See <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/5/changes>
Changes:
[aaime] [GEOS-4638] GeoServer WMS fails to re-encode 4bit paletted png images back in png
[jmacchi] Removing spatialite native libraries for each OS.
[aaime] GEOS-4631, switch to java 6, this part fixes file encodings and still builds fine with java 5. Patch by Christian Mueller
[aaime] [GEOS-4593] 'Edit Layer' title shows up three times in the publish layer settings page
[aaime] [GEOS-4600] orphaned link in devel guide, patch by Rudi Hochmeister
[dwinslow] Update to GeoCSS 0.7.1 - with new labelling support
[aaime] [GEOS-4291] enable logging about gzip compression, patch by David Winslow
[aaime] Fixing the logic to disable the native png encoder, it will blow up with 2 bits as well
[aaime] Fixing the logic to disable the native png encoder, it will blow up with 2 bits as well (this time without changing data dir)
[riniangreani] App-schema: function and special characters support for web service backend.
[riniangreani] Correcting a comment for my web service test.
[aaime] [GEOS-4632] Add CQL_FILTER support to WCS as well
[aaime] New GetFullCoverage process, and handle multi-output processes better with annotations
[aaime] Adding missing class
[jdeolive] GEOS-4631, switching build to java 6
[jgarnett] note about minimal directory for eclipse users
[aaime] [GEOS-3754] Add support for TIME and ELEVATION parameters, WCS 1.0 support
[victortey] GEOS-4300:complex feature not reprojecting if top level feature has no geometry
[riniangreani] gt-webservice: Test functions as linkedField in feature chaining.
[dwinslow] Correct the description of the strReplace function
[aaime] Build failure in wcs1_0 GetCoverageTest testElevation{First,Second} (and adding WMS semantics when no time or elevation is specified
[aaime] Adding a couple of tests for parametric sld in GetMap
[nielscharlier] Update documentation with respect to GEOT-2636
[bencaradocdavies] Added fork.javac pom property to permit optional use of embedded compiler. Added jvm.opts pom property to allow control of test jvm options.
[nielscharlier] GEOT-3529 and GEOT-3522 app-schema not supporting predicates
[aaime] Making the code generate namespaces, some versions of ogr2ogr seem to require it
[aaime] Centralize all the parsing needed to access the grid coverage reader dimensions in a helper object
[groldan] fix typo in appcontext
[groldan] make FakeServletOutputStream an inner class
[groldan] code formatting
[groldan] minor gwc ui text/layout fixes
[groldan] hide WMS-C/TMS/WMTS capabilities links from home page if the service is disabled
[groldan] proxy GWC Service beans to perform enablement checks
[jmacchi] New wfs output format. Spatialite. WFS is working and generating database file. Now working on JAR files.
[groldan] make TransactionType part of TransactionEvent. Some listeners may need it
[groldan] GEOS-4543: Make TransactionPlugin.afterTransaction receive the transaction result object and TransactionEvent know about the original request
[groldan] Use a Set instead of a List for InsertElementHandler.getTypeNames() as intermediate place holder.Makes for a once only lookup of the FeatureTypeInfo into the Catalog later and avoid memory issues when inserting a large number of Features.
[groldan] Add generics to TransactionElementHandler
[groldan] use Transaction.extraData as placeholder to collect gwc affected bounds for truncation
[nielscharlier] Fix app-schema id encoding bug
[aaime] Use the new ImageWorker facility to avoid repeated crop operations
[aaime] [GEOS-4651] GetFeatureInfo + GML output + click on a empty area = service exception
[aaime] Don't NPE against a broken configuration that does not have a default style associated to a layer
[aaime] Adding output path option to the georectify process, make the geotiff ppio work also for un-referenced images
[aaime] Better error message when a grid format cannot be found in the classpath
[aaime] Better error message when time format cannot be parsed
[groldan] expose CatalogIconFactory.getVectorIcon(Class geomClass) method for others to use it
[groldan] Let subclasses override GeoServerTablePanel.selectOneCheckBox(Item item)
[groldan] two new simple wicket components
[groldan] revert unintentional change to web/app/pom.xml
[aaime] [GEOS-4656] Configuring a mosaic with a lot of files can result in "too many open files"
[aaime] Fixing the build
[aaime] The build works fine on my box... attempting a blind fix for the build box
[aaime] Better fix for the too many open files issue, hoping it does not break the build box again
[groldan] correctly set atom:link's href in geosearch's kml Document
[groldan] fix geosearch returned kml MIME Type
[groldan] add keywords to description and don't enclose sample data inside a Folder element
[aaime] [GEOS-4657] main's org.geoserver.catalog.impl.CatalogBuilderTest#testLargeNDMosaic breaking on Windows
[aaime] [GEOS-4597] Switch GeoServer to MapContent/Layer, MapLayer -> Layer part, by Jody Garnett
[aaime] [GEOS-4597] Switch GeoServer to MapContent/Layer, MapContext -> MapContent part, by Andrea Aime
[aaime] [GEOS-4667] OutputTransparentColor not honored anymore on trunk
[aaime] [GEOS-4666] GridReaderLayer breaks reader caching on trunk
[aaime] [GEOS-4668] WFS reprojection won't work on a secured layer
[aaime] [GEOS-4674] Attribute restriction are not applied when not accompained by a corresponding filter
[bencaradocdavies] GEOS-4674 changes broke app-schema; fixed by changing SecuredFeatureSource to not check schema length for complex features
[bencaradocdavies] Fixed incorrect @author tag
[aaime] Warn the administartor that app-schema is breaking the security sandbox when more properties than allowed are returned
[whatnick] GEOS-3586: Upgraded to worldwind 0.6
[aaime] [GEOS-4615] WMS 1.1.1 geotiff output format uses incorrect mime type
[aaime] [GEOS-4676] Add content disposition header for raster outputs as well (inline mode)
[aaime] [GEOS-4643] GetFeatureInfo and SLD substitution fails
[aaime] [GEOS-4158] enable env parameter in getlegendgraphic
[aaime] Removing extra import
[aaime] [GEOS-4358] Exception page when creating a workspace named 'default'
[aaime] [GEOS-4557] Show the store type in the store list page
[aaime] Backport of filter default and reprojection code to geotools, removing it from GeoServer and using the geotools one instead
[aaime] New generic cookie cutter clippin process (not limited to rectangles
[aaime] forgot to add the clip process itself
[victortey] SISS-969:Proper spatial SQL queries are not issued for some BBOX WFS requests
[aaime] Removing WMSMapLayer leftovers
[aaime] Fixing the nightly build
[aaime] In case there are multiple execute methods, prefer the annotated one
[aaime] [GEOS-4664] Allows RangeLookup (reclassifier) process to specify noData and outputPixelsValues (patch by Daniele Romagnoli)
[bmmpxf] Slight update to download information on Teradata extension page
[jmacchi] Remove unnecessary files. Latest spatialite output format version.
[jmacchi] Spatialite application context file and documentation.
[bmmpxf] Adding link to external GeoServer INSPIRE tutorial.
[bencaradocdavies] GEOT-3680: ComplexType definitions in GML 3.2 subpackages are empty
[dany111] GEOS-4663: Committing forgotten classes
[bmmpxf] Teradata: adding note about needing a key/index/identity for editing.
[jdeolive] Avoid double encoding of special characters in WFS service exception, patch submitted by Tim Schaub
[aaime] [GEOS-4686] Secured coverage wrappers will dispose the readers making fruther reads impossible
[aaime] Fix build
[aaime] [GEOS-4682] Upgrade WPS to JAITools 1.2.0
[jmacchi] Tests for SpatialiteOutputFormat.
[jdeolive] GEOS-3842, updating default driver version to 4.0 now that java 1.6 is the default
[jdeolive] GEOS-4596, auto configuring coverages on POST, patch submitted by Tony Young
[jdeolive] spatialite pom fixes, using parent declared versions of test libs
[jdeolive] fixing package declaration
[jdeolive] disabling spatialite from nightly build
[jmacchi] Documentation and delete some unnecessary files.
[afabiani] - sldService JetRamp
[afabiani] - minor improvements and code-checks
[aaime] [GEOS-4677] Expose the reset command via rest-config as well
[jmacchi] Windows 64bits issues. Tests.
[ianschneider] GEOS-4685 - xercesImpl indecision
[ianschneider] GEOS-4683 - OWS services provide content-disposition support
[jmacchi] Delete unnecessary folder.
[ianschneider] additional fixes to make GEOS-4683 not break things
[bencaradocdavies] GEOS-4689: Stale WGS84 axis order in KMLUtils breaks Maven 3 build
[bencaradocdavies] GEOS-4652: Support building GeoServer with Maven 3
[bencaradocdavies] Removed what looks like test output inadvertently committed in r16201
[groldan] make GWC direct WMS integration work with additional parameter filters
[groldan] veify gridsubset coverage when checking if a wms request matches a gwc tile
[groldan] beware mapContent could be null
[groldan] FakeHttpServletRequest may be asked for a header
[groldan] use the tile's md5 hash as ETag instead of the created time that might be stale as coming from the metastore
[groldan] setCharacterEncoding may be called in case of an exception
[jdeolive] GEOS-4691, firing POST_INSERT on Insert transaction
[aaime] [GEOS-4587] NPE and potential memory leak on concurrent load of DescribeFeatureType with custom schemas
[jdeolive] GEOS-4692, ensuring all temporary data base files end up under target directory during tests
[jmacchi] Changes related to native-loading method (improvement. Now loading is 100% delegated to native-jar file)
[aaime] Forgot to add a test resource
[aaime] Schedule schema disposal only for short lived schemas, not for the ones that are going to be merged into the WFS schema
[ischneider] respect getHeaders return value from Responses when disposition is specified - see GEOS-4683
[groldan] ignore transparent for now, gwc defaults to transparent=true. but beware may lead to mixed transparent and opaque tiles
[ischneider] make GWC play nice with content-disposition headers
[ischneider] workaround Responses that don't return a preferredDisposition
[aaime] [GEOS-4700] Fixed typos and added note about escaping commas and semicolons in sql view parameter values, patch by Charles Galpin
[aaime] [GEOS-4710] Image mosaics configured on the GUI will return just a single tile
[aaime] [GEOS-4712] Add file logging option to the monitoring module
[groldan] GEOS-4650: no anonymousProcessingFilter for /gwc/rest/**
[groldan] Resource stored namespace as Name.getURI() instead of name.getNamespaceURI() leading to the New Layer page asking the datastore for <namespace:typeName>#<typeName> instead of <namespace>#<typeName>
[aaime] Adding audit filter docs
[aaime] [GEOS-4719] Bug in org.geoserver.wms.web.data.StyleNewPageTest (won't work on windows)
[aaime] [GEOS-4714] Problems running tests on windows with git svn using FeatureCollection.ftl template, patch by Walter Deane
[groldan] StoreEditPanel didn't respect sample value if parameter type is URL
[aaime] [GEOS-4733] Querylayer module won't work properly in WFS 1.1 spatial queries over geographic data
[groldan] GEOS-4736: Cache not truncated for layer groups upon feature edits
[groldan] GEOS-4737: avoid failure of tile encoding for embedded raster layers
[afabiani] - GEOS-4734: WMS Animator
[afabiani] - fixing build
[jgarnett] Cut over to geotools process implementations and GSProcess
[jgarnett] build recovery notes for maven
[afabiani] - fixing build after GEOS-4734 break
[jgarnett] migrate tests over to 'gs' processes rather than 'gt'
[aaime] [GEOS-4730] Use a soft cache in resource pool
[jdeolive] pulled some convenience methods from ReflectiveResource up into AbtstractResource
[jdeolive] added method to expose resource loader, and some methods to get files/directories from root of data dir
[jdeolive] factored out close method
[jdeolive] added StoreModel and StoresModel for accessing StoreInfo(s) through wicket model
[jdeolive] GEOS-4743, allows OwsUtils get/set to handle property 'paths'
[jdeolive] added some additional Icon constructors accepting a model, and added a model for specifing a tooltip for the icon
[jdeolive] GEOS-4740, updating file location when store for a resource changes, patch contributed by Milton Jonathan
[jdeolive] added some more silk icons
[jdeolive] factored out method for save behaviour
[groldan] RetypingFeatureCollection did not clone Feature.getUserData(), which can lead to losing important information such as the USE_PROVIDED_FID hint on inserts
[jdeolive] GEOS-4745, allow lookupSRS and setupBounds to work with objects not added to the catalog
[jdeolive] GEOS-4744, Allow for selection of rows by object and index in GeoServerTablePanel
[aaime] [GEOS-4750] Improve raster concurrency
[aaime] [GEOS-4757] geoserver deletes wrong layer if two layers have the same name in different workspaces
[groldan] allow SLD 1.1 documents to be submitted through the style configuration page
[jdeolive] allow to set permgen size for tests
[jdeolive] support for password datastore parameters
[jdeolive] setting projection of created feature types
[jdeolive] changing assertion based on change in Bounds string representation
[jdeolive] dependency on gt-xsd-kml and upping permgen memory for tests
[jdeolive] python api updates, allowing for passing in underlying catalog objects
[jdeolive] added kml to python artifact
[jdeolive] including html resources
[dwinslow] Factor out the AjaxCallDecorator for working with CodeMirrorEditor
[aaime] [GEOS-4765] KVPUtils will fail to parse a url that uses cql filters with an equality comparison
[aaime] Adding dependency to the area grid process
[fgdrf] fixes for typo's in de i18n for wms property file
[fgdrf] minor typo fixes in de i18n
[fgdrf] minor updates for de security properties (removed duplicated entries and fixed typos)
[dany111] fixing build
[aaime] Fixing compile error (the test was written against the java interface instead of using a WPS Execute, it would not have broken in the latter case)
[aaime] Removing dependency on a process that is gone
[aaime] [GEOS-4769] Allow stores to receive the existing catalog as a geotools respository
[aaime] [GEOS-4770] Simplify GetFeatureInfo filters before sending them down to the stores
[aaime] Allow links to show a confirmation popup or other javascript behavior
[aaime] Allow a store panel to perform actions before the form is submitted
[aaime] New feature aggregate module
[aaime] Increasing the test permgen, the build won't work on 64bit java anymore otherwise
[aaime] Adding missing classes
[aaime] Adding feature-aggregate to the community release
[aaime] Forgot the release config file
[jdeolive] GEOS-4772, qualifying datastore lookup with workspace, issue/patch submitted by German Osin
[aaime] Removing a test that duplicates one available in Geotools already
[groldan] GEOS-4774: Present dropdown choice for DataStore parameters that provide a list of options
[groldan] updated WFSDataStore parameter labels
[bmmpxf] Docs: Getting specific about JRE version numbers.
[jdeolive] GEOS-4775, setting additional metadata on wms layer when created through REST api
[aaime] [GEOS-4779] Log location system variable override ignored when the logs are reconfigured at runtime
[aaime] [GEOS-4777] Allow layers to be available, but not advertised in the capabilities documents
[jdeolive] falling through when arg passed to getLayerByName contains a colon to handle case where the layer name contains a colon, and its not meant to specify the workspace
[aaime] [GEOS-4778] Virtual services do not play well with layer groups
[groldan] GEOS-2668: set the cascade="<1 + remote hop count>" attribute on wms layers capabilities sld section
[groldan] GEOS-4595: patch by John Hudson
[aaime] [GEOS-4749] Dynaminc spring beans lookup limits concurrency
[jdeolive] GEOS-4741, option available_with_geom to filter out geometryless feature types, patch submitted by Lucas Heezen
[jdeolive] GEOS-4741, documenting available_with_geom parameter
[aaime] [GEOS-4704] DescribeCoverage 1.1.1 response has 'wcs:AnyValue' instead of 'ows:AnyValue'
[aaime] [GEOS-4257] Default workspace cannot be set after deleting the default layers, stores, workspaces
[groldan] GEOS-4595: no space in ISO19115:2003 as it's an NMTOKEN
[jdeolive] documenting from scratch feature type creation, added a cURL example
[tybion] GEOS-4766
[fgdrf] ticket #4784 : added missing property key/value pairs to core module
[groldan] GEOS-4650: basicProcessingFilter with rememberme service makes gwc ReloadRestlet to ge an empty form. Use a basicProcessingFilter without rememberme service as workaround for /gwc/rest/**
[groldan] GEOS-4672: allow setting a WMSStoreInfo auth credentials and max concurrent connections to the backend
[groldan] GEOS-4672: update wms user documentation to reflect the new user, password, and max connections parameters
[aaime] [GEOS-4788] Mosaic background color transparency broken
[jdeolive] GEOS-4658, adding support for vocabulary, and language to keywords for services and resources
[jdeolive] GEOS-4659, added option to allow WMS capabilities to output a bounding box for every supported projection
[jdeolive] some updates to extension and community modules as per KeywordInfo api changes for GEOS-4658
[bmmpxf] Docs: Added note about two-pass PDF creation. (GEOS-4790)
[aaime] [GEOS-4796] Removing all workspaces will cause an NPE at the first namespace related operation
[groldan] GEOS-4673: do not output metadatalinks other than FGDC/TC211 in WMS 1.1.1 capabilities to conform to the DTD
[groldan] fix typo
[jdeolive] updated python and querylayer modules based on geotools function name api change (GEOT-3871)
[jdeolive] setting gml 3.2 schema location manually in gml 3.2 output format since wfs 2.0 schema does not declare any dependency on gml 3.2
[groldan] GEOS-4798: avoid NPE on keyword parsing
[fgdrf] updated README.txt (java jdk dependency to 1.6 instead of 1.5)
[groldan] GEOS-4672: send http auth credentials when validarting the WMS url in case the GetCaps method is protected
[fgdrf] updated StorePages - i18 failed because of wrong property references (merged from 2.1.x branch)
[aaime] [GEOS-4752] Add Install Guide for Debian Linux + tomcat7, patch by Rudi Hochmeister
[aaime] [GEOS-4708] GetCapabilites fails for rasters not available to user
[aaime] [GEOS-4696] Documented parameters for GeoTIFF store
[aaime] Adding codes for Van Der Grinten projection
[aaime] Adapting to api change in geotools
[aaime] [GEOS-4799] MetatileMapOutputFormat should dispose JAI Chains when possible, patch by Simone Giannecchini with minor improvements from yours truly
[aaime] [GEOS-4800] More Aggressive TileCache cleaning, patch by Simone Giannecchini plus some improvements by yours truly
[groldan] added missing (c) headers
[riniangreani] Allows complex types with simple contents to be feature chained, e.g. for gml:name.
[groldan] GEOS-4803: set class attribute on input text fields with missing style
[fgdrf] Ticket #4804 : i18 support for username and password textfields
[aaime] Full cleaning of image chains without breaking GWC integration assumptions
[fgdrf] i18n for table headers of user roles management Palette
[groldan] let integrated gwc layers cascade feature_count on GetFeatureInfo requests
[groldan] fix build
[groldan] GEOS-4491: support for AuthorityURL and Indentifier on published WMS layers, including the root layer.
[groldan] port null check added by afabiani on 2.1.x
[groldan] GEOS-4791: use same method than MetaTileMapOutputFormat to slice tiles out of the metatile and hence leverage the cleverness of the different RenderedImageMapOutputFormat.formatImageOutputStream
[dwinslow] Rework CSS GUI for GEOS-4767. Clean up the build some too.
[groldan] fix misplaced xlink ns declaration for AuthorityURL in WMS GetCapabilities
[aaime] [GEOS-4809] Move WFSV back into community land
[dwinslow] CSS: Port UpdatingTextArea from Scala to Java
[groldan] let ParamInfo respect the default value when the store parameter has options
[dwinslow] Sleuth out some wicket structure and start fleshing out tests
[aaime] [GEOS-4823] Creating a new Style the CatalogAddEvent is fired before the relative file is written on the FileSystem
[dwinslow] Move OpenLayers script generation over to freemarker
[jdeolive] made code and locator protected, and added some chaining methods to set them
[jdeolive] added OwsUtils.put for reflectively setting key/value of a map property
[jdeolive] making enum lookup case insensitive
[jdeolive] deprecating DefaultServiceExceptionHandler and renaming to OWS10ServiceExceptionHandler
[jdeolive] normalizing version up to 3 components
[jdeolive] using service id to group xml readers rather than namespace
[jdeolive] adding service descriptor that was actually dispatched to the request object
[jdeolive] allowing ows 1.1 exception handler to specify version of hte service, rather than ows version
[jdeolive] tweaking kvp parser matching to favor candidate that more closley matches properties of a request
[jdeolive] GEOS-4634, support for joins and startIndex
[jdeolive] added TypeNameExtractingVisitor, a visitor for extracting type names from a filter
[jdeolive] GEOS-4687 - SOAP support
[jdeolive] added filter 2.0, gml 3.2.1, and wfs 2.0 schemas to webapp
[jdeolive] GEOS-4511, GEOS-4512, GEOS-4513, GEOS-4515, GEOS-4514, wfs 2.0 service
[bencaradocdavies] Added missing version in GET URL, for consistency with other tests
[bencaradocdavies] GEOS-4824: Fix FeatureTypeSchemaBuilder handling of multiple includes
[dwinslow] Start moving SummaryTable over to Java
[fgdrf] GEOS-4828 : i18n support for NewLayerPage
[fgdrf] - removed a comment in DemoRequestPage.html and corresponding property that has never been used since 2008
[bencaradocdavies] Updated app-schema tutorial and documentation for compatibility with GeoServer defaulting to WFS 2.0. Also documented support for GML 3.2.
[aaime] [GEOS-4830] Allow the user to force the content disposition mode and file name via kvp params
[aaime] [GEOS-4782] ResourcePool may fail with NPE on a catalog reload towards a configuration that has less layers than before
[aaime] [GEOS-4831] Allow to use templated map decorations with the animator
[fgdrf] fix for GEOS-4827 (switch between data stores to create a new layer doesn't refresh components correctly)
[fgdrf] GEOS-4811 : image for admin status representation of user table
[groldan] make gwc create an empty template config
[fgdrf] cleanup never used property NewLayerPage.th.action
[fgdrf] fixed typo in arcsde extension
[fgdrf] typo in properties file
[dwinslow] Move SummaryProvider over to Java
[dwinslow] Avoid use of by-name parameters in StylePanel
[dwinslow] Remove disused UI components
[aaime] Adding a profile to get the OGR store into the mix
[bencaradocdavies] Refactored giant FeatureChainingWfsTest.testDescribeFeatureType into many smaller tests. Fixed GEOS-4836: AppSchema test trip up over inconsistent DescribeFeatureType response
[aaime] Fixing a NPE introduced along with GEOS-4823
[dwinslow] Make CssDemoPage a bit more Java-shaped
[fgdrf] [GEOS-4294] : initial completed i18n (German) support for web modules
[groldan] SRSDescriptionPage: show decode exception reason and use 4326 map instead of failing when a CRS can't be parsed o projected to 4326
[dwinslow] Avoid use of scala.Option to reduce reliance on Scala stdlib
[dwinslow] Factor out sldText model rather than defining it inline
[dwinslow] Rely on passing in the page rather than closing over its methods
[riniangreani] Refactoring testDescribeFeatureTypeNoType in FeatureChainingWfsTest.
[riniangreani] Fix test/FeatureChainingWfsTest.java that broke the build.
[dwinslow] More abstract classes instead of passing closures around
[dwinslow] Move StylePanel over to Java
[groldan] GEOS-4829: JSON output formatting of date/time to ISO 8601, including Calendar instances
[groldan] GEOS-4817: added connect and read timeout properties to WMSStoreInfo
[groldan] adapt to gwc api change
[dwinslow] Remove unneeded DemoPanel abstract class
[dwinslow] Move DataPanel, DocsPanel, SLDPreviewPanel over to Java
[groldan] fix weaving of TMS service bean
[bencaradocdavies] Added layer.xml to enable WMS for gsml:MappedFeature in the app-schema tutorial configuration.
