[Geoserver-devel] Build failed in Jenkins: geofence-master #1
See <http://ares.opengeo.org/jenkins/job/geofence-master/1/&gt;
[...truncated 2294 lines...]
487/586 KB
488/586 KB
492/586 KB
492/586 KB
495/586 KB
498/586 KB
501/586 KB
504/586 KB
506/586 KB
509/586 KB
512/586 KB
515/586 KB
518/586 KB
521/586 KB
522/586 KB
526/586 KB
528/586 KB
532/586 KB
533/586 KB
537/586 KB
539/586 KB
543/586 KB
545/586 KB
549/586 KB
549/586 KB
550/586 KB
554/586 KB
556/586 KB
560/586 KB
562/586 KB
563/586 KB
566/586 KB
567/586 KB
571/586 KB
573/586 KB
577/586 KB
579/586 KB
580/586 KB
583/586 KB
584/586 KB
586/586 KB
Downloaded: http://download.osgeo.org/webdav/geotools/com/vividsolutions/jts/1.10/jts-1.10.jar (586 KB at 1196.7 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.jar
3/57 KB
7/57 KB
11/57 KB
14/57 KB
16/57 KB
18/57 KB
21/57 KB
24/57 KB
27/57 KB
30/57 KB
33/57 KB
35/57 KB
38/57 KB
41/57 KB
43/57 KB
44/57 KB
48/57 KB
50/57 KB
52/57 KB
56/57 KB
57/57 KB
Downloaded: http://repo.maven.apache.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.jar (57 KB at 209.6 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geofence-model-internal ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ geofence-model-internal ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ geofence-model-internal ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 39 source files to <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ geofence-model-internal ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ geofence-model-internal ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/test-classes&gt;
Downloading: http://repo.maven.apache.org/maven2/com/vividsolutions/jts/1.10/jts-1.10.pom
[INFO]
[INFO] --- maven-surefire-plugin:2.17:test (default-test) @ geofence-model-internal ---
[WARNING] The POM for com.vividsolutions:jts:jar:1.10 is missing, no dependency information available
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geofence-model ---
[INFO]
[INFO] --- maven-dependency-plugin:2.8:unpack (unpack-model) @ geofence-model ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/surefire-reports&gt;
T E S T S
Running org.geoserver.geofence.core.model.Base64EncodersTest
apache commons: dGhpcyBpcyB0aGUgbWVzc2FnZSB0byBlbmNvZGU=
DatatypeConverter: dGhpcyBpcyB0aGUgbWVzc2FnZSB0byBlbmNvZGU=
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.124 sec - in org.geoserver.geofence.core.model.Base64EncodersTest
Running org.geoserver.geofence.core.model.IPAddressRangeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec - in org.geoserver.geofence.core.model.IPAddressRangeTest
Running org.geoserver.geofence.core.model.GSUserTest
[INFO] Configured Artifact: org.geoserver.geofence:geofence-model-internal:sources:?:jar
[INFO] Unpacking <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/classes&gt; to <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target/generated-sources/original&gt; with includes "**/*.java,**/*.xml" and excludes ""
[INFO]
[INFO] Skipping GeoFence - Module - Generic API
[INFO]
[INFO] Skipping GeoFence - Modules - Login
[INFO]
[INFO] Skipping GeoFence - Modules - REST root
[INFO]
[INFO] Skipping GeoFence - GUI - Plugin module
Marshalling 2 groups
Marshalling group IdNameBundle[id:10 name=groupname]
Marshalling group IdNameBundle[id:11 name=groupname2]
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<GSUser admin="false" enabled="true">
    <id>42</id>
    <extId>extid</extId>
    <name>name</name>
    <fullName>fullname</fullName>
    <password>pwd</password>
    <emailAddress>a@anonymised.com</emailAddress>
    <dateCreation>2014-10-07T09:28:48.772Z</dateCreation>
    <groups>
        <group>
            <id>10</id>
            <name>groupname</name>
        </group>
        <group>
            <id>11</id>
            <name>groupname2</name>
        </group>
    </groups>
</GSUser>
Unmarshalling group IdNameBundle[id:10 name=groupname]
Unmarshalling group IdNameBundle[id:11 name=groupname2]
Unmarshalled user has 2 groups
2nd marshalling:
    <id>42</id>
    <name>name</name>
    <groups>
        <group>
            <id>10</id>
        </group>
        <group>
            <id>11</id>
        </group>
    </groups>
</GSUser>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.86 sec - in org.geoserver.geofence.core.model.GSUserTest
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ geofence-model-internal ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/geofence-model-internal-2.2-SNAPSHOT.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.3:jar (attach-sources) @ geofence-model-internal >>>
