[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wfs-1.0 #61
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/61/display/redirect&gt;
[...truncated 134.10 KB...]
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] ... 188 more
     [exec] Caused by: java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1526)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] ... 203 more
     [exec] Caused by: java.lang.reflect.InvocationTargetException
     [exec] at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
     [exec] at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
     [exec] at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
     [exec] at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
     [exec] at com.occamlab.te.util.Misc.makeInstance(Misc.java:192)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1524)
     [exec] ... 211 more
     [exec] Caused by: java.lang.IllegalArgumentException: Connection timed out (Connection timed out)
     [exec] at com.galdosinc.glib.xml.jaxp.ValidatingDocumentBuilderFactory.setAttribute(ValidatingDocumentBuilderFactory.java:62)
     [exec] at com.occamlab.te.parsers.GMLValidatingParser.<init>(GMLValidatingParser.java:79)
     [exec] ... 217 more
     [exec]
     [exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.lang.Exception: Can't instantiate parser wfs:GMLValidatingParser
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 Failed
     [exec] Testing wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d1e861_1)...
     [exec] Assertion: When a wfs:GetCapabilities request is made to a basic WFS, the result document must define the Query operation either globally or for at least one feature type.
./run.sh: line 120: 4618 Killed ant -Dcite.headless=true -Dcite.headless.formroot=$FORMS $PROFILE
+ ant wfs-1.0-log
+ grep Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d1e825_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d1e845_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d1e851_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d1e856_1) Failed
./run.sh: line 123: 3992 Killed ( ./startup.sh -Djetty.http.port=$PORT > geoserver.log ) (wd: ~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin)
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ./shutdown.sh
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 3992
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/62/display/redirect&gt;
[...truncated 854.87 KB...]
     [exec] ... 190 more
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [exec] ... 205 more
     [exec] ... 214 more
     [exec] ... 220 more
     [exec]
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-25 Failed
     [exec] Testing wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-3 (wfs-1.0.0/d41e1227_1)...
     [exec] Assertion: This test checks that the PropertyIsBetween operator returns the correct feature for a date comparisson with the boundary values set to the expected value of the property.
./run.sh: line 120: 18073 Killed ant -Dcite.headless=true -Dcite.headless.formroot=$FORMS $PROFILE
+ ant wfs-1.0-log
+ grep Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-4 (wfs-1.0.0/d41e704_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-5 (wfs-1.0.0/d41e712_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-6 (wfs-1.0.0/d41e721_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-7 (wfs-1.0.0/d41e729_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-4 (wfs-1.0.0/d41e778_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-5 (wfs-1.0.0/d41e786_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-6 (wfs-1.0.0/d41e794_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-7 (wfs-1.0.0/d41e802_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d41e825_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d41e830_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d41e835_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d41e840_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d41e845_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d41e851_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d41e856_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d41e861_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-1 (wfs-1.0.0/d41e868_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-2 (wfs-1.0.0/d41e876_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-3 (wfs-1.0.0/d41e884_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-4 (wfs-1.0.0/d41e893_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-5 (wfs-1.0.0/d41e901_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-6 (wfs-1.0.0/d41e909_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-7 (wfs-1.0.0/d41e917_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-8 (wfs-1.0.0/d41e925_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-1 (wfs-1.0.0/d41e1080_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-10 (wfs-1.0.0/d41e1089_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-11 (wfs-1.0.0/d41e1097_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-12 (wfs-1.0.0/d41e1105_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-13 (wfs-1.0.0/d41e1113_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-14 (wfs-1.0.0/d41e1121_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-15 (wfs-1.0.0/d41e1129_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-16 (wfs-1.0.0/d41e1138_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-17 (wfs-1.0.0/d41e1146_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-18 (wfs-1.0.0/d41e1154_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-19 (wfs-1.0.0/d41e1162_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-2 (wfs-1.0.0/d41e1170_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-20 (wfs-1.0.0/d41e1178_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-21 (wfs-1.0.0/d41e1187_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-22 (wfs-1.0.0/d41e1195_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-23 (wfs-1.0.0/d41e1203_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-24 (wfs-1.0.0/d41e1211_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-25 (wfs-1.0.0/d41e1219_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
./run.sh: line 134: pushd: geoserver/geoserver-2.14-SNAPSHOT/bin: No such file or directory
+ popd
./run.sh: line 136: popd: directory stack empty
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 17529
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/63/display/redirect&gt;
[...truncated 1.53 MB...]