[aaime] [GEOS-4819] Support for WPS asyncronous processes
[aaime] More robust font lookup in text decoration
[dwinslow] Move StyleChooser over to Java
[aaime] [GEOS-4842] GeoServer WPS fails to open a remote zipped shapefile
[aaime] The new text decoration does not work properly when bound to the top of the image, silly mistake computing its size
[dwinslow] Move LayerChooser over to Java
[bencaradocdavies] GEOS-4841: restconfig ClassCastException when creating app-schema feature type
[dwinslow] Move LayerNameInput over to Java
[dwinslow] Move MultipleLayerChooser over to Java
[aaime] [GEOS-4845] Make it easier to build a custom version of GeoServer
[aaime] In case of style removal failure use the default point and save the layer, instead of sticking a null style in the layer (which will cause troubles with caps generation later)
[aaime] Always try to dispose the store in case of creation exception
[groldan] fix assumtions about FeatureId.getID() being the full representational state of a feature identifier in transactions
[fgdrf] git-svn-id: https://svn.codehaus.org/geoserver/trunk@anonymised.com ef1d6e69-97e5-0310-af46-8a06194da32a
[fgdrf] deleted committed patch file
[fgdrf] deleted committed backup file (sorry for that)
[fgdrf] updated web core de properties file
[dwinslow] Move OpenLayersMapPanel and SummaryTable over to Java
[fgdrf] fixed typo in properties file
[dwinslow] Move CssDemoPage over to Java
[aaime] [GEOS-4851] Safeguard catalog and configuration code from concurrent access
[jdeolive] updating location of bmreduced.tiff
[dwinslow] Use compat module for CSS conversion (more java friendly)
[aaime] [GEOS-4853] KML Time template does not work anymore due to XSDateTimeBinding changes
[aaime] [GEOS-4855] Browsers won't show png8 files generated by GeoServer
[jdeolive] GEOS-4838, GSIP 66, adding ability to configure services at the workspace level
[aaime] [GEOS-4862] Asynch process execution will be stuck forever in 'process started' state if an error occurs while encoding the process results
[aaime] Hopefully fix the cite tests after GEOS-4855 breakage
[aaime] [GEOS-4863] WPS back link to store resources uses the parameter 'mime', it should be 'mimetype'
[jdeolive] GEOS-4859, picking up metadata from underlying geotools ResourceInfo
[jdeolive] updating HibGeoServerFacade with stubs for workspace specific service methods
[aaime] [GEOS-4874] Map decoration horizonal centering does not account for the decoration size
[aaime] [GEOS-4856] StyleEditPage saves style before writing content, which is bad for Catalog listeners
[aaime] [GEOS-4880] WMS 1.3 CapabiltiesSystemTest will fail if schemas.opengis.net is not accessible
[aaime] [GEOS-4881] WPS build takes several minutes if schemas.opengis.net is not accessible
[fgdrf] updated i18n (de) for wms
[aaime] [GEOS-4870] Exception after changing data store to DB with different schema
[aaime] [GEOS-4865] NPE in WMS.getFeatureTypeTimes when feature has null time attribute
[groldan] GEOS-4887: do not round up coordinates to three decimals in EnvelopePanel
[jdeolive] GEOS-4753, properly initializing coverage grid dimensions, patch contributed by Tony Young
[groldan] EnvelopePanel.convertInput checked maxX twice and didn't check maxY
[groldan] Make DecimalTextField not to fail on malformed input
[jdeolive] GEOS-4859, handling empty keywords from metadata source
[aaime] [GEOS-4896] Animator won't work over a layer list
[aaime] [GEOS-4897] GeoServer won't animate a standard WMS request with multiple times/elevation and animated gif output
[dany111] GEOS-4869
[jdeolive] GEOS-4871, renaming RESOURCE to NAME iin REQUEST_RESOURCES table as RESOURCE is a reserved word in oracle
[jdeolive] GEOS-4872, adding user-agent to gathered request data, patch submitted by Tony Young
[aaime] [GEOS-4892] Upgrade OpenLayers embedded in GeoServer to version 2.11
[aaime] [GEOS-4893] GeoServer own on the fly meta-tiling won't work with WMS 1.3
[aaime] [GEOS-4894] Add a drop down in the OL preview to work with the WMS 1.3 protocol
[aaime] [GEOS-4900] map decoration layout fails on empty layer title
[aaime] Remove the wcs loader override, does not seem to be necessary anymore
[aaime] Follow up paging support on 2.1.x, adding sorting for all on trunk as well
[ischneider] fix for GEOS-4864 - NPE in DimensionHelper when feature store is empty
[aaime] Sorting and paging togheter would not work correctly
[aaime] [GEOS-4903] superfluous sorted collection used in WMS.getDimensionCollection
[yjacolin] [fr] adding french translation
[groldan] GEOS-4847: use a dynamic property to check for default workspace in the workspace list instead of a non existing 'default' property
[groldan] adapt to gwc pre 1.3-RC2 changes
[aaime] [GEOS-4905] Cascading WMS 1.3 servers using the CRS:XYZ crs results in maps with wrong proportions
[jdeolive] GEOS-4854,GEOS-4899 - handling reflective describefeaturetype calls inline, rather than as separate request, deals with deadlocking issues
[groldan] GEOS-4908: WMSStoreInfo configuration option to use the regular or commons-httpclient HTTP backend.
[jdeolive] adding flag to set max heap size for forked javac processes, with a default value of 256m
[aaime] [GEOS-4911] GeorectifyProcess not properly identified as rendering process
[aaime] [GEOS-4912] NullPointerException if WPSResoruceManager.addResource is called without a set execution id
[fgdrf] added i18n (de), thx to marc jansen
[aaime] [GEOS-4913] A disappearing scaleline
[aaime] [GEOS-4336] PNG encoder does not support indexed images with alpha in the pallete entries
[aaime] Fixing build
[aaime] Really having a bad day...
[aaime] Import cleanups
[groldan] Add dbconfig's missing hibernate UserType for KeywordInfo
[groldan] have all CatalogImpl.add(*) methods use the facade returned object once added
[aaime] Make sure png8 output is not dithered
[riniangreani] Add wfs version 1.1.0 to requests in data reference online tests so they work with wfs 2.0 support.
[aaime] [GEOS-4922] Authentication by unique key community module
[jdeolive] GEOS-4924, GSIP 67 - workspace local settings
[riniangreani] Remove unnecessary dependency to gt-webservice.
[aaime] Fixing version number
[riniangreani] Fix dependency for web-service-test.
[jdeolive] GEOS-4888, proper handling of accepts header for media type all, patch submitted by Steve Ikeoka
[aaime] Upgrading imports to spring security
[riniangreani] Enable geoserver app-schema-test to run online.
[jdeolive] locking down printing module to specific version, built for java 5
[aaime] [GEOS-4876] wfsrequest.txt must not encode real server host name (fix by Rudi Hochmeister, test by yours truly
[bencaradocdavies] Renamed methods used for cache automatic configuration
[aaime] Follow up to GEOT-2867 (the memory mapped mosaic needs to be disposed on windows, not required on Linux instead
[aaime] [GEOS-4918] Support JDBC stores parametric session startup/teardown sql commands
[aaime] Updating docs to account for SQL Azure support
[aaime] Document the new 'sql session scripts' functionality
[aaime] Forgot to add an image
[riniangreani] Updating reference data set version to the new one (1.0.6) to cater for app-schema-test with online mode.
[riniangreani] Changes to make app-schema-test run successfully with Oracle.
[groldan] GEOS-4938: Add GUAVA dependency to root pom on 2.2.x
[shane907] Very minor fix to developer Eclipse preferences instructions
[groldan] port gwc rest mappings to match the fix of https://github.com/GeoWebCache/geowebcache/issues/95
[aaime] Document the system variable used to specify the audit path in clustered installations
[bencaradocdavies] Fix for build failure with subversion >= 1.7 working directory (as in GeoTools; see GEOT-3932)
[bencaradocdavies] Changed GML 3.2 test geometries to MultiPoints to test gml:id of inner geometries in multigeometries introduced in GEOT-3824
[bencaradocdavies] Added documentation for app-schema configuration steps required for GML 3.2
[bencaradocdavies] Refactored GML version sections into a single page
[bencaradocdavies] Added a section on GML 3.3 support in app-schema
[groldan] fixes GEOS-4945: blank capabilities response when proxy base is wrong and an ExtendedCapabilitiesProvider contributes contents to the internal DTD declaration
[aaime] [GEOS-4069] SLD examples for lines in the SLD-cookbook don't validate
[shane907] Updating excel plugin to use improved streaming api for Excel 2007 (xml) format GEOS-4940
[shane907] Adding release files from GEOS-4940 Excel WFS improvements
[shane907] Small update to Excel WFS plugin user docs
[aaime] [GEOS-4927] Refactoring of legend decoration to use getLegendGraphic, patch by Hajo Kliemeck and yours truly
[aaime] [GEOS-4930] OpenLayers Map Preview always points to localhost
[riniangreani] Support isList in app-schema wfs config.
[riniangreani] Updated app-schema configuration doc with isList usage.
[aaime] GEOS-4953, Click on OpenLayers map fails to identify elements on small windows with Firefox 10, patch by Tim Schaub
[fgdrf] fixed GEOS-4837 : i18n support for geosearch Sitemap
[riniangreani] Corrected example for isList.
[groldan] fixing build until merging the GEOS-4460 branch
[aaime] [GEOS-4958] GetFeatureInfo and Getfeature will fail for shapefiles and directory of shapefiles configured in a workspace other than the default one
[groldan] Allow EnvelopePanel to be extended
[groldan] allow to hide the EnvelopePanel labels
[groldan] Allow CRSPanel to be extended
[groldan] remove System.out.println call from SimpleAjaxLink
[riniangreani] - Update AppSchemaDataAccess.xsd copy with Geotools copy.
[riniangreani] New app-schema-test modules for online testing.
[riniangreani] Undo accidental commit.
[riniangreani] Corrected isList example (again).
[aaime] Follow up Geotools update of commons-io to 2.1
[aaime] [GEOS-4960] SQL view params support broken on trunk for WFS service
[ischneider] [GEOS-4957] add end date support for WMS time dimension and elevation
[ischneider] [GEOS-4956] WMS time extent does not properly encode dates with negative years
[riniangreani] Add app-schema online tests guide.
[riniangreani] Add dependency to OracleDriver for app-schema-online-test profile (for maven 3).
[riniangreani] Add gt-jdbc-oracle dependency to app-schema-postgis-test.
[riniangreani] Added section for memory requirements for app-schema online tests.
[riniangreani] Fix app-schema online tests failures in linux (due to line separator difference with windows).
[aaime] Work in progress on GetLegendGraphics
[aaime] [GEOS-4100] Expose dpi setting to getLegendGraphics requests
[riniangreani] Clarify JUnit instructions for app-schema online tests.
[riniangreani] Update memory requirements for JUnit to run app-schema online tests.
[aaime] control flow enhancements (GSIP 72)
[aaime] [GEOS-2630] Allow user to choose which properties will be included in the GetFeatureInfo output
[aaime] Docs for GEOS-2630
[aaime] [GEOS-4934] not able to query wms getFeatureInfo with layername derived by sld, patch by Hajo Kliemeck
[groldan] Adapt to gwc api additions in support of GEOS-4460
[groldan] GEOS-4460: allow to set the response page to the resource and layergoup edit pages, and to set which tab to open by default in the resource configuration page
[groldan] GEOS-4460: Allow LayerEditTabPanel implementations to use an IModel of their choice
[groldan] GEOS-4460: let layer group configuration panels to save any exatra state if it's dettached from LayerGroupInfo
[groldan] GEOS-4460: gwc integration to fully manage GeoServerTileLayer/Info throgh the CatalogConfiguration and external persistence
[groldan] GEOS-4460: Integrated gwc layer admin through the UI
[groldan] fail if adding a new tile layer with a duplicate name.
[jdeolive] GSIP 73, GEOS-4962 - support for styles and layer groups per workspace
[groldan] GEOS-4987: use prefixed layer group name as tile layer name for layer groups local to a workspace
[jdeolive] GEOS-4984, dealing with issues with layer groups with same name in separate workspaces; GEOS-4985, added prefixedName() to LayerGroupInfo
[jdeolive] updating hibernate catalog facade to compile against recent catalog api changes
[groldan] GEOS-4987: use LayerGroupInfo.prefixedName() to name TileLayers, now that GEOS-4985 is fixed.
[jdeolive] GEOS-4994, adding call to ImageIO.scanForPlugins() on startup
[jdeolive] GEOS-4987, using LayerGroupInfo.prefixedName() on map preview page
[jdeolive] updating TEST_LOGGING config so that wicket tester messages are shown in the default test configuration
[groldan] GEOS-4983: use a GeoServerLifeCycleHandler to reload the gwc config
[groldan] GEOS-4987: beware ImmutableMap does not support null values
[aaime] [GEOS-4756] web.xml Reverse Proxy Filter=true has side effect of double gzipping GetCap, GML and CSV output in 2.1.1 --> removing the filter, it is apparently not needed anyways
[aaime] [GEOS-4860] WCS 1.0's DescribeCoverage in GeoServer r16592 does not work with ArcMap 10.0, patch by Tony Young, test by yours truly
[jdeolive] GEOS-4988, avoiding call to underlying createTypeNames() for every data access
[aaime] [GEOS-4995] GetLegendGraphics dpi rescaling would not work if a specific rule is requested
[aaime] Blind attempt to fix wcs 1.0 cite tests
[mdavis] Fixed hatched line SLD to not have 2 rules
[riniangreani] GEOT-4035: handle substitutionGroup for basic GML types
[mdavis] Improved flow of Monitoring HTTP page
[mdavis] improved wording of line example
[mdavis] improved wording of line with border example
[mdavis] small fix to linecap wording
[mdavis] Fixes to Web Admin quickstart wording
[jdeolive] GEOS-4963, GSIP-74, finer grained admin security, support for workspace level administrators
[aaime] Following up GEOT-4077, the test was actually checking with a invalid output geometry...
[aaime] [GEOS-4955] Mismatch between WMS GetMap image and GetFeatureInfo output
[aaime] [GEOS-5004] Allow : in SQL view parameter values without escaping, patch by Robert Coup
[groldan] GEOS-5007: do not force loading the tile layer config at every CatalogConfiguration.getTile(String name) call
[dwinslow] Fix a markup bug in the LayerChooser, add test for future
[dwinslow] Use "computer audience" for templated JS in OL Map
[dwinslow] Fix bug where SummaryProvider wasn't providing summaries (...)
[dwinslow] Fix up SLD character handling (don't drop newlines!)
[dwinslow] Get CSS saving and loading working properly
[mdavis] Fixes to quickstart wording, rename to Publishing data
[groldan] GEOS-5009: Provide a way for the dispatcher to call a service operation avoiding reflection, for cases where it impacts performance due to thread contention
[jdeolive] added findbugs profile to build
[mdavis] Minor fix to pronoun
[dwinslow] Add some info on using Findbugs to the developer manual
[dwinslow] Fix some markup errors in the developers' guide.
[groldan] warn if the coverage access page's imageio cache memory threshold is not set.
[aaime] Removing left-over testing code
[dwinslow] Fix "greater/greather" typo throughout docs
[aaime] [GEOS-5015] Layers backed by a WMSLayer resource do not link back to it in the REST config xml representation
[mdavis] Clarified titles text
[groldan] increse gwc performance by increasing the metastore connection pool size. Now that it uses commons-dbcp we should use a .properties file to configure it though
[groldan] Fixes GEOS-5010. Classes in the org.geoserver.gwc.dispatch package mediate between the GeoServer and GeoWebCache dispatchers
[groldan] properly comment the package
[groldan] GEOS-5010: basic docs about throttling gwc requests through control-flow
[groldan] avoid NPE in WMS 1.1.1 capabilities if the root layer bounds can't be reprojected
[victortey] Change the dependency version of the data reference set to 1.0.7 which adds primary key to the oracle script
[jdeolive] GEOS-5016, dropping layer name prefixes when accessing through local workspace / virtual service, original patch by Juan Marin
[aaime] [GEOS-4932] JSON outputFormat extremely slow for GetFeature + BBOX with big WFS-layer, patch by Rudi Hochmeister
[aaime] Improvements to EMF logging, request logging for WPS
[aaime] [GEOS-5006] GeoserverGridShiftLocator, patch by Oscar Fonts
[aaime] Reprojection console, wiring up the srs description panel, and improving label styling in the area of validity preview
[aaime] Forgot to commit a file
[victortey] Add prefix and suffix predicate to capture alter table statement for inserting primary key to the oracle database for the reference data set used for online testing app-schema
[dwinslow] Add volatile modifier to AbstractResource.formats
[dwinslow] Add final modifier to static fields on RESTDispatcher
[jdeolive] updating developer docs to reference 2.1.x as current stable branch
[mdavis] Enhanced wording & spec description
[mdavis] Added date/time range example
[riniangreani] Check islist ordering for timeseries tests.
[groldan] GEOS-5029 findbugs error removal for web demo module. Patch by Robert Marianski.
[mdavis] Fixed misspelling in leftToRight option
[aaime] Adding geometry metadata table description
[mdavis] Improved wording
[jdeolive] GEOS-4554, GSIP 71 - new security subsystem
[jdeolive] ensuring the wicket tester is destroyed in test tear down
[nielscharlier] Documentation: app-schema WMS layer.xml
[nielscharlier] GEOT-4006 SLDParser needs to set namespace context for Geometry/PropertyName
[jdeolive] null check for data store factory getParametersInfo()
[jdeolive] adding profile for security jdbc jndi tests and ecluding all jndi tests when profile not active
[jdeolive] updating commuinty modules authkey and ftp to compile against security api changes
[jdeolive] some cleanup of security manager during shutdown
[jdeolive] fixing help popup on workspace edit page
[jdeolive] fixing issue with dialog component not properly being passed through to callback on commit, fixes issue with file chooser on store configuration page
[jdeolive] GEOS-5037, allowing GEOSERVER_LOG_LOCATION to be set from web.xml context param during startup
[nielscharlier] GEOT-4086 GetFeatureInfo on app-schema based WMS layer fails
[jdeolive] adding link to downloadable acme-ldap jar
[nielscharlier] GEOS-5032 GetLegendGraphic doesn't work for WMS with app-schema
[groldan] beware when checking for the configuration staleness that multiple requests may be coming
[groldan] GEOS-4961: Create the SingleIpFlowController with the actual IP and not just its first part
[groldan] GEOS-4961: simplify SingleIpFlowController, all it needs to do is to extend SingleQueueFlowController and check the ip matches
[groldan] GEOS-4961: Let IpBlacklistFilter react to config changes, use a set.contains instead of list traversal, and get rid of the shared isBlocked instance field
[groldan] GEOS-4961: Simplify IpFlowController, get rid of the unneeded ipAddresses instance field, and synchronize creation of queues
[jdeolive] ensuring secuirty manager properly initialized in order to decrypt datastore config passwords during startup
[jdeolive] README for 2.2-beta1
[jgarnett] Updated license information
[jdeolive] using Arrays.equals for password comparison
[jdeolive] avoiding passing null into properties object
[bencaradocdavies] GEOS-5041: Broken File/URL conversions in security
[bencaradocdavies] Documented use of 'Expose primary keys' data store parameter in app-schema
[bencaradocdavies] Fixed typo in manual
[mcr] Finishing CAS core code
[mdavis] Clarified wording
[mdavis] Clarified wording, source format
[mdavis] Clarified wording, added list of operators
[mdavis] Wording improvements, more links, etc
[mdavis] Wording clarification
[mdavis] split formats into bullet items
[mdavis] Minor wording change
[jdeolive] GEOS-5047, ensuring file streams ar are properly cleaned up, patch submitted by Brett Walker
[jdeolive] cleaning up bad import
[mdavis] wording improvements, linking
[mdavis] Changed terminology to variable substitution for consistency
[mdavis] Changed reference tag to sld_variable_substitution
[groldan] check for workspace attribute when modifying a style through the rest config api
[groldan] Clarify and enforce the Catalog.getStyleByName(String name) contract to mean getStyleByName((Workspace) null, name)
[mdavis] minor wording change
[mdavis] Added doc for predefined variables
[mdavis] removed dead reference to teradata
[mdavis] removed duplicate misplaced file
[mdavis] Reordered sections for consistency and flow
[mdavis] Wording, formatting improvements
[mdavis] minor wording improvements
[groldan] avoid possible NPE on misconfigured layer
[mcr] Fixing GEOS-5043
[groldan] define a property for the jetty port, or mvn jetty:run -Djetty.port=<port> doesn't work
[mcr] Avoid erasing credentials for xml/memory user objects
[mdavis] wording clarification
[mdavis] fixed name of if_then_else function
[mdavis] fixed name of lessEqualThan function
[mdavis] fixed case of area function name
[dwinslow] Use absolute paths instead of relative for JDBCTest
[jdeolive] GEOS-5064 - cas support; GEOS-5050 - starting jetty with optional ssl
[jdeolive] Bug fix url param encoding
[jdeolive] Redesign http session listener
[mdavis] Fixed intro, added new function categories Control and Spatial Rels
[aaime] [GEOS-4919] Support alpha transparency in png8 output
[riniangreani] GEOT-4116: App-schema joining needs to sort by primary key
[riniangreani] - tests for GEOT-4116: App-schema joining needs to sort by primary key
[riniangreani] Updated doc for GEOT-4116: App-schema joining needs to sort by primary key
[mcr] Adding a LRU authentication cache
[jdeolive] handling null case in LRUAuthCacheImpl.put
[jdeolive] refactored security filter chain enum into a regular class, making it easier for extensions to contribute to the chain, related to GEOS-5065
[jdeolive] fixing bad import
[riniangreani] App-schema: Unit tests for isList support with simple type.
[mdavis] Various wording improvements
[mdavis] Added ECQL Reference, linked it in to document
[jdeolive] GEOS-5065, factoring out filter chain configuration for cas into cas auth provider
[riniangreani] Add validation to WaterMLTimeSeriesWfsTest (using AppSchemaCatalog).
[jdeolive] GEOS-5065, moved cas specific code out into separate security module
[jdeolive] GEOS-5071, supporting zip file uploads containing multiple shapefiles
[mdavis] Rightsized the title of ECQL Reference
[jdeolive] commenting out System.err.println
[mdavis] Added external links, minor typos fixed
[mdavis] Wording changes, better linking
[mdavis] Minor wording changes
[groldan] fixes #GEOS-5073
[groldan] fixes #GEOS-5074
[dwinslow] Correct some build warnings in the user docs
[dwinslow] Merge unused linux page with the index for the linux section
[dwinslow] Fix some Sphinx warnings in the user docs
[mdavis] Added doc for configuring Oracle module
[jdeolive] test case for GEOS-5053
[jdeolive] added warning to home page about default password not being changed, only visible when logged in as admin of course
[jdeolive] fixing build, adding files meant to be included in last commit adding warning about password change
[mdavis] Edited wording, added new section header
[mdavis] minor fixes, added a link
[jdeolive] added callback to GeoServerTablePanel for when table item is created, useful for being able to set attribues on the column td element itself
[jdeolive] having StoreModel respect null set as the model object
[groldan] fixes #GEOS-5078, always clip the saved gridsubset's extent to the gridset's area of validity
[groldan] do not rely on a specific list order, nothing mandates the returned list to be in the same order FeaturetypeInfos were added
[groldan] make org.geoserver.wms.WatermarkInfo serializable
[mcr] Fixing GEOS-5079
[mdavis] minor text fixes
[mdavis] Wording improvements, adding links to filter usage pages
[groldan] SettingsInfoImpl lacks a setId method. Adding it.
[groldan] Force saving the layer resource in CatalogImplTest.testEnableLayer(), otherwise the final assert works by accident on the default catalog implementation
[groldan] fixes #GEOS-5081: fix non deterministic behavior of the Catalog.getLayerGroupByName(...) family of methods
[groldan] GEOS-5081: fix LocalWorkspaceCatalog.getLayerGroupByName(String) and GeoServerPersisterTest's usage of it
[groldan] GEOS-5081: restore LocalWorkspaceCatalog.getLayerGroupByName to its original form, have interpreted it wrong, and make sure LayerGroupResource uses the specified workspace
[riniangreani] Tests: App-schema isList experimental/temporary solution to subsetting timeseries via filters.
[mcr] Fixing GEOS-5082 on trunk
[aaime] Make sure we log failures for exceptions on asynch process failures
[riniangreani] App-schema isList tests: subsetting should affect other property values outside the filter properties.
