[Geoserver-devel] Build failed in Jenkins: 2.6-cite-wms-1.3 #204
See <http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.3/204/&gt;
[...truncated 4087 lines...]
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] ... 91 more
     [exec] Caused by: java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}HTTPParser
     [exec] java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}XMLValidatingParser
     [exec] org.xml.sax.SAXParseException: schema_reference.4: Failed to read schema document 'http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd’, because 1) could not find the document; 2) the document could not be read; 3) the root element of the document is not <xsd:schema>.
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1558)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [exec] at java.lang.reflect.Method.invoke(Method.java:606)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] ... 111 more
     [exec] Caused by: java.lang.Exception: Error invoking parser {http://www.occamlab.com/te/parsers\}XMLValidatingParser
     [exec] at com.occamlab.te.parsers.HTTPParser.parse(HTTPParser.java:243)
     [exec] at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1549)
     [exec] ... 119 more
     [exec] Caused by: org.xml.sax.SAXParseException; schema_reference.4: Failed to read schema document 'http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd’, because 1) could not find the document; 2) the document could not be read; 3) the root element of the document is not <xsd:schema>.
     [exec] at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
     [exec] at org.apache.xerces.util.ErrorHandlerWrapper.error(Unknown Source)
     [exec] at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
     [exec] at org.apache.xerces.impl.xs.traversers.XSDHandler.reportSchemaError(Unknown Source)
     [exec] at org.apache.xerces.impl.xs.traversers.XSDHandler.getSchemaDocument(Unknown Source)
     [exec] at org.apache.xerces.impl.xs.traversers.XSDHandler.parseSchema(Unknown Source)
     [exec] at org.apache.xerces.impl.xs.XMLSchemaLoader.loadSchema(Unknown Source)
     [exec] at org.apache.xerces.impl.xs.XMLSchemaLoader.loadGrammar(Unknown Source)
     [exec] at org.apache.xerces.jaxp.validation.XMLSchemaFactory.newSchema(Unknown Source)
     [exec] at com.occamlab.te.parsers.XMLValidatingParser.validate(XMLValidatingParser.java:347)
     [exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:238)
     [exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:170)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
     [exec] ... 125 more
     [exec]
     [exec] Test getfeatureinfo:feature_count-default Passed
     [exec] Testing getfeatureinfo:feature_count-1 (wms-1.3.0/d3717e379_1/d2546e47_1/d2546e96_1)...
     [exec] Assertion: When the FEATURE_COUNT parameter is 1, then less data is returned than when FEATURE_COUNT is 2.
     [exec] Test getfeatureinfo:feature_count-1 Passed
     [exec] Test getfeatureinfo:feature_count Passed
     [exec] Testing getfeatureinfo:info_format (wms-1.3.0/d3717e379_1/d2546e52_1)...
     [exec] Assertion: The FORMAT parameter behaves properly.
     [exec] Testing getfeatureinfo:invalid-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e111_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid INFO_FORMAT parameter, then the server returns an exception (code=InvalidFormat).
     [exec] Test getfeatureinfo:invalid-info_format Passed
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_1)...
     [exec] Assertion: For format "text/plain", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Test getfeatureinfo:each-info_format Passed
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_2)...
     [exec] Assertion: For format "application/vnd.ogc.gml", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_3)...
     [exec] Assertion: For format "application/vnd.ogc.gml/3.1.1", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_4)...
     [exec] Assertion: For format "text/html", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_5)...
     [exec] Assertion: For format "application/json", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Test getfeatureinfo:info_format Passed
     [exec] Testing getfeatureinfo:i-and-j (wms-1.3.0/d3717e379_1/d2546e54_1)...
     [exec] Assertion: The I and J parameters behaves properly.
     [exec] Testing getfeatureinfo:invalid-i (wms-1.3.0/d3717e379_1/d2546e54_1/d2546e137_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid I parameter, then the response is an exception (code=InvalidPoint).
     [exec] Test getfeatureinfo:invalid-i Passed
     [exec] Testing getfeatureinfo:invalid-j (wms-1.3.0/d3717e379_1/d2546e54_1/d2546e139_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid J parameter, then the response is an exception (code=InvalidPoint).