[INFO]
[INFO] <<< maven-source-plugin:2.3:jar (attach-sources) @ geofence-model-internal <<<
[INFO]
[INFO] --- maven-source-plugin:2.3:jar (attach-sources) @ geofence-model-internal ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/geofence-model-internal-2.2-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geofence-model-internal ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/geofence-model-internal-2.2-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/geofence-model-internal-2.2-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/geofence-model-internal-2.2-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target/geofence-model-internal-2.2-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/geofence-model-internal-2.2-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoFence - 0 Services ............................. SUCCESS [0.455s]
[INFO] GeoFence - Core ................................... SUCCESS [0.029s]
[INFO] GeoFence - Core - Model internal .................. SUCCESS [21.949s]
[INFO] GeoFence - Core - Model external .................. FAILURE [20.271s]
[INFO] GeoFence - Core - Persistence ..................... SKIPPED
[INFO] GeoFence - Core - Services API .................... SKIPPED
[INFO] GeoFence - Core - Services implementation ......... SKIPPED
[INFO] GeoFence - Core - Web Test Module ................. SKIPPED
[INFO] GeoFence - Modules - 0 Root ....................... SUCCESS [0.077s]
[INFO] GeoFence - Module - Generic API ................... SKIPPED
[INFO] GeoFence - Modules - Login ........................ SKIPPED
[INFO] GeoFence - Modules - Login - API .................. SKIPPED
[INFO] GeoFence - Modules - Login - Impl ................. SKIPPED
[INFO] GeoFence - Modules - REST root .................... SKIPPED
[INFO] GeoFence - Modules - REST API ..................... SKIPPED
[INFO] GeoFence - Modules - REST services implementation . SKIPPED
[INFO] GeoFence - Modules - REST services test ........... SKIPPED
[INFO] GeoFence - Modules - REST client .................. SKIPPED
[INFO] GeoFence - Module - LDAP Support .................. SKIPPED
[INFO] GeoFence - GUI .................................... SUCCESS [0.512s]
[INFO] GeoFence - GUI - Core ............................. SUCCESS [0.421s]
[INFO] GeoFence - GUI - Resources ........................ SKIPPED
[INFO] GeoFence - GUI - Plugin module .................... SKIPPED
[INFO] GeoFence - GUI - User plugin ...................... SKIPPED
[INFO] GeoFence - GUI - Map plugin ....................... SKIPPED
[INFO] GeoFence - GUI - Web .............................. SKIPPED
[INFO] Master GeoFence POM ............................... SUCCESS [0.178s]
[INFO] BUILD FAILURE
[INFO] Total time: 28.010s (Wall Clock)
[INFO] Finished at: Tue Oct 07 09:28:50 UTC 2014
[INFO] Final Memory: 20M/176M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-dependency-plugin:2.8:unpack (unpack-model) on project geofence-model: Artifact has not been packaged yet. When used on reactor artifact, unpack should be executed after packaging: see MDEP-98. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :geofence-model
See <http://ares.opengeo.org/jenkins/job/geofence-master/2/changes&gt;
Changes:
[andrea.aime] Change GeoFence basemap and use OSGeo VMap0 one
[...truncated 96 lines...]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geofence ---
[INFO]
[INFO] Building GeoFence - GUI - Core 2.2-SNAPSHOT
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofences/geofence/2.2-SNAPSHOT/geofence-2.2-SNAPSHOT.pom
[INFO]
[INFO] Building GeoFence - Core - Model internal 2.2-SNAPSHOT
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
[INFO]
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model/target&gt;
[INFO]
[INFO]
740/740 B
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml (740 B at 1.3 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-eclipse-plugin/maven-metadata.xml
709/709 B
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-eclipse-plugin/maven-metadata.xml (709 B at 5.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geofence-gui-core ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geofence-gui-core ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/gui/core/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-gui-core/2.2-SNAPSHOT/geofence-gui-core-2.2-SNAPSHOT.pom
[INFO]
[INFO] Building GeoFence - Core - Model external 2.2-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target&gt;
[INFO]
Downloading: http://maven.geo-solutions.it/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/maven-metadata.xml
