See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2251/changes>
Changes:
[jdeolive] GEOS-3729, ensuring styles are not overwritten on data directory migration
[...truncated 20427 lines...]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/surefire-reports>
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target>
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/classes>
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.186 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target>
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/classes>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/surefire-reports>
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Dec 19, 2009 4:40:10 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Dec 19, 2009 4:40:10 PM it.geosolutions.util.KakaduUtilities loadKakadu
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no kdu_jni in java.library.path
Dec 19, 2009 4:40:12 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Dec 19, 2009 4:40:14 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock37191data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.166 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Dec 19, 2009 4:40:19 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock37193data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.349 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target>
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/classes>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/surefire-reports>
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Dec 19, 2009 4:40:32 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Dec 19, 2009 4:40:32 PM it.geosolutions.util.KakaduUtilities loadKakadu
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.417 sec
Running org.geoserver.web.demo.SRSListPageTest
Dec 19, 2009 4:40:43 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.292 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target>
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports>
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Dec 19, 2009 4:40:56 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Dec 19, 2009 4:40:56 PM it.geosolutions.util.KakaduUtilities loadKakadu
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 16.947 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.982 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.67 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.724 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.512 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.012 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.456 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.327 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.135 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.46 sec
Results :
Tests in error:
testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports> for the individual test results.
[INFO] Total time: 5 minutes 29 seconds
[INFO] Finished at: Sat Dec 19 16:41:19 EST 2009
[INFO] Final Memory: 43M/115M
