See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/713/changes>
Changes:
[groldan] geoserver custom extension to StyledLayerDescriptor.xsd for parameter substitutions to validate
[aaime] [GEOS-4563] Direct raster path + paletted tiff without transparency + transparency request in the request -> opaque image
[victortey] SISS-710:Reference data set for complex feature WFS
[whatnick] GEOS-3586: Added dds to communityRelease profile
[...truncated 5013 lines...]
5948/6851K
5952/6851K
5956/6851K
5960/6851K
5964/6851K
5968/6851K
5972/6851K
5976/6851K
5980/6851K
5984/6851K
5988/6851K
5992/6851K
5996/6851K
6000/6851K
6004/6851K
6008/6851K
6012/6851K
6016/6851K
6020/6851K
6024/6851K
6028/6851K
6032/6851K
6036/6851K
6040/6851K
6044/6851K
6048/6851K
6052/6851K
6056/6851K
6060/6851K
6064/6851K
6068/6851K
6072/6851K
6076/6851K
6080/6851K
6084/6851K
6088/6851K
6092/6851K
6096/6851K
6100/6851K
6104/6851K
6108/6851K
6112/6851K
6116/6851K
6120/6851K
6124/6851K
6128/6851K
6132/6851K
6136/6851K
6140/6851K
6144/6851K
6148/6851K
6152/6851K
6156/6851K
6160/6851K
6164/6851K
6168/6851K
6172/6851K
6176/6851K
6180/6851K
6184/6851K
6188/6851K
6192/6851K
6196/6851K
6200/6851K
6204/6851K
6208/6851K
6212/6851K
6216/6851K
6220/6851K
6224/6851K
6228/6851K
6232/6851K
6236/6851K
6240/6851K
6244/6851K
6248/6851K
6252/6851K
6256/6851K
6260/6851K
6264/6851K
6268/6851K
6272/6851K
6276/6851K
6280/6851K
6284/6851K
6288/6851K
6292/6851K
6296/6851K
6300/6851K
6304/6851K
6308/6851K
6312/6851K
6316/6851K
6320/6851K
6324/6851K
6328/6851K
6332/6851K
6336/6851K
6340/6851K
6344/6851K
6348/6851K
6352/6851K
6356/6851K
6360/6851K
6364/6851K
6368/6851K
6372/6851K
6376/6851K
6380/6851K
6384/6851K
6388/6851K
6392/6851K
6396/6851K
6400/6851K
6404/6851K
6408/6851K
6412/6851K
6416/6851K
6420/6851K
6424/6851K
6428/6851K
6432/6851K
6436/6851K
6440/6851K
6444/6851K
6448/6851K
6452/6851K
6456/6851K
6460/6851K
6464/6851K
6468/6851K
6472/6851K
6476/6851K
6480/6851K
6484/6851K
6488/6851K
6492/6851K
6496/6851K
6500/6851K
6504/6851K
6508/6851K
6512/6851K
6516/6851K
6520/6851K
6524/6851K
6528/6851K
6532/6851K
6536/6851K
6540/6851K
6544/6851K
6548/6851K
6552/6851K
6556/6851K
6560/6851K
6564/6851K
6568/6851K
6572/6851K
6576/6851K
6580/6851K
6584/6851K
6588/6851K
6592/6851K
6596/6851K
6600/6851K
6604/6851K
6608/6851K
6612/6851K
6616/6851K
6620/6851K
6624/6851K
6628/6851K
6632/6851K
6636/6851K
6640/6851K
6644/6851K
6648/6851K
6652/6851K
6656/6851K
6660/6851K
6664/6851K
6668/6851K
6672/6851K
6676/6851K
6680/6851K
6684/6851K
6688/6851K
6692/6851K
6696/6851K
6700/6851K
6704/6851K
6708/6851K
6712/6851K
6716/6851K
6720/6851K
6724/6851K
6728/6851K
6732/6851K
6736/6851K
6740/6851K
6744/6851K
6748/6851K
6752/6851K
6756/6851K
6760/6851K
6764/6851K
6768/6851K
6772/6851K
6776/6851K
6780/6851K
6784/6851K
6788/6851K
6792/6851K
6796/6851K
6800/6851K
6804/6851K
6808/6851K
6812/6851K
6816/6851K
6820/6851K
6824/6851K
6828/6851K
6832/6851K
6836/6851K
6840/6851K
6844/6851K
6848/6851K
6851/6851K
6851K downloaded (worldwind-0.6.jar)
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'ca2afb6982d8bae335761cbaf482cdb89364e1fd'; remote = 'e9c0cd827ad61887a44e6fdb2c2381ae8ef15837' - IGNORING
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dds/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dds/src/main/java/org/geoserver/wms/worldwind/DDSMapResponse.java>:\[3,\-1\] cannot access gov.nasa.worldwind.formats.dds.DDSConverter
bad class file: /home/tomcat/.m2/repository/gov/nasa/worldwind/0.6/worldwind-0.6.jar(gov/nasa/worldwind/formats/dds/DDSConverter.class)
class file has wrong version 50.0, should be 49.0
[INFO] Total time: 3 minutes 1 second
[INFO] Finished at: Sat May 21 03:35:36 UTC 2011
[INFO] Final Memory: 88M/317M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-05-21-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