[INFO] Unpacking /var/lib/jenkins/.m2/repository/org/geoserver/geofence/geofence-model-internal/2.2-SNAPSHOT/geofence-model-internal-2.2-SNAPSHOT-sources.jar to <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target/generated-sources/original&gt; with includes "**/*.java,**/*.xml" and excludes ""
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (default) @ geofence-model ---
[INFO] Executing tasks
main:
[INFO]
[INFO]
[INFO] Executed tasks
[INFO]
[INFO] --- build-helper-maven-plugin:1.9:add-source (default) @ geofence-model ---
[INFO] Source directory: <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target/generated-sources/original&gt; added.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ geofence-model ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ geofence-model ---
[INFO] Compiling 39 source files to <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target/classes&gt;
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec - in org.geoserver.geofence.core.model.Base64EncodersTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec - in org.geoserver.geofence.core.model.IPAddressRangeTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ geofence-model ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ geofence-model ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.17:test (default-test) @ geofence-model ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ geofence-model ---
    <id>42</id>
    <name>name</name>
    <dateCreation>2014-10-07T11:34:21.290Z</dateCreation>
    <groups>
        <group>
            <id>11</id>
        </group>
        <group>
            <id>10</id>
        </group>
    </groups>
</GSUser>
2nd marshalling:
    <id>42</id>
    <name>name</name>
    <groups>
        <group>
            <id>10</id>
        </group>
        <group>
            <id>11</id>
        </group>
    </groups>
</GSUser>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.46 sec - in org.geoserver.geofence.core.model.GSUserTest
Results :
[INFO]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geofence-master/ws/src/services/core/model-external/target/geofence-model-2.2-SNAPSHOT.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.3:jar (attach-sources) @ geofence-model >>>
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoFence - 0 Services ............................. SUCCESS [0.416s]
[INFO] GeoFence - Core ................................... SUCCESS [0.019s]
[INFO] GeoFence - Core - Model internal .................. SUCCESS [9.573s]
[INFO] GeoFence - Core - Model external .................. FAILURE [7.691s]
[INFO] GeoFence - Modules - 0 Root ....................... SUCCESS [0.022s]
[INFO] GeoFence - GUI .................................... SUCCESS [0.455s]
[INFO] GeoFence - GUI - Core ............................. SUCCESS [1.629s]
[INFO] Master GeoFence POM ............................... SUCCESS [0.295s]
[INFO] Total time: 12.500s (Wall Clock)
[INFO] Finished at: Tue Oct 07 11:34:23 UTC 2014
[INFO] Final Memory: 23M/197M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geofence-master/3/changes&gt;
Changes:
[e.tajariol] Delete obsolete appcontext file.
[...truncated 46651 lines...]
389/605 KB
392/605 KB
395/605 KB
397/605 KB
400/605 KB
403/605 KB
407/605 KB
409/605 KB
413/605 KB
413/605 KB
416/605 KB
419/605 KB
421/605 KB
424/605 KB
427/605 KB
430/605 KB
433/605 KB
436/605 KB
438/605 KB
441/605 KB
444/605 KB
447/605 KB
450/605 KB
453/605 KB
455/605 KB
458/605 KB
461/605 KB
464/605 KB
467/605 KB
470/605 KB
472/605 KB
475/605 KB
478/605 KB
481/605 KB
484/605 KB
487/605 KB
491/605 KB
491/605 KB
492/605 KB
496/605 KB
496/605 KB
498/605 KB
502/605 KB
502/605 KB
503/605 KB
507/605 KB
508/605 KB
509/605 KB
513/605 KB
513/605 KB
516/605 KB
519/605 KB
522/605 KB
525/605 KB
528/605 KB
530/605 KB
533/605 KB
536/605 KB
539/605 KB
Downloaded: http://repo1.maven.org/maven2/org/apache/logging/log4j/log4j-jcl/2.0-beta7/log4j-jcl-2.0-beta7.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-io/7.2.2.v20101205/jetty-io-7.2.2.v20101205.jar
540/605 KB
542/605 KB
543/605 KB
546/605 KB
549/605 KB
552/605 KB
554/605 KB
557/605 KB
560/605 KB
563/605 KB
567/605 KB
567/605 KB
569/605 KB
573/605 KB
573/605 KB
574/605 KB
578/605 KB
578/605 KB
580/605 KB
584/605 KB
584/605 KB
587/605 KB
590/605 KB
593/605 KB
595/605 KB
598/605 KB
601/605 KB
604/605 KB
605/605 KB