[jdeolive] GEOS-5087, adding access mode admin to data access page drop down
[mdavis] Formatting and concept clarification
[mdavis] Wording improvements, linking, formatting
[dwinslow] Implement automatic bbox recalculation via REST
[aaime] [GEOS-5088] GeoServer WPS would execute at most one asynch request at a time
[aaime] Log the execution id for asynch requests
[jdeolive] updated to layer security docs to include admin access mode
[jdeolive] added some note to data direcetory migration section about changes occuring from 2.1.x to 2.2.x
[jdeolive] added notes about upgrading, also ported rest security docs from 2.1.x
[groldan] fixes #GEOS-5092: don't fail when a layer or layer group that has an associated tile layer doesn't exist anymore
[mdavis] Improved wording, added explanation
[mdavis] Added note about being read-only
[groldan] GEOS-5093: make the tile layer edit tab robust to missing GridSets
[aaime] GEOS-5006] GeoserverGridShiftLocator, documentation pages by Oscar Fonts
[aaime] [GEOS-5048] User-defined Datum Shifts, patch by Oscar Fonts, tests by yours truly
[mcr] Insert special cas chain at the start of the list
[aaime] [GEOS-5068] document missing forceLabel parameter for GetLegendGraphic, patch by Lars Lingner
[jdeolive] GEOS-5060, added a multiplexing password encoder to be able to decode
[aaime] [GEOS-5096] Build hang in wps-core ExecuteTest.testConcurrentRequests, blind attempt to fix geos-5096
[aaime] Fully separate each MonkeyProcess based test from each other
[groldan] fixes #GEOS-5003: NullPointer in GWC when caching enabled for TIME or ELEVATION parameters
[mcr] Fix GEOS-5100
[afabiani] - JIRA: GEOS 5099
[afabiani] fix test
[nielscharlier] kak
[nielscharlier] gmi
[nielscharlier] wmstests
[nielscharlier] newtests
[nielscharlier] revertrefmappings
[nielscharlier] testing
[nielscharlier] merge
[nielscharlier] rini
[nielscharlier] info
[nielscharlier] Fix Integration Test
[bencaradocdavies] Disabled MapPreviewPageTest.testLayerNamesPrefixed as a temporary workaround for GEOS-5106
[bencaradocdavies] GEOS-5096: Build hang in wps-core ExecuteTest.testConcurrentRequests on one CPU
[nielscharlier] Go back to Revision 17039
[bencaradocdavies] GEOS-5067: Random build failure in wms DimensionHelperTest
[nielscharlier] Improve App-schema/WMS unit tests
[nielscharlier] App-schema WmsGetMapTest with spaces in path GEOS-5107
[nielscharlier] App-schema WmsGetMapTest with spaces in path GEOS-5107 (2)
[nielscharlier] App-schema WMS test improvements: increasing pdiff threshold
[dwinslow] Add more info to JavaDoc comments on SecurityNamedServiceConfig
[mdavis] added links to reference, better wording
[riniangreani] Include tiff files in app-schema online tests resources.
[afabiani] - GEOS-5110
[afabiani] - fix build
[riniangreani] Add app-schema dev guide to toc tree.
[riniangreani] app-schema unit test for <sourceExpression>index(LAST)</sourceExpression> to cater for timeseries filtering
[riniangreani] Update appschemadataaccess.xsd for GEOT-4126: Enable specifying row number in getting sourceExpression for denormalised rows (for timeseries subsetting).
[nielscharlier] WMS tests pdiff documentation
[nielscharlier] GEOS-5080 app-schema WMS reprojection
[mdavis] reordered in function names
[dwinslow] Fix "already-configured" check during datastore upload - fixes GEOS-5109
[aaime] [GEOS-5117] OpenLayers preview won't switch to an alternate style anymore
[mdavis] Clarified wording for offline operation
[mdavis] Clarified wording for building with Oracle
[riniangreani] Fix svn properties for some app-schema files.
[groldan] Peg to gwc 1.3-RC3. We're adopting the policy of not depending on GWC SNAPSHOT builds.
[dwinslow] Add lenient XML generation option - GEOS-5084
[dwinslow] Add missing class to support new configuration option
[mdavis] Text wording improvement
[mdavis] Wording clarifications
[jdeolive] adding RELEASE_NOTES.txt template, and taking content out of README, making it more generic
[groldan] fix CatalogImplTest.testGetLayerGroupByNameWithWorkspace(), was adding a LayerInfo related to a StyleInfo that wasn't previously added to the Catalog
[mdavis] Various wording, formatting improvements
[afabiani] - GEOS-5120
[mdavis] Added missing closing tags
[mdavis] Fixed bad syntax in SLDs, layout, content
[mdavis] Fixed fill parameter in spaced-symbols example
[mdavis] Made section headings consistent with other symbolizers
[mdavis] Better wording
[mdavis] Formatting code element
[bencaradocdavies] GEOS-5085: WFS 2.0 paging returns wrong features for startindex=0
[jdeolive] updating CompositeFeatureCollection to match api changes to DataUtilities.bounds()
[mdavis] Fixed section headings, text improvements
[aaime] [GEOS-5126] Saving a layer whose native SRS has no native EPSG code takes several seconds
[jdeolive] GEOS-5128, ensuring acceptversions and acceptformats parsed properly when version not explicitly specified
[jdeolive] GEOS-5129, support for idgen = UseExisting
[jdeolive] GEOS-5130, only setting acceptVersions if it is not already set
[jdeolive] GEOS-5129, preserving user data when reprojecting feature
[groldan] fix other CatalogImplTest cases where objects were being added to the catalog with related objects not having been added first
[groldan] yet another missing related object to CatalogImplTest
[groldan] Revert "yet another missing related object to CatalogImplTest". Sorry, cherry picking mistake.
[jdeolive] GEOS-5131, skipping srsDimension during gml3 encoding when cite compliance is set
[mdavis] Expanded documentation for symbolizer elements, better headings, remove empty scale page
[mdavis] GEOS-5133 - Missing auth in cURL REST example
[victortey] GEOT-4105:app-schema GML 3.2 gml:id xlink:href for repeated elements in wrong location
[jdeolive] adding build scripts for automated releases
[mdavis] fixed element name styling, minor text changes
[jdeolive] GEOS-5134, adding doReturn() functionality to geoserver base page
[jdeolive] some CRS/SRS converter tests
[jdeolive] allowing store edit pages to take a direct object, and allowing for custom action for saving
[jdeolive] GEOS-5132, dispatching based on xml namespace in POST requests
[jdeolive] GEOS-4545, making srs name syntax configurable, ensuring gml configuration in place for wfs 2.0, updating wfs capabilities to respect configured srs syntax
[jdeolive] updating cite wfs 1.1 config to force non-experimental urn syntax required for cite compliance
[mdavis] fixed cql_filter sep to semicolon, added syntax, minor formatting
[mdavis] better explanation of scale selection
[mdavis] documented all elements
[jdeolive] calling correct super method to delegate authentication
[mdavis] added line and text examples
[mdavis] refactored rules ref doc onto separate page
[jdeolive] properly specifying svn branch url
[mdavis] added note about requirement for valid URLs
[mdavis] added full syntax for rules
[mdavis] made title, ref consistent
[mdavis] clarified text, added headings
[jdeolive] GEOS-5140, updating GetLegendGraphic on layer publishing page to use workspace service url to handle both global and workspace local styles
[mdavis] Added example of external graphic
[aaime] [GEOS-5142] Have the wms scale denominator among the wms default environment variables
[mdavis] Created new section for cascaded services
[mdavis] Fixed text, reference tag
[mdavis] Created Working with Databases section
[mdavis] Created Working with Vector Data section
[mdavis] Added Vector Data index page
[mdavis] Created Working with Raster Data section
[mdavis] Fixed links to pages
[mdavis] Added Concatenate function
[mdavis] Added note about coercion of non-string args
[mdavis] Text clarification, added sections
[mdavis] Minor text changes
[mdavis] text clarification
[mdavis] Made app-schema section a primary section in the index
[mdavis] Added wms_scale_denominator env variable doc
[mdavis] Changed title to Working with App Schemas
[mdavis] Added Styling with Transformation Functions page
[jdeolive] don't advertise wfs 2.0 as provided version when client made explicitly a non 2.0 request
[jdeolive] don't set targetNamespace in heterogenoous DFT case, conflicts with wfs 2.0 compliance but required by 1.0 cite tests
[mdavis] Added filter function doc for Transformation functions
[mdavis] Text improvments
[jdeolive] updating ip of win and mac installer servers
[aaime] Make wms 1.3 cite tests pass (with the online version, r1
[aaime] [GEOS-5124] WITHIN Spatial Operator missing from GetCapabilities WFS 1.1 and 2.0, patch by Gerson Galang
[aaime] Roll back a change in GEOS-5124, in wfs 1.0 the filter is really named 'intersect' instead of 'intersects'
[aaime] [GEOS-5013] WFS request containing viewparams parameter causes an IllegalArgumentException
[aaime] whoops, forgot to add back the service param
[jdeolive] removing teradata dependency, moved to extension, removing spatialite dependency, currently disabled
[mdavis] Added ILIKE predicate
[jdeolive] supporing JAVA_OPTS in startup/shutdown scripts
[jdeolive] GEOS-5139, preserving ordering in rest.securities, patch provided by ftringali
[jdeolive] GEOS-5103, updating rest api to propererly deal with worksapce local styles
[mdavis] SLD Intro - added content, reordered sections, deleted empty sections
[mdavis] SLD Ref - added multiplicity of sub-elements
[dwinslow] GEOS-5158 init() and destroy() hooks for GeoServerSecurityProvider
[bmmpxf] Docs: Updated Global Settings page
[aaime] [GEOS-5169] Shapefile memory mapping options uneditable under recent Firefox versions
[dwinslow] Correct typo in REST overview page
[victortey] GEOT-3454 : Geoserver app-schema: types that only have client properties attributes are always skipped
[aaime] [GEOS-5147] Typo in WMS Interpolation Settings, patch by Michael Romero
[aaime] [GEOS-5173] SLDs with Rendering Transformations do not validate in Style Editor, patch by Martin Davis
[aaime] [GEOS-5161] Even/odd rows display oddly on Server Status page
[mdavis] Improved wording for Data Directory index and structure sections
[mdavis] Improved wording for Static files tutorial
[jdeolive] updated programming-guide ows-service tutorial
[jdeolive] GEOS-5171, having file upload endpoint support loading FileDataStoreFactorySpi interfaces as well as built in defaults, patch contributed by Rob Marianski
[mdavis] Fixed short section underline
[mdavis] Created Working with SLD page
[mdavis] Added logs section, links, more description to Structure of Data Dir
[mdavis] Fixed links to Working with data sections
[mdavis] Adding file for Working with SLD page
[mcr] Security role rework
[mdavis] Corrected/clarified some ECQL syntax rules
[jmarinotero] GEOS-5166: Extent WPS chaining documentation
[mdavis] Added configuration for Rendering Transformation processes BarnesSurface, Heatmap, PointStacker
[mdavis] Added missing legendoptions graphic
[mdavis] Added parameter lists for WMS operations, spec links, wording improvements
[jdeolive] changing default for DIST_USER
[mdavis] Excel extension formatting improvements
[victortey] GEOT-3454: Geoserver app-schema: types that only have client properties attributes are always skipped : fix mapping file to be schema valid
[mdavis] Improved wording for WPS Operations
[aaime] Relax the test for complex feature collection wrapping
[jmarinotero] GEOS-5189: Reorganize WPS section in programming guide. Add Hello World WPS tutorial
[ischneider] [GEOS-5193] DimensionHelper eats exception details - resolve
[mdavis] Added more details on spatial predicates in ECQL
[mdavis] Add Rendering Transformation section to the User Guide
[bencaradocdavies] Fixed argLine for -Papp-schema-online-test so -Dtest.maxPermSize is honoured (needed for 64-bit)
[jdeolive] GEOS-5172, fixing search dial filter on tables in dialogs on webkit and ie browsers
[mdavis] Added more content, examples to Rendering Transformation doc
[mdavis] Added contour labelling to Rendering Transform example
[bmmpxf] Adding new Ruby REST page, and update to Java REST page
[aaime] [GEOS-4608] Dynamic symbolizers not evaluated in KML output for relative path ExternalGraphics, patch by Christopher S. Dillard, tests by yours truly
[aaime] [GEOS-5198] Broken link in user documentation, patch by Michael Romero
[aaime] [GEOS-5199] Web UI documentation needs some updating, patch by Michael Romero
[aaime] [GEOS-4175] REST service to show a list of fonts available to the java runtime, documentation patch
[aaime] [GEOS-4209] Add a way to control the meta tile output format cache so that external apps can drop it on demand
[aaime] [GEOS-3901] Have rest endpoint display a note when no rest extensions are installed, patch by David Winslow
[jdeolive] updating SecuredGetFeatureTest to store rules
[jdeolive] adding wagon-webdav extension
[jdeolive] GEOS-5201, deadling with layer name clases with local workspaces, patch submitted by Rob Marianski
[mdavis] Improvements to Rendering Transform text
[mdavis] Text improvements in SLD Labelling page
[jdeolive] GEOS-5200, adding .gitignore files
[jdeolive] changing default configDirectory value to point out to data directory three levels out
[jdeolive] GEOS-5200, updating revision info to use git-commit-id plugin, and removed references to all svn revisions
[jdeolive] GEOS-5200, updating documentation to reflect switch to git
[jdeolive] fixing typo in checkout docs, co -> clone
[jdeolive] GEOS-5200, updating release scripts for git switchover
[jdeolive] updating version numbers to 2.3, gt version to 9
[jdeolive] updating hudson release script
[jdeolive] fixing branch/revision info for pom projections, setting skipPoms = false for git commit id plugin
[jdeolive] creating placeholder file for Java directory in mac installer root
[jdeolive] proper setting of author on commit
[jdeolive] using single quotes for author parameter
[fgdrf] removed svn url from Codebase stucture
[andrea.aime] [GEOS-5027] DescribeFeatureType contains all attributes despite attribute limitations setup by the security subsytem
[gabriel.roldan] update <scm> section in main pom.xml file to reflect the move to github and specify different urls for fecth and push as recommended at http://maven.apache.org/scm/git.html
[jdeolive] using git config to set author for release commits rather than --author option
[mdavis] Minor fixes to Dev Source page
[jdeolive] GEOS-5212, adding EPSG:102113 as an alias for spherical mercator
[jdeolive] added init scripts to cite data dirs needed for nightly cite testing
[jdeolive] fixing modules with typo in test scope dependencies, so they don't end up in the final build
[andrea.aime] [GEOS-5168] Metadata Links should be in WCS capabilities, patch by Michael Romero with tests and additional fixes of my own
[andrea.aime] [GEOS-4323] Documentation for translating the GeoServer UI
[jody.garnett] Update quick start with clone instructions for git
[jdeolive] setting init.sh scripts executable
[mdavis] GEOS-5211 - Fix for duplicate processes shown in WPS, with test to detect this
[jdeolive] removing doc artifact descriptor as no longer needed
[jdeolive] GEOS-5202, encoding crs without strictness to be lax about persisting CRS objects that we can actually handle
[jdeolive] using proper method to lookup db.properties file and added some debug logging
[mdavis] Dev Guide Git reference edits
[cdwinslow] Include filename in stack trace when coverage loading fails in MockData::coverageInfo
[mdavis] Dev Guide Source section text changes
[mdavis] Improved wording of WPS Process section
[cdwinslow] Use a distinct function for extracting zip archives vs. copying flat files
[jdeolive] GEOS-5167, fixing handling of localhost metadata urls, patch contributed by Michael Romero
[jdeolive] changing reference to svn from quickstart
[jdeolive] ensuring extensions deployed at release publish time
[jdeolive] GEOS-5167, #3 - moving utility class to central location to be used by all services
[jdeolive] deploying communityRelease modules at release time
[jdeolive] GEOS-5217, updating geoserver release docs
[andrea.aime] [GEOS-5208] WPS chaining may result in a NPE if the inner process attempts to report progress
[jdeolive] updating cite test guide and removing old obsolete community module
[mdavis] Added Dev Guide section on implementing Rendering Transformations
[gabriel.roldan] GEOS-5001/GEOS-5121: fix CatalogImpl and CatalogImplTests assumptions that layer names can be changed and saved without saving the resource, and that more than one layer can be added for a resource
[jdeolive] GEOS-5219, using path only syntax to indicate back reference for metadata link url
[mdavis] GEOS-5021 - Fix for SLDs with RenderingTransformations which create attributes fail SLD attribute name checking
[daniele.romagnoli] GEOS-5227: validate pool sizes changes on submit
[mromero1509] fixed a few typos in the docs
[jdeolive] reviving the spatialite community module
[gabriel.roldan] fixes #GEOS-5162: label for the CachedLayers 'Actions' column and remove ellipses from seed and truncate labels
[jdeolive] switching wms 1.3 schema to w3c xlink
[jdeolive] adding w3c xlink schema and updated wms caps validation test
[jdeolive] added some developer docs for how to contribute a patch
[daniele.romagnoli] GEOS-5231: Document the coverage settings page
[cdwinslow] Parse 'recalculate' parameter by splitting on comma, not apostrophe
[gabriel.roldan] peg master to GWC 1.3-SNAPSHOT
[gabriel.roldan] fixes #GEOS-5039: new Tile Caching menu with entries for tile layers, global gwc defaults, gridsets, and disk quota
[gabriel.roldan] fixes #GEOS-4980: implement GeoServer tile layers configuration through GWC's REST API, full documentation and extensive unit tests
[gabriel.roldan] more test coverage for GWCSettingsPage (relates to GEOS-5039)
[gabriel.roldan] GEOS-5235: write specific gwc response headers when tile request is handled by the direct WMS integration interceptor
[gabriel.roldan] Support the If-Modified-Since request header in direct WMS integration mode and return a 304
[Victor.Tey] Change System.out.print to use logger instead.
[Victor.Tey] Remove sql insert logging. Change logger.info of files to depend on boolean printDoc
[gabriel.roldan] fixes #GEOS-4993: add unqualified layer names to TileSets if a LocalWorkspace is present, and several unit tests.
[gabriel.roldan] update the new gwc icons for the tile layers and gridsets pages, and set the gwc settings page menu entry title to 'Caching Defaults'
[mdavis] User Manual front page wording fix
[Ben.Caradoc-Davies] GEOS-5135: Incorrect canonical schema location in WFS 2.0.0 GetCapabilities response
[mdavis] User Manual - clarified warning for Dynamic Symbolizers
[jdeolive] added gwc revision info to build
[Ben.Caradoc-Davies] Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4.
[cdwinslow] Remove accidentally committed LDAP class
[cdwinslow] Add 'abstract' modifier to AbstractSecurityWicketTestSupport
[cdwinslow] Fix typo in container setup instructions.
[aaime] Move the controlflow documentation in the extensions section
[aaime] [GEOS-5242] Improve logging for control-flow
[aaime] [GEOS-5243] Using both user and ip flow controllers leads to ip users being locked out
[riniangreani] App-schema: enable feature chaining for geometries.
[cdwinslow] Correct typo in registration bean for RememberMeAuthFilterPanel
[cdwinslow] Tighten type constraints on AuthenticationFilterPanel[Info]
[jdeolive] using Implementation-Version, rather than Git-Version from gwc-core manifest
[gabriel.roldan] use a case insensitive map for GetMapRequest's httpRequestHeaders. Tomcat lower-cases their names
[gabriel.roldan] lower logging severity of geoserver tile layer loading
[jdeolive] build script tweaks, ensuring git user/email set propertly, and tweaks around merging into release brnach
[juan.marin.otero] GEOS-5122: REST API enhancements
[jdeolive] ensuring specified revision on branch being released from
[mdavis] User Manual - edits to Data Dir page
[mike] New framework for tile caching section of the docs
[mike] Updates and edits to GWC REST docs
[mike] Edited UI text for Tile Caching section
[mike] Added docs on the new Tile Caching section in the UI
[mike] Removing unecessary blank file
[mike] Hiding todos and copyright year in user docs config file
[christian.mueller] Adding security documentation
[andrea.aime] GSIP77, dev documentation changes
[mike] Resize to fit images in docs
[mromero1509] Added security module to src assembly and fixed path to minimal data_dir
[mike] More details about the improved GWC integration
[jdeolive] updated community module doc, web/pom.xml -> web/app/pom.xml
[jdeolive] tweaked time boxed release schedule docs
[mike] Added GWC If-Modified-Since info, plus typo fixes
[mike] GWC response headers actually work with direct WMS integration
[Victor.Tey] Update the release guide documentation. updated gained from releasing GS 2.2-RC2
[Victor.Tey] Add documentation on updating GeoServer wiki to reflect new releases
[daniele.romagnoli] -GEOS-5226: CoverageAccessSettings and JAI page and global change events handling fix
[dwinslow] Add missing test dependency for web/gwc
[jdeolive] make wms describeLayer strip prefix for workspace
[jdeolive] GEOS-5016, fixing test case based on assumptions of workspace != namespace
[christian.mueller] Fix GEOS-5259
[jdeolive] GEOS-5261, fixing typo checking for fallback on rule name as legend title
[mdavis] GEOS-5244 - Added request parameter name to WPS Request Builder
[mdavis] Fix unit test to match changed JTS:area process metadata
[andrea.aime] [GEOS-5209] Avoid altering attribute name case in GetFeatureInfo HTML template
[andrea.aime] [GEOS-5266] Coverage parameters may fail to be properly converted
[christian.mueller] GEOS-5256 obtaining a master password during migration
[andrea.aime] [GEOS-5263] Allow the administrator to select which processes to expose to the users
[andrea.aime] Fixing the buid
[Ben.Caradoc-Davies] GEOT-4160: Support parsing srsName in OGC HTTP URI format
[Ben.Caradoc-Davies] Fix build failure caused by GEOT-4224 process identifier changes
[andrea.aime] [GEOS-5263] followups, rename filter removing processes with inputs we cannot decode with PPIO and sort the process names in the selector page
[jdeolive] declaring bean dependency on spring process factory to ensure the WPSInfo object gets initialized properly on startup
[jdeolive] Moving process group/factory initialization out of bean and into xstream loader.
[jdeolive] consistent use of processGroup vs processFactories property
[jdeolive] dropping info suffix of xstream mapping
[jdeolive] initlializing process groups when creeating from scratch
[jdeolive] added WPSLifecycleHandler class to reconsile process list on reload, handling pre 2.0.x data dir conversion
[mdavis] GEOS-5272 - Display line numbers in SLD validation error messages
[mdavis] Edit process metadata
[walkermatt] Updated name of template referenced in the Freemarker tutorial.
[mdavis] better wording in User Guide Style Reference Rule section
[andrea.aime] Removing the enumeration converter factory
[andrea.aime] Increase the likelyhood of using a buffered operation factory in the code, since we consistently ask for lenient datum shifts
[niels] Support three-dimensional Envelopes and Bounding Box filters GEOS-5148
[niels] GEOS-5223 WFS reprojection of 3D point and 3D Linestring
[Ben.Caradoc-Davies] Updated PSC membership list
[walkermatt] Attempt at clarifying template lookup using an example
[andrea.aime] [GEOS-2801] WCS Reprojection using an XML GetCoverage request seems to be somewhat broken (WCS 1.1.1)
[mromero1509] [GEOS-5218] Allow the WMS elevation units to be editable
[christian.mueller] Fixing GEOS-5275
[dwinslow] Support reduced accuracy in WMS TIME parameter
[dwinslow] Revert "Support reduced accuracy in WMS TIME parameter"
[christian.mueller] Adding security information on the welcome page of an admin
[christian.mueller] fixing GEOS-5281
[andrea.aime] Fixing build
[christian.mueller] GEOS-5278
[andrea.aime] [GEOS-5283] Bin package will OOM after a few demo requests
[andrea.aime] Forgot a bit in the windows startup script
[andrea.aime] [GEOS-5286] Tasmania cities preview fails due to empty bbox
[christian.mueller] Enhancing security documentation for role services
[jdeolive] Adding a filter to provide open entity manager in view support for JPA
[jdeolive] Added comments to OpenEntityManagerInViewFilter
[christian.mueller] Updating master password documentation
[andrea.aime] [GEOS-5287] KML with superoverlays generates empty documents
[andrea.aime] [GEOS-5284] wfsTransactioninsert demo request fails
[dwinslow] Re-introduce reduced accuracy time parsing in WMS and WCS
[simone.giannecchini] GEOS-5289
[jdeolive] Added HTTP Referer field.
[jdeolive] Broke test cases for MonitoringFilterTest into smaller parts.
[jdeolive] Trim request bodies to max length of Hibernate persistance DB and fixed related lazy initialization bug and test case bug.
[jdeolive] Updated docs for configuing DB for Monitoring extension.
[jdeolive] Fixed HTTP Response code handling
[jdeolive] Added CSV quoted text implementation.
[jdeolive] Updated documentation on Monitoring extension's reporting API.
[jdeolive] Changed referer property to httpReferer.
[jdeolive] Made maximum body length configurable and documented configuration option.
[jdeolive] Optimizations to CSV output.
