
Running org.geoserver.security.DataAccessRuleDAOTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.09 sec
Running org.geoserver.catalog.SchemaMappingTest
03 Sep 05:22:51 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
03 Sep 05:22:51 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
03 Sep 05:22:51 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.797 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.615 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.DataAccessRuleTest
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 44, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.521 sec
Results :
Tests run: 214, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/2.0-SNAPSHOT/main-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/2.0-SNAPSHOT/main-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/2.0-SNAPSHOT/main-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:gt-imagemosaic:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 37 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/src/main/java/org/vfny/geoserver/wcs/responses/CoverageResponse.java :[62,65] cannot find symbol
symbol : variable IGNORE_COVERAGE_OVERVIEW
[INFO] Total time: 1 minute 20 seconds
[INFO] Finished at: Thu Sep 03 05:23:00 EDT 2009
[INFO] Final Memory: 35M/116M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1692/changes