Downloaded: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-continuation/7.2.2.v20101205/jetty-continuation-7.2.2.v20101205.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-util/7.2.2.v20101205/jetty-util-7.2.2.v20101205.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/cxf/cxf-rt-transports-http-jetty/2.3.2/cxf-rt-transports-http-jetty-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/geronimo/specs/geronimo-servlet_3.0_spec/1.0/geronimo-servlet_3.0_spec-1.0.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/logging/log4j/log4j-core/2.0-beta7/log4j-core-2.0-beta7.jar (605 KB at 1386.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/cxf/cxf-rt-databinding-aegis/2.3.2/cxf-rt-databinding-aegis-2.3.2.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-http/7.2.2.v20101205/jetty-http-7.2.2.v20101205.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/cxf/cxf-rt-ws-security/2.3.2/cxf-rt-ws-security-2.3.2.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-io/7.2.2.v20101205/jetty-io-7.2.2.v20101205.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/santuario/xmlsec/1.4.4/xmlsec-1.4.4.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/jetty/jetty-util/7.2.2.v20101205/jetty-util-7.2.2.v20101205.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/xalan/xalan/2.7.1/xalan-2.7.1.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/geronimo/specs/geronimo-servlet_3.0_spec/1.0/geronimo-servlet_3.0_spec-1.0.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15/1.45/bcprov-jdk15-1.45.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/cxf/cxf-rt-databinding-aegis/2.3.2/cxf-rt-databinding-aegis-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/cxf/cxf-rt-ws-security/2.3.2/cxf-rt-ws-security-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloaded: http://repo1.maven.org/maven2/org/apache/santuario/xmlsec/1.4.4/xmlsec-1.4.4.jar (0 B at 0.0 KB/sec)
Downloaded: http://repo1.maven.org/maven2/xalan/xalan/2.7.1/xalan-2.7.1.jar (0 B at 0.0 KB/sec)
Downloaded: http://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15/1.45/bcprov-jdk15-1.45.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/jettison/jettison/1.2/jettison-1.2.jar
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-api/2.3.2/cxf-api-2.3.2.jar
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/neethi/neethi/2.0.4/neethi-2.0.4.jar
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-common-schemas/2.3.2/cxf-common-schemas-2.3.2.jar
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-transports-http/2.3.2/cxf-rt-transports-http-2.3.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/jettison/jettison/1.2/jettison-1.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-transports-common/2.3.2/cxf-rt-transports-common-2.3.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/neethi/neethi/2.0.4/neethi-2.0.4.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-bindings-xml/2.3.2/cxf-rt-bindings-xml-2.3.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-api/2.3.2/cxf-api-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-frontend-jaxrs/2.3.2/cxf-rt-frontend-jaxrs-2.3.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-transports-http/2.3.2/cxf-rt-transports-http-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-common-utilities/2.3.2/cxf-common-utilities-2.3.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-transports-common/2.3.2/cxf-rt-transports-common-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/woodstox/woodstox-core-asl/4.0.8/woodstox-core-asl-4.0.8.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-common-schemas/2.3.2/cxf-common-schemas-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/woodstox/stax2-api/3.0.2/stax2-api-3.0.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/woodstox/woodstox-core-asl/4.0.8/woodstox-core-asl-4.0.8.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/javax/ws/rs/jsr311-api/1.1.1/jsr311-api-1.1.1.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-frontend-jaxrs/2.3.2/cxf-rt-frontend-jaxrs-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/wsdl4j/wsdl4j/1.6.2/wsdl4j-1.6.2.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-rt-bindings-xml/2.3.2/cxf-rt-bindings-xml-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/apache/cxf/cxf-common-utilities/2.3.2/cxf-common-utilities-2.3.2.jar (0 B at 0.0 KB/sec)
Downloading: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/org/codehaus/woodstox/stax2-api/3.0.2/stax2-api-3.0.2.jar (0 B at 0.0 KB/sec)
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/javax/ws/rs/jsr311-api/1.1.1/jsr311-api-1.1.1.jar (0 B at 0.0 KB/sec)