     [exec] ... 190 more
     [exec] at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
     [exec] ... 205 more
     [exec] at sun.reflect.GeneratedConstructorAccessor20.newInstance(Unknown Source)
     [exec] ... 213 more
     [exec] ... 218 more
     [exec]
     [exec] Testing wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-10 (wfs-1.0.0/d1e1497_1)...
     [exec] Assertion: When a wfs:GetFeature request with the BBOX spatial operator applied to a gml:multiPointProperty on a cgf:MPoints comparing a value that is a BBox that partially encloses the search feature, the result document must match the feature t0003.
./run.sh: line 120: 32492 Killed ant -Dcite.headless=true -Dcite.headless.formroot=$FORMS $PROFILE
+ ant wfs-1.0-log
+ grep Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-4 (wfs-1.0.0/d1e704_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-5 (wfs-1.0.0/d1e712_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-6 (wfs-1.0.0/d1e721_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-get-7 (wfs-1.0.0/d1e729_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-4 (wfs-1.0.0/d1e778_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-5 (wfs-1.0.0/d1e786_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-6 (wfs-1.0.0/d1e794_1) Failed
     [exec] Test wfs:test1.0.0-basic-describefeaturetype-post-7 (wfs-1.0.0/d1e802_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d1e830_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d1e835_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d1e840_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d1e861_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-1 (wfs-1.0.0/d1e868_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-2 (wfs-1.0.0/d1e876_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-3 (wfs-1.0.0/d1e884_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-4 (wfs-1.0.0/d1e893_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-5 (wfs-1.0.0/d1e901_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-6 (wfs-1.0.0/d1e909_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-7 (wfs-1.0.0/d1e917_1) Failed
     [exec] Test wfs:test1.0.0-basic-getcapabilities-post-8 (wfs-1.0.0/d1e925_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-1 (wfs-1.0.0/d1e1080_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-10 (wfs-1.0.0/d1e1089_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-11 (wfs-1.0.0/d1e1097_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-12 (wfs-1.0.0/d1e1105_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-13 (wfs-1.0.0/d1e1113_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-14 (wfs-1.0.0/d1e1121_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-15 (wfs-1.0.0/d1e1129_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-16 (wfs-1.0.0/d1e1138_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-17 (wfs-1.0.0/d1e1146_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-18 (wfs-1.0.0/d1e1154_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-19 (wfs-1.0.0/d1e1162_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-2 (wfs-1.0.0/d1e1170_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-20 (wfs-1.0.0/d1e1178_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-21 (wfs-1.0.0/d1e1187_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-22 (wfs-1.0.0/d1e1195_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-23 (wfs-1.0.0/d1e1203_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-24 (wfs-1.0.0/d1e1211_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-25 (wfs-1.0.0/d1e1219_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-3 (wfs-1.0.0/d1e1227_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-4 (wfs-1.0.0/d1e1236_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-5 (wfs-1.0.0/d1e1244_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-6 (wfs-1.0.0/d1e1252_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-7 (wfs-1.0.0/d1e1260_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-8 (wfs-1.0.0/d1e1268_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-9 (wfs-1.0.0/d1e1276_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-1 (wfs-1.0.0/d1e1285_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-10 (wfs-1.0.0/d1e1293_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-11 (wfs-1.0.0/d1e1301_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-12 (wfs-1.0.0/d1e1309_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-13 (wfs-1.0.0/d1e1317_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-14 (wfs-1.0.0/d1e1325_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-15 (wfs-1.0.0/d1e1334_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-16 (wfs-1.0.0/d1e1342_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-17 (wfs-1.0.0/d1e1350_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-18 (wfs-1.0.0/d1e1358_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-19 (wfs-1.0.0/d1e1366_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-2 (wfs-1.0.0/d1e1374_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-20 (wfs-1.0.0/d1e1383_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-21 (wfs-1.0.0/d1e1391_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-22 (wfs-1.0.0/d1e1399_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-23 (wfs-1.0.0/d1e1407_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-24 (wfs-1.0.0/d1e1415_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-25 (wfs-1.0.0/d1e1423_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-3 (wfs-1.0.0/d1e1432_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-4 (wfs-1.0.0/d1e1440_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-5 (wfs-1.0.0/d1e1448_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-6 (wfs-1.0.0/d1e1456_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-7 (wfs-1.0.0/d1e1464_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-8 (wfs-1.0.0/d1e1472_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-9 (wfs-1.0.0/d1e1481_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-1 (wfs-1.0.0/d1e1489_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 31841
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/64/display/redirect&gt;
[...truncated 3.14 MB...]
