[Geoserver-devel] Build failed in Hudson: geoserver-trunk #4110
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4110/changes&gt;
Changes:
[jdeolive] GEOS-4630, updated NativeType parsing in transaction to allow for content inside Native element
[...truncated 1187 lines...]
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Jun 15, 2011 8:37:59 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 32, Failures: 0, Errors: 32, Skipped: 0, Time elapsed: 8.637 sec <<< FAILURE!
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 1.198 sec <<< FAILURE!
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 1.643 sec <<< FAILURE!
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.442 sec <<< FAILURE!
Running org.geoserver.catalog.SchemaMappingTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 1.635 sec <<< FAILURE!
Running org.geoserver.catalog.impl.CatalogImplTest
Jun 15, 2011 8:38:07 PM org.geoserver.catalog.impl.CatalogImpl event
WARNING: Catalog listener threw exception handling event.
java.lang.RuntimeException
  at org.geoserver.catalog.impl.CatalogImplTest$ExceptionThrowingListener.handleAddEvent(CatalogImplTest.java:1342)
  at org.geoserver.catalog.impl.CatalogImpl.event(CatalogImpl.java:1157)
  at org.geoserver.catalog.impl.CatalogImpl.fireAdded(CatalogImpl.java:1121)
  at org.geoserver.catalog.impl.CatalogImpl.added(CatalogImpl.java:1110)
  at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:925)
  at org.geoserver.catalog.impl.CatalogImplTest.testExceptionThrowingListener(CatalogImplTest.java:1239)
  at sun.reflect.GeneratedMethodAccessor43.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.304 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 1.029 sec <<< FAILURE!
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 1.216 sec <<< FAILURE!
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.206 sec <<< FAILURE!
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.49 sec <<< FAILURE!
Running org.geoserver.config.util.XStreamPersisterTest
Jun 15, 2011 8:38:12 PM org.geoserver.config.util.XStreamPersister$ResourceInfoConverter doUnmarshal
INFO: Loaded feature type 'ft', disabled
Jun 15, 2011 8:38:13 PM org.geoserver.config.util.XStreamPersister$StoreInfoConverter doUnmarshal
INFO: Loaded store 'bar', disabled
INFO: Loaded store 'foo', disabled
Jun 15, 2011 8:38:13 PM org.geoserver.config.util.XStreamPersister$SpaceMapConverter unmarshal
INFO: Loading namespace 'acme'
INFO: Loading workspace 'foo'
Jun 15, 2011 8:38:13 PM org.geoserver.config.util.XStreamPersister$ResourceInfoConverter doUnmarshal
INFO: Loaded resource 'wmsLayer', disabled
Tests run: 15, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.622 sec <<< FAILURE!
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Jun 15, 2011 8:38:13 PM org.geoserver.security.impl.DataAccessRuleDAO parseDataAccessRule
WARNING: Namespace/Workspace topp is unknown in rule topp.*.r=*
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.w=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.r=READER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.r=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
Jun 15, 2011 8:38:13 PM org.geoserver.security.impl.DataAccessRuleDAO loadRules
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.084 sec
Running org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Running org.geoserver.config.GeoServerPropertyConfigurerTest
15 Jun 20:38:13 INFO [config.GeoServerPropertyConfigurer] - Loading properties file from URL [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/foo.properties\]>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec
Results :
Tests in error:
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest)
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
  testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
  testOverride(org.vfny.geoserver.crs.OvverideCRSTest)
  testFeatureTypeCacheInstance(org.geoserver.catalog.ResourcePoolTest)
  testAttributeCache(org.geoserver.catalog.ResourcePoolTest)
  testCacheClearing(org.geoserver.catalog.ResourcePoolTest)
  testDispose(org.geoserver.catalog.ResourcePoolTest)
  testLRU(org.geoserver.catalog.ResourcePoolTest)
  testGeoServerReload(org.geoserver.catalog.ResourcePoolTest)
  testConfigureFeatureTypeCacheSize(org.geoserver.catalog.ResourcePoolTest)
  testCatalogUpdates(org.geoserver.config.UpdateSequenceListenerTest)
  testServiceUpdates(org.geoserver.config.UpdateSequenceListenerTest)
  testCascadeLayer(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testFullAccess(org.geoserver.security.impl.SecureCatalogIntegrationTest)
  testCannotRead(org.geoserver.security.impl.SecureCatalogIntegrationTest)
  testCannotWrite(org.geoserver.security.impl.SecureCatalogIntegrationTest)
  test(org.geoserver.template.GeoServerTemplateLoaderTest)
  testRemoteType(org.geoserver.template.GeoServerTemplateLoaderTest)
  testAddWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddDataStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveDataStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyDataStore(org.geoserver.config.GeoServerPersisterTest)
  testChangeDataStoreWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testAddCoverage(org.geoserver.config.GeoServerPersisterTest)
  testAddWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testAddLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayer(org.geoserver.config.GeoServerPersisterTest)
