See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3310/changes>
Changes:
[jdeolive] added type mapping to StoreInfo, and made Layer -> Resource association non lazy
[...truncated 7838 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.1-SNAPSHOT/web-core-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.1-SNAPSHOT/web-core-2.1-SNAPSHOT-sources.jar
[INFO] Building WMS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target>
[INFO] Copying 14 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/src/main/resources>
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/2.7-SNAPSHOT/net.opengis.ows-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-referencing/2.7-SNAPSHOT/gt-referencing-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.7-SNAPSHOT/gt-jdbc-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/2.7-SNAPSHOT/gt-render-2.7-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/classes>
[INFO] Copying 1 resource
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/surefire-reports>
T E S T S
Running org.geoserver.wms.web.data.WMSAdminPageTest
Nov 16, 2010 11:43:44 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.754 sec
Running org.geoserver.wms.web.data.StylePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 sec
Running org.geoserver.wms.web.publish.AttributionLayerConfigTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.527 sec
Running org.geoserver.wms.web.data.StyleEditPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.367 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.984 sec
Running org.geoserver.wms.web.data.StyleNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.991 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.1-SNAPSHOT/web-wms-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.1-SNAPSHOT/web-wms-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/web-wms-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.1-SNAPSHOT/web-wms-2.1-SNAPSHOT-sources.jar
[INFO] Building GWC UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target>
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/src/main/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/classes>
[INFO] Copying 0 resource
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/surefire-reports>
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target>
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/src/main/resources>
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Nov 16, 2010 11:44:00 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.497 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target>
[INFO] Copying 8 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/src/main/resources>
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/classes>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/test-classes>
[ERROR] BUILD ERROR
[INFO] Fatal error compiling
Embedded error: Unknown error trying to execute the external compiler:
javac @/tmp/org.codehaus.plexus.compiler.javac.JavacCompiler4827315727645993480arguments
[INFO] Total time: 5 minutes 13 seconds
[INFO] Finished at: Tue Nov 16 23:44:03 UTC 2010
[INFO] Final Memory: 58M/216M