Downloaded: http://mirrors.ibiblio.org/pub/mirrors/maven2/wsdl4j/wsdl4j/1.6.2/wsdl4j-1.6.2.jar (0 B at 0.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloading: http://repo.boundlessgeo.com/main/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloading: http://repo.boundlessgeo.com/main/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloading: http://maven.restlet.org/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloading: http://maven.restlet.org/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloading: http://maven.ucdavis.edu/maven2/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloading: http://maven.ucdavis.edu/maven2/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Oct 07, 2014 1:03:51 PM org.apache.maven.wagon.providers.http.httpclient.client.protocol.ResponseProcessCookies processCookies
WARNING: Cookie rejected: "[version: 0][name: rememberMe][value: deleteMe][domain: maven.ucdavis.edu][path: /nexus][expiry: Tue Oct 07 13:03:51 UTC 2014]". Illegal path attribute "/nexus". Path of origin: "/maven2/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar"
WARNING: Cookie rejected: "[version: 0][name: rememberMe][value: deleteMe][domain: maven.ucdavis.edu][path: /nexus][expiry: Tue Oct 07 13:03:51 UTC 2014]". Illegal path attribute "/nexus". Path of origin: "/maven2/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar"
Downloading: http://repo.maven.apache.org/maven2/org/hibernatespatial/hibernate-spatial-h2-geodb/1.1.1/hibernate-spatial-h2-geodb-1.1.1.jar
Downloading: http://repo.maven.apache.org/maven2/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloading: http://repository.jboss.org/nexus/content/groups/public-jboss/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
Downloading: http://repo.opengeo.org/org/hibernatespatial/hibernate-spatial/1.1.1/hibernate-spatial-1.1.1.jar
[INFO]
[INFO] GeoFence - 0 Services ............................. SUCCESS [0.694s]
[INFO] GeoFence - Core ................................... SUCCESS [0.041s]
[INFO] GeoFence - Core - Model internal .................. SUCCESS [9.083s]
[INFO] GeoFence - Core - Model external .................. SUCCESS [6.623s]
[INFO] GeoFence - Core - Persistence ..................... SUCCESS [49.443s]
[INFO] GeoFence - Core - Services API .................... SUCCESS [1.888s]
[INFO] GeoFence - Core - Services implementation ......... SUCCESS [19.385s]
[INFO] GeoFence - Core - Web Test Module ................. SUCCESS [59.070s]
[INFO] GeoFence - Modules - 0 Root ....................... SUCCESS [0.021s]
[INFO] GeoFence - Module - Generic API ................... SUCCESS [4.394s]
[INFO] GeoFence - Modules - Login ........................ SUCCESS [0.008s]
[INFO] GeoFence - Modules - Login - API .................. SUCCESS [1.024s]
[INFO] GeoFence - Modules - Login - Impl ................. SUCCESS [21.879s]
[INFO] GeoFence - Modules - REST root .................... SUCCESS [0.006s]
[INFO] GeoFence - Modules - REST API ..................... SUCCESS [10.828s]
[INFO] GeoFence - Modules - REST services implementation . SUCCESS [33.046s]
[INFO] GeoFence - Modules - REST services test ........... SUCCESS [12.355s]
[INFO] GeoFence - Modules - REST client .................. SUCCESS [8.297s]
[INFO] GeoFence - Module - LDAP Support .................. SUCCESS [16.663s]
[INFO] GeoFence - GUI .................................... SUCCESS [0.662s]
[INFO] GeoFence - GUI - Core ............................. SUCCESS [2.786s]
[INFO] GeoFence - GUI - Resources ........................ SUCCESS [1:37.809s]
[INFO] GeoFence - GUI - Plugin module .................... SUCCESS [0.008s]
[INFO] GeoFence - GUI - User plugin ...................... SUCCESS [4:09.144s]
[INFO] GeoFence - GUI - Map plugin ....................... SUCCESS [3:08.524s]
[INFO] GeoFence - GUI - Web .............................. FAILURE [17.637s]
[INFO] Master GeoFence POM ............................... SUCCESS [0.279s]
[INFO] Total time: 7:05.379s (Wall Clock)
[INFO] Finished at: Tue Oct 07 13:03:53 UTC 2014
[INFO] Final Memory: 47M/199M
[ERROR] Failed to execute goal on project geofence-gui-web: Could not resolve dependencies for project org.geoserver.geofence:geofence-gui-web:war:2.2-SNAPSHOT: The following artifacts could not be resolved: org.hibernatespatial:hibernate-spatial-h2-geodb:jar:1.1.1, org.hibernatespatial:hibernate-spatial:jar:1.1.1: Failure to find org.hibernatespatial:hibernate-spatial-h2-geodb:jar:1.1.1 in http://maven.geo-solutions.it was cached in the local repository, resolution will not be reattempted until the update interval of geosolutions has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :geofence-gui-web
See <http://ares.opengeo.org/jenkins/job/geofence-master/4/changes&gt;
