[Geoserver-devel] Build failed in Hudson: geoserver-trunk #229
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/229/changes
Changes:
[aaime] GEOS-1969, enabling secured catalog as default catalog
[aaime] Fixing unwrapping when accessing the catalog
[...truncated 197 lines...]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] [resources:resources]
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 20 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.48 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jun 5, 2008 11:37:19 AM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.852 sec
Results :
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:ogc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 70 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Jun 5, 2008 11:37:24 AM org.geoserver.ows.Dispatcher exception
SEVERE:
org.geoserver.ows.HttpErrorCodeException
  at org.geoserver.ows.HelloWorld.httpErrorCodeException(HelloWorld.java:17)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:499)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:190)
  at org.geoserver.ows.DispatcherTest.testHttpErrorCodeException(DispatcherTest.java:325)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.62 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
  <ows:Exception exceptionCode="helloCode" locator="helloLocator">
    <ows:ExceptionText>hello service exception
helloText
I/O exception here
Illegal argument here</ows:ExceptionText>
    <ows:ExceptionText>helloText</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.168 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 219 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/security/decorators/ReadOnlyLayerGroupInfo.java :[9,44] cannot find symbol
symbol: class DecoratingLayerGroupInfo
public class ReadOnlyLayerGroupInfo extends DecoratingLayerGroupInfo {
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/security/decorators/ReadOnlyLayerGroupInfo.java :[40,5] method does not override a method from its superclass
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/security/SecureCatalogImpl.java :[357,19] incompatible types
found : org.geoserver.security.decorators.ReadOnlyLayerGroupInfo
required: org.geoserver.catalog.LayerGroupInfo
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/geoserver/security/SecureCatalogImpl.java :[518,31] <T>deepUnwrap(org.geoserver.catalog.Wrapper<T>) in org.geoserver.catalog.util.WrapperUtils cannot be applied to (org.geoserver.security.decorators.ReadOnlyLayerGroupInfo)
[INFO] Total time: 49 seconds
[INFO] Finished at: Thu Jun 05 11:37:30 EDT 2008
[INFO] Final Memory: 25M/52M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/230/changes