[jdeolive] Upped size of HTTP_REFERER field in Hibernate mappings from default 255 to 4096
[andrea.aime] Basic service insfrastructure for CSW
[rob] update link to to download optional extensions
[andrea.aime] Adding KVP parsing for CSW GetCapabilities, refactoring the acceptVersions/Formats to avoid duplicated code around WFS/WCS/CSW
[jdeolive] GSIP-69: Catalog and CatalogFacade method additions and default implementation for the in-memory catalog
[jdeolive] GSIP-69: port GeoServerHomePage to use Catalog.count() instead of Catalog.getWorkspaces/Stores/Layers().size()
[jdeolive] GSIP-69: port WMS GetCapabilities 1.3 to extended Catalog API
[jdeolive] GSIP-69: port StatusPage to use Catalog.list() instead of Catalog.getDataStores()
[jdeolive] GSIP-69: port LayerPage to Catalog API extensions
[jdeolive] GSIP-69: catalog stress tool on the demo module to aid in bulk creation of catalog resources and stress test the new API and implementations
[jdeolive] GSIP-69: jdbc catalog backend using the db as a key/value store where the catalog objects id are the keys and its xstream xml representation the values
[jdeolive] GSIP-69: Some fixes around handling of misconfigured layers in WMS capabilities when skip broken config is selected.
[andrea.aime] Adding GetCapabilities POST request support and reader tests
[andrea.aime] Adding support for CSW DescribeRecord parsing, moving NamespaceKVPParser to main to share it, make it throw proper ServiceExceptions, adding common OWS exception code constants to ServiceException
[andrea.aime] Adding KVP/XML parsing for GetDomain
[andrea.aime] [GEOS-1689] WCS output formats should be pluggable
[daniele.romagnoli] GEOS-5292: fixing sldService
[andrea.aime] Adding support for parsing KVP/POST style GetRecords requests
[andrea.aime] Adding instructions to create the download page in the wiki
[andrea.aime] Small fix to the download page title
[andrea.aime] [GEOS-5246] cumulative patch
[andrea.aime] [GEOS-5248] cumulative patch
[andrea.aime] Fixing formatting issues in GEOS-5248 and GEOS-5246 patches
[andrea.aime] Adding the CSW Record FeatureType and a test proving we can build a feature against that type
[niels] Support three-dimensional Envelopes and Bounding Box filters GEOS-5148 Online Test Bug Fix
[Ben.Caradoc-Davies] Updated and sorted the PSC list (by full name, so first personal name is most significant, with LC_COLLATE=C)
[ccancellieri] Fix setting contentype and doc.
[andrea.aime] Refactoring the csw module so that we can create a simple implementation of the CatalogStore without having csw-core necessarily embed/depend on it
[andrea.aime] Adding support for bbox in the record features, fixing the type and attribute builders to allow the creation of also simple attributes
[ccancellieri] junit tests improvements
[jdeolive] GEOS-5301 - handling exception back from FeatureSource.getInfo()
[jdeolive] GEOS-5298 - Handling WPS Execute when input layer name clashes.
[andrea.aime] Basic record reading and feature generation (no filtering, sorting, property subsetting and so on) working in SimpleFeatureStore
[andrea.aime] Adding support for filtering and paging in the simple catalog store, sorting and attribute selection still missing
[jdeolive] Added stubs for new catalog api methods
[andrea.aime] Sorting and attribute selection support in SimpleCatalogStore
[andrea.aime] Adding support for domain extraction to SimpleCatalogStore
[andrea.aime] Wiring up the catalog store with the service, first half of the DescribeResponse implementation
[alessio.fabiani] - CSW: GetCapabilities 1st draft
[mdavis] Better doc for operation parameters, minor edits
[andrea.aime] Fixing compile error, removing FES20 factory reference, calm down generics related warnings
[andrea.aime] Adding support for CSW DescribeRecord, with tests
[nielscharlier] Update App-schema online Documentation for 3D Testing
[mdavis] Edits to User Guide WPS operations reference
[mdavis] Added property function to User Guide filter function reference
[alessio.fabiani] - CSW: GetCapabilities improvements and test cases
[riniangreani] Support 3D tests with full app-schema-online-test option.
[mdavis] Added limit of 255 ColorMapEntrys to User Guide SLD sections
[jdeolive] GEOS-5306 - unadapting transaction element objects before passing into transaction listeners/plugins
[christian.mueller] updates to security and web admin interface documentation (#SUITE-30)
[andrea.aime] CSW D.C. Record encoding and GetRecordsRseponse encoding, with tests
[niels] GetRecordById Kvp Parser + Test
[jdeolive] increasing PermGen settings for mac installer
[andrea.aime] Added code to run GetRecords, tests are still missing
[alessio.fabiani] CSW: GetDomain first draft
[alessio.fabiani] CSW: GetDomain - ParameterName
[mike] Adds MaxPermSize setting to Windows installer
[christian.mueller] Fixing GEOS-5309
[christian.mueller] Fixing broken build due to GEOS-5309
[alessio.fabiani] CSW: fix tests
[andrea.aime] Adding tests and fixes for GetRecords hits mode and simple tests for results mode
[andrea.aime] Better support for record filtering
[andrea.aime] Making CSW GetCapabilities and DescribeRecord CITE compliant
[andrea.aime] Properly handling spatial filters in CSW GetRecords
[alessio.fabiani] - CSW: getDomain.propertyName
[ccancellieri] GEOS-5279
[niels] csw remove obsolete file
[andrea.aime] Adding support for GetRecords validate mode
[alessio.fabiani] - CSW: GetDomain finalize
[simone.giannecchini] GEOS-5308
[alessio.fabiani] Fix WFS KVP parser
[ccancellieri] Improved IM filter junit tests
[Ben.Caradoc-Davies] Workaround for app-Schema PropertySelectionTest failure caused by 4615daa694a5d84e
[mdavis] Improved User Manual WMS Animator section
[mdavis] Added params sld and sld_body to User Manual WMS Reference
[alessio.fabiani] cleanup
[niels] CSW: implementation of getrecordbyid
[andrea.aime] Fixing time regexp following up strict date parsing introduced in GEOT-4263
[andrea.aime] Fix GetRecordById response (it's different than the GetRecords one) and improve exception reporting and elementsetname handling
[andrea.aime] Adding data dir for CSW CITE tests
[alessio.fabiani] - CSW: GetRepositoryItem KVP reader
[alessio.fabiani] - CSW: GetRepositoryItem - draft (incomplete)
[andrea.aime] Adding a profile to run CSW with the simple store
[andrea.aime] moving the filter factory from the test context to the main one
[andrea.aime] Removing files that should not have been committed from the csw data dir
[mdavis] Formatting for WMS Animator User Manual section
[andrea.aime] Adding comments to the CatalogStore interface, moving the static vars describing the possible values for parameters from CatalogCapabilites to GetCapabilities, renaming CatalogCapabilities to CatalogCapabilities to stress the fact it's the caps of the store, not of the entire service
[andrea.aime] Fix GetCapabilities to use the store own queriables and domain queriables, and finished up the support for GetRepositoryItem
[jdeolive] moving cas to extension
[jdeolive] updating release scripts to forgo idea of main release branch, working directly from release branch, pushing up tag in isoltation
[jdeolive] matching jira version name exactly
[jclark] Fixed error in loading multiple shapefiles example (#SUITE-1157)
[hennr] updating SCM location; add lin/win instructions
[hennr] update CI server description
[jclark] renamed datastore for loading multiple shapefiles example
[mdavis] Fixes to User Guide Filter function reference
[christian.mueller] Cumulative fix for
[mdavis] Minor fixes to User Guider Animator tutorial
[mdavis] Improved User Guide SLD Filter reference page
[mike] Copyediting GeoWebCache sections
[jdeolive] tweaked logging null app context case, from severe to warning
[jdeolive] logging data directory at INFO, and added setter for catalog
[jdeolive] added constructor taking a GeoServerDataDirectory instance directly
[jdeolive] updated constructors to take catalog interface, rather than impl
[jdeolive] added flag to turn off extended validation, needed for system test setup
[jdeolive] safely disposing a resource from its cache, and fixing issue not closing file stream when loading schema.xml/xsd file
[jdeolive] handling case during cascade delete of a resource not having any layers that reference it
[jdeolive] fixing issue not closing file stream
[jdeolive] factored out directory removal, and made null safe
[jdeolive] fixing issue not checking for non-existance of workspaces directory
[jdeolive] updated how id for service and settings objects are handled, also ensured collections resolved
[jdeolive] added ServiceLoader.create() method for public api to create a service config object from scratch
[jdeolive] added flag to forgo encrypting password fields, and refactored force logging level
[jdeolive] adding constructors to xml security config objects for cloning from another instance
[jdeolive] exposing spring app context and added accessors for data access and service access daos
[jdeolive] added method to remove named filter from all chains
[jdeolive] refactored to a single method for looking up beans from spring context, and getting app context from security manager rather than grabbing directly
[jdeolive] made class public for testing purposes
[jdeolive] not setting ServiceInfo id's
[jdeolive] added method for removing all stored qqueries
[jdeolive] changing default value to something in allowable range
[jdeolive] updated to take root directory directly
[jdeolive] falling back to min/max if range is null
[jdeolive] GSIP-80 - porting tests to JUnit4 and new system and mock test base classes
[jdeolive] GSIP 80 - adding developer docs to describe geoserver testing
[mike] Copyedit review of GWC config section
[dyskante] Don't add virtual table if the virtual table's already in the datastore
[jdeolive] Added adapt method for TransactionResponse
[jdeolive] added scripting modules
[andrea.aime] Fix the build for maven 3.0.4 on Windows, won't work without a reference to the location of the parent module
[andrea.aime] Modify test to account for slower build boxes (or lower granularity in Windows timers, not sure which one)
[christian.mueller] Migrating CAS tests to the new test framework
[andrea.aime] Allow windows machines with broken graphic cards/drivers to perform the build nevertheless
[andrea.aime] Make sure to release the input stream for the property file reader, otherwise on windows it won't be possible to delete it and the build will fail
[andrea.aime] Make feature info deeply release the coverage used to build the output, fix a test that was not closing the feature iterator
[andrea.aime] Make sure to release the coverage used for GFI tests, otherwise it won't be deletable
[andrea.aime] Do not depend on the @before execution order to do the revert of the layer modification name
[mdavis] Added links to User Manual WMS Reference
[mike] Updating static files tutorial
[jdeolive] GEOS-4857 - fixing connection leak in GetFeatureINfo templates
[ccancellieri] added check for null readParameters and fix format
[riniangreani] Applying GSIP 80 to webservice-test
[mdavis] Improved text in User Manual WMS Configuration
[christian.mueller] Adding a documentation page for Postgis raster
[christian.mueller] GEOS-5343
[jody.garnett] Delegate setBBox( Evenlope ) to match change in GetMapRequest API
[aaime] [GEOS-5345] Grid coverages generated by WCS 1.0 and 1.1 are not getting disposed at the end of the call
[aaime] [GEOS-5346] WCS 1.1 resolution estimation broken on reprojection, plus making sure coverages are properly disposed during tests
[aaime] [GEOS-5347] RestConfig leaves files opened when downloading stores as zip
[aaime] Removing debugging statement that won't work on windows
[Ben.Caradoc-Davies] Revert "[GEOS-5346] WCS 1.1 resolution estimation broken on reprojection, plus making sure coverages are properly disposed during tests"
[Ben.Caradoc-Davies] Revert "[GEOS-5345] Grid coverages generated by WCS 1.0 and 1.1 are not getting disposed at the end of the call"
[dwinslow] Update pager widget when searching
[dwinslow] Clean up passwords before testing password config
[dwinslow] Fix some typos in error messages
[dwinslow] Avoid unhandled exception in dimension handling
[dwinslow] Adjust WMS tests for API change
[andrea.aime] [GEOS-5354] wms_scale_denominator env variable might not be set when making GetMap larger than world
[andrea.aime] [GEOS-5345] Grid coverages generated by WCS 1.0 and 1.1 are not getting disposed at the end of the call
[andrea.aime] [GEOS-5346] WCS 1.1 resolution estimation broken on reprojection, plus making sure coverages are properly disposed during tests
[christian.mueller] GEOS geoserver username/password filter
[aaime] [GEOS-5364] WPS code may fail to release coverage objects, which may result in file locks on windows
[christian.mueller] Temporary fix for GEOS-5353
[aaime] [GEOS-5364] WPS code may fail to release coverage objects, which may result in file locks on windows, adding file I forgot on the disk
[jdeolive] [GEOS-5324] Unable to configure or read already configured layergroup with name in the form 'test:foo', #34 from ccancellieri
[jdeolive] GEOS-5271 - Added wps process factory for deprecations to handle recent reorg in GeoTools.
[ccancellieri] GEOS-[5346 5247] Cumulative fixes
[jdeolive] making git commit id plugin less verbose
[jdeolive] GEOS-5315, resetting mime type on form change
[dwinslow] Layout fixes for IE
[mike] Updating developer guide to require JDK 6
[davide] GEOS-4970: fixed ScaleRatio value when using custom DPI
[jdeolive] rolling back upgrade of git-commit-id plugin
[mdavis] Improved description of User Guide SLD Reference PointSymbolizer
[dwinslow] Make table styling more consistent cross-browser
[dwinslow] Use the MIME subtype rather than general type
[mike] Adding two new steps to the release process
[ccancellieri] fixes wfs getcapabilities character escaping problem
[dwinslow] Fix erroneous error message in default filename guesser
[dwinslow] Revert filename guessing changes (GEOS-5366)
[mdavis] Minor text and data fixes to User Guide REST cURL section
[andrea.aime] [GEOS-5374] New XSLT based WFS output format generator, configuration repository
[andrea.aime] [GEOS-5376] Line sizes with UOM in legend decoration are doubly scaled when using DPI
[gabriel.roldan] Added check for geometryless layers
[gabriel.roldan] Added Type to mock layers, defaulting to RASTER. Required to have existing test cases pass with new check.
[gabriel.roldan] Moved WMS exposability check to more general location.
[gabriel.roldan] added test case for geometry coloumn check for layer to cache
[gabriel.roldan] fixes #GEOS-4648: make GWCInitializer ignore geometryless layers and LayerCacheOptionsTabPanel present a label instead of the tile layer config panel for geometryless layers
[aaime] Do no depend on execution order
[aaime] Make mock ready for jdk 7, where every insertion in a TreeSet causes the inserted element to be compareTo itself
[aaime] JDK7 TreeSet 'compare on insert' fix
[aaime] Don't do a treeset of objects that are not comparable (QName is not)
[aaime] Null safe check for ids in keys, which are generated as we play with the GUI on readers that are still not saved in the catalog (and that need proper disposing like all others)
[jdeolive] GEOS-5377, removing explicit casts to simpleFeatureCollection when not necessary
[davide] added Title and Abstract to LayerGroup
[davide] added LayerGroup Title and Abstract to WMS GetCapabilities
[gabriel.roldan] fix #GEOS-5386: avoid unpredictable lookup on non existent tilelayer in GWCIntegrationTest.testBasicIntegration
[aaime] Make the test independent of the order execution, on jkd7 testAuthentificationWithoutUserGroupService is executed last and fails, could not find a simple way to undo the changes performed in testAuthentificationWithUserGroupService
[aaime] Don't cache coverage readers if the key is null, they would end up overlapping and we end up with NPE while cleaning the cache. Oddly enough these symptoms seem to surface only with JDK 7
[aaime] Roll back changes to local maxes so that the test is really independent of test methods execution order
[aaime] Fix broke test expectations unveiled by fixing the coverage reader caching in resource pool
[aaime] Rollback changes to the CITE workspace URI so that the test is independent of test method execution order
[aaime] Revert layer deletion on test startup to avoid the test being dependent of the execution order of test methods
[jdeolive] updated preUpdate and postUpdate transaction hooks, passing in changed properties
[jdeolive] added decorators for python wfs transaction hooks
[jdeolive] ressurecting python community module, adding back to nightly builds
[jdeolive] removing reference to old python module
[jdeolive] adding script-core module to python artifact
[jdeolive] adding geoscript-py jar to python artifact
[ksmith] plug in the url manglers with gwc's hook
[ksmith] added WMS and WMTS support for URL mangling
[ksmith] Fix for URL mangling base paths, and adding WMS and WMTS mangling
[mdavis] Added User Guide SLD Reference pages for layers and styles
[jdeolive] added link to Christians master thesis to security docs
[mdavis] Added User Guide info for styling mixed geometry using dimension function
[shane] Upgrading Apache poi to 3.8 in excel plugin
[mdavis] User Guide - edits to Mixed Geometry Styling section
[Ben.Caradoc-Davies] [GEOS-5352] Use JDK Xalan to reduce PermGen consumption
[jdeolive] GEOS-5157, taking configured media type into account when generating capabilities
[jared.erickson] Exclude old json-lib version from GWC
[andrea.aime] [GEOS-5374] New XSLT based WFS output format generator, transformation and rest resources
[andrea.aime] [GEOS-5394] Put per workspace service configuration under a workspaces container
[andrea.aime] XSLT output format, finishing touches
[andrea.aime] XSLT output format, documentation
[andrea.aime] Adding XSLT module to community release
[alessio.fabiani] - Allowed Import Process to import rasters too
[mdavis] User Guide ECQL Ref - fixed doc for BBOX
[andrea.aime] [GEOS-5395] Catalog reload breaks GWC integration, update sequence upgrade and namespace/workspace consistency
[andrea.aime] [GEOS-5396] KML scale computation does not follow OGC recommendations
[christian.mueller] proxy auth documentation
[davide] GEOS-3885: REST config for Freemarker templates
[davide] GEOS-3885: added index mapping and improved tests
[ksmith] GEOS-5271:Added Heatmap and BarnesSurface to DeprecatedProcessFactory
[christian.mueller] Fix for GEOS-5402 and GEOS-5388
[dwinslow] Revert "Revert filename guessing changes (GEOS-5366)"
[davide] GEOS-3885: added documentation
[jody.garnett] Fill in a header comment for pom.xml files
[davide] GEOS-5380: fixed documentation
[jody.garnett] Updates for GeoTools FeatureCollection api changes
[jody.garnett] Fill in missing headers, and provide a correct header for Browser (GEOS-5456)
[aaime] [GEOS-5378] Rest config and ogr2ogr failures under JDK7
[aaime] Clean up workspaces created in other tests during test setup to avoid order dependence in tests
[andrea.aime] [GEOS-5464] Intermittent build failure in org.geoserver.catalog.impl.CatalogImplTest.testGetLayerByIdWithConcurrentAdd
[jody.garnett] Correct the header for GEOS-5457 based on andrea's clarification
[jody.garnett] Fix up documentation copyright except for scripts which mention david winslow
[jody.garnett] CITE RST file added (so readable by github) capturing the OGC software notice GEOS-5465
[jody.garnett] format notice correctly under data license
[jody.garnett] Fix up default eclipse generated headers contributed by refractions research. GEOS-5455
[jody.garnett] Add header comment to applicationContext.xml files GEOS-5467
[jody.garnett] Fix up header from GeoTools GEOS-5416
[jody.garnett] Fix up header to reflect a file with an GeoTools LGPL history GEOS-5459
[jody.garnett] Fixup some code that referenced GeoTools linage GEOS-5468
[jody.garnett] Fix reference to GeoTools code used by wps GEOS-5469
[jody.garnett] Patch file accidentally committed
[jody.garnett] Header for component builder
[jody.garnett] Initial data directory readme
[jody.garnett] Remove wfsv implementations GEOS-5471
[andrea.aime] Upgrading code to comply with changes in feature collection
[andrea.aime] Make the test be independent of test method execution order
[jody.garnett] add links to the various build servers and notification email groups aaime has set up
[jody.garnett] Documentation fixes for a range of license issues including Apache 2.0 and Apache 1.1 see GEOS-5454, GEOS-5460, GEOS-5470, GEOS-5453
[jody.garnett] no longer needed
[jclark] Fixes for missing references and formatting errors
[christian.mueller] Adding documentation about role source
[andrea.aime] Fixing tests passing by accident
[andreas.hocevar] Proper handling of POST/PUT bodies (#fixes #GEOS-4173)
[davide] GEOS-4982: LayerGroup visibility issue
[mdavis] User Guide WFS Output Formats - editing, updated content, links
[alessio.fabiani] enabled set style on coverage import process
[mdavis] Added note about using global service to User Guide App-Schema doc
[jdeolive] Moved device-spatial coordinate space transformation methods to utility class
[jdeolive] Having monitoring extension capture bounding box information, closes #38 courtesy of Kevin Smith
[Ben.Caradoc-Davies] Added app-schema-tutorial data provenance documentation
[peter.hopfgartner] adapt DXF output to current API
[peter.hopfgartner] Revert "adapt DXF output to current API"
[peter.hopfgartner] PPIO for dxf file format
[peter.hopfgartner] corrected comments on code authoring
[jody.garnett] Sort out README files for data directories
[peter.hopfgartner] increase number of digits, so that maps can be exported even in latlong
[peter.hopfgartner] fix typo
[peter.hopfgartner] quick fix, a false reference to a block "0" was generated. DWG TrueView stumbled on this
[peter.hopfgartner] white space
[jody.garnett] New screen snap for Run GeoServer from Eclipse
[mdavis] GEOS-5479 - Fixed User Guide Styling mixed geometry Literal closing tag
[etj] Adding wcs2.0 community module.
[peter.hopfgartner] port ti new FeatureCollaction API
[etj] WCS2.0 getCapabilities implementation
[andrea.aime] [GEOS-5483] json output in WPS extension does not work due to missing library
[jody.garnett] EnvelopePanel and ReferencedEnvelope fixes for GEOS-5474 and GEOS-5475
[andrea.aime] Adding the schemas required to parse a wcs 2.0 request/response and a test showing that the currently generated caps document is invalid
[andrea.aime] Fix logic typo in png8 quantizer
[etj] WCS2.0 getCapabilities fixes. Handling OWS2.0 exceptions.
[jdeolive] setting Monitor#server regardless of enabled/disabled
[etj] WCS2.0 revising OWS2.0 exceptions.
[etj] WCS2.0: util class for encoding/decoding a Resources in a NSName
[mdavis] User Guide WPS - added note about WFS limit
[andrea.aime] Adding WCS 2.0 Getcoverage subset kvp parser
[andrea.aime] Add backwards compatibility for layer group title and abstract
[andrea.aime] More tests for get caps, and the subset kvp parser for Getcoverage
[andrea.aime] Fixing paths to on disk schemas
[dwinslow] Add some examples of specifying the geometry property to the docs
[etj] WCS2.0: describeCoverage implementation (WIP)
[mdavis] User Guide - added note about Oracle SID vs Service
[jdeolive] added getters for running and blocked requests
[jdeolive] exposing running and blocked requests from underlying control flow callback
[etj] WCS2.0: describeCoverage: added gml:boundedBy node
[andrea.aime] Adding support for multiple params with the same key in KVP requests
[andrea.aime] First bits of support for GetCoverage
[andrea.aime] Add a method to test ows 2.0 exceptions
[andrea.aime] Adding support for (very basic) GetCoverage 2.0
[dwinslow] Correct MIME information in CSS property listing
[etj] WCS2.0: describeCoverage: added gml:domainSet node
[etj] WCS2.0: describeCoverage: added gml:domainSet node (fixed typo)
[andrea.aime] Adding sample request with geotiff extensions
[andrea.aime] Add test for DescribeCoveage XML parsing
[hennr] Update src/README.txt
[andrea.aime] Have the image tests also run in geoserver provided perceptualdiff is around
[jared.erickson] Add GeoScript to the Groovy Script module
[jared.erickson] Add license headers
[jared.erickson] Fix failing test
[andrea.aime] Adding GeoSolutions as provider for raster data
[mike] Resolving Windows service param conflict (so MaxPermSize can be changed)
[mike] Updates to scripting extension install docs
[andrea.aime] Adding 2.0.1 as a possible version... static init of versions, ugh, yet making a dynamic lookup seems sort of impossible in the service loader
[andrea.aime] Some amendments to make wcs 2.0 cite tests work against a 2.0.1 version
[andrea.aime] Use canonical schema locations for the moment, add the xml profile
[mdavis] Clarifications to User Guide Labelling section
[andrea.aime] Add support for custom dimensions.
[andrea.aime] Add units attribute for validation purposes.
[andrea.aime] Confine DIM_ prefix processing to core WMS handling code, so that the reader and other protocols use the original (unprefixed) dimension name.
