[Geoserver-devel] Build failed in Hudson: geoserver-trunk-online #104
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/104/&gt;
[...truncated 324 lines...]
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] [compiler:compile]
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/classes&gt;
[INFO] [resources:testResources]
[INFO] Copying 4 resources
[INFO] [compiler:testCompile]
[INFO] Compiling 17 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ows.DispatcherTest
May 1, 2010 4:01:27 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.839 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.635 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.079 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/target&gt;
[INFO] [resources:resources]
[INFO] Copying 28 resources
[INFO] Copying 1 resource
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.7-SNAPSHOT/gt-jdbc-2.7-SNAPSHOT.pom
3/5K
5/5K
5K downloaded (gt-jdbc-2.7-SNAPSHOT.pom)
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.7-SNAPSHOT/gt-property-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.7-SNAPSHOT/gt-jdbc-2.7-SNAPSHOT.jar
3/241K
7/241K
11/241K
15/241K
19/241K
23/241K
27/241K
31/241K
35/241K
39/241K
43/241K
47/241K
51/241K
55/241K
59/241K
63/241K
67/241K
71/241K
75/241K
79/241K
83/241K
87/241K
91/241K
95/241K
99/241K
103/241K
107/241K
111/241K
115/241K
119/241K
123/241K
127/241K
131/241K
135/241K
139/241K
143/241K
147/241K
151/241K
155/241K
159/241K
163/241K
165/241K
167/241K
171/241K
173/241K
174/241K
177/241K
178/241K
181/241K
182/241K
184/241K
185/241K
187/241K
188/241K
189/241K
191/241K
192/241K
194/241K
195/241K
197/241K
198/241K
199/241K
201/241K
202/241K
205/241K
206/241K
209/241K
211/241K
212/241K
214/241K
215/241K
216/241K
218/241K
219/241K
221/241K
222/241K
223/241K
225/241K
226/241K
229/241K
230/241K
232/241K
233/241K
235/241K
236/241K
239/241K
241/241K
241K downloaded (gt-jdbc-2.7-SNAPSHOT.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.7-SNAPSHOT/gt-property-2.7-SNAPSHOT.jar
[INFO] Compiling 242 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java&gt;:\[43,7\] org.geoserver.feature.retype.RetypingDataStore is not abstract and does not override abstract method getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java&gt;:\[292,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
found : org.geotools.data.FeatureSource<org.opengis.feature.simple.SimpleFeatureType,org.opengis.feature.simple.SimpleFeature>
required: org.geotools.data.simple.SimpleFeatureSource
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java&gt;:\[142,59\] getFeatureSource(java.lang.String) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java&gt;:\[164,59\] getView(org.geotools.data.Query) in org.geoserver.feature.retype.RetypingDataStore cannot implement getView(org.geotools.data.Query) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/catalog/ResourcePool.java&gt;:\[732,44\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.feature.retype.RetypingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java&gt;:\[50,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java&gt;:\[55,59\] getFeatureSource(java.lang.String) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/DecoratingDataStore.java&gt;:\[99,59\] getView(org.geotools.data.Query) in org.geoserver.security.decorators.DecoratingDataStore cannot implement getView(org.geotools.data.Query) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java&gt;:\[27,7\] org.geoserver.security.decorators.ReadOnlyDataStore is not abstract and does not override abstract method getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java&gt;:\[38,59\] getFeatureSource(org.opengis.feature.type.Name) in org.geoserver.security.decorators.ReadOnlyDataStore cannot implement getFeatureSource(org.opengis.feature.type.Name) in org.geotools.data.DataStore; attempting to use incompatible return type
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/ws/main/src/main/java/org/geoserver/security/decorators/ReadOnlyDataStore.java&gt;:\[45,59\] getFeatureSource(java.lang.String) in org.geoserver.security.decorators.ReadOnlyDataStore cannot implement getFeatureSource(java.lang.String) in org.geotools.data.DataStore; attempting to use incompatible return type
[INFO] Total time: 33 seconds
[INFO] Finished at: Sat May 01 04:01:40 EDT 2010
[INFO] Final Memory: 43M/116M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk-online/105/&gt;