     [exec] ... 190 more
     [exec] ... 205 more
     [exec] ... 214 more
     [exec] ... 220 more
     [exec]
./run.sh: line 120: 4458 Killed ant -Dcite.headless=true -Dcite.headless.formroot=$FORMS $PROFILE
+ grep Failed
+ ant wfs-1.0-log
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-3 (wfs-1.0.0/d41e1227_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-4 (wfs-1.0.0/d41e1236_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-5 (wfs-1.0.0/d41e1244_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-6 (wfs-1.0.0/d41e1252_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-7 (wfs-1.0.0/d41e1260_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-8 (wfs-1.0.0/d41e1268_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-get-9 (wfs-1.0.0/d41e1276_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-1 (wfs-1.0.0/d41e1285_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-10 (wfs-1.0.0/d41e1293_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-11 (wfs-1.0.0/d41e1301_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-12 (wfs-1.0.0/d41e1309_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-13 (wfs-1.0.0/d41e1317_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-14 (wfs-1.0.0/d41e1325_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-15 (wfs-1.0.0/d41e1334_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-16 (wfs-1.0.0/d41e1342_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-17 (wfs-1.0.0/d41e1350_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-18 (wfs-1.0.0/d41e1358_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-19 (wfs-1.0.0/d41e1366_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-2 (wfs-1.0.0/d41e1374_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-20 (wfs-1.0.0/d41e1383_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-21 (wfs-1.0.0/d41e1391_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-22 (wfs-1.0.0/d41e1399_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-23 (wfs-1.0.0/d41e1407_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-24 (wfs-1.0.0/d41e1415_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-25 (wfs-1.0.0/d41e1423_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-3 (wfs-1.0.0/d41e1432_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-4 (wfs-1.0.0/d41e1440_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-5 (wfs-1.0.0/d41e1448_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-6 (wfs-1.0.0/d41e1456_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-7 (wfs-1.0.0/d41e1464_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-8 (wfs-1.0.0/d41e1472_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-comparisonoperators-post-9 (wfs-1.0.0/d41e1481_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-1 (wfs-1.0.0/d41e1489_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-10 (wfs-1.0.0/d41e1497_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-11 (wfs-1.0.0/d41e1505_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-12 (wfs-1.0.0/d41e1513_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-13 (wfs-1.0.0/d41e1521_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-14 (wfs-1.0.0/d41e1530_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-15 (wfs-1.0.0/d41e1538_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-16 (wfs-1.0.0/d41e1546_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-17 (wfs-1.0.0/d41e1554_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-18 (wfs-1.0.0/d41e1562_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-2 (wfs-1.0.0/d41e1570_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-3 (wfs-1.0.0/d41e1579_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-4 (wfs-1.0.0/d41e1587_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-5 (wfs-1.0.0/d41e1595_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-6 (wfs-1.0.0/d41e1603_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-7 (wfs-1.0.0/d41e1611_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-8 (wfs-1.0.0/d41e1619_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-get-9 (wfs-1.0.0/d41e1628_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-1 (wfs-1.0.0/d41e1636_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-10 (wfs-1.0.0/d41e1644_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-11 (wfs-1.0.0/d41e1652_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-12 (wfs-1.0.0/d41e1660_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-13 (wfs-1.0.0/d41e1668_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-14 (wfs-1.0.0/d41e1677_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-15 (wfs-1.0.0/d41e1685_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-16 (wfs-1.0.0/d41e1693_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-17 (wfs-1.0.0/d41e1701_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-18 (wfs-1.0.0/d41e1709_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-2 (wfs-1.0.0/d41e1717_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-3 (wfs-1.0.0/d41e1726_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-4 (wfs-1.0.0/d41e1734_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-5 (wfs-1.0.0/d41e1742_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-6 (wfs-1.0.0/d41e1750_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-7 (wfs-1.0.0/d41e1758_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-8 (wfs-1.0.0/d41e1766_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-bbox-post-9 (wfs-1.0.0/d41e1775_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-1 (wfs-1.0.0/d41e1783_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-10 (wfs-1.0.0/d41e1791_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-11 (wfs-1.0.0/d41e1799_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-12 (wfs-1.0.0/d41e1807_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-2 (wfs-1.0.0/d41e1815_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-3 (wfs-1.0.0/d41e1824_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-4 (wfs-1.0.0/d41e1832_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-5 (wfs-1.0.0/d41e1840_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-6 (wfs-1.0.0/d41e1848_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-7 (wfs-1.0.0/d41e1856_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-8 (wfs-1.0.0/d41e1864_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-get-9 (wfs-1.0.0/d41e1873_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-1 (wfs-1.0.0/d41e1881_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-10 (wfs-1.0.0/d41e1889_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-11 (wfs-1.0.0/d41e1897_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-12 (wfs-1.0.0/d41e1905_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-2 (wfs-1.0.0/d41e1913_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-3 (wfs-1.0.0/d41e1922_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-4 (wfs-1.0.0/d41e1930_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-5 (wfs-1.0.0/d41e1938_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-6 (wfs-1.0.0/d41e1946_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-7 (wfs-1.0.0/d41e1954_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-8 (wfs-1.0.0/d41e1962_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-beyond-post-9 (wfs-1.0.0/d41e1971_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-1 (wfs-1.0.0/d41e1979_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-10 (wfs-1.0.0/d41e1987_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-11 (wfs-1.0.0/d41e1995_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-12 (wfs-1.0.0/d41e2003_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-2 (wfs-1.0.0/d41e2011_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-3 (wfs-1.0.0/d41e2020_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-4 (wfs-1.0.0/d41e2028_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-5 (wfs-1.0.0/d41e2036_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-6 (wfs-1.0.0/d41e2044_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-7 (wfs-1.0.0/d41e2052_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-8 (wfs-1.0.0/d41e2060_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-get-9 (wfs-1.0.0/d41e2069_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-1 (wfs-1.0.0/d41e2077_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-10 (wfs-1.0.0/d41e2085_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-11 (wfs-1.0.0/d41e2093_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-12 (wfs-1.0.0/d41e2101_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-2 (wfs-1.0.0/d41e2109_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-3 (wfs-1.0.0/d41e2118_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-4 (wfs-1.0.0/d41e2126_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-5 (wfs-1.0.0/d41e2134_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-6 (wfs-1.0.0/d41e2142_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-7 (wfs-1.0.0/d41e2150_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-8 (wfs-1.0.0/d41e2158_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-contains-post-9 (wfs-1.0.0/d41e2167_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-1 (wfs-1.0.0/d41e2175_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-10 (wfs-1.0.0/d41e2183_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-11 (wfs-1.0.0/d41e2191_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-12 (wfs-1.0.0/d41e2199_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-2 (wfs-1.0.0/d41e2207_1) Failed
     [exec] Test wfs:test1.0.0-basic-getfeature-filter-spatialoperators-crosses-get-3 (wfs-1.0.0/d41e2216_1) Failed
./run.sh: line 123: 4136 Killed ( ./startup.sh -Djetty.http.port=$PORT > geoserver.log ) (wd: ~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin)
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 4136
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wfs-1.0/65/display/redirect&gt;