[andrea.aime] Adapting custom dimension work to Dec 2012 trunk code
[andrea.aime] Adding GUI for custom raster dimensions, and handling units and unit symbols
[andrea.aime] Support for WCS 2.0 GeoTiff encodining params and fix the mime type
[andrea.aime] Adding support for the GML grid output format
[andrea.aime] Disabling a test that keeps on breaking the build. The catalog subsystem is not thread safe, a test for concurrent modification is pointless and bound to fail
[andrea.aime] Adding a prefix for custom dimensions in the metadata map to avoid collisions with other params in the metadata map
[etj] WCS2.0: fixes and changes for CITE compliance
[daniele.romagnoli] Minor improvement to the USER doc about the Geoserver Data Directory
[christian.mueller] GSIP 82, reworking filter chains including the GUI
[christian.mueller] CAS based on GSIP-82
[christian.mueller] Fixing the build for the CAS module
[andrea.aime] Adding example of range subset requeset
[andrea.aime] committing first cut of work on extensions
[andrea.aime] Adding support for parsing the geotiff exception, kvp style
[andrea.aime] [GEOS-5513] WCS 2.0 GeoTiff extensions with invalid values should return a 404, they return a 200 instead
[andrea.aime] Adding support for KVP parsing the wcs 2.0 scaling extension
[andrea.aime] Adding KVP parsing for the range subset extension
[andrea.aime] Adding kvp parsing of the crs extension, and crs extension getcapabilites extras
[andrea.aime] GetCoverage support for scaling, interpolation, crs, range subsetting
[andrea.aime] Following up wcs 2.0 exception code class name change
[andrea.aime] Adding support for KVP parsing the interpolation extension
[steenhulthin] replaced hardcoded geoserver version number.
[andrea.aime] Hopefully fixing the build on windows
[andrea.aime] Improvements in interpolation handling an range subsetting
[davide] GEOT-4358: added style test for isCoverage filter function
[andrea.aime] Switching gif files to png since pdf2latex cannot handle gif files
[andrea.aime] Fixing schema location in DescribeCoverage output
[andrea.aime] Follow up to GEOS-5346, WCS 1.1 resolution estimation broken on reprojection, to handle rotated coverages as well
[andrea.aime] Fixing one of the WFS 1.0 failures, inability to deal with repeated request=DescribeFeatureType in the request
[andrea.aime] Make DDS compile again
[andrea.aime] Improving error message for accepts versions not found
[mike] Added WFS 2.0.0 reference
[mike] Resolving Sphinx errors
[mike] Aligning fixed references between branches
[andrea.aime] [GEOS-5371] Reloading config break status config page (porting test over, trunk was not breaking but we want to make sure we don't have regressions on this error)"
[andrea.aime] [GEOS-5159] changes from GEOS-4100 breaks LegendDecoration with custom DPI
[andrea.aime] [GEOS-5197] Use the layer abstract as the GeoRSS channel description
[andrea.aime] Fixed a few typos in the developer/policies directory
[maurobartolomeoli] Added support for LayerGroup to the WMS GetLegendGraphic action
[mike] Adding examples for WFS 2.0 operations
[mike] Fixing typo in WFS reference
[mdavis] User Guide - added Filter Encoding reference section
[jared.erickson] import geoscript's geometry class
[andrea.aime] GEOS-5533: fixed critical bug in FreemarkerTemplateResource
[jesse.eichar] wfs capability extension point
[jdeolive] added groovy and javascript script modules to nightly community builds
[maurobartolomeoli] fixed some bugs and added forceTitles legend option
[mdavis] Fixed typo in User Guide Rendering Transformation section
[andrea.aime] [GEOS-5539] Support raster custom dimensions generated at runtime
[steenhulthin] Fixed version number reference to follow the project convention.
[nuno] Add Web 3D Service as a community module.
[nuno] Add group.id to w3ds pom. Add w3ds as a profile in web app.
[andrea.aime] Improving range subsettting code and coverage response delegate class
[andrea.aime] Make WCS 2.0 work against both lon/lat and lat/lon oriented coverages
[andrea.aime] Improved WCS 2.0 GetCapabilities output
[andrea.aime] Fixing dynamic dimension tests after changes to coverage delegate handlers
[maurobartolomeoli] fixed layer, style and rule parameters size mismatch; fixed tests not running on linux
[davide] GEOS5547 - GSIP84 - LayerGroup: added Mode, RootLayer and RootLayerStyle. Updated WMS GetCapabilities and GetMap
[simone.giannecchini] fix for GEOS-5537, Tiling artifacts with RasterSymbolizer using bilinear interpolation
[jdeolive] adding some required dependencies to groovy artifact
[jdeolive] updating test case to add layer before layer group
[jdeolive] some test cleanup, and some reorganization of files stored in data directory
[jdeolive] GSIP-86 - some refactoring of monitor extension and moving to extension
[maurobartolomeoli] GetLegendGraphic LayerGroup: fixed issue with fontAntiAliasing legend option
[andrea.aime] [GEOS-5551] WFS 1.0 capabilities will NPE with misconfigured OGR and XSLT output formats
[christian.mueller] GEOS-5554, add a role sevice parsing roles from web.xml
[christian.mueller] Describe how to open a ssl port for Jetty (developer guide)
[andrea.aime] Fixing WCSInfo latLon property to make it follow javabean conventions, and update WCSAdminPage to follow suit
[andrea.aime] Make WCS 2.0 SRS list configurable like in WMS
[andrea.aime] Avoid cloning the code of xstream loaders in restconfig, delegate to it instead
[spatialguru] sqlview.rst minor typo fixes
[spatialguru] primarykey.rst minor typo fixes
[spatialguru] sqlsession.rst minor typo fixes
[jdeolive] some tweaks to jdbcconfig with regard to configuration loading
[jdeolive] loading jdbc driver class before creating data source
[jdeolive] ensuring service objects initialized
[jdeolive] refactored some tests
[jdeolive] removed System.err statement
[jdeolive] removed bonecp dependency
[fgdrf] fixed docguide URL from translation page
[fgdrf] [doc] changed shapefiles url to git master branch
[davide] GEOS5547 - fixed backward compatibility for serialized layer groups
[davide] GEOS5547 - fixed PreviewLayerProvider
[andrea.aime] Fix test expectations on error message
[fgdrf] i18n for ReporojectPage 'show transformation details' link
[jdeolive] ensure ServiceInfo.geoServer member initialized when loading
[fgdrf] fix for GEOS-5563 (mixed order of X and Y Transformation parameters
[davide] GEOS5547 - fixed LayerGroup Container exception in GetMapKvpRequestReader
[davide] GEOS5547 - UI: improved LayerGroup Root Layer style selection
[christian.mueller] GEOS-5557 Enhance API for GeoserverUserGroupService
[davide] GEOS5547 - added test to CatalogBuilderTest
[davide] GEOS5547 - wms: removed TODO comment
[christian.mueller] GEOS-5558 Integrating the AuthKey module into the new security architecture
[davide] GEOS5547 - UI: hidden Root Layer form when LayerGroup is not in EO mode
[jdeolive] GEOS-5565, using workspace admin authorizier on sql view pages
[jdeolive] using initdb rather than import to determine if init scripts should be copied over
[jdeolive] GEOS-5565, using workspace admin authorizer for create new feature type pages
[jdeolive] ensuring gml info for wfs 2.0 initialized when creating wfs config from scratch
[jdeolive] adding flag to disable jdbcconfig module
[davide] GEOS5547 - fixed LayerGroup REST issue
[davide] GEOS5547 - improved UI
[jdeolive] proper handling of global settings object
[andrea.aime] Removing debug statements breaking build on windows
[ccancellieri] GEOS-5332 KMLTransformer does not include sld and vendor parameters into the request
[fgdrf] GEOS-5562 : added i18n support for WorkspaceEditPage
[ccancellieri] GSIP 83 - REST Extensible and customizable versions report
[ccancellieri] adding documentation
[mike] GeoServer doesn't support MS palette format
[fgdrf] uncommented last sentences of AboutGeoServerPage.information (supporter map)
[fgdrf] GEOS-5569 : added wicket keys and properties for CatalogStressTester
[andrea.aime] WCS20: More tests for multiband rasters, adding first cut of resource limits for WCS
[andrea.aime] WCS 2.0, getcaps tests improvements
[andrea.aime] fixing tests on windows + getcap
[andrea.aime] GEOS-5566
[andrea.aime] Fixing the build so that it works both on windows and linux
[jdeolive] refactoring resource pool, making it possible to plug in custom implementation
[dwinslow] Update to use geoscript/geocss 0.7.5
[andrea.aime] [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[fgdrf] GWC : added missing properties
[andrea.aime] Upgrade GWC dependency to 1.4-SNAPSHOT, make it compile again
[andrea.aime] Make the lock provider configurable via GUI
[andrea.aime] Adding a chooser for the quota store
[andrea.aime] Check the quota store can be created in the configuration page, allow GeoServer to startup anyways in case the quota store cannot be configured, and show error messages in the home page and disk quota config page in such case
[andrea.aime] Translate gwc related combo boxes contents
[andrea.aime] Use password field for... hum... the password
[ccancellieri] remove geowebcache dependency from ManifestLoader;
[andrea.aime] GEOS-5548 - Nested Layer Groups
[fgdrf] German properties files modified, thanks to Stefan Engelhardt
[fgdrf] externalized an other i18 property
[fgdrf] externalized error message for ReprojectPage
[fgdrf] fixed typos and changed descr. of Geometry fields
[andrea.aime] Fix WCS 1.0 cite tests failure
[fgdrf] updated German properties (consitency)
[andrea.aime] GEOS-5574, forward porting tests (no fixes needed on trunk)
[christian.mueller] GSIP 91
[christian.mueller] disable SSL filter test, works locally, but not in hudson
[christian.mueller] Kicking out the dbconfig module because of GSIP 85 - Nested Layer Groups
[maurobartolomeoli] fixed exception with generic Geometry type in WMS GetLegendGraphic
[daniele.romagnoli] improved custom dimensions management
[davide] GEOS-5548 - reverted change to SystemTestData.tearDown()
[andrea.aime] Update data/release/README.rst
[maurobartolomeoli] Added symbols size handling in WMS GetLegendGraphic
[jdeolive] ensuring upstream objects added before, not an issue for memory catalog but is for jdbcconfig
[jdeolive] changed some default test db params
[jdeolive] updated db init scripts to include some convenience views derived from the core table model
[jdeolive] fully disabling dbconfig community module, replacing with jdbcconfig artifact
[jdeolive] updating copyright header, added openplans copyright, GEOS-5460
[jdeolive] updated openplans copyright headers, GSIP-38
[davide] GEOS-5548: fixed nested layer groups rest support
[mike] Improved / corrected REST documentation (see GEOS-5595)
[mdavis] User Manual SLD Reference - fixed Halo syntax
[mdavis] User Manual Filter reference - added boolean Literal
[jdeolive] using direct reference to Catalog to avoid startup race condition
[jdeolive] ensuring intermediate checkouts of geotools/geowebcache checked out into build, and ignored so not added on commit and tag
[mike] Clarifying the difference between Read/Write/Admin
[mdavis] User Guide Filter reference - clarify PropertyIsBetween
[mdavis] User Guide SLD Reference - added TextSymbolizer extended options
[ccancellieri] remove unuseful snippet of code
[simone.giannecchini] created passthrough tile recycler
[simone.giannecchini] Update src/main/src/main/java/org/geoserver/jai/ConcurrentTileFactory.java
[fgdrf] added i18n support for CatalogStressTester progress message
[jdeolive] preventing WPSInitializer from producing unecessary event traffic
[mdavis] User Guide SLD Reference - added labelling options
[mdavis] User Guide SLD Reference - added TextSymbolizer Graphic doc
[fgdrf] added 'action' table header to properties files
[christian.mueller] GEOS-5606 Add a possibility to obtain a forgotten master password
[andrea.aime] [GEOS-5556] count=0 - WFS GetFeature
[andrea.aime] [GEOS-5541] Invalid WFS Layer Preview entry
[fgdrf] added i18n support for available/selected palette headers
[fgdrf] added i18n support for security PaletteFormComponent's
[ccancellieri] JSON WFS adding simple json mime type response handler (backward compatibility)
[ccancellieri] align and fix WFS JSON documentation
[mdavis] User Guide - Working with SLD improvements
[mdavis] User Guide SLD Ref - labeling sections edits
[christian.mueller] GEOS-5602 REST GETs and authentication under 2.3
[christian.mueller] GEOS-5608 Make the exception translation filter configurable
[mdavis] User Guide function ref - added endAngle, startAngle
[christian.mueller] GEOS-5606 works for Oracle sdk, but not for other sdks --> fixed
[davide] GEOS-5607 fixed exception throwed by nested layer group in Container mode
[mdavis] User Guide WMS Ref - fixed info_format GML types
[mdavis] User Guide SLD Ref Labeling - minor edits
[mdavis] User Guide SLD Extension - renamed Graphic Symbology, added links
[davide] doc: updated geoserver-manager link
[davide] documentation: layer group updates
[gabriel.roldan] remove stax as a dependency, it comes with the JDK since Java 6
[jody.garnett] Build fix - monitor parent pom now points to extension
[davide] JDK7: fixed VersionNegotiationTest
[davide] JDK7: fixed FeatureTimeTemplateTest
[davide] JDK7: fixed RenderingBufferTest
[davide] JDK7: fixed GlobalSettingsTest
[andrea.aime] [GEOS-5534] GetFeatureInfo templates don't work when layer has more than 20 class breaks
[andrea.aime] [GEOS-5528] Server Status timestamps
[davide] GEOS5620 - added wms-eo module containing EoStyleCatalogListener
[jdeolive] updated version numbers to 2.4
[jody.garnett] Documentation license Creative Commons by Attribution (GEOS-5543)
[jdeolive] upping geotools dependency to 10-SNAPSHOT
[mdavis] User Guide Point Symbols - various fixes, added Symbol Position doc
[mdavis] User Guide SLD Labelling - add Priority default, various edits
[andrea.aime] [GEOS-5623] GSIP 92 - Allow plugins to modify WMS MapContent before map rendering
[christian.mueller] GEOS-5611 Avoid security migration whenever possible
[andrea.aime] Adding WCS 2.0 among the community release extensions
[davide] GEOS5620 - added GetFeatureInfo XML output format
[mike] Re-adding REST manifests page
[mike] Re-adding manifest API examples
[mike] Removing stale directory
[mike] Re-adding Freemarker templates REST docs
[davide] GEOS5510 - added file chooser to ImageMosaic store
[jdeolive] Removing xerces dependency, using version provided by JDK. See GEOT-4382.
[andrea.aime] Fixing release module, does not build after xerces removal
[andrea.aime] [GEOS-5628] CatalogInfo objects will be cloned and rendered often useless when working against the GUI with multiple tabs open
[andrea.aime] [GEOS-5375] Update JAITools dependency to 1.3.0
[andrea.aime] [GEOS-5518] Validate SLD - Parameter message can't be null
[simone.giannecchini] fixing custom dimensions management
[riniangreani] Fix app-schema online test (exclude SecondaryNamespaceExceptionTest with online mode).
[Ben.Caradoc-Davies] [GEOS-5631] Build failure in wms GetFeatureInfoIntegrationTest caused by custom template leak
[Ben.Caradoc-Davies] [GEOS-5496] Add gt-complex to app-schema plugin release descriptor
[Ben.Caradoc-Davies] Clearer app-schema plugin fileSet rules
[andrea.aime] Fixing build after de-xercification
[davide] GEOS5548 - added javadoc to PublishedInfo
[jdeolive] added constructor to RawMap taking input stream
[jody.garnett] Code contribution agreement restored to the developers guide
[jdeolive] Some updates to WMSTestSupport.
[gabriel.roldan] Make GeoServerTileLayer to self configure non default styles if isAutoCacheStyles == true and no explicit parameter filter overrides
[gabriel.roldan] make PageInfo.setExtension public as the other setters are
[jdeolive] GEOS-5629, synchronizing version of poi library
[jdeolive] GEOS-5624, ensuring element name non null in AggregatePPIO and all XSTreamPPIO classes
[bosth] REST API doc fixes
[tim] Fixes to index.html
[fgdrf] changed encoding for de properties files temp. back to UTF8
[davide] GEOS5620 WMS-EO - fixed logging and javadoc
[davide] GEOS5620 WMS-EO - added module to web-app
[davide] GEOS5620 WMS-EO: added page to create eo layer group
[jdeolive] GEOS-5646, adding dependency mgmt for jfreechart dependency
[davide] GEOS5620 WMS-EO - created page to add EO layers
[andrea.aime] Remove xerces dependency still getting in via old JTS from GWC
[andrea.aime] [GEOS-5597] GWC_DISKQUOTA_DISABLED not respected
[andrea.aime] [GEOS-5634] enabling 'disk quota' causes disk quota page to bug-out, and [GEOS-5633] Disk quota never goes down
[andrea.aime] Clean up the old quota store when disabled, the stats are othewise going out of synch as gwc is used while the quota store is disabled
[davide] GEOS5620 WMS-EO - improved group creation page and added delete group page
[daniele.romagnoli] - Updated ImageIO-EXT GDAL section with references to latest release
[daniele.romagnoli] trivial improvement to the GDAL documentation
[gabriel.roldan] remove obsolete bxml profile from web/app/pom.xml
[Ben.Caradoc-Davies] [GEOS-5650] Build failure in wps-core SnapTest caused by leaking *ProcessFilterTest fixtures
[Ben.Caradoc-Davies] GEOT-4386 schema resolver api changes and promotion to gt-xml
[Ben.Caradoc-Davies] Removed xml-commons-resolver from the app-schema plugin as it is now included in the core distribution since GEOT-4386
[andrea.aime] [GEOS-5645] GET Request including same parameter multiple times fails
[andrea.aime] [GEOS-5653] Error setting JAVA_OPTS in startup.sh
[andrea.aime] Factoring out the kml code as a separate core module
[volayaf] fixed typo
[andrea.aime] [GEOS-5627] geoserver hit counts > server max features
[andrea.aime] fixed problem when showing WPS info from workspace page
[davide] GEOS-5549: fixed up/down arrows in LayerGroups UI
[simone.giannecchini] improving geotiff tests
[simone.giannecchini] added interleaving tests plus some more fixes
[simone.giannecchini] better testing for WCS GML kvp
[simone.giannecchini] improving tests for Scaling Extension
[simone.giannecchini] more tests on scaling, fixing a few issues with exceptions
[simone.giannecchini] more tests on subsetting and scaling
[simone.giannecchini] removed hack for error in tests
[simone.giannecchini] more tests for WCS20 trimming and slicing
[simone.giannecchini] #18, Add more KVP tests for RangeSubset extension
[simone.giannecchini] more javadoc
[simone.giannecchini] more tests for CRS Extension
[simone.giannecchini] #15, Fix Mime Type Management in DescribeCoverage
[simone.giannecchini] fixing GML tests
[dwinslow] Correct erroneous use of statics in DataAccessRuleDAO's
[xurxosanz] Update doc/en/user/source/services/wms/reference.rst
[andrea.aime] Get proper attachment filename for WCS 2.0 GetCoverage respones
[simone.giannecchini] more testing against real data for wcs20
[davide] GEOS5620 WMS-EO: fixes & UI refactoring
[davide] GEOS5620 WMS-EO: added TIME Dimension to OUTLINES Layer
[davide] GEOS5620 WMS-EO: fixed getmap and getfeatureinfo
[davide] GEOS5620 WMS-EO: UI refactoring
[davide] GEOS5620 WMS-EO: reverted changes to DimensionHelper
[andrea.aime] [GEOS-5667] Add support for multipart responses in WCS 2.0
[jody.garnett] Update committing.rst
[davide] GEOS5273: disabled entities evaluation for remote SLD files
[kevloral] [GEOS-4011] Unquoded subtype=gml/<version> breaks HTTP/1.1 standard
[andrea.aime] First cut at a kml refactor
[jdeolive] fixing typo in python buffer example
[andrea.aime] Adding missing imports
[andrea.aime] Some NPE safety
[andrea.aime] [GEOS-5482] GetLegendGraphic does not work for styles with rendering Transformation
[andrea.aime] GEOS-5549: fixed up/down arrows in LayerGroups UI, follow up to fix annoying extra issues (arrows on all the time, visual alternation broken, error messages on the console
[andrea.aime] [GEOS-5660] ScaleRatioDecoration attributes for enable/disable transparency, patch initially contributed by Francisco Ernesto Teixeira
[andrea.aime] [GEOS-5530] GML2-GZIP - Wrong MIME type?
[davide] GEOS5672: fixed nested group loop
[simone.giannecchini] GOS-5682, Fix WCS20 ScaleToExtent and ScaleToSize operations
[Ben.Caradoc-Davies] Revert "GEOS5672: fixed nested group loop" to fix the build
[breuil] [GEOS-5507] Explain how to upload a style to a workspace, and how to assign that style to a layer in the same workspace
[andrea.aime] [GEOS-5691] WCS 2.0 DescribeCoverage fails against image mosaic layers, and [GEOS-5690] WCS 2.0 GET DescribeCoverage fails against a list of coverageIds
[riniangreani] GEOS-5693: Make app-schema joining default behaviour.
[riniangreani] Make app-schema data reference tests work with joining on by default.
