See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/284/>
[...truncated 144 lines...]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/src/test/java>
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT.jar>
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/config/target/config-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/target>
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/target/pom-transformed.xml> to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Web Plugin Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target>
[INFO] [resources:resources]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/src/main/java>
[INFO] Copying 7 resources
[INFO] [compiler:compile]
[INFO] [resources:testResources]
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/src/test/java>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/src/main/java>
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/src/test/java>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/src/main/resources>
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/classes>
[INFO] Copying 1 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/platform/target/platform-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target>
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/src/main/resources>
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/classes>
[INFO] Copying 4 resources
[INFO] Compiling 17 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/test-classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/ows/target/ows-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/target>
[INFO] Copying 28 resources
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 242 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java>:\[43,7\] org.geoserver.feature.retype.RetypingDataStore is not abstract and does not override abstract method getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java>:\[292,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
found : org.geotools.data.FeatureSource<org.opengis.feature.simple.SimpleFeatureType,org.opengis.feature.simple.SimpleFeature>
required: org.geotools.data.simple.SimpleFeatureSource
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java>:\[142,59\] getFeatureSource(java.lang.String) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java>:\[164,59\] getView(org.geotools.data.Query) in org.geoserver.feature.retype.RetypingDataStore cannot implement getView(org.geotools.data.Query) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/catalog/ResourcePool.java>:\[732,44\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java>:\[50,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java>:\[55,59\] getFeatureSource(java.lang.String) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java>:\[99,59\] getView(org.geotools.data.Query) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getView(org.geotools.data.Query) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java>:\[27,7\] org.geoserver.security.decorators.ReadOnlyDataStore is not abstract and does not override abstract method getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java>:\[38,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.security.decorators.ReadOnlyDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java>:\[45,59\] getFeatureSource(java.lang.String) in org.geoserver.security.decorators.ReadOnlyDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
[INFO] Total time: 35 seconds
[INFO] Finished at: Sat May 01 03:32:20 EDT 2010
[INFO] Final Memory: 44M/117M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/trunk/geoserver-trunk-2010-05-01-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
