See http://hudson.opengeo.org/hudson/job/geoserver-trunk/752/changes
Changes:
[jdeolive] refactoring+cleanup
[jdeolive] added resolve looks ps for all catalog types
[jdeolive] added resolve() method for feature type info
[...truncated 720 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:987)
... 31 more
12 Feb 02:38:14 ERROR [geoserver.global] - Could not load feature type cite:BasicPolygons
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:991)
at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:516)
at org.vfny.geoserver.global.Data.toDTO(Data.java:1599)
at org.vfny.geoserver.global.Config.getData(Config.java:107)
at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:47)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:133)
... 31 more
12 Feb 02:38:14 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Feb 12 02:38:13 EST 2009]; root of context hierarchy
12 Feb 02:38:14 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
12 Feb 02:38:14 INFO [geoserver.global] - Done disposing datastores.
Feb 12, 2009 2:38:13 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'sf'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
Feb 12, 2009 2:38:14 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.138 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
12 Feb 02:38:14 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
12 Feb 02:38:14 INFO [geoserver.catalog] - Default namespace: 'gs'
12 Feb 02:38:14 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.config.util.XStreamPersisterTest
12 Feb 02:38:14 INFO [org.geoserver] - Persisted data store 'bar'
12 Feb 02:38:14 INFO [org.geoserver] - Loaded store 'bar', disabled
12 Feb 02:38:14 INFO [org.geoserver] - Persisted coverage store 'bar'
12 Feb 02:38:14 INFO [org.geoserver] - Persisting workspace '{foo=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com, null=org.geoserver.catalog.impl.WorkspaceInfoImpl@anonymised.com}'
12 Feb 02:38:14 INFO [org.geoserver] - Persisting namespace '{null=acme, acme=acme}'
12 Feb 02:38:14 INFO [org.geoserver] - Persisted data store 'foo'
12 Feb 02:38:14 INFO [org.geoserver] - Loading workspace 'foo'
12 Feb 02:38:14 INFO [org.geoserver] - Loading namespace 'acme'
12 Feb 02:38:14 INFO [org.geoserver] - Loaded store 'foo', disabled
12 Feb 02:38:14 INFO [org.geoserver] - Persisting resource 'ft'
Feb 12, 2009 2:38:14 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Feb 12, 2009 2:38:14 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
12 Feb 02:38:14 INFO [org.geoserver] - Loaded feature type 'ft', disabled
Tests run: 11, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 0.35 sec <<< FAILURE!
Running org.geoserver.config.LegacyConfigurationImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.geoserver.template.FeatureWrapperTest
Feb 12, 2009 2:38:15 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.328 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Feb 12, 2009 2:38:15 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.748 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 40, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Results :
Failed tests:
testService(org.geoserver.config.util.XStreamPersisterTest)
testServiceOmitGlobal(org.geoserver.config.util.XStreamPersisterTest)
Tests run: 110, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 22 seconds
[INFO] Finished at: Thu Feb 12 02:38:16 EST 2009
[INFO] Final Memory: 29M/63M