[andrea.aime] [GEOS-5696] WCS services need to declare their namespace
[andrea.aime] [GEOS-4761] AdvancedDispatchFilter throws NPE for additional non directory servlet mappings
[andrea.aime] Revert "[GEOS-4011] Unquoded subtype=gml/<version> breaks HTTP/1.1 standard"
[andrea.aime] Comment out image write breaking tests on non *nix platforms
[christian.mueller] Applying GEOS-5549 to security filter chains
[christian.mueller] GEOS-5678 Improve logging in geoserver.security
[Ben.Caradoc-Davies] Fixed 3D app-schema online test instructions (spatialreference.org SQL has a typo, so inlined fixed SQL)
[andrea.aime] Time dimension support for WCS 2.0
[simone.giannecchini] rebased to include KML split
[davide] GEOS5273: moved external entity setting to global configuration
[simone.giannecchini] adding libjpeg to the nightly deploys
[andrea.aime] [GEOS-5705] Enabled and advertised flags in the resource will get out of synch with the LayerInfo ones right after GUI editing
[damianofds] more doc on imagemosaic
[davide] GEOS5707: disabled entities evaluation in WFS POST requests
[riniangreani] GEOT-4417: App-schema joining with toXlinkHref results in some missing
[daniele.romagnoli] GEOS-5704, GEOS-5703: fixing a couple of TurboJPEG issues
[maurobartolomeoli] GEOS-5710 GetLegendGraphic for a layergroup with a coverage invisble at current scale fails
[planablediglet] cache-control headers in integrated wms, GEOS-5686
[maurobartolomeoli] GEOS-5711 org.geoserver.security.decorators.DecoratingWMSLayerInfo prefixName method calls itself indefinitely
[davide] GEOS5273 - GEOS5707: created EntityResolverProvider
[daniele.romagnoli] Simple update of the GDAL documentation, by updating the Imageio-ext version from 1.1.6 to 1.1.7
[andrea.aime] JAVA_OPTS setup won't work on bash
[andrea.aime] [GEOS-5715] Upgrade JUnit to version 4.11, adopt a predictable test execution order
[andrea.aime] Reducing usage of TestSetupFrequency.REPEAT test setup
[damianofds] fixes
[davide] GEOS5273 - GEOS5707: relaxed NoExternalEntityResolver path checks for schema files
[g.williams2] support for viewParams in WFS GetFeature POST requests
[hanchao0123] Add Chinese translation
[markus.innerebner] Update imagemosaic_timeseries.rst
[andrea.aime] Adding back support for relative links
[andrea.aime] Adding copyright headers and class javadocs where missing
[andrea.aime] Moving featuretymetemplate to the kml module, as it's the only user of that class
[andrea.aime] Adding placemark decorator for time
[andrea.aime] Adding missing files
[fgdrf] fix for GEOS-5641 : replacefilter for origin file, updated de properties, removed tokens from i18n files
[fgdrf] Revert "fix for GEOS-5641 : replacefilter for origin file, updated properties, removed tokens from i18n files"
[fgdrf] fix for GEOS-5641 : thanks to Oscar Fonts
[fgdrf] patch from Oscar Fonts applied, great suggestion to use native2ascii
[fgdrf] Revert "patch from Oscar Fonts applied, great suggestion to use native2ascii"
[fgdrf] GEOS-5641 : patch from Oscar Fonts applied, great suggestion to use native2ascii
[fgdrf] updated de web-core properties
[christian.mueller] GEOS-5716 Reduce repeated setup need in securty tests
[andrea.aime] [GEOS-5701] Add support for raster with time validity interval to GeoServer
[andrea.aime] Adding support for kmz and ground overlays
[andrea.aime] More kmz tests
[christian.mueller] Cumulative Fix for GEOS-5698 and GEOS-5215, security GUI bugs
[christian.mueller] Adding a passwd element in the curl tutorial (Adding a PostGIS database)
[andrea.aime] Avoid NPE when no time range available
[fgdrf] updated de properties
[maurobartolomeoli] GEOS-5723 workspace filter wfs getfeature request can't find a non namespace prefixed typeName
[andrea.aime] Remove references to people and companies, this is documentation, not a blog
[andrea.aime] Warn users about the consequences of enabling timestamp support in shapefiles
[andrea.aime] [GEOS-3387] Metadata links should be included in the WFS capabilites document as well
[jdeolive] GEOS-5725, catching exceptions resulting from request object handler
[jdeolive] GEOS-5732, better bbox handling of wfs inserts
[andrea.aime] [GEOS-5733] WCS 1.1 multipart output has newlines in HTTP response heades, that is invalid, and [GEOS-5734] WCS 1.1 GetCoverage response fails in multipart mode
[andrea.aime] Adding GeoSearch selflink support
[milo] First steps translating to Dutch
[andrea.aime] Optimizing template application in kml2, adding tests for time and height support, better support for kmattr
[milo] Dutch translation
[g.williams2] use KVP parser for viewParams in POST requests
[fgdrf] moved printing properties to resources folder
[fgdrf] moved proxy community properties to resources folder
[fgdrf] moved arcsde extension properties to resources folder
[fgdrf] moved h2 extension properties to resources folder
[fgdrf] moved wps-web extension properties to resources folder
[fgdrf] moved resource inti src/main/resources for web-wps module
[fgdrf] moved resource into src/main/resources for h2 module
[fgdrf] moved resources into src/main/resources (arcsde,proxy)
[fgdrf] moved resources into src/main/resources (printing)
[milo] Dutch translation GWC module
[milo] Dutch translation GWC, got to get the kids from school
[milo] Dutch translation for security
[milo] Dutch translation, finished
[milo] revert accidental changes to web.xml
[milo] revert accidental changes to .gitignore
[andrea.aime] [GEOS-5740] Failure to compute lat/lon bounds when native srs is not found and declared srs is not EPSG:4326
[andrea.aime] Simplify the layer filters before having the rest of the machinery handle them
[andrea.aime] Improvements in kml reflector and tests
[maurobartolomeoli] fixed Fifteen properties file
[fgdrf] added Korean properies files : Thanks to mapplus and Team for contributing
[jdeolive] GEOS-5742, adding dep mgmt for gt-process-geometry, and updating geoscript-py dep to gt 9.x/10.x compatible version
[Ben.Caradoc-Davies] Updated Eclipse Jetty JNDI instructions
[andrea.aime] Make this test platform independent
[andrea.aime] Better handling of paths with spaces on windows
[andrea.aime] Following up shapefile-ng swap
[christian.mueller] GEOT-5751 JDBCAuthenticationProvider does not work if a user is not registered as GeoServer user
[andrea.aime] Adapt the XSLT module tests to the junit 4.11 execution order
[g.williams2] support for viewParams in GetFeature POST requests. ViewParams updated in bindings
[christian.mueller] GEOS-5753 Add "Test connection" for JDBCAuthentication Provicer
[ccancellieri] GEOT-4416 ResultSet is closed: documentation update
[andrea.aime] Fix describe coverage generation, the dimension toString can contain weird chars
[andrea.aime] Make the test more tolerant to file system order
[andrea.aime] [GEOS-5757] Build fails on Windows due to unreleased input streams in security subsystem
[andrea.aime] [GEOS-5758] Monitoring module build fails on windows because the H2 data source is not disposed of
[andrea.aime] More attempts to shut down stuff
[Ben.Caradoc-Davies] Regularise handling of "+" in file URLs to fix Jenkins build on Windows
[ccancellieri] fix: GEOS-5749 Failed to find response for output format jsonp
[damianofds] GEOS-5765, Bug in Alpha Aware Quantizer
[planablediglet] GEOS-5766 - MonitorInputStream ignores maxSize
[andrea.aime] [GEOS-5752] Graduate the XSLT module to extension status
[andrea.aime] [GEOS-5752] Graduate the XSLT module to extension status, moving docs
[Ben.Caradoc-Davies] Removed temporary file that was part of the header review and testing regex expressions for invalid headers
[geoff] support for escaping SQL special characters (UI & featurestore config to activate support in GeoTools)
[simone.giannecchini] GEOS-5775
[andrea.aime] [GEOS-5774] Fix concurrency issue in TimeKvpParser
[andrea.aime] [GEOS-5775] WMS GetCapabilities file should be given a meaningful name
[andrea.aime] Fix inconsistency in mock request, the port is by default 8080 but the url says nothing (thus, port 80)
[andrea.aime] [GEOS-5782] Trying to upload a non existing file to rest config in external mode results in NPE
[andrea.aime] [GEOS-5781] Grid coverage readers might alter the hints provided during construction, resource pool should do a defensive copy of them
[andrea.aime] Remove dependency from shapefile-renderer
[christian.mueller] GEOS-5783 SSL redirect to wrong path
[andrea.aime] In case someone copied the gwc tag from the cite tests, that contains rev/shortrev, the checkout will fail, but when redoing it right the script thinks the checkout is really alredy done, and will eventually fail
[andrea.aime] Whoops, forgot to commit the xslt docs in extension
[andrea.aime] Adding xslt module in the assembly directives
[nuno] Remove obsolete KML response format.
[andrea.aime] Increase code coverage
[Ben.Caradoc-Davies] Added unit test for minimal schema-valid spec:SF_Specimen WFS response
[Ben.Caradoc-Davies] Added mapping for SF_Specimen/spec:size and unit test on WFS response
[Ben.Caradoc-Davies] Do not use SIZE as a test fixture property file column name as it is an Oracle reserved word and causes online tests to fail
[andrea.aime] [GEOS-5784] Missing release/ext-xslt.xml causes assembly:attached to fail
[Ben.Caradoc-Davies] Added missing samplingSpecimen-2.0 schema dependency required for PostGIS and Oracle online tests
[Paul.Biskup] JSON-GeometryCollection Bug
[niels] GEOS-5779 Implementation of SortBy in App-Schema
[riniangreani] Make SortByTest run online only.
[riniangreani] Amend last commit - enable SortByTest online only.
[andrea.aime] Moving KML test data to the kml module
[andrea.aime] Porting more tests from kml to kml2 module, fixing placemarks not being generated when working in ground overlay mode + kmplacemark being true
[andrea.aime] Whoops, forgot to add back the KML test files in the kml module2
[andrea.aime] Increase test coverage, add support for WFS spatial data identifiers
[andrea.aime] Reuse components in the extension panels list, or we'll lose edits if the submit fails due to validation errors
[andrea.aime] Make sure we don't convert from string over and over, otherwise we'll lose the changes to the value object
[andrea.aime] [GEOS-572] Set min max scale in the Geoserver featuretype configuration
[nuno] Extended styles to support the inclusion of 3D models. W3DS X3D format response improved to suport the inclusion of inline X3D models based on styles.
[andrea.aime] Update publish_release.sh
[jdeolive] Update publish_release.sh
[jdeolive] GEOS-5797 - fixing process with multiple outputs
[jdeolive] fixing py transaction test, handling null properties passed in
[nuno] 3D styles extended to support transform operations on 3D models.
[nuno] Add KML responde format for W3DS service. Currently only POINT features are supported.
[andrea.aime] Adding legend overlay support to kml2 module, leverage Mauro's multi-layer legend call in the process
[riniangreani] Test for GEOT-4460: Using functions in linkElement causes WMS error
[andrea.aime] Setting the stage for adding back superoverlay code
[andrea.aime] Promoting INSPIRE module to extension status
[andrea.aime] Updating INSPIRE docs to include WFS
[andrea.aime] [GEOS-4014] servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2.
[andrea.aime] Avoid NPE when no spatial dataset identifiers are provided
[riniangreani] Remove Boolean type in app-schema test fixture as it's not recognized in Oracle.
[riniangreani] app-schema tests: Tests other than SortByTest weren't running online.
[niels] GEOS-5755 Support Local Resolve in App-Schema
[niels] GEOS-5756 GetPropertyValue support for complex features and App-schema
[niels] GEOS-5795 Update App-Schema docs for WFS 2.0 features
[niels] GEOS-5756 GetPropertyValue support for complex features and App-schema - fix duplicate patch
[jansen] Fix typo.
[jdeolive] GEOS-5801 - exposing option to hide file system through geoserver web admin file browser
[jdeolive] GEOS-5803, using proper name for storage parameter
[mbertrand] Enclose code for disposing source and deleting directory inside finally block
[maurobartolomeoli] GEOS-5054 implemented role lookup for secured LDAP servers (e.g. ActiveDirectory)
[jdeolive] utility script to list info about pull requests
[jdeolive] support for connection pooling ooptions in config file
[jdeolive] factored out script reading and execution into util class, and added optional (ignore failure) statements
[martin.sucha] Remove hacks for comments in WMS capabilities.
[christian.mueller] GEOS-5811 Changing the SSL Port has no effect for
[riniangreani] GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[maurobartolomeoli] GEOS-5054 added groupAdminGroup parameter to LDAPAuthenticationProvider
[maurobartolomeoli] Added comments
[jesse.eichar] Add local workspace remove prefix configuration
[Ben.Caradoc-Davies] Switched to GeoWebCache milestone 1.4-M20130509
[Ben.Caradoc-Davies] Switched to GeoWebCache milestone 1.4-M20130509a
[andrea.aime] [GEOS-5790] Bad WFS request causes GeoServer to stop responding to certain requests types
[andrea.aime] [GEOS-5804] Adding XSLT module without proper configuration results in exceptions for normal GML requests
[Ben.Caradoc-Davies] Restore xslt to release profile
[riniangreani] GEOS-5618: app-schema joining wrongly groups nested children to the first feature if using getID()
[riniangreani] GEOS-5618: Remove references to getID() in app-schema tutorial.
[riniangreani] Make app-schema postgis scripts create tables in upper case for
[simone.giannecchini] GEOS-5816
[riniangreani] fix online postgis tests
[riniangreani] Rename IdFunctionWfsTestWithJoining.java to IdFunctionWfsWithJoiningTest.java
[cdwinslow] CSS bugfixes: Squashed commit of the following:
[cdwinslow] Update to v0.8.0 of GeoScript CSS
[andrea.aime] [GEOS-5786] GWC - Tile gutter is not cropped when metatile contains only one tile
[cdwinslow] Add raster properties in CSS module
[riniangreani] Wrong test name excluded.
[maurobartolomeoli] GEOS-5819 - partial fix for LDAPAuthenticationProviderTest failures
[tmarks60] Changed FileNotFOundException to 'return null'
[Ben.Caradoc-Davies] [GEOS-5810] Packaging error for the CAS extension
[jdeolive] Update to latest GeoScript JS to work with GeoTools 9, forward port of #237
[cdwinslow] Use stricter file patterns for CSS packaging
[niels] GEOS-5809 Support namespaces in WFS 2.0 fes filters
[niels] GEOS-5796 X-Paths with predicates only work with @attribute references
[simone.giannecchini] GEOS-5825,Missing jar for Jpg2K and GDAL Extension
[andrea.aime] Make sure the test is running in a clean enviroment (no stale manifest.properties in the root of the main module)
[andrea.aime] [GEOS-5754] Some 'Save' buttons do not work with Google Chrome
[andrea.aime] [GEOS-5754] Some 'Save' buttons do not work with Google Chrome, improved patch
[andrea.aime] Superoverlay code re-integrated, network link generation code cleaned up, still needs more testing
[maurobartolomeoli] GEOS-5826 allow request parameters access from HTMLFeatureInfoOutputFormat content templates
[niels] Fix GEOS-5796 test
[andrea.aime] [GEOS-5370] WPS requests fail when performed on a secured layer
[andrea.aime] [GEOS-5536] GeoWebCache settings won't be persisted on Windows
[andrea.aime] [GEOS-5836] Editing some GUI elements can result in config changes even without saving
[maurobartolomeoli] GEOS-5826 simplified patch and removed regression
[andrea.aime] [GEOS-5840] Changing the default style of a layer won't cause truncation of the tile caches for layer groups containing the layer, and, [GEOS-4760] Make GWC tile layers use the GeoServer layer's http caching settings
[andrea.aime] [GEOS-5818] WMS 1.3 cascading broken after GEOT-4283 changes
[christian.mueller] GEOS-5820 Disabling security does not work as expected
[christian.mueller] GEOS-5824 http://…/geoserver matches wrong security filter chain
[cdwinslow] Complete Java port of CSS extension code
[christian.mueller] GEOS-5760 Documentation not referrencing Xms correctly
[jdeolive] Updated CatalogFacade.list() to take collection of sortBy entries.
[jdeolive] added special case for ResourceInfo.boundingBox() to CatalogPropertyAccessor.java
[jdeolive] CSW Module : Internal Catalog - ISO MetaData Profile
[jdeolive] dropping csw prefix from directory names
[jdeolive] copying schemas to root of classpath
[jdeolive] added getAsDOM methods that allow to override XML doc encoding
[jdeolive] using ISO-8859-1 to parse returned documents
[jdeolive] removing ElementSet argument from CatalogStore.getRecords()
[jdeolive] updated javadoc for CatalogStore.translateProperty
[jdeolive] updating test to include port
[andrea.aime] Refactoring superoverlay code generation, adding more tests
[andrea.aime] KML 2 superoverlay refactor and tests
[planablediglet] GEOS-5844 fix nulls in SecureCatalog.list
[andrea.aime] [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
[lore.gnafu] Valid xml
[andrea.aime] [GEOS-5769] JDK 7 gives a preference to the pure java PNG writer even if the native one is available
[jdeolive] GEOS-5844 fix nulls in SecureCatalog.list
[jdeolive] Revert "GEOS-5844 fix nulls in SecureCatalog.list"
[andrea.aime] [GEOS-5854] Add file browser support for GDAL formats
[andrea.aime] Clean up the kml feature access code and separate it from kmlutils, remove all kmlutils dead methods
[maurobartolomeoli] GEOS-5849 added localized rule labels support to GetLegendGraphic output
[andrea.aime] Add support for extended data and schemas in kml
[andrea.aime] Adding a WFS KML output format
[jdeolive] implementing list with vararg sort by, for now only handling single argument
[maurobartolomeoli] GEOS-5847 fixed issue with nested layergroups
[andrea.aime] Ensure network links are always getting downloaded, without shrinking the bbox
[andrea.aime] GEOS-5851 Make sure we don't synch up computing a non cacheable feature type each time we need a feature source
[andrea.aime] Fix build
[christian.mueller] GEOS-5852 default filter chain does not create HTTP session even with session creation enabled
[christian.mueller] Security documentation enhancments
[maurobartolomeoli] trying fixing the build after GEOS-5847 broke it
[andrea.aime] GEOS-5862 - GSUSER variable not available in REST requests
[andrea.aime] GEOS-5863 Add support for white space margin in graphic fills
[Ben.Caradoc-Davies] Updated test axis order and added srsName check for [GEOT-4471] App-schema: filtering by xlink:href causes ClassCastException if the type has native CRS
[andrea.aime] [GEOS-5865] Make GeoServer leverage the GeoTools multicoverage raster API
[andrea.aime] Avoid dispose warnings when feature type infos are getting disposed with the new keys taking into account projection policy
[andrea.aime] [GEOS-5866] KML feature downloads may fail when GE asks for them looking at the entire world
[andrea.aime] Fix style generation, cache JAXB context as it's expensive to create
[andrea.aime] Unplug sequence generators that are probably not neededd anymore
[andrea.aime] Comment out generators that we should not really need
[andrea.aime] Make sure the request bbox is respected
[andrea.aime] Allow to control the label size from SLD
[andrea.aime] Improve placemark name selection logic
[andrea.aime] Fix height templates behavior
[andrea.aime] Add support for the extrude=false request directive (which is not honored by the old kml document, but part of the online docs
[andrea.aime] Minor fixes to the kml time template tutorial
[andrea.aime] Increase the resolution of ground overlays, they look rather blocky on desktop displays
[andrea.aime] Adding test for kml time spans
[andrea.aime] Removing empty tutorial page
[jansen] Fix minor typos in the README.
[cdwinslow] Move CSS module to extensions
[cdwinslow] Refactor docs/sources to reflect css change to extension status
[andrea.aime] Fix kmplacemark compliancy
[andrea.aime] Ensure proper behavior with refresh mode
[andrea.aime] Fix kml docs, kml_reflect does not exist anymore (not even in the stable kml module), use wms/kml instead
[andrea.aime] Superoverlay generation fixes
[andrea.aime] More superoverlay tests, now working as they should
[jdeolive] updating internal mac build server ip
[jdeolive] Throw a more useful exception when a resource can't be found.
[jdeolive] Allow styles to be added to specific workspaces in SystemTestData
[jdeolive] dependency mgmt for hamcrest-library
[jdeolive] Render point symbols for KML on the server to allow for complicated symbols.
[jdeolive] moved kml icon service to separate service outside of restconfig
[niels] CSW Documentation
[niels] CSW Documentation: Tutorial
[jdeolive] ported kml dynamic icons to new kml2 module
[niels] CSW plugin zip assembly configuration
[andrea.aime] Follow up GeoTools changes and add basic support for structured coverage grid readers
[andrea.aime] [GEOS-5875] Expose and allow manipulation of structured coverage grid readers via rest api, and [GEOS-5853] Allow creation of a image mosaic by uploading a zip file with the necessary data and config files
[andrea.aime] Several WCS 2.0 improvements
[andrea.aime] The wcs 2.0 EO and web wcs 2.0 EO modules
[jdeolive] fixing injectGraphic to fall back on existing properties of graphic, rather than setting to null
[jdeolive] fixing version numbers, #260
[dwinslow] Hook up CSS artifact descriptor for extension packaging
[jdeolive] added easymock dependency
[jdeolive] making icon service uri matching a bit more lax
[andrea.aime] [GEOS-5828] GWC - External Database issues (including security one)
[andrea.aime] [GEOS-5877] Replace old KML module with the new KML2 one
[andrea.aime] Documentation for the REST API extensions
[Ben.Caradoc-Davies] @Ignored tests as workaround for [GEOS-5879] KML TimeStamp date-month swap
[dwinslow] Revert "Refactor docs/sources to reflect css change to extension status"
[dwinslow] Restore accidentally deleted CSS docs
[niels] Support (relative) URLS in property data store directory.
[niels] Support (relative) URLS in property data store directory: Unit Test
[niels] CSW bug fixes + cite tests internal catalog
[g.williams2] updated app-schema mapping file schema
[geoff] documentation update for GEOT-4510 (app-schema plugin -- allows maxFeatures to work with normalised datasources)
[geoff] fix spelling mistakes
[Ben.Caradoc-Davies] [GEOS-5884] app-schema test failures due to timezone handling
[Ben.Caradoc-Davies] Fixed duplicate label
[Ben.Caradoc-Davies] Improved app-schema CQL function documentation
[andrea.aime] Fix issue with configuration and retrieval of multi-coveage grid readers
[andrea.aime] Fixes for the wcs-eo dependencies and make sure they get into the wcs2.0 community nightly build
[jdeolive] Parameter Filter UI and Revised Style Caching. Fixes GEOS-4978, closes #249.
[jody.garnett] Change baseman from metacarta to demo.opengeo.org ne:ne (GEOS-5848)
[Ben.Caradoc-Davies] Documented encoding of single quotes in CQL string literals
[andrea.aime] Preserve structured coverage grid reader nature
[andrea.aime] [GEOS-5890] Expose grid coverage band configuration in GUI
[andrea.aime] [GEOS-5891] REST config upload fail in path with spaces
[andrea.aime] Fixing location of standard styles, some copyright headers, and some formatting issues
[andrea.aime] [GEOS-5895] When a format fails to create a reader, ResourcePool comes out with a mysterious exception about a null value
[andrea.aime] Removing duplicated class from GEoTools, this should fix the build
[g.williams2] fix typo
[andrea.aime] Make sure kml2 is in the .war, and amend geosearch module so that it builds
[andrea.aime] Force kml module into the build, when listing explit profiles the auto-activating ones do not actually activate...
[andrea.aime] Fixing css related poms, css is now in extension, no more in community
[dwinslow] Fix erroneous mark examples from CSS documentation.
[andrea.aime] [GEOS-5903] Link to CSS reference in the css demo page does not work
[andrea.aime] [GEOS-5904] CSS documentation inconsistencies
[andrea.aime] Update the pull request section with policites about
[andrea.aime] Update patches.rst
[andrea.aime] [GEOS-5906] Gathering attribute statistics in the CSS demo page should be optional
[francois.vanderbiest] support for opaque WMS layers
[niels] Support publishing an app-schema layer in the webapp, no more buggy behaviour.
[andrea.aime] CSS cookbook, point page
[planablediglet] GEOS-5564, updated LocalWorkspaceURLMangler to handle path with multiple components
[andrea.aime] css cookbook, line examples
[andrea.aime] Whoops, forgot to save the last example
[mike] Copyedit of CSW section
[andrea.aime] CSS cookbook, polygon examples
[jody.garnett] Fix sphinx warnings
[andrea.aime] Adding css cookbook raster page too
[andrea.aime] Add a profile for wcs-eo inclusion in the web/app module
[andrea.aime] [GEOS-5923] Adjust aspect ratio of KML ground overlays
[daniele.romagnoli] [GEOS-5931]: use String url instead of File(url) when not dealing with actual file
[andrea.aime] [GEOS-5886] GWC service capabilities
[andrea.aime] [GEOS-5881] LayerGroup page does not mandate the specification of the CRS
[simone.giannecchini] GEOS-5842, List of drives is invisible for Adding store
[simone.giannecchini] GEOS-4762, WCS should force usage of imageread
[andrea.aime] [GEOS-5681] Relative path to watermark file does not work as advertised
[simone.giannecchini] GEOS-5896, Document uconfiguration of GDAL_DRIVER_PATH on Windows
[jonathanmoules] Update gettinginvolved.rst
[andrea.aime] Removing import that's breaking the build
[andrea.aime] [GEOS-5651] Uploading smaller freemarker template file leads to invalid file on server, and also make sure all file based resources (including the random access file) are properly closed no matter what might happen during the upload
[andrea.aime] [GEOS-5911] Document the geometry metadata table for sql server
[andrea.aime] [GEOS-5761] maxDisplacement works for simple TextSymbolizers as well
[andrea.aime] [GEOS-5870] Submitting incomplete styles wipes style (could not find a way to write a test for this...
[andrea.aime] [GEOS-5685] GeoWebCache not WMS 1.3.0 compliant
[andrea.aime] Avoid NPE when setting the file path to null
[andrea.aime] Making sure extensions list is in alphabetical order
[andrea.aime] [GEOS-5942] GetFeatureInfo with GML3 output will fail on raster layers
[mike] Fixed bad link to WFS axis order
[jdeolive] Added importer community module.
[jdeolive] JDBCConfig improvments, closes #257.
[simone.giannecchini] GEOS-5947, Remove Raster Custom Dimension additional ordering
[jdeolive] upgrading geoscript-py dependency
[simone.giannecchini] fixing build by imposing order NOT to be OS dependent
[jdeolive] upgrading dependency on geoscript-groovy
[andrea.aime] Add suggestion to update the JDBC driver if working with recent versions of Oracle
[jdeolive] updating module names to include Importer prefix
[jdeolive] updating sources to include copyright headers
[andrea.aime] [GEOS-5954] Capabilities resource error handling is not applied to layer groups
[jdeolive] Removing dependency on restlet json, using net.sf.json instead
[jdeolive] removing hard dependencies on libs inheireted on geoserver main
[jdeolive] removing preview link to geoexplorer
[jdeolive] Added geopackage community module
[niels] CSW Improvements: GEOS-5930 , GEOS-5937, GEOS-5934, tutorial prefixed name in mapping
[christian.mueller] GEOS-5921 Disabling anonymous authentication for the GUI results in an HTTP redirect loop
[andrea.aime] Make layer group panels reusable, make the store new page reusable in other context, made the stores model reusable as well
[andrea.aime] Streamline EO layer group UI, make it more flexible and easier to use
[andrea.aime] i18n fixes for wms-eo
[niels] Make CSW compatible with jdbcconfig
[andrea.aime] Don't assume we can build the sample feature from the original layer if there is a vector transformation in the middle
[andrea.aime] [GEOS-5966] Switch GetFeatureInfo minimum search area to 5 pixels
[andrea.aime] [GEOS-5943] KML wfs output format does not properly set the output file name
[andrea.aime] Give kml wfs output a display name for the preview pane
[andrea.aime] [GEOS-5953] Trying to change the style of a layer in a group wil have (visually) no effect
[andrea.aime] Fix the build. Unfortunately wicket tester cannot be trusted to reproduce real app execution...