  testAddStyle(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyle(org.geoserver.config.GeoServerPersisterTest)
  testRemoveStyle(org.geoserver.config.GeoServerPersisterTest)
  testAddWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyGlobal(org.geoserver.config.GeoServerPersisterTest)
  testDefaultWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverage(org.geoserver.config.GeoServerPersisterTest)
  testRemoveCoverage(org.geoserver.config.GeoServerPersisterTest)
  testModifyWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testAddLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testGlobal(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRemoteType(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToFeatureType(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToStore(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToWorkspace(org.geoserver.template.GeoServerTemplateLoader2Test)
  testBasic(org.geoserver.ows.URLManglersTest)
  testKVP(org.geoserver.ows.URLManglersTest)
  testProxyBase(org.geoserver.ows.URLManglersTest)
  testMissingFeatureTypes(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testMissingCoverages(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testCRSPrefix(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testNoMapping(org.geoserver.catalog.SchemaMappingTest)
  testXsdMapping(org.geoserver.catalog.SchemaMappingTest)
  testXmlMapping(org.geoserver.catalog.SchemaMappingTest)
  testBasic(org.geoserver.ows.CustomManglerTest)
  testKVP(org.geoserver.ows.CustomManglerTest)
  testValid(org.vfny.geoserver.util.SLDValidatorTest)
  testInvalid(org.vfny.geoserver.util.SLDValidatorTest)
  testContextStartup(org.geoserver.vfny.global.TolerantStartupTest)
  testGobalContactDefault(org.geoserver.config.util.XStreamPersisterTest)
  testChangeWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespaceURI(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
Tests run: 268, Failures: 0, Errors: 86, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 21 seconds
[INFO] Finished at: Wed Jun 15 20:38:14 UTC 2011
[INFO] Final Memory: 99M/765M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4111/&gt;
[...truncated 15653 lines...]
  at java.lang.reflect.Method.invoke(Method.java:592)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:670)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:300)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:297)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:130)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:109)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 52 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:128)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:715)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:607)
  at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:661)
  ... 57 more
ERROR: 'Invalid update sequence value, it's higher than the current value, 0'
15 Jun 21:33:07 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:757)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:238)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:560)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1217)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1236)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1177)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1159)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:778)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:725)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:705)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:912)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:895)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:204)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:145)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  ... 53 more
  ... 58 more
ERROR: 'Unknown section Bogus'
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:593)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:576)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:561)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:846)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:810)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:211)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  ... 52 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:173)
  ... 57 more
SchemaLocation: schemaLocation value = 'http://localhost:8080/geoserver/schemas/wcs/1.1.1/wcsGetCapabilities.xsd’ must have even number of URI's.
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.521 sec
Results :
Tests run: 79, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset&gt; are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree&gt; are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.2-SNAPSHOT/wcs1_1-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs&gt;
[INFO] Copying 10 resources
[INFO] Copying 2 resources
[INFO] Compiling 179 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes&gt;
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/src/main/java/org/geoserver/wfs/xml/v1_1_0/NativeTypeBinding.java&gt;:\[99,59\] cannot find symbol
symbol : method isEmpty()
[INFO] Total time: 2 minutes 10 seconds
[INFO] Finished at: Wed Jun 15 21:33:12 UTC 2011
[INFO] Final Memory: 62M/303M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/4112/changes&gt;
