Niels,
I am getting exactly the same failure on my 64-bit Linux machine, even with a 32-bit JDK.
The test passes in Eclipse running with jdk1.5.0_22.i586, and it passes with this JDK under 32-bit Debian.
My environment:
Apache Maven 2.2.1 (r801777; 2009-08-07 03:16:01+0800)
Java version: 1.5.0_22
Java home: /home/car605/junk/java/jdk1.5.0_22.i586/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux" version: "2.6.35.11-83.fc14.x86_64" arch: "i386" Family: "unix"
Kind regards,
Ben.
-------- Original Message --------
Subject: [Geoserver-devel] Build failed in Hudson: geoserver-trunk #3632
Date: Fri, 4 Mar 2011 13:05:40 +0800
To: geoserver-devel@lists.sourceforge.net <geoserver-devel@lists.sourceforge.net>
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3632/changes>
Changes:
[NielsCharlier] Property Selection with namespace/nested paths GEOS-4380
[...truncated 23526 lines...]
</ex:nestedFeature>
<ex:nestedFeature xlink:href="http://example.com/UrnResolver/?uri=1"/>
</ex:geomContainer>
</gml:featureMember>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:pos>31.29 42.58</gml:pos>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:exterior>
<gml:LinearRing>
<gml:posList>52.5 -1.2 52.6 -1.2 52.6 -1.1 52.5 -1.1 52.5 -1.2</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature>
<ex:nestedGeom gml:id="secondNested.1">
<ex:name>NAME</ex:name>
<ex:nestedFeature>
<ex:nestedGeom gml:id="thirdNested.2">
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature xlink:href="http://example.com/UrnResolver/?uri=2"/>
</ex:geomContainer>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.687 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
04 Mar 05:04:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1916150301587239238data>
Mar 4, 2011 5:04:51 AM org.geoserver.test.SameNameDiffNamespaceTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2011-03-04T05:04:51.463Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1916150301587239238data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:MyTestFeature gml:id="f1">
<gml:name>Feature 1</gml:name>
<ex:name>First Feature</ex:name>
</ex:MyTestFeature>
<gml:featureMember>
<ex:MyTestFeature gml:id="f2">
<gml:name>Feature 2</gml:name>
<ex:name>Second Feature</ex:name>
</ex:MyTestFeature>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.18 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock7156898359372103420data>
Mar 4, 2011 5:04:52 AM org.geoserver.test.PolymorphismInlineWfsTest testGetFeature
INFO: WFS GetFeature&typename=ex:PolymorphicFeature response:
<wfs:FeatureCollection numberOfFeatures="6" timeStamp="2011-03-04T05:04:52.652Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock7156898359372103420data/featureTypes/ex_PolymorphicFeature/polymorphism.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f1">
<ex:firstValue>
<gsml:CGI_TermValue gsml:qualifier="approximate">
<gsml:value codeSpace="codespace">1</gsml:value>
</gsml:CGI_TermValue>
</ex:firstValue>
</ex:PolymorphicFeature>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f2">
<ex:firstValue>
<gsml:CGI_TermValue>
<gsml:value codeSpace="some:uri">x</gsml:value>
</ex:firstValue>
<ex:firstValue>
<gsml:value codeSpace="codespace">0</gsml:value>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f3">
<ex:firstValue>
<gsml:value codeSpace="some:uri">y</gsml:value>
</ex:firstValue>
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f4">
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f5">
<ex:firstValue>
</ex:firstValue>
<ex:firstValue>
</ex:firstValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f6">
<ex:firstValue>
<gsml:value codeSpace="codespace">1000</gsml:value>
</ex:firstValue>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.test.MappingNameTest
04 Mar 05:04:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock1647176027296525843data>
Mar 4, 2011 5:04:54 AM org.geoserver.test.MappingNameTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2011-03-04T05:04:54.923Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf1">
<gsml:observationMethod>
<gsml:value codeSpace="codespace01">value01</gsml:value>
</gsml:observationMethod>
<gsml:value codeSpace="codespace02">value02</gsml:value>
<gsml:shape>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>-23.6701 133.8855</gml:pos>
</gml:Point>
</gsml:shape>
</gsml:MappedFeature>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf2">
<gsml:value codeSpace="codespace03">value03</gsml:value>
<gsml:shape>
<gml:pos>-29.0434 167.9388</gml:pos>
</gml:Point>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf3">
<gsml:shape>
<gml:pos>-12.1883 96.8339</gml:pos>
</gml:Point>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
<gsml:shape>
<gml:pos>-34.9502 117.8102</gml:pos>
</gml:Point>
</gsml:shape>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.232 sec
Running org.geoserver.test.PropertyEncodingOrderTest
04 Mar 05:04:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock2818524949744325046data>
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 44.413 sec <<< FAILURE!
Results :
Tests in error:
Tests run: 66, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 9 minutes 2 seconds
[INFO] Finished at: Fri Mar 04 05:05:39 UTC 2011
[INFO] Final Memory: 74M/313M
Failed to send e-mail to NielsCharlier because no e-mail address is known, and no default e-mail domain is configured
What You Don't Know About Data Connectivity CAN Hurt You
This paper provides an overview of data connectivity, details
its effect on application quality, and explores various alternative
solutions. http://p.sf.net/sfu/progress-d2d
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