[andrea.aime] [GEOS-5955] Reosurce error handling drop down choice is not internationalized
[riniangreani] - Remove references to getID() in app-schema examples.
[niels] GEOS-5967: Provide default mapping instead of empty mapping in CSW
[jdeolive] allow scripts to return a map/dictionary
[jody.garnett] refreshed contributor agreement from open plans
[jody.garnett] fix release guide warnings
[jody.garnett] fix broken references in security programming instructions
[maurobartolomeoli] GEOS-5960 fixed test connection in LDAP Authentication Provider GUI
[g.williams2] support for -DGEOSERVER_CONSOLE_DISABLED=true to disable geoserver web console
[riniangreani] - Further clarifications for idExpression in app-schema.
[riniangreani] Update app-schema-online-test guide for 3D Oracle tests with the SC4OUser parameter.
[jdeolive] poms - make work with maven 3
[jdeolive] Fixed maven3 pom warnings.
[jody.garnett] JDK7 coordinate list test [GEOS-5973]
[riniangreani] app-schema Oracle tests should pick up "user" from test fixture, not System properties.
[jdeolive] removing uncessary pom dependencies
[cdwinslow] GEOS-5929
[cdwinslow] Rebase CSS legend support onto latest master
[cdwinslow] Update CSS tests for layout changes
[andrea.aime] [GEOS-5961] GetFeatureInfo doesn't round scales
[andrea.aime] [GEOS-1676] verify org.vfny.geoserver.servlets.AbstractService is actually not used anymore and remove/deprecate
[andrea.aime] Adding GEOS-2795 test, it works now
[jody.garnett] fixed up blog post examples
[andrea.aime] Switching to 1.5-beta as gwc dependency to prepare for the release
[andrea.aime] Updating master to be the 2.5 series
[braam.roy] scaleHint computation for wms 1.1.1
[braam.roy] standard pixel converted to meters
[braam.roy] fixing test cases for capabilities' scalehint
[braam.roy] scale denomentator computation for wms 1.3.0
[niels] Fix CSW test mappings
[niels] GSIP 98 Move CSW from community to extensions
[braam.roy] Added WMS scalehint units per pixel checkbox. When selected the scalehint is in units per pixel instead of scaledenominator.
[braam.roy] When 'Scalehint Units per Pixel' is configured for the WMS, Compute the scale hint with a pixel size of 0.28mm x 0.28mm.
[braam.roy] Reverted change: For wms 1.3.0 always use the scaledenominators and don't compute the units per pixel(0.28mm * 0.28mm).
[andrea.aime] Removing dependency towards css module, it's in extension now, no more in community
[niels] GSIP 98: Move CSW from community to extensions (fix)
[robert] Update REST docs to match changes in GEOS-5512.
[braam.roy] Completed the unit tests with tests for 'Scalehint in units per diagonal pixel' and as denominators.
[braam.roy] remove start main class
[braam.roy] updated unit test comments
[braam.roy] updated propertie files and added properties for dutch language.
[andrea.aime] Improve logging for asynch requests
[andrea.aime] [GEOS-5983] Add a way for styling to know what kind of KML output mode we are using
[andrea.aime] Whoops, forgot to add a test resource
[riniangreani] GEOT-4531: 1D borehole tests.
[riniangreani] ToLineString user doc.
[jdeolive] changing extension to .gpkg, as per spec recommendation
[andrea.aime] Make sure CSW is built by hudson during normal builds (not just nightlies)
[andrea.aime] [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[riniangreani] Change dependency to point to recently published geosciml 3.2 schemas.
[andrea.aime] [GEOS-5988] CSW spatial filters checks are too simplistic, do not work with a deeply nested schema
[andrea.aime] [GEOS-5369] CSW GetRecordById will NPE in case there are multiple record types available
[andrea.aime] Remove debugging code that breaks the build on windows
[andrea.aime] [GEOS-5689] Reloading configuration with workspace specific settings results in exception
[andrea.aime] [GEOS-5992] Searching for an unqualified layer should always give precedence to layers in the default workspace
[andrea.aime] [GEOS-5516] GetFeatureInfo fails against 3D data
[andrea.aime] Follow up changes with GetFeatureInfo buffer defaults
[andrea.aime] Merging Jonathan's suggestion
[andrea.aime] [GEOS-5643] problem with legend decoration and input parameter
[braam.roy] removed 'tabs' for spaces
[niels] GEOS-5938: CSW admin page
[niels] GEOS-5968: Jdbcconfig FilterToCatalogSQL breaks on 'unusual' filters
[fgdrf] fixed contrary meaning of i18 property
[niels] GEOS-5940: CSW support mapping multi-valued metadata property with multiple catalog properties.
[ccancellieri] fix GEOS-5995-deadlock setting spring to 3.1.4
[niels] GEOS-5968: Jdbcconfig FilterToCatalogSQL breaks on 'unusual' filters (added comments)
[andrea.aime] [GEOS-5985] Tomcat with APR can result in full JVM crashes
[riniangreani] Test for GEOT-4550: WMS app-schema with reprojection returns blank image
[andrea.aime] [GEOS-6007] WFS bbox filters with the 5th srs parameter will loose the srsName if the CRS cannot be turned back into a code (e.g., AUTO:xyzw projections)
[dwinslow] Update GeoScript dependency in CSS extension
[riniangreani] Fix argLine for app-schema-test so it picks up maxHeapSize etc.
[jdeolive] updated release artifact descriptor versions to 2.5-SNAPSHOT
[jdeolive] updating version numbers to 2.5 for mac/win installer files, and extension readmes
[gabriel.roldan] Transfer WFS transaction extra properties down to the geotools transaction.
[christian.mueller] GEOS-6000 LRUAuthenticationCacheImpl TimerTask causes deadlock
[christian.mueller] GEOS-5997 Basic authentication filter message digest is not thread safe
[jody.garnett] remove vpf etension GEOT-2347
[jody.garnett] Remove vpf reference used by assembly step
[fgdrf] fixed little typo
[niels] GEOS-5940: Improve CSW Mapping File Documentation
[bjorn.harrtell] Add option to override expire clients for tile layer
[niels] GEOS-5400: Freemarker template stopped support of TemplateSequenceModel.
[tkunicki] attach web-app war artifact for use with maven war overlays
[jody.garnett] Switch groovy compiler to the eclipse groovy compiler because it supports Groovy 2.x
[andrea.aime] [GEOS-6015] GeoJSON uses wrong mime type
[jdeolive] added profiles for individual script modules
[riniangreani] GEOS-6019: GetFeatureInfo with reprojection fails
[maurobartolomeoli] GEOS-6025 extended userFilter parameter to have an additional placemark for unformatted username
[riniangreani] GEOT-4554: Test no idExpression using primary keys as ID.
[niels] GEOS-6012: Automatically link CSW (ISO) records to the respective WMS/WFS/WCS sources
[andrea.aime] [GEOS-6027] Wrong lookat generated in kml superoverlays if when the layer bbox happens to be contained only in some higher level tile
[andrea.aime] [GEOS-6028] Superoverlay outputs are not always visible from the start (one needs to zoom in)
[andrea.aime] [GEOS-6029] KML: force output in 4326 even if the request calls for a different SRS
[andrea.aime] [GEOS-6034] Explicit GetMap with KML output defaulted to download mode, now it defaults to refresh mode
[riniangreani] Test for GEOT-4567: String constants in idExpression causes error
[andrea.aime] [GEOS-6024] 2.4-RC2 - rest PUT for style reference (and possibly other references) does not work anymore
[andrea.aime] [GEOS-6039] Monitoring audit logging broken
[ch.picone] Update DefaultControlFlowConfigurator.java
[ch.picone] Update IpBlacklistFilter.java
[fdgrf] Inital Romanian translation : Many thanks to Sorin Călinică
[niels] JDBCConfig Documentation
[niels] GEOS-6011: CSW: publish records for layer groups too
[jdeolive] GEOS-6042, handling null bounds, which can result from using the wms reflector
[jdeolive] fixing parent reference for web-csw
[ksmith] Ignore broken test rather than excluding the whole test case
[ksmith] JDBCConfig, more unit tests, avoid unnecessary JNDI lookups
[ksmith] GEOS-6010: Stop REST from bypassing the Catalog for Service config.
[jdeolive] updated release scripts for new build server
[jdeolive] fixing typo in DIST_HOST
[jdeolive] updated location of nsis installer
[jjjtaylor] Adding module geoserver-sync
[mbertrand] Catch and log layer-specific exceptions when GWC searches for layers that have been affected by a style change.
[francois.vanderbiest] fixed typo in documentation regarding LEGEND_OPTIONS parameter
[niels] Importer module: international support
[jjjtaylor] Fixed module geoserver-sync missplacement
[ksmith] Updated EasyMock dependency to 2.5.2
[ksmith] Clear cached config/catalog data in JDBCConfig
[jjjtaylor] second push attempt to get rid of black folder on push
[jjjtaylor] trying to remove empty black geoserver-sync module
[jjjtaylor] removing empty module
[jjjtaylor] test on pushing with src/community/geoserver/.gitignore
[jjjtaylor] added back geoserver-sync module
[ksmith] Better error message when JDBCConfig can't connect to datasource
[andrea.aime] Make newlines in test platform independent
[aaime] On windows one cannot rename towards an existing file and overwrite it in the process, on *nix, yes, it can be done instead
[andrea.aime] Harden a bit this test
[andrea.aime] Adding first attempt at a travis build config
[andrea.aime] Fixing travis file
[andrea.aime] Make it build in src directory
[andrea.aime] Leverage the plentiful 1.5 core Travis gives us (and disable mail notifications for the moment
[andrea.aime] More tweaks to the flow controllers tests
[niels] Automatically link CSW (ISO) records to the respective WMS/WFS/WCS sources (fix)
[niels] Support CSW requests with different types in query and in outputschema.
[niels] CSW: fix and improve default mappings
[maurobartolomeoli] GEOS-6063 Allow creation of imagemap for points using a wellknownname different from circle
[jdeolive] updating doc versions to 2.5
[andrea.aime] Try to quiet down Travis a bit
[Ben.Caradoc-Davies] [GEOS-6065] Build failure in MemoryUserDetailsServiceTest
[bjorn.harrtell] Handmade merge with http://jira.codehaus.org/browse/GEOS-6020
[Ben.Caradoc-Davies] Added missing test dependency on gt-jdbc-postgis [GEOS-6065]
[daniele.romagnoli] Adding NetCDF community module to support NetCDF input coverages
[maurobartolomeoli] GEOS-6052 fixed unmarshalling of virtualtables missing escapeSql param
[daniele.romagnoli] Appending -plugin suffix to the NetCDF community module package
[andrea.aime] [GEOS-5984] Add support for polygon fill margin vendor option in CSS, and [GEOS-5963] Cannot use all CSS standard colors in CSS styling module
[andrea.aime] Try harder to quiet down Travis
[daniele.romagnoli] [Netcdf community module]:recovering h2 dependencies
[daniele.romagnoli] Adding NetCDF output support
[daniele.romagnoli] [NetCDF community: fixing version number]
[jdeolive] Add a reference to the current org.geotools.data.Transaction to TransactionRequest, #320
[jdeolive] Add a getter for the Transaction from TransactionEvent. #320
[andrea.aime] Switch h2 tests to use an in memory db
[andrea.aime] Make sure the test works even with odd chars in the build path (a @ in this case)
[andrea.aime] Make sure the parent dir for the db connection config file exists
[andrea.aime] Make this test independent of doubles formatting
[andrea.aime] PNGJ based PNG map output format
[andrea.aime] Link compression level to image quality
[Ben.Caradoc-Davies] [GEOS-6074] Build failure in wms GetMapKvpRequestReaderTest in path with spaces
[andrea.aime] [GEOS-5858] Inconsistent representation of workspace specific styles in rest
[ksmith] UI notification that JDBCConfig is working.
[ksmith] Localization for JDBCConfig
[ksmith] Docs for JDBCConfig UI
[ksmith] Added missing copyright header
[ksmith] Fixed unit tests in JDBCConfig
[andrea.aime] Quiet down the build more
[maurobartolomeoli] Fixed a couple of unit tests to run on some Windows machines
[riniangreani] Update test for GEOT-4582: App-schema generates empty order by if there
[planablediglet] GEOS-6086 remove WfsDispatcher from describelayer
[andrea.aime] [GEOS-6088] Add support for count in json output
[andrea.aime] [GEOS-6089] Enable WCS 1.0 support for WPS
[andrea.aime] Fixing build after pull request #267 broke it
[niels] CSW: add test for unsupported outputschema
[andrea.aime] Increasing test coverage, fixing a couple of issues in the process
[niels] CSW: wms link in DC out of box mapping
[andrea.aime] Adding the new png encoder to the community release
[niels] CSW: Fix syntax error in mapping file.
[andrea.aime] Whoops, adding missing file for the night release
[jdeolive] Factored out web secrity modules, GEOS-5972. Fixes #357.
[jdeolive] GEOS-6077 Create an endpoint for webapps to authenticate against
[Ben.Caradoc-Davies] Upgraded GeoWebCache dependency from 1.5.0-beta to 1.5.0 final
[ccancellieri] fix spaces in ImageMosaic custom dimension
[daniele.romagnoli] Updating libjpeg turbo documentation with updated downloads repository
[daniele.romagnoli] [NetCDF-out]:Fixing mimetype and updated the doc
[jdeolive] added ability to put scripts
[maurobartolomeoli] GEOS-6080: added standard RoleSource support (Header, RoleService, UserGroupService) to J2EEAuthenticationFilter
[jdeolive] adding check for default admin password to security manager
[jdeolive] improved security in script extension, disabling rest api when default password has not been changed
[andrea.aime] [GEOS-6099] Layergroup titles not shown on layerpreview
[andrea.aime] [GEOS-5487] WCS 1.0.0 can't be disabled
[Ben.Caradoc-Davies] Fixed security extension parentage and dependencies
[Ben.Caradoc-Davies] Added missing release web-sec-cas dependency required for the cas plugin
[jdeolive] using write creds for firing off jenkins installer jobs
[maurobartolomeoli] GEOS-6080: added more docs to MigrationHelper
[Ben.Caradoc-Davies] Updated release guide with Jenkins changes and small reordering and content fixes
[andrea.aime] [GEOS-6083] Wrong character encoding, and [GEOS-6079] Saving styles from the Admin UI use the wrong encoding on some systems
[ksmith] Default JDBCConfig to disabled
[ksmith] JDBCConfig documentation updates
[bjorn.harrtell] Forgot to unset transient members from patch
[maurobartolomeoli] fixed cas extension broken by GEOS-6080
[rudi.hochmeister] Update web.xml
[rudi.hochmeister] add LDAP config
[tkunicki] GEOS-6006: add filter to remove "Request=GetMap" when called against animator
[maurobartolomeoli] GEOS-6092: WFS 2.0 GetFeature ignores the feature bounding settings
[dustin.a.parker] Add wfs-notification module from 2.4 to master.
[rudi.hochmeister] Add ORACLE DDL
[rudi.hochmeister] fixed typo
[maurobartolomeoli] GEOS-6092: splitted patch to do most of the work in Geotools (GEOT-4603)
[andrea.aime] Do not rely on getting the first layer, it might be a different one on different systems and cause the test to fail
[andrea.aime] Uncomment output printing to figure out what's going on in the build server
[andrea.aime] Attempt to fix build on windows
[rudi.hochmeister] enable useSreenMenuBar Property
[aaime] Attempt to fix the build on windows in path with special chars
[andrea.aime] Ok, this setup should work on both windows and linux
[andrea.aime] [GEOS-6113] Exception : The input argument(s) may not be null with gs:Contour
[geoff] added unit tests and documentation for PR-296
[andrea.aime] [GEOS-6122] WFS GeoJSON output format strips z from 3d data
[jody.garnett] GetMap XML example
[jody.garnett] fix roc reference when building docs
[jody.garnett] WMS GetMap example for demo request page
[andrea.aime] GEOS-6122, making json work also with full 3d srs
[simone.giannecchini] GEOS-6126, JP2K Extension is missing as a profile in web/app
[rudi.hochmeister] update ORACLE section
[andrea.aime] [GEOS-6128] On the fly metatiling can return repeated tiles at (very) high zoom levels
[mase] Document WFS 2.0.0 change of maxFeatures -> count
[mase] Document WFS 2.0.0 change of typeName -> typeNames
[jdeolive] using version for importer-rest dependency
[jdeolive] removing unused import
[jdeolive] Fixing some broken keys
[andrea.aime] documentation - Straight line behaviour with followLine
[andrea.aime] Update function_reference.rst
[andrea.aime] Update geometry-transformations.rst
[andrea.aime] Update shapefile.rst
[andrea.aime] Update GeoServerApplication.properties
[maurobartolomeoli] GEOS-6072: added xerces module dependencies to the community printing plugin module
[mbertrand] Change XML output from:
[andrea.aime] [GEOS-6135] NPE when trying to access a OGR generated output format via WFS 2.0
[mase] Remove out-of-date caveats on feature chaining doc
[maurobartolomeoli] GEOS-5813: Added LDAP based GeoServerRoleService
[andrea.aime] Adding a README.md for all those getting to github first
[andrea.aime] Update README.md
[andrea.aime] [GEOS-5962] Log error when skipping faulty layers or layer groups during caps document generation
[nofatclips] Update data-dir-structure.rst
[daniele.romagnoli] [Fixing classes involving dataStore and dataAccess, after GEOT-2333 fix]
[daniele.romagnoli] Fixing decorating dataAccess/dataStore
[michael.benowitz] Add LegendGraphic support for Rules in SLDs
[michael.benowitz] Set scale to 1.0 in testExternalGraphic request.
[maurobartolomeoli] GEOS-5813: integrated userFilter cfg parameter for better ActiveDirectory support
[maurobartolomeoli] GEOS-5813: fixed unit tests
[andrea.aime] [GEOS-6151] WPS can report progress percentage above 100 with asynch process execution
[eric.c.dahl] Add IntelliJ IDEA generated files to gitignore
[eric.c.dahl] Remove redundant calls to toString() on String objects
[fgdrf] updated German translations for master, added community modules translations
[fgdrf] updated Romanian translations
[fgdrf] updated Korean translations and some for community/extension modules - thanks tp Minpa Lee
[fgdrf] inital Polish translations - thanks to Jarosław Pękala
[fgdrf] updated French translations (and added some for community/extension modules)
[andrea.aime] One more custom build of css to include the randomized fills work
[andrea.aime] [GEOS-6111] Support repeated and randomized graphic fills in polygons
[mbertrand] Add option to reverse colors
[mbertrand] Fix some formatting issues
[mbertrand] Formatting (whitespace) issues
[andrea.aime] [GEOS-6159] Document the kmlOutputMode enviroment variable
[jjjtaylor] Update geoserver-sync module to work with geoserver/geotools 2.4/10.0
[andrea.aime] [GEOS-6101] Controlling legend appearance with LEGEND_OPTIONS Documentation has small error
[andrea.aime] [GEOS-5523] Document special behaviour for connection strings with oracle NG
[andrea.aime] Unbalanced double quote breaking release, fixing it
[ijturton] updated tutorial to mention the SORTING parameter
[jdeolive] GEOS-6162, stubbing data source when plugin disabled
[jdeolive] copying scripts over at same time as copying over sample configs, GEOS-6161
[jdeolive] cleaned up some uncessary i18n keys
[jdeolive] Geopackage WFS outputformat, fixes #364
[mbertrand] Unit tests for sldService
[mbertrand] Got rid of autogenerated comment
[niels] Geopackage: add file headers
[niels] Geopackage: clean up getmap -> only tiles
[rhastings] Remove profile that points back to Moebius artifactory server.
[rhastings] Resurrect one of the commented out tests and fix the test when
[rhastings] Geoserver now has a default function factory that should suffice.
[rhastings] Filter working now. Started with geoserver example then added back
[rhastings] Removed dead code.
[rhastings] Filter function working now. Started with geoserver example, then
[rhastings] Removed more dead code.
[rhastings] All unit tests in sync-server plugins are working now.
[niels] GEOS-4217 Support Data Security with GWC requests
[niels] GEOS-4217 Support Data Security with GWC requests: documentation + pom update
[rudi.hochmeister] fixed typo in docu - http://jira.codehaus.org/browse/GEOS-6166
[niels] KML DataStore: add profile in web-app.
[maurobartolomeoli] GEOS-6193: LDAP test connection is broken when using userGroupService
[andrea.aime] GetFeatureInfo refactor, making it more object oriented, and extensible
[andrea.aime] Removing svn directories from the repo
[andrea.aime] [GEOS-6176] Create a new wosrkspace specific style breaks CSS extension user interface
[andrea.aime] [GEOS-6209] Fees and AccessContraints should be set to none when there are no constraints
[ksmith] Resource Pool performance patch from Ordnance Survey
[ksmith] Avoid unneccesary synchronization.
[rhastings] Moved resources into correct package to fix broken unit tests.
[rhastings] Whitespace changes.
[rhastings] Reduce logging level back to FINER.
[rhastings] Fix header comment.
[rhastings] Removed extra logging.
[rhastings] Whitespace.
[rhastings] Upgrade to JUnit 4 annotations.
[rhastings] Fix logging in finally if m_server is null.
[rhastings] Upgraded to JUnit 4.
[andrea.aime] Avoid NPE when coverageId is missing from request using the EO plugin, report the right exception instead
[andrea.aime] Use Long/Lat as axis names
[andrea.aime] [GEOS-6212] Control flow can log a negative number of active requests when requests fail to parse
[andrea.aime] Adding more logging to investigate GEOS-6205 and GEOS-6106
[rhastings] -Dsha1.keep.name is no longer supported. Instead, name is
[rhastings] Convert unit test to JUnit 4 annotations.
[rhastings] Fixed missing call to write method.
[rhastings] Link pom files back to geoserver community parent pom.
[jdeolive] Ensuring http response info set properly.
[rhastings] Removed old incomplete Complex Feature configuration.
[rhastings] Fixed version for geoserver-sync community module.
[riniangreani] Update AppSchemaDataAccess.xsd in tutorial.
[andrea.aime] [GEOS-5317] Fetching data from sql views uses more queries than strictly necessary
[andrea.aime] Removing unecessary dependencies
[andrea.aime] Adding setup sql for postgis2 series, still needs to be tested in detail
[andrea.aime] Porting wfs 1.1 dataset to postgis2 syntax. Still needs to be tested in detail
[andrea.aime] [GEOS-6206] Prefix all geoserver jars with "gs-"
[maurobartolomeoli] GEOS-6219: fix DXF community module build and add it to nightly builds
[niels] GEOS-4217: fix gwc pom
[jdeolive] changing default port for postgis to standard 5432
[jdeolive] removing assumption that import data is non null, might have been specified as part of task instead
[jdeolive] support for title/abstract/description on rest upload
[riniangreani] Doc for CSV outputFormat with app-schema.
[riniangreani] GEOS-6218: CSV output format support for complex features with SF0
[riniangreani] GEOS-6218: CSV output format test.
[Ben.Caradoc-Davies] [GEOS-6222] Build failure in gt-app-schema-test caused by change for [GEOT-4634] MetaBufferEstimator won't give the right response if a Mark is used, but its size is not specified
[rhastings] Made parseWfs protected so that subcasses can override.
[bradh] Fix minor typos in Time / Elevation Series docs.
[maurobartolomeoli] GEOS-6152: fixed links in documentation pointing to gridlock site
[andrea.aime] Doc for CSV outputFormat with app-schema.
[andrea.aime] GEOS-6218: CSV output format support for complex features with SF0
[andrea.aime] GEOS-6218: CSV output format test.
[andrea.aime] [GEOS-6215] workspace styles can only use images/graphics from global workspace
[andrea.aime] [GEOS-6201] Missing abstract definition of layer group in gwc integration
[bradh] Editor work on the ImageMosaic docs.
[andrea.aime] GEOS-6170, updating GeorectifyProcess to work without ant (and adding a test in the process).
[rhastings] Updated to build against changed geoserver gs-* artifact names.
[riniangreani] Added dependencies for CSV outputFormat test to app-schema online tests.
[andrea.aime] [GEOS-6221] Have GetFeatureInfo report what the user really clicked onto (taking into account symbol shapes and the like)
[maurobartolomeoli] GEOS-6238: added support for withattributes option to dxf community module
[andrea.aime] [GEOS-6208] Make the PNGJ based encoder the default PNG encoder
[andrea.aime] [GEOS-6247] KML points not extruding, patch by Victor Gonzalez
[riniangreani] GEOS-6216: update unit tests for bbox filters with different SRS formats.
