[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #375
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/375/changes&gt;
Changes:
[victortey] GEOT-2679: Improve app-schema handling of nillable properties: add test cases to handle simple content of type integer. Indentation is fixed
Started by timer
Updating http://svn.codehaus.org/geoserver/trunk
U src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java
U src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java
Fetching 'http://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/css’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/test/java/org/geoserver/wicket/test/css’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/img’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/src/test/java/org/geoserver/wicket/test/img’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/citewfs-1.1/styles’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/data/citewfs-1.1-h2/styles’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/legacy/web/minimal’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/web/app/minimal’>
At revision 14638
At revision 14638
no change for http://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/css since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/img since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/data/citewfs-1.1/styles since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
[workspace] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson836742747235103189.sh
+ ver=trunk
+ dist=/var/www/html/geoserver/trunk
+ date +%Y-%m-%d
+ datestamp=2010-07-29
+ cd geoserver_trunk/src
+ mvn -DskipTests -P release,communityRelease clean install
/opt/tomcat-6.0/temp/hudson836742747235103189.sh: 1: mvn: not found
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2010-07-29-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/376/&gt;
