[Geoserver-devel] Build failed in Hudson: geoserver-trunk #359
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/359/changes
Changes:
[aaime] GEOS-2050, Proxy filter engages even if the proxying is not enabled
[...truncated 7218 lines...]
here
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
18 Jul 15:43:26 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:106)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:585)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:637)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:921)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:888)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:437)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:418)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:630)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:122)
  at sun.reflect.GeneratedMethodAccessor108.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:104)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:196)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:156)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:703)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.loadFeatureCollection(KMLTransformer.java:404)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:192)
  ... 51 more
18 Jul 15:43:26 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:43:25 EDT 2008]; root of context hierarchy
18 Jul 15:43:26 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
18 Jul 15:43:26 INFO [geoserver.global] - Done disposing datastores.
18 Jul 15:43:26 INFO [geoserver.catalog] - Disposing datastore 'sf'
18 Jul 15:43:26 INFO [geoserver.catalog] - Disposing datastore 'cgf'
18 Jul 15:43:26 INFO [geoserver.catalog] - Disposing datastore 'cdf'
18 Jul 15:43:26 INFO [geoserver.catalog] - Disposing datastore 'cite'
here
18 Jul 15:43:26 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:43:26 EDT 2008]; root of context hierarchy
here
18 Jul 15:43:27 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:43:26 EDT 2008]; root of context hierarchy
18 Jul 15:43:27 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
18 Jul 15:43:27 INFO [geoserver.global] - Done disposing datastores.
18 Jul 15:43:27 INFO [geoserver.catalog] - Disposing datastore 'cgf'
18 Jul 15:43:27 INFO [geoserver.catalog] - Disposing datastore 'cdf'
18 Jul 15:43:27 INFO [geoserver.catalog] - Disposing datastore 'sf'
18 Jul 15:43:27 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.648 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
here
18 Jul 15:43:27 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:43:27 EDT 2008]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.221 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
here
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Results :
Tests run: 89, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.8.0-SNAPSHOT/wms-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.8.0-SNAPSHOT/wms-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.8.0-SNAPSHOT/wms-1.8.0-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 108 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
here
18 Jul 15:44:28 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "Hello, this is a test" as buffer
18 Jul 15:44:28 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "LongLongLongLongLongLongLongLongLongLongLongLongLongLongLongLong" as buffer
18 Jul 15:44:28 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "" as buffer
18 Jul 15:44:28 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:44:24 EDT 2008]; root of context hierarchy
18 Jul 15:44:28 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
18 Jul 15:44:28 INFO [geoserver.global] - Done disposing datastores.
18 Jul 15:44:28 INFO [geoserver.catalog] - Disposing datastore 'cgf'
18 Jul 15:44:28 INFO [geoserver.catalog] - Disposing datastore 'sf'
18 Jul 15:44:28 INFO [geoserver.catalog] - Disposing datastore 'cite'
18 Jul 15:44:28 INFO [geoserver.catalog] - Disposing datastore 'cdf'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.217 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.025 sec <<< FAILURE!
Running org.vfny.geoserver.jetty.SpringContextTest
here
18 Jul 15:44:28 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:44:28 EDT 2008]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Running org.geoserver.filters.BufferedRequestStreamTest
here
18 Jul 15:44:29 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jul 18 15:44:28 EDT 2008]; root of context hierarchy
18 Jul 15:44:29 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
18 Jul 15:44:29 INFO [geoserver.global] - Done disposing datastores.
18 Jul 15:44:29 INFO [geoserver.catalog] - Disposing datastore 'cgf'
18 Jul 15:44:29 INFO [geoserver.catalog] - Disposing datastore 'sf'
18 Jul 15:44:29 INFO [geoserver.catalog] - Disposing datastore 'cdf'
18 Jul 15:44:29 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.398 sec
Results :
Tests in error:
  testInit(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterDisabled(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterExtraProxyContext(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterNonMatchingMime(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterRelativeUrl(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterProxyRoot(org.geoserver.filters.ReverseProxyFilterTest)
  testDoFilterContentContainsProxifiedUrl(org.geoserver.filters.ReverseProxyFilterTest)
Tests run: 11, Failures: 0, Errors: 7, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports for the individual test results.
[INFO] Total time: 7 minutes 56 seconds
[INFO] Finished at: Fri Jul 18 15:44:29 EDT 2008
[INFO] Final Memory: 34M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/360/changes
Changes:
[dwinslow] Port testing reorg and empty-body POST fix from 1.7.x
[...truncated 134 lines...]
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.8.0-SNAPSHOT/config-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.8.0-SNAPSHOT/config-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.8.0-SNAPSHOT/config-1.8.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.8.0-SNAPSHOT/platform-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.8.0-SNAPSHOT/platform-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.8.0-SNAPSHOT/platform-1.8.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 19 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.786 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jul 18, 2008 4:37:39 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.007 sec
Results :
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.8.0-SNAPSHOT/data-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.8.0-SNAPSHOT/data-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.8.0-SNAPSHOT/data-1.8.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:ogc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 71 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compiling 14 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.781 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.256 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.055 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.8.0-SNAPSHOT/ows-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.8.0-SNAPSHOT/ows-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.8.0-SNAPSHOT/ows-1.8.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geoserver:ows:1.7.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:ows:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geoserver:geoserver:1.7.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:geoserver:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geoserver:platform:1.7.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:platform:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 227 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] snapshot org.geoserver:data:1.8.0-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:data:1.8.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 23 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/test/java/org/geoserver/test/GeoServerAbstractTestSupport.java :[988,8] cannot find symbol
symbol : class CodeExpectingHttpServletResponse
location: class org.geoserver.test.GeoServerAbstractTestSupport
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/test/java/org/geoserver/test/GeoServerAbstractTestSupport.java :[988,56] cannot find symbol
[INFO] Total time: 1 minute 45 seconds
[INFO] Finished at: Fri Jul 18 16:38:19 EDT 2008
[INFO] Final Memory: 29M/56M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/361/changes
Changes:
[aaime] Fixing unit test according to changes performed in the proxy filter.
[aaime] GEOS-2052, Can't disable caching and remove the caching time (in feature type configuration). Also added i18n error messages that were missing
[...truncated 125 lines...]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.474 sec
Jul 18, 2008 5:02:47 PM org.geotools.data.DefaultTransaction finalize
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.899 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.658 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.191 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 1 minute 43 seconds
[INFO] Finished at: Fri Jul 18 17:03:28 EDT 2008
[INFO] Final Memory: 30M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/362/changes
