[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3664
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3664/changes&gt;
Changes:
[bencaradocdavies] GEOT-3466: Upgrade EMF to 2.6.1
[...truncated 484 lines...]
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Mar 16, 2011 2:41:29 AM org.geoserver.platform.GeoServerExtensions extensions
SEVERE: bean lookup error
java.lang.IllegalArgumentException: Argument "value" should not be null.
  at org.geotools.util.SoftValueHashMap.ensureNotNull(SoftValueHashMap.java:130)
  at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:271)
  at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:109)
  at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:146)
  at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:224)
  at org.geoserver.platform.GeoServerExtensionsTest.testExtensionFilterByClass(GeoServerExtensionsTest.java:169)
  at org.geoserver.platform.GeoServerExtensionsTest.testExtensionFilterByClass(GeoServerExtensionsTest.java:174)
Mar 16, 2011 2:41:29 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.141 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.2-SNAPSHOT/platform-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.2-SNAPSHOT/platform-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.2-SNAPSHOT/platform-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.2-SNAPSHOT/platform-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.8-SNAPSHOT: checking for updates from osgeo
[WARNING] repository metadata for: 'snapshot org.geotools.ogc:net.opengis.ows:2.8-SNAPSHOT' could not be retrieved from repository: osgeo due to an error: Error transferring file: Connection timed out
[INFO] Repository 'osgeo' will be blacklisted
[INFO] snapshot org.geotools:ogc:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/eclipse/emf/common/2.6.0/common-2.6.0.pom
[INFO] Unable to find resource 'org.eclipse.emf:common:pom:2.6.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://maven.restlet.org/org/eclipse/emf/common/2.6.0/common-2.6.0.pom
[INFO] Unable to find resource 'org.eclipse.emf:common:pom:2.6.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://download.java.net/maven/2/org/eclipse/emf/common/2.6.0/common-2.6.0.pom
[INFO] Unable to find resource 'org.eclipse.emf:common:pom:2.6.0' in repository maven2-repository.dev.java.net (http://download.java.net/maven/2)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/common/2.6.0/common-2.6.0.pom
[INFO] Unable to find resource 'org.eclipse.emf:common:pom:2.6.0' in repository central (http://repo1.maven.org/maven2)
Downloading: http://repo.opengeo.org//org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.pom
[INFO] Unable to find resource 'org.eclipse.emf:ecore:pom:2.6.1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://maven.restlet.org/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.pom
[INFO] Unable to find resource 'org.eclipse.emf:ecore:pom:2.6.1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://download.java.net/maven/2/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.pom
[INFO] Unable to find resource 'org.eclipse.emf:ecore:pom:2.6.1' in repository maven2-repository.dev.java.net (http://download.java.net/maven/2)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.pom
[INFO] Unable to find resource 'org.eclipse.emf:ecore:pom:2.6.1' in repository central (http://repo1.maven.org/maven2)
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:2.8-SNAPSHOT: checking for updates from opengeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/xsd/2.8-SNAPSHOT/xsd-2.8-SNAPSHOT.pom
[INFO] snapshot org.geotools:extension:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/2.8-SNAPSHOT/gt-xsd-gml3-2.8-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/eclipse/emf/common/2.6.0/common-2.6.0.jar
[INFO] Unable to find resource 'org.eclipse.emf:common:jar:2.6.0' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://maven.restlet.org/org/eclipse/emf/common/2.6.0/common-2.6.0.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/2.8-SNAPSHOT/gt-xsd-gml3-2.8-SNAPSHOT.jar
[INFO] Unable to find resource 'org.eclipse.emf:common:jar:2.6.0' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://download.java.net/maven/2/org/eclipse/emf/common/2.6.0/common-2.6.0.jar
[INFO] Unable to find resource 'org.eclipse.emf:common:jar:2.6.0' in repository maven2-repository.dev.java.net (http://download.java.net/maven/2)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/common/2.6.0/common-2.6.0.jar
[INFO] Unable to find resource 'org.eclipse.emf:common:jar:2.6.0' in repository central (http://repo1.maven.org/maven2)
Downloading: http://repo.opengeo.org//org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.jar
[INFO] Unable to find resource 'org.eclipse.emf:ecore:jar:2.6.1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://maven.restlet.org/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.jar
[INFO] Unable to find resource 'org.eclipse.emf:ecore:jar:2.6.1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://download.java.net/maven/2/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.jar
[INFO] Unable to find resource 'org.eclipse.emf:ecore:jar:2.6.1' in repository maven2-repository.dev.java.net (http://download.java.net/maven/2)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/ecore/2.6.1/ecore-2.6.1.jar
[INFO] Unable to find resource 'org.eclipse.emf:ecore:jar:2.6.1' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.eclipse.emf:common:jar:2.6.0
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.eclipse.emf -DartifactId=common -Dversion=2.6.0 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.eclipse.emf -DartifactId=common -Dversion=2.6.0 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:ows:jar:2.2-SNAPSHOT
    2) org.geotools.ogc:net.opengis.ows:jar:2.8-SNAPSHOT
    3) org.eclipse.emf:common:jar:2.6.0
2) org.eclipse.emf:ecore:jar:2.6.1
      mvn install:install-file -DgroupId=org.eclipse.emf -DartifactId=ecore -Dversion=2.6.1 -Dpackaging=jar -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=org.eclipse.emf -DartifactId=ecore -Dversion=2.6.1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    3) org.eclipse.emf:ecore:jar:2.6.1
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  opengeo (http://repo.opengeo.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
[INFO] Total time: 1 minute 6 seconds
[INFO] Finished at: Wed Mar 16 02:41:52 UTC 2011
[INFO] Final Memory: 43M/218M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3665/&gt;
