[Geoserver-devel] Build failed in Hudson: geoserver-trunk #834
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/834/changes
Changes:
[aaime] Normalize class naming, GeoServer specific classes often have GeoServer as the prefix, never GS
[aaime] Fixed imports
[aaime] Allow to specify the number of items per page
[...truncated 3325 lines...]
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:126)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 50 more
16 Mar 10:39:08 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:702)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1037)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1004)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:636)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:583)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:563)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:772)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:755)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:189)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  ... 49 more
  ... 51 more
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:451)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:432)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:706)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:668)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:196)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:173)
  ... 50 more
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.386 sec
Results :
Tests run: 77, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree are up to date.
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0-SNAPSHOT/wcs1_1-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0-SNAPSHOT/wcs1_1-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/wcs1_1-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0-SNAPSHOT/wcs1_1-2.0-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.6-SNAPSHOT: checking for updates from opengeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/2.6-SNAPSHOT/net.opengis.wfs-2.6-20090316.063152-17.pom
1/1K
1K downloaded
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/2.6-SNAPSHOT/net.opengis.wfs-2.6-20090316.063152-17.jar
3/139K
3/139K
6/139K
10/139K
14/139K
18/139K
22/139K
26/139K
30/139K
34/139K
38/139K
42/139K
46/139K
50/139K
54/139K
58/139K
62/139K
66/139K
70/139K
74/139K
78/139K
82/139K
86/139K
90/139K
94/139K
98/139K
102/139K
106/139K
110/139K
114/139K
118/139K
122/139K
126/139K
130/139K
134/139K
138/139K
139/139K
139K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 165 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 41 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/test-classes
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/),
  maven2-repository.dev.java.net (http://download.java.net/maven/2),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver:wfs:jar:2.0-SNAPSHOT
  2) org.geoserver:main:jar:2.0-SNAPSHOT
  3) org.geotools:gt-metadata:jar:2.6-SNAPSHOT
  4) org.opengis:geoapi-pending:jar:2.3-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/opengis/geoapi-pending/2.3-SNAPSHOT/geoapi-pending-2.3-SNAPSHOT.jar
[INFO] Total time: 1 minute 46 seconds
[INFO] Finished at: Mon Mar 16 10:39:16 EDT 2009
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/835/changes
