[Geoserver-devel] Build failed in Jenkins: 2.14-cite-wms-1.1 #88
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/88/display/redirect&gt;
[...truncated 126.49 KB...]
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ '[' 1 == 1 ']'
+ echo 'GeoServer did not shutdown properly'
+ exit 1
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/89/display/redirect&gt;
[...truncated 761.45 KB...]
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: net.sf.saxon.trans.XPathException: Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
     [exec] java.lang.NullPointerException
     [exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:148)
     [exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
     [exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
     [exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
     [exec] at net.sf.saxon.expr.LazyExpression.evaluateItem(LazyExpression.java:86)
     [exec] at net.sf.saxon.value.SingletonClosure.asItem(SingletonClosure.java:75)
     [exec] at net.sf.saxon.value.Value.asItem(Value.java:69)
     [exec] at net.sf.saxon.expr.VariableReference.evaluateItem(VariableReference.java:421)
     [exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
     [exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
     [exec] at net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:298)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.ExpressionTool.lazyEvaluate(ExpressionTool.java:431)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:144)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] ... 190 more
     [exec] Caused by: java.lang.NullPointerException
     [exec] at java.net.URLEncoder.encode(URLEncoder.java:204)
     [exec] at java.net.URLEncoder.encode(URLEncoder.java:170)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:498)
     [exec] at com.occamlab.te.saxon.TEJavaFunctionCall.iterate(TEJavaFunctionCall.java:138)
     [exec] ... 229 more
     [exec]
     [exec] Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
     [exec] Test wms:basic_elements-validate-exception Failed
     [exec] Test wms:wms_main Failed (Inherited failure)
     [exec] Suite wms:main_wms Failed
     [copy] Copying 1 file to <https://build.geoserver.org/job/2.14-cite-wms-1.1/ws/tools/users/geoserver/wms-1.1.1&gt;
BUILD SUCCESSFUL
Total time: 7 seconds
+ ant wms-1.1-log
+ grep Failed
     [exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
     [exec] Test wms:basic_elements-param_rules-order_and_case-3 (wms-1.1.1/d247e766_1) Failed
     [exec] Test wms:basic_elements-version-negotiation-2 (wms-1.1.1/d247e804_1) Failed
     [exec] Test wms:basic_elements-version-negotiation-4 (wms-1.1.1/d247e811_1) Failed
     [exec] Test wms:dims-declaring-1 (wms-1.1.1/d247e820_1) Failed
     [exec] Test wms:dims-declaring-3 (wms-1.1.1/d247e828_1) Failed
     [exec] Test wms:dims-declaring-4 (wms-1.1.1/d247e835_1) Failed
     [exec] Test wms:profiles-queryable-1 (wms-1.1.1/d247e865_1) Failed
     [exec] Test wms:profiles-queryable-2 (wms-1.1.1/d247e875_1) Failed
     [exec] Test wms:profiles-queryable-3 (wms-1.1.1/d247e885_1) Failed
     [exec] Test wms:wmsops-getcapabilities-output_formats-1 (wms-1.1.1/d247e895_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-request-1 (wms-1.1.1/d247e902_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-updatesequence-1 (wms-1.1.1/d247e912_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-1 (wms-1.1.1/d247e981_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-2 (wms-1.1.1/d247e988_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-3 (wms-1.1.1/d247e995_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-4 (wms-1.1.1/d247e1002_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-5 (wms-1.1.1/d247e1009_1) Failed
     [exec] Test wms:wmsops-getcapabilities-params-version-6 (wms-1.1.1/d247e1016_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-1 (wms-1.1.1/d247e1024_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d247e1031_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-capability_metadata-1 (wms-1.1.1/d247e1038_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-capability_metadata-2 (wms-1.1.1/d247e1047_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-general_metadata-1 (wms-1.1.1/d247e1055_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-general_metadata-2 (wms-1.1.1/d247e1064_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-bbox-1 (wms-1.1.1/d247e1073_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 (wms-1.1.1/d247e1080_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 (wms-1.1.1/d247e1087_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 (wms-1.1.1/d247e1094_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 (wms-1.1.1/d247e1101_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 (wms-1.1.1/d247e1108_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 (wms-1.1.1/d247e1116_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-srs-1 (wms-1.1.1/d247e1123_1) Failed
     [exec] Test wms:wmsops-getcapabilities-response-layer_properties-style-1 (wms-1.1.1/d247e1130_1) Failed
     [exec] Test wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d247e1541_1) Failed
     [exec] Test wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d247e1550_1) Failed
     [exec] Test wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d247e1706_1) Failed
     [exec] Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d247e2131_1) Failed
     [exec] Test wms:basic_elements-validate-exception (wms-1.1.1/d247e2137_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.14-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.14-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 21470
  PID TTY STAT TIME COMMAND
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/90/display/redirect&gt;
[...truncated 801.15 KB...]
     [exec] ... 190 more
     [exec] ... 229 more
     [exec]
BUILD SUCCESSFUL
+ ant wms-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ ps 8825
+ '[' 1 == 0 ']'
+ exit 1
See <https://build.geoserver.org/job/2.14-cite-wms-1.1/91/display/redirect&gt;
