See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2961/changes>
Changes:
[aaime] Adding hints to improve the rendering quality (they don't hinder performance significantly accorcing to some local tests
[...truncated 6226 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
10 Jul 12:41:58 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:138)
at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:98)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:52)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy11.describeFeatureType(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:648)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1069)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1036)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:649)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:596)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:576)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:785)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:768)
at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:52)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:127)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor171.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
sf
cdf
cgf
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:cdf="http://www.opengis.net/cite/data" xmlns:cgf="http://www.opengis.net/cite/geometry" xmlns:cite="http://www.opengis.net/cite" xmlns:gml="http://www.opengis.net/gml" xmlns:gs="http://geoserver.org" xmlns:sf="http://cite.opengeospatial.org/gmlsf" elementFormDefault="qualified" targetNamespace="http://cite.opengeospatial.org/gmlsf">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd"/>
<xsd:complexType name="PrimitiveGeoFeatureType">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="description" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="name" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="surfaceProperty" nillable="true" type="gml:SurfacePropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="curveProperty" nillable="true" type="gml:LineStringPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="intProperty" nillable="true" type="xsd:int"/>
<xsd:element maxOccurs="1" minOccurs="0" name="uriProperty" nillable="true" type="xsd:anyURI"/>
<xsd:element maxOccurs="1" minOccurs="0" name="measurand" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="dateTimeProperty" nillable="true" type="xsd:dateTime"/>
<xsd:element maxOccurs="1" minOccurs="0" name="dateProperty" nillable="true" type="xsd:date"/>
<xsd:element maxOccurs="1" minOccurs="0" name="decimalProperty" nillable="true" type="xsd:double"/>
<xsd:element maxOccurs="1" minOccurs="0" name="booleanProperty" nillable="true" type="xsd:boolean"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="PrimitiveGeoFeature" substitutionGroup="gml:_Feature" type="sf:PrimitiveGeoFeatureType"/>
<xsd:complexType name="GenericEntityType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="attribut.geom" nillable="true" type="gml:GeometryPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="boolProperty" nillable="true" type="xsd:boolean"/>
<xsd:element maxOccurs="1" minOccurs="0" name="str4Property" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="featureRef" nillable="true" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:element name="GenericEntity" substitutionGroup="gml:_Feature" type="sf:GenericEntityType"/>
</xsd:schema>
10 Jul 12:41:59 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: Streams.
Strict WFS protocol conformance is being applied.
Make sure the type name is correctly qualified
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:464)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:445)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:719)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:681)
at org.geoserver.wfs.v1_1.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:170)
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.164 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.255 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.123 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type :InvalidTypeName unknown
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.506 sec
Running org.geoserver.wfs.response.ShapeZipTest
Jul 10, 2010 12:42:00 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.808 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.502 sec
Results :
Tests run: 211, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target>
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 153 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/DefaultRasterMapProducer.java>:\[416,37\] cannot find symbol
symbol : variable TEXT_RENDERING_ADAPTIVE
location: class org.geotools.renderer.lite.StreamingRenderer
[INFO] Total time: 3 minutes 33 seconds
[INFO] Finished at: Sat Jul 10 12:42:16 EDT 2010
[INFO] Final Memory: 45M/120M