     [exec] Test getfeatureinfo:invalid-j Passed
     [exec] Test getfeatureinfo:i-and-j Passed
     [exec] Testing getfeatureinfo:query-layers (wms-1.3.0/d3717e379_1/d2546e56_1)...
     [exec] Assertion: The QUERY_LAYERS parameter behaves properly.
     [exec] Testing getfeatureinfo:two-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e154_1)...
     [exec] Assertion: When a GetFeatureInfo request contains two layers, then the response is valid.
     [exec] Test getfeatureinfo:two-query_layers Passed
     [exec] Testing getfeatureinfo:three-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e156_1)...
     [exec] Assertion: When a GetFeatureInfo request contains three layers, then the response is valid.
     [exec] Test getfeatureinfo:three-query_layers Passed
     [exec] Testing getfeatureinfo:less-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e158_1)...
     [exec] Assertion: When a GetFeatureInfo request contains fewer layers in the QUERY_LAYERS parameter than it does in the LAYERS parameter, then the response is valid.
     [exec] Test getfeatureinfo:less-query_layers Passed
     [exec] Testing getfeatureinfo:invalid-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e160_1)...
     [exec] Assertion: When a layer requested is not contained in the Capabilities XML of the WMS, then the server issues a Service Exception (code=LayerNotDefined).
     [exec] Test getfeatureinfo:invalid-query_layers Passed
     [exec] Testing getfeatureinfo:query_layers-not-queryable (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e162_1)...
     [exec] Assertion: When GetFeatureInfo is requested on a Layer that is not queryable, then the server issues a Service Exception (code=LayerNotQueryable).
     [exec] No named layers that are not queryable.
     [exec] Test getfeatureinfo:query_layers-not-queryable Passed
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_1)...
     [exec] Assertion: For layer "cite:Autos", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Test getfeatureinfo:each-queryable-layer Passed
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_2)...
     [exec] Assertion: For layer "cite:BasicPolygons", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_3)...
     [exec] Assertion: For layer "cite:Bridges", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_4)...
     [exec] Assertion: For layer "cite:BuildingCenters", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_5)...
     [exec] Assertion: For layer "cite:Buildings", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_6)...
     [exec] Assertion: For layer "cite:DividedRoutes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_7)...
     [exec] Assertion: For layer "cite:Forests", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_8)...
     [exec] Assertion: For layer "cite:Lakes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_9)...
     [exec] Assertion: For layer "cite:LakesWithElevation", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_10)...
     [exec] Assertion: For layer "cite:MapNeatline", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_11)...
     [exec] Assertion: For layer "cite:NamedPlaces", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_12)...
     [exec] Assertion: For layer "cite:Ponds", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_13)...
     [exec] Assertion: For layer "cite:RoadSegments", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_14)...
     [exec] Assertion: For layer "cite:Streams", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Test getfeatureinfo:query-layers Passed
     [exec] Test getfeatureinfo:main Failed (Inherited failure)
     [exec] Testing recomendations:main (wms-1.3.0/d3717e386_1)...
     [exec] Assertion: If the "Check Recommendations" option was selected, the server supports fuctionality which is recommended in the spec, but not required.
     [exec] Testing recomendations:service-keywords (wms-1.3.0/d3717e386_1/d2997e13_1)...
     [exec] Assertion: The capabilities document includes a list of keywords or keyword phrases describing the server.
     [exec] Test recomendations:service-keywords Passed
     [exec] Testing recomendations:service-contact-info (wms-1.3.0/d3717e386_1/d2997e15_1)...
     [exec] Assertion: The capabilities document includes contact information.
     [exec] Test recomendations:service-contact-info Passed
     [exec] Testing recomendations:png-getmap-format (wms-1.3.0/d3717e386_1/d2997e17_1)...
     [exec] Assertion: The server advertises the image/png format for the GetMap operation.
     [exec] Test recomendations:png-getmap-format Passed
     [exec] Testing recomendations:layer-abstracts (wms-1.3.0/d3717e386_1/d2997e19_1)...
     [exec] Assertion: Each Layer in the capabilities document contains an abstract.
     [exec] Test recomendations:layer-abstracts Passed
     [exec] Testing recomendations:layer-keywordlists (wms-1.3.0/d3717e386_1/d2997e21_1)...
