[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3277
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3277/changes&gt;
Changes:
[aaime] [GEOS-4208] Use an interactive server side file chooser to pick shapefiles, directories, geotiffs and the like
[...truncated 62 lines...]
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] WCS UI Module
[INFO] Demoes Module
[INFO] Security UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] Versioned Web Feature Service Module
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] REST Configuration Service Module
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-main:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-main/2.7-SNAPSHOT/gt-main-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-main/2.7-SNAPSHOT/gt-main-2.7-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/2.1-SNAPSHOT/maven-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/2.1-SNAPSHOT/maven-2.1-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target&gt;
[INFO] [plugin:descriptor {execution: default-descriptor}]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/src/main/resources&gt;
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/src/test/java&gt;
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT.jar&gt;
[INFO] [plugin:addPluginArtifactMetadata {execution: default-addPluginArtifactMetadata}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Web Plugin Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/src/main/java&gt;
[INFO] Copying 7 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/src/main/java&gt;
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/src/main/resources&gt;
[INFO] Compiling 17 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes&gt;
[ERROR] BUILD ERROR
[INFO] Fatal error compiling
Embedded error: Error while executing the external compiler.
java.io.IOException: Cannot allocate memory
[INFO] Total time: 25 seconds
[INFO] Finished at: Thu Nov 04 16:20:36 UTC 2010
[INFO] Final Memory: 40M/185M
Duh, this one is new. Who's the funny guy that removed RAM chips from
the build server?
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3278/&gt;
