See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2216/changes>
Changes:
[simboss] various improvements for WCS - GEOS-3610,GEOS-3702,GEOS-3219
[jdeolive] GEOS-3609, enabling resources from UI, linking layer.setEnabled() to resource.setEnabled()
[jdeolive] GEOS-3713, flushing of feature type schema cache on reload of feature type, added listeners to resource pool
[groldan] add gt-sample-data to dependencyManagement
[groldan] GEOS-3616
[RiniAngreani] GEOS-3553: app-schema describeFeatureType output is schema invalid
[bencaradocdavies] Fix for GEOS-3709 (build failure in path with spaces)
[aaime] GEOS-3568, New web UI does not control which workspace is the default workspace
[aaime] GEOS-3715, GeoServerAbstractTestSupport should reset the referening subsystem on startup
[...truncated 2366 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
SchemaLocation: schemaLocation value = 'http://localhost:80/geoserver/schemas/wcs/1.1.1/wcsGetCapabilities.xsd’ must have even number of URI's.
12 Dec 20:40:24 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:725)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1061)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1028)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:470)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:451)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:725)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:687)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:177)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:127)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 50 more
java.io.IOException
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:655)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:602)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:582)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:791)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:774)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:189)
... 49 more
... 51 more
java.io.IOException
at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:196)
... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:172)
... 50 more
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.944 sec
Results :
Tests in error:
testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
Tests run: 69, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 6 seconds
[INFO] Finished at: Sat Dec 12 20:40:24 EST 2009
[INFO] Final Memory: 41M/115M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to RiniAngreani because no e-mail address is known, and no default e-mail domain is configured