     [exec] Assertion: Each Layer in the capabilities document contains a keyword list.
     [exec] Test recomendations:layer-keywordlists Passed
     [exec] Testing recomendations:layer-crs (wms-1.3.0/d3717e386_1/d2997e24_1)...
     [exec] Assertion: All layers in the capabilities document are available in the CRS:84 and/or EPSG:4326 CRS.
     [exec] Test recomendations:layer-crs Passed
     [exec] Testing recomendations:metadataurls (wms-1.3.0/d3717e386_1/d2997e26_1)...
     [exec] Assertion: Every named Layer in the capabilities document contains a MetadataURL element.
     [exec] Test recomendations:metadataurls Passed
     [exec] Testing recomendations:dims-no-whitespace (wms-1.3.0/d3717e386_1/d2997e28_1)...
     [exec] Assertion: No dimension name values in the capabilities document contain whitespace.
     [exec] Test recomendations:dims-no-whitespace Passed
     [exec] Testing recomendations:dims-defaults (wms-1.3.0/d3717e386_1/d2997e30_1)...
     [exec] Assertion: Each dimension declaration in the capabilities document contains a default value.
     [exec] Test recomendations:dims-defaults Passed
     [exec] Test recomendations:main Passed
     [exec] Testing dims:main (wms-1.3.0/d3717e389_1)...
     [exec] Assertion: Support for dimensional data is correct.
     [exec] Testing dims:missing-no-default (wms-1.3.0/d3717e389_1/d3067e182_1)...
     [exec] Assertion: When a layer that has a dimension without a default value is requested without supplying the dimension parameter, the response is an exception with code=MissingDimensionValue.
     [exec] No Named layers that have a dimension without a default value.
     [exec] Test dims:missing-no-default Passed
     [exec] Test dims:main Passed
     [exec] Test main:main Failed (Inherited failure)
     [exec] Suite wms-1.3.0:compliance_suite Failed
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.3/ws/tools/users/geoserver/wms-1.3.0&gt;
BUILD SUCCESSFUL
Total time: 44 seconds
+ ant wms-1.3-log
+ grep Failed
     [exec] Test main:main (wms-1.3.0) Failed (Inherited Failure)
     [exec] Test getmap:main (wms-1.3.0/d3717e372_1) Failed (Inherited Failure)
     [exec] Test getmap:exceptions (wms-1.3.0/d3717e372_1/d1097e44_1) Failed (Inherited Failure)
     [exec] Test getmap:exceptions-default (wms-1.3.0/d3717e372_1/d1097e44_1/d1097e177_1) Failed
     [exec] Test getmap:exceptions-xml (wms-1.3.0/d3717e372_1/d1097e44_1/d1097e179_1) Failed
     [exec] Test getfeatureinfo:main (wms-1.3.0/d3717e379_1) Failed (Inherited Failure)
     [exec] Test getfeatureinfo:exceptions (wms-1.3.0/d3717e379_1/d2546e30_1) Failed (Inherited Failure)
     [exec] Test getfeatureinfo:exceptions-default (wms-1.3.0/d3717e379_1/d2546e30_1/d2546e74_1) Failed
     [exec] Test getfeatureinfo:exceptions-xml (wms-1.3.0/d3717e379_1/d2546e30_1/d2546e76_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
~/workspace/geoserver-cite
+ pushd geoserver/geoserver-2.6-SNAPSHOT/bin
~/workspace/geoserver-cite/geoserver/geoserver-2.6-SNAPSHOT/bin ~/workspace/geoserver-cite
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ ./shutdown.sh
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ ps 27580
  PID TTY STAT TIME COMMAND
27580 ? Sl 1:08 /usr/lib/jvm/java-7-oracle-x64/bin/java -Xmx256m -XX:MaxPermSize=128m -DGEOSERVER_DATA_DIR=<http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.3/ws/geoserver_data/2.6.x/citewms-1.3&gt; -Djava.awt.headless=true -Djetty.port=11010 -DSTOP.PORT=11009 -DSTOP.KEY=geoserver -jar start.jar
+ '[' 0 == 0 ']'
+ kill -9 27580
+ exit 1
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/2.6-cite-wms-1.3/205/&gt;
