[Geoserver-devel] Build failed in Hudson: geoserver-trunk-nightly #914
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/914/changes&gt;
Changes:
[jdeolive] GEOS-4838, GSIP 66, adding ability to configure services at the workspace level
[aaime] [GEOS-4855] Browsers won't show png8 files generated by GeoServer
[aaime] [GEOS-4853] KML Time template does not work anymore due to XSDateTimeBinding changes
[...truncated 1893 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/monitoring-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/monitoring-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/monitoring-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/monitoring-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/monitoring/target/monitoring-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/extension-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/target/extension-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.2-SNAPSHOT/extension-2.2-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2&gt;
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/src/main/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/extension/h2/target/h2-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.2-SNAPSHOT/h2-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Python Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python&gt;
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:8-SNAPSHOT: checking for updates from osgeo
[INFO] [antrun:run {execution: generate-sources}]
[INFO] Executing tasks
checkout:
     [echo] Pulling master from git://github.com/jdeolive/geoscript-py.git (ignore fatal warning)
     [exec] fatal: destination path 'geoscript' already exists and is not an empty directory.
     [exec] Result: 128
     [exec] From git://github.com/jdeolive/geoscript-py
     [exec] * branch master -> FETCH_HEAD
     [exec] Already up-to-date.
     [exec] Already on 'master'
     [exec] Your branch is ahead of 'origin/master' by 103 commits.
[INFO] Executed tasks
[INFO] [antrun:run {execution: generate-resources}]
[INFO] Copying 4 resources
[INFO] Copying 98 resources
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/python-2.2-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/python/2.2-SNAPSHOT/python-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Hibernate Catalog/Configuration Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig&gt;
[INFO] Copying 6 resources
[INFO] Compiling 22 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dbconfig/src/main/java/org/geoserver/config/hib/HibGeoServerFacade.java&gt;:\[15,7\] org.geoserver.config.hib.HibGeoServerFacade is not abstract and does not override abstract method <T>getServiceByName(java.lang.String,org.geoserver.catalog.WorkspaceInfo,java.lang.Class<T>) in org.geoserver.config.GeoServerFacade
[INFO] Total time: 4 minutes 5 seconds
[INFO] Finished at: Tue Nov 22 03:37:06 UTC 2011
[INFO] Final Memory: 82M/399M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-11-22-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/915/changes&gt;
Changes:
[aaime] Hopefully fix the cite tests after GEOS-4855 breakage
[aaime] [GEOS-4862] Asynch process execution will be stuck forever in 'process started' state if an error occurs while encoding the process results
[...truncated 1834 lines...]
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] Total time: 6 minutes 6 seconds
[INFO] Finished at: Wed Nov 23 03:38:31 UTC 2011
[INFO] Final Memory: 82M/413M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-11-23-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/916/changes&gt;
Changes:
[jdeolive] GEOS-4859, picking up metadata from underlying geotools ResourceInfo
[aaime] [GEOS-4863] WPS back link to store resources uses the parameter 'mime', it should be 'mimetype'
[...truncated 1727 lines...]
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] Total time: 3 minutes 49 seconds
[INFO] Finished at: Thu Nov 24 03:59:22 UTC 2011
[INFO] Final Memory: 82M/403M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/trunk/geoserver-trunk-2011-11-24-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/917/changes&gt;
