[Geoserver-devel] Build failed in Hudson: geoserver-trunk #357
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/357/changes
Changes:
[aaime] GEOS-1692, added support for store=true
[arneke] GEOS-1738 XML configuration, line termination characters need special treatment
[aaime] GEOS-1777, updatesequence reports errors in the wrong attribute of serviceexception
[aaime] Handle ...&updateSequence=&... as if UpdateSequence wasn'tprovided
[...truncated 990 lines...]
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.getCapabilities(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:710)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:411)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:520)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:503)
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionPost(GetCapabilitiesTest.java:69)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
29 Feb 08:28:49 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find any matching version
  at org.geoserver.ows.util.RequestUtils.getVersionOws11(RequestUtils.java:205)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCapabilities(DefaultWebCoverageService111.java:99)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:305)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:286)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:453)
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:77)
29 Feb 08:28:50 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:145)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 41 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:120)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
  ... 43 more
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:157)
  ... 41 more
  ... 43 more
Tests run: 14, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.392 sec <<< FAILURE!
Results :
Failed tests:
  testStoreUnsupported(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGetBasic(org.geoserver.wcs.GetCapabilitiesTest)
Tests run: 74, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 31 seconds
[INFO] Finished at: Fri Feb 29 08:28:50 EST 2008
[INFO] Final Memory: 34M/63M
Updating GEOS-1777
Updating GEOS-1738
Updating GEOS-1692
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/358/changes
[...truncated 960 lines...]
29 Feb 08:30:10 ERROR [geoserver.ows] -
29 Feb 08:30:11 ERROR [geoserver.ows] -
java.io.IOException
  ... 41 more
  ... 43 more
29 Feb 08:30:12 ERROR [geoserver.ows] -
java.io.IOException
  ... 41 more
  ... 43 more
Tests run: 14, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.492 sec <<< FAILURE!
Results :
Failed tests:
[INFO] Total time: 1 minute 14 seconds
[INFO] Finished at: Fri Feb 29 08:30:12 EST 2008
[INFO] Final Memory: 28M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/359/changes
29 Feb 08:37:23 ERROR [geoserver.ows] -
29 Feb 08:37:24 ERROR [geoserver.ows] -
java.io.IOException
  ... 41 more
  ... 43 more
java.io.IOException
  ... 41 more
  ... 43 more
Tests run: 14, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.124 sec <<< FAILURE!
Results :
Failed tests:
[INFO] Total time: 1 minute 12 seconds
[INFO] Finished at: Fri Feb 29 08:37:25 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/360/changes
Changes:
[aaime] Fixed old test, now we do support store=true
[aaime] Added support for GetCapabilities sections as well
[...truncated 1269 lines...]
  at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:78)
29 Feb 10:34:50 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:146)
  ... 41 more
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:125)
  ... 43 more
29 Feb 10:34:51 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:158)
  ... 41 more
  ... 43 more
java.io.IOException
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:165)
  ... 41 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:172)
  ... 43 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.4 sec
Results :
Failed tests:
  testKvpBasic(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageSupportsStoreTrueTest)
Tests in error:
  testKvpBasic(org.geoserver.wcs.GetCoverageTest)
  testAntimeridianWorld(org.geoserver.wcs.GetCoverageTest)
  testAntimeridianTaz(org.geoserver.wcs.GetCoverageTest)
  testDefaultGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testGridOffsetsSubsample(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyInterpolation(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyField(org.geoserver.wcs.GetCoverageTest)
  testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testTiffOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testPngOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
Tests run: 76, Failures: 3, Errors: 14, Skipped: 0
[INFO] Total time: 1 minute 19 seconds
[INFO] Finished at: Fri Feb 29 10:34:52 EST 2008
[INFO] Final Memory: 27M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/361/changes
