[Geoserver-devel] Build failed in Hudson: geoserver-trunk-deploy #1189
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/1189/&gt;
[...truncated 33390 lines...]
112/140K
116/140K
120/140K
124/140K
128/140K
132/140K
136/140K
140/140K
140/140K
144/140K
148/140K
152/140K
156/140K
160/140K
164/140K
168/140K
172/140K
176/140K
180/140K
184/140K
188/140K
192/140K
196/140K
200/140K
204/140K
208/140K
212/140K
216/140K
220/140K
224/140K
228/140K
232/140K
236/140K
240/140K
244/140K
248/140K
252/140K
256/140K
260/140K
264/140K
268/140K
272/140K
276/140K
280/140K
281/140K
140K uploaded (wps-core-2.2-SNAPSHOT-sources.jar)
[INFO] Building Web Processing Service GUI
[INFO] task-segment: [deploy]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps/src/main/resources&gt;
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/zonalstats/1.0-SNAPSHOT/zonalstats-1.0-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/2.7-SNAPSHOT/gt-geotiff-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/2.7-SNAPSHOT/gt-shapefile-renderer-2.7-SNAPSHOT.jar
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/utils/1.0-SNAPSHOT/utils-1.0-SNAPSHOT.jar
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/rangelookup/1.0-SNAPSHOT/rangelookup-1.0-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 0 resource
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps/target/web-wps-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps/target/web-wps-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps/target/web-wps-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/ws/extension/wps/web-wps/target/web-wps-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
[INFO] repository metadata for: 'snapshot org.geoserver.extension:web-wps:2.2-SNAPSHOT' could not be found on repository: opengeo, so will be created
Uploading: http://repo.opengeo.org/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT.jar
4/54K
8/54K
12/54K
16/54K
20/54K
24/54K
28/54K
32/54K
36/54K
40/54K
44/54K
48/54K
52/54K
54/54K
58/54K
62/54K
66/54K
70/54K
74/54K
78/54K
82/54K
86/54K
90/54K
94/54K
98/54K
102/54K
106/54K
108/54K
54K uploaded (web-wps-2.2-SNAPSHOT.jar)
[INFO] Retrieving previous metadata from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3e45584107424b68893bae42020439d5f71da0e7'; remote = 'd993dad6bd09daf3c940b00d37fb20ae873d4cfc' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3e45584107424b68893bae42020439d5f71da0e7'; remote = 'd993dad6bd09daf3c940b00d37fb20ae873d4cfc' - IGNORING
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:web-wps'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:web-wps:2.2-SNAPSHOT'
[INFO] Uploading project information for web-wps 2.2-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '649b99b1b897de1331aa4308de7f5c724e9766ef'; remote = 'a1d5e6fd20fdd7473946d3fa2431a4c5702b8a94' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '649b99b1b897de1331aa4308de7f5c724e9766ef'; remote = 'a1d5e6fd20fdd7473946d3fa2431a4c5702b8a94' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT-tests.jar
4/4K
4/4K
8/4K
9/4K
4K uploaded (web-wps-2.2-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/web-wps/2.2-SNAPSHOT/web-wps-2.2-SNAPSHOT-sources.jar
4/24K
8/24K
12/24K
16/24K
20/24K
24/24K
24/24K
28/24K
32/24K
36/24K
40/24K
44/24K
48/24K
48/24K
24K uploaded (web-wps-2.2-SNAPSHOT-sources.jar)
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [10.278s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.296s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [1.658s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.203s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [0.366s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.345s]
[INFO] Core Platform Module .................................. SUCCESS [1.033s]
[INFO] Open Web Service Module ............................... SUCCESS [3.128s]
[INFO] Main Module ........................................... SUCCESS [9.772s]
[INFO] Web Coverage Service Module ........................... SUCCESS [0.726s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [3.250s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [1.340s]
[INFO] Web Feature Service Module ............................ SUCCESS [1.037s]
[INFO] Web Map Service Module ................................ SUCCESS [2.594s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.391s]
[INFO] REST Support Module ................................... SUCCESS [0.526s]
[INFO] REST Configuration Service Module ..................... SUCCESS [2.281s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.954s]
[INFO] Core UI Module ........................................ SUCCESS [2.635s]
[INFO] WMS UI Module ......................................... SUCCESS [0.732s]
[INFO] GWC UI Module ......................................... SUCCESS [0.687s]
[INFO] WFS UI Module ......................................... SUCCESS [0.836s]
[INFO] Demoes Module ......................................... SUCCESS [1.012s]
[INFO] WCS UI Module ......................................... SUCCESS [0.708s]
[INFO] Security UI Module .................................... SUCCESS [0.740s]
[INFO] Community Space ....................................... SUCCESS [1.385s]
[INFO] Printing Module ....................................... SUCCESS [2.105s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [1.283s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [1.206s]
[INFO] GeoServer Web Application ............................. SUCCESS [13.089s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.423s]
[INFO] Application Schema Support ............................ SUCCESS [0.850s]
[INFO] Application Schema Integration Test ................... SUCCESS [0.823s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [0.647s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [1.212s]
[INFO] GeoSearch Index Module ................................ SUCCESS [0.741s]
[INFO] H2 DataStore Extension ................................ SUCCESS [0.640s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.452s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.251s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.405s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [1.272s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.409s]
[INFO] ImageMap Output Format ................................ SUCCESS [0.682s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [0.681s]
[INFO] Excel Output Format ................................... SUCCESS [0.497s]
[INFO] Validation Module ..................................... SUCCESS [0.418s]
[INFO] Chart external graphics support ....................... SUCCESS [1.654s]
[INFO] Feature Generalization Extension ...................... SUCCESS [0.635s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [0.417s]
[INFO] OWS request flow controller ........................... SUCCESS [0.451s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.283s]
[INFO] Web Processing Service Module ......................... SUCCESS [4.728s]
[INFO] Web Processing Service GUI ............................ SUCCESS [1.495s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 1 minute 31 seconds
[INFO] Finished at: Mon Jan 17 19:50:35 UTC 2011
[INFO] Final Memory: 79M/321M
[geoserver] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson5841434813368770420.sh
+ VER=2.1-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.1-SNAPSHOT.jar
md5sum: web-app-2.1-SNAPSHOT.jar: No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-deploy/1190/&gt;