[jdeolive] GEOS-6257, IE issues that arise when it excepts text/html
[niels] Mbtiles GetMap outputformat
[planablediglet] be more explicit about updatemode, add javadoc
[planablediglet] allow serial binding to be used via system property
[planablediglet] use ValidationException when reading transforms
[planablediglet] add attributes to layer representation
[planablediglet] cleanup, error handling, remove broken user tracking
[planablediglet] handle missing/disabled target store better
[planablediglet] fix broken test and behavior in LayerResource
[planablediglet] move style computation ahead of other checks
[planablediglet] check client provided workspace and store exist
[planablediglet] write out json attribute binding correctly
[planablediglet] remove failing postgis tests, need to move
[planablediglet] fix advanceId in memoryimportstore, test coverage
[planablediglet] remove print stmt generating large xml output
[planablediglet] copy resource properties specifically
[daniele.romagnoli] [GEOS-6243]:EmptyMosaic: REST APIs support
[niels] Mbtiles/geopkg: remove duplicated abstract class + fix various bugs
[jdeolive] GEOS-6258 - Not considering http error codes < 400 as an error.
[damiano.albani] Have label match CQL filter
[maurobartolomeoli] GEOS-6261: promoting dxf community module to extension
[jansen] Fix typo.
[tommaso.doninelli] Added the endpoint to /masstruncate rest service
[andrea.aime] Temporary fix for the icon renderer tests failing when perceptual diff is installed
[andrea.aime] GEOS-6264 - Graduate WCS 2.0 to core module
[tkunicki] make application context for test framework more consistent with runtime
[Ben.Caradoc-Davies] Migrated app-schema WMS tests to PNG
[andrea.aime] Dont' use printstacktrace, use logging as the TODO says...
[dwinslow] Fix up positioning code in IconRenderer for KML
[andrea.aime] [GEOS-6274] Graduate WCS 2.0 EO module to extension status
[alessio.fabiani] - #GEOS-6275
[alessio.fabiani] - #GEOS-6276
[daniele.romagnoli] Updating GS code to deal with GEOT-4640
[daniele.romagnoli] Updating WCS-20_EO to GEOT-4640
[alessio.fabiani] - #JIRA-6275 : removing unusefull and personal comments
[andrea.aime] [GEOS-6283] Graduate libjpeg-turbo community module to extension status
[alessio.fabiani] - GEOS-6276 : changed the class package, updated JIRA comment, updated and fixed the test cases
[andrea.aime] Adding release packaging file for wcs2.0-eo, forgot to commit it earlier
[riniangreani] GEOS-6216: app-schema axis order is wrong if bbox property is specified in POST request.
[andrea.aime] Adding missing libjpegturbo release files
[andrea.aime] [GEOS-6171] 'Disk used' to say 'N/A' when quota off
[andrea.aime] Ops, forgot the test
[andrea.aime] And another file change too...
[andrea.aime] Fixing importer build
[jdeolive] Added documentation for importer module.
[maurobartolomeoli] GEOS-6288: moved dxf docs from community to extensions
[andrea.aime] Share the same env variables as a GetMap in the new rendering based GetFeatureInfo engine
[alessio.fabiani] - minor fix to a class header comment
[andrea.aime] Speep up epsg lookup, thus boosting significantly the tests (but also normal operation)
[daniele.romagnoli] GEOS-6256:[Supporting delete stores from REST]
[andrea.aime] [GEOS-6294] Graduate the importer module to extension status
[andrea.aime] Make sure we point to the GeoServer documentation, not the OpenGeo suite one
[andrea.aime] Adding missing i18n property
[andrea.aime] Migrate importer tests to the new tests infrastructure
[andrea.aime] [GEOS-6265] Allow integrated GWC to cascade WMS requests (other than GetMap) just like a stand alone one
[Ben.Caradoc-Davies] GEOS-6298] Build failure in gs-importer CSVDataStoreTest caused by bad URL<->File conversion
[andrea.aime] Fixing build for this module
[lago.88] Fixed an error in community/release pom.xml file caused by an old libjpeg-turbo reference
[andrea.aime] Depend on the up to date wms tests jar
[andrea.aime] Have release produce a complete src.zip (was missing most modules after the gs- prefix rename
[andrea.aime] Disabling these two tests untile they can be fixed properly
[andrea.aime] Reducing the logging level for this, as this is something the admin requested via configuration, nothing exceptional about this
[andrea.aime] GEOS-6039, don't log warnings about workspace specific styles/layer groups dirs not containing data store definitions
[andrea.aime] GEOS-6309, complain only if a valid element name cannot be found for the output format, and fix the kml producer to generate a valid output format name
[andrea.aime] GEOS-6310) GeoRSS output uses the wrong mime type
[jansen] Correct spelling of word 'cryptography'.
[andrea.aime] GEOS-6309, avoid using deprecated property editor setup so that Spring does not complain at every startup
[andrea.aime] GEOS-6309, do not complain about styles/layergroup workspace subdirectories, they are configuration, not an empty store directory
[andrea.aime] [GEOS-6312] OpenLayers output format is not listed in WMS 1.3 capabilities document
[andrea.aime] [GEOS-6304] Remove stax-api-1.0.1.jar from excel extension
[andrea.aime] [GEOS-6305] Remove unnecessary jar from WPS module archive
[andrea.aime] [GEOS-5777] Cascading WMS fails if source image is an indexed one with nbits < 8
[andrea.aime] Switch visibility of several methods to protected to allow reuse by subclassing
[andrea.aime] [GEOS-6317] GetRecordById is not accepted in POST requests
[jdeolive] accounting for gs- prefix
[daniele.romagnoli] GEOS-6184: DynamicColorMap
[jdeolive] Removing wcs 2.0 jars during wcs 1.0 run
[jdeolive] disabling wcs 2.0 for wcs 1.1 cite run
[jody.garnett] JSON format option id_policy (GEOS-6314)
[mike] Adding note about disk usage not being updated
[user] [GEOS-6322] Automatically generate the PDF documentation during the release process
[daniele.romagnoli] [GEOS-6328]: use direct read instead of JAI when creating the small sample coverage
[user] Make service strategy configurable also via system and env variable
[user] Silence the build a bit
[Ben.Caradoc-Davies] Honour quietTests in app-schema
[ksmith] Fixed unit test that depended on default values in jdbcconfig.properties
[ksmith] Fixed double trimming of offset/limit in JDBCConfig.
[daniele.romagnoli] [GEOS-6321]:Make sure to use the proper coverageName when dealing with multiple coverages
[daniele.romagnoli] [GEOS-6336]:NetCDF output coordinates management
[maurobartolomeoli] GEOS-6052: fixed VirtualTable deserializing when some elements are missing
[user] [GEOS-6338] GetFeatureInfo does not handle symbols whose size is expressed via UOM
[ksmith] Fixed vague and misleading javadoc
[ksmith] JDBCConfig was returning workspace specific services when global services were expected.
[ksmith] Updated Unit Tests for JDBCConfig
[ksmith] Fixed lack of filtering of ServiceInfo objects in JDBCConfig.
[user] [GEOS-6324] Unable to configure WPS per workspace
[andrea.aime] [GEOS-6234] Explicit advise on character encoding in the cURL-example
[andrea.aime] remove restconfig findbugs errors
[andrea.aime] [GEOS-6341] Associate css style as default for a layer from the css demo page
[daniele.romagnoli] [GEOS-6330]: REST HTML interface links to coverages contain coveragestores against instead of coverages
[andrea.aime] [GEOS-6344] PNGJWriter logs exceptions at warning level even if the client closed the connection
[andrea.aime] Removing warnings about missing formats in GeoServer preview page
[jody.garnett] Test custom dimension result has at least three bands (GEOS-6345)
[andrea.aime] [GEOS-6320] When migrating layergroups from 2.3.x Web Admin UI can fail
[jody.garnett] Force pure java tif reader for test (GEOS-6345)
[andrea.aime] [GEOS-6347] csw release packages misses the web-csw jar
[garnertb] Fix a small typo in an importer exception.
[maurobartolomeoli] GEOS-6351 fixed context bean id conflicting with css module
[surzhin.konstantin] Attribute name "type" associated with an element type "style" must be followed by the ' = ' character
[the_pleiades] i've changed '=' to ':'
[the_pleiades] i've changed '.' to '-'
[jody.garnett] Updating version numbers to 2.6-SNAPSHOT
[jody.garnett] Relax TIFF reader constrains for mac
[Ben.Caradoc-Davies] [GEOS-6354] Polar stereographic projections broken
[the_pleiades] I've chenged ':' to '{'
[the_pleiades] I've removed unnecessary quotes
[jody.garnett] revert to mvn 2 syntax for release script
[andrea.aime] [GEOS-6075] Leverage XStream ability to ignore unknown elements
[juha.hyvarinen] Add support for XML3D output format in W3DS module.
[juha.hyvarinen] Add support for octet-stream output to XML3D request. This output format is used to optimize network traffic and only elevation information is returned.
[andrea.aime] Adding an example on how to emulate the old KML marks with CSS
[andrea.aime] Fixing path to image
[maurobartolomeoli] GEOS-6362: avoid side effects in SecuredGetMapRequest getFinalURL when called multiple times (for example for fine logging)
[andrea.aime] [GEOS-6187] wfs2 + resultType=hits + maxFeatures returns bad numberMatched
[ccancellieri] fix persisters writing temporary writing
[the_pleiades] I've removed inefficient new String(String) constructor
[juha.hyvarinen] Add support for predefined LODset to XML3D output. Scale is from 1 to 10 and 10 is with maximum details.
[andrea.aime] [GEOS-6368] CSW regression: record type handling is not namespace aware anymore
[andrea.aime] Making the build serial again
[andrea.aime] Reinstating parallel build, takes too much time on Travis otherwise
[tim.schaub] Don't try to reinitialize the runtime scope when invoking a function
[tim.schaub] Fold scope initialization into eval to avoid misuse
[garnertb] Change the word 'seeding' to 'truncating' in the geowebcache rest documentation.
[tim.schaub] Try to wrap/unwrap objects for use in functions
[tim.schaub] Test wrapping/unwrapping with geo-related objects
[christian.mueller] GEOS-6378 CAS extension throws exception in case of empty URL params
[maurobartolomeoli] GEOS-6380: updated tomcat JNDI tutorial with note on jdbc driver removal
[jody.garnett] Assorted CSS doc glitches [GEOS-6211]
[jody.garnett] PostGSI doco -primary key WFS-T restrictions, and mention multi-line labels
[damianofds] Modifications on the input/output limit check and addition of tests on the netcdf-out community module
[jdeolive] Added WPS process to GeoPackage. Closes #500.
[jdeolive] Using FeatureTypeInfo abstract/description for GeoPackage metadata
[jdeolive] Added mbtiles profile, and mbtiles module to geopkg profile
[damianofds] Moved code to geotools and imageio-ext
[christian.mueller] GEOS-6381 Missing user roles if using Authkey Authentication Filter
[andrea.aime] [GEOS-6387] VectorRenderingLayerIdentifier will return the same feature multiple times, if there are multiple rules in the SLD matching it
[jody.garnett] Introduce ResourceStore API with initial FileSystemResourceStore and DataDirectoryResourceStore implementations.
[jody.garnett] Update assignment agreement instructions and add a CONTRIBUTING.md file for GitHub
[andrea.aime] Addig a profile to include colormap extension in the build
[daniele.romagnoli] [GEOS-6372]: Support CoverageBandDetails customization: name, null values, range
[jody.garnett] Fix markdown errors using github preview
[planablediglet] GEOS-6394 - importer cannot handle jagged geojson
[niels] GeoPackage & MbTiles: Plugin Configurations
[niels] GeoPackage & MBTiles: documentation
[jdeolive] Updated WPS section of developer to reflect current state of code.
[lago.88] Footprint doc
[lago.88] Minor fixes on footprint documentation
[jody.garnett] i've changed LOGGER to private static final
[jody.garnett] Remove reference to private LOGGER
[jody.garnett] Ensure ResourceStore does not return null and pull request feedback
[jody.garnett] Fix reference to LOGGER
[jody.garnett] Port LockProvider from GWC
[jody.garnett] Integration of LockProvider with Resource API
[daniele.romagnoli] Minor fix on array size, wrong initialization
[andrea.aime] [GEOS-5964] Make GeoServer nodes in a cluster identifiable by label and color in the UI
[daniele.romagnoli] [GEOS-6377]: Support null values on WCS 2.0 DescribeCoverge
[fgdrf] updated German properties files (sync from Transifex)
[fgdrf] updated French properties files (sync from Transifex)
[fgdrf] updated/added Japanese properties files (sync from Transifex)
[fgdrf] updated Romanian properties files (sync from Transifex)
[fgdrf] updated Polish properties files (sync from Transifex)
[fgdrf] updated Korean properties files (sync from Transifex)
[fgdrf] initial contribution for Russian properties files (sync from Transifex - 96%)
[fgdrf] added translations for csw extension (sync from Transifex)
[blanchard.glen] Fix NPE when CRS Envelope isn't available and just use the envelope as is
[andrea.aime] [GEOS-5511] Help icons on various GWC pages do nothing (icons removed, they have been confusing users long enough)
[andrea.aime] Whoops, last commit left some tags unbalanced and broke the build
[jdeolive] Providing better logging when fallback on embedded data directory occurs.
[jody.garnett] Update references to 2.6 for master
[jody.garnett] UI integration of Lock Provider (includes docs)
[niels] App-schema docs: Fix formatting errors (trivial)
[ijturton] removed unicode dashes
[ijturton] changed file to png
[jody.garnett] Missed dependencies thanks for the fix Kevin
[andrea.aime] Track rename of dependent artifacts.
[andrea.aime] Added back sorting of attributes since some client libraries order attributes differently.
[andrea.aime] No longer need to use SyncGML output format. Switched to GML3.
[andrea.aime] Apply patches from Dale to compute sha1 of time the same when client uses XMLGregorianCalendar.
[andrea.aime] Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[andrea.aime] [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[lago.88] [GEOS-6339] Add documentation to ImageMosaic module
[andrea.aime] [GEOS-5683] Implementation of OtherSRS for WFS getCapabilities as a global srs-list, and [GEOS-1207] No way to configure acceptable target SRS by feature type
[andrea.aime] [GEOS-5532] Renaming workspaces doesn't translate over to Tile Caches
[andrea.aime] [GEOS-3662] Documentation for jp2kak extension
[andrea.aime] [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[ksmith] Don't add filter for advertised layers when not GetCap request
[ksmith] Reinitialize Logging if JDBCConfig differs from logging.xml
[maurobartolomeoli] Promoted printing module from community to extension and updated mapfish print-lib version to 2.0.0
[andrea.aime] [GEOS-5550] Top/Bottom statement on Layers Group
[ccancellieri] fix jetty log versions and deps
[jody.garnett] suppress several pages of response output
[andrea.aime] [GEOS-6383] Allow admin to specify selection strategy for the WMS dimensions default values
[andrea.aime] Use GeoTools NearestVisitor
[andrea.aime] Added section 'Edit dimensions' in the user guide under webadmin/data/layers
[andrea.aime] [GEOS-6410] LookAt value in SimpleNetworkLinkBuilder not set correctly, and [GEOS-6411] Time and elevation parameter is not passed in KML export
[jody.garnett] Resource addListener / removeListener with Await test support class
[jody.garnett] TestCase for Content and Content.Read
[jody.garnett] Remove Content interface
[jody.garnett] Revise based on feedback
[Ben.Caradoc-Davies] Update release guide to fix broken links and add maintenance release instructions
[lago.88] Creation of a module for grib support
[andrea.aime] [GEOS-6451] Allow direct raster rendering path to work against rendering transformations as well
[jdeolive] Extend the rest config support for the script community module. Closes #556.
[Ben.Caradoc-Davies] [GEOS-6445] IOUtils.xStreamPersist fails if /tmp on a different filesystem
[daniele.romagnoli] GEOS-6455: Updating GeoServerInitStartupListener
[maurobartolomeoli] GEOS-6456: CSW GetRecords numberOfRecordsReturned is negative if startPosition > numberOfRecordsMatched
[christian.mueller] GEOS-6542 CAS doesn't work with GeoServer
[christian.mueller] Cumulative fix for
[andrea.aime] [GEOS-6457] Make the dispatched Operation available in Dispatcher.REQUEST thread local
[jody.garnett] Migrate use of GeoserverDataDirectory to GeoServerResourceLoader.
[jody.garnett] Small fix for modify workspace, modify namespace to respect change of directory name.
[jody.garnett] GeoServerExtensionsHelper class
[maurobartolomeoli] GEOS-6459: removed dependency from online resources in printing module unit tests
[jody.garnett] GEOS-6461 GeoServerPersister stray namespace and workspace files
[jody.garnett] Migrate proxy config file to Resource
[andrea.aime] [GEOS-6420] WMS GetFeatureInfo does reproject the featureMember geometry in GeoServer 2.5
[andrea.aime] Adding back lost node id doc page
[jody.garnett] Update StreamingSVGMap to use filter factory
[ccancellieri] GEOS-6466 CSSDemoPage may create the sld file before a CatalogAddEvent is fired
[simone.giannecchini] GEOS-6466, CSSDemoPage may create the sld file before a CatalogAddEvent is fired
[gabriel.roldan] make GWCIntegrationTest's set up repeated for each test. Otherwise it can fail on certain platforms
[gabriel.roldan] GEOS-6468: force eager creation of GWCLifeCycleHandler to avoid a shutdown failure that prevents datastores to be disposed
[andrea.aime] Fix wrong type declaration in one of the tables
[andrea.aime] Removing xerces from the bin package, attempt to fix some cite failures while putting the bit on a diet
[andrea.aime] Force connection validation
[andrea.aime] Update CONTRIBUTING.md
[andrea.aime] [GEOS-6471] GetFeatureWithLock expiry is not parsed when using WFS 1.1 POST requests
[simone.giannecchini] fixing documentation for libJPEG-Turbo
[andrea.aime] [GEOS-6458] Allow plugins to customize XStreamPersister (register custom converters, aliases and the like)
[andrea.aime] Extract a reusable reorderable panel base class
[andrea.aime] A reusable enum choice renderer for wicket dropdowns
[andrea.aime] [GEOS-6478] Dynamic dimensions value module
[andrea.aime] Follow up on [GEOS-6383], the code NPE's against old configurations that have no strategy set
[andrea.aime] Fix colormap module after Jody's refactor, the location of the ramp was missing the . before the extension
[lago.88] Fixed REST upload
[andrea.aime] Adding the dynamic dimension defaults module to the nightly build
[jared.erickson] Add script wicket user interface
[andrea.aime] [GEOS-6414] WMS-T time range query incorrect, patch by Chris Van Orman
[jody.garnett] Change compile target to 1.7
[ksmith] Change compile target to 1.7
[jody.garnett] Call GeoTools init and suppress JAI warnings
[andrea.aime] Adding log config and connection validation to wfs 1.0 too
[andrea.aime] GEOS-6484 Improve bbox reprojection accuracy
[mike] Updating/correcting x509 tutorial
[Ben.Caradoc-Davies] [GEOS-6482] Scale line pixel wrong location causes failure in GetMapIntegrationTest
[andrea.aime] [GEOS-6487] Coverage band customization fails against old raster layers (making the layer unusable)
[lago.88] Modifications on the REST interface supporting pathMapper
[ksmith] Moved responsibility for building security filter from SecureCatalogImpl to ResourceAccessManager
[andrea.aime] [GEOS-6491] Add legend preview in the style edit pages
[ksmith] Unit Test fixes
[Craig.Jones] Fix leaking connection when 'Return bounding box' is selected for WFS service
[andrea.aime] [GEOS-6491], alternative approach that does not break the build
[damianofds] Upgraded ImageIO-Ext version from 1.1.9 to 1.1.10
[andrea.aime] [GEOS-6495] Allow specification of min/max/domain attributes in python process input arguments
[andrea.aime] Update contributor agreement link
[andrea.aime] Update some links previously pointing to the confluence site
[ksmith] Added Javadoc
[Ben.Caradoc-Davies] More permissive fix for [GEOS-6482] Scale line pixel wrong location causes failure in GetMapIntegrationTest
[damianofds] Fixed geoserver rest-ext plugin release build
[andrea.aime] [GEOS-6504] If one of the top level service configuration files fails to load, the whole startup fails
[andrea.aime] [GEOS-6503] WPS won't work with workspace specific urls, a 404 is returned, and also, [GEOS-6501] Links in workspace specific WPS GetCapabilities are incorrect
[andrea.aime] Whoops, forgot a file
[mike] Updating CSS section
[lago.88] [GEOS-6505]Fixed test failure on RESTMapperTest class
[andrea.aime] [GEOS-6506] Allow custom namespaces for scripted processes
[mike] Updating license info
[andrea.aime] [GEOS-6507] DescribeProcess should return the default value in literal input description
[andrea.aime] [GEOS-5143] Update CodeMirror to the 4.x series
[andrea.aime] [GEOS-5143] Detect codemirror unsupported editors and fall back to textarea
[christian.mueller] GEOS-6514 Restrict MIME types for WMS GetMap and GetFeatureInfo requests
[andrea.aime] Fixing web build
[ksmith] Fixed failing unit test from GSIP-113 PR
[andrea.aime] [GEOS-6522] Add support for raw inputs and outputs to GeoServer WPS
[andrea.aime] [GEOS-6524] Allow python wps processes to fill the input and output Parameter metadata section
[jody.garnett] fix wiki links
[jody.garnett] suppress a few doc warnings
[christian.mueller] GEOS-4943 /geoserver/accessDenied.jsp not found
[gabriel.roldan] upgrade to guava 17.0
[gabriel.roldan] Fix usage of Stopwatch, call to start() left after createStarted() by mistake
[andrea.aime] [GEOS-5545] Two different SLD's that seem to be connected
[damianofds] Fixed issue on REST upload with externally configured mosaics
[ksmith] Refactor GeoServerPersister to use ResourceStore API.
[ksmith] Listen for changes to an SLD and invalidate ResourcePool
[ksmith] Unpack resources used by SLD
[ksmith] Workaround for GEOT-4803
[ksmith] Allow injection of ResourceLocator
[ksmith] Unpack Resources to Files using ResourceLocator
[ksmith] Deprecate security file methods on GeoServerDataDirectory
[ksmith] Add rename and delete operations to Resource
[ksmith] Make Resource ostreams thread safe
[planablediglet] GEOS-6533-6534 improve File/AbstractURL Publisher
[riniangreani] Very basic test for paging works.
[andrea.aime] [GEOS-6535] Allow scripted processes to advertise progress status
[andrea.aime] [GEOS-6536] Provide GeoServerLifecycleHandler a callback right before reload starts
[jdeolive] Removing jaitools snapshot repository
[maurobartolomeoli] GEOS-6530 Implemented PagedUnique WPS process
[ksmith] Allow workspace to be specified as a parameter in GWC
[jared.erickson] Add support for wps namespaced scripts with the rest config module
[christian.mueller] Adjust copyright headers
[riniangreani] Test denormalised view for paging.
[lago.88] [GEOS-6537] Improve documentation about JNDI connection pool configuration
[maurobartolomeoli] GEOS-6530: moved JSON encoding into PPIO class
[andrea.aime] [GEOS-6541] Document usage of transformation functions in CSS
[andrea.aime] Upgrade cobertura to a java 7 compatible version
[ksmith] Unit test for GWC Workspace parameter
[jared.erickson] Add support for WPS scripts with custom namespaces.
[jared.erickson] Use CodeMirror as the editor for scripts.
[jody.garnett] SourceForge directory structure changed
[jody.garnett] update mac release offline instructions
[smithkm] Document WORKSPACE parameter
[christian.mueller] Cumulative Fix for
[jdeolive] Storing intermediate jjtree artifactes outside of generates-sources.
[daniele.romagnoli] GSIP-115: CoverageView GUI and classes
[weskamm] added documentation for featuretypecachesize
[jody.garnett] javadoc clarification
[maurobartolomeoli] GEOS-6402: workaround for dxf extension to handle
[Ben.Caradoc-Davies] Fix ResourcePoolTest failure in path with spaces [GEOS-6551]
[Ben.Caradoc-Davies] Fix GeoServerPersisterTest failure in path with spaces [GEOS-6551]
[Ben.Caradoc-Davies] Fix support for dynamic symbolizer CQL templates [GEOS-6551]
[ksmith] Validate content of MetadataLinkInfo as a URL
[Ben.Caradoc-Davies] Fix bad URL to File conversion
[Ben.Caradoc-Davies] Fix GeoServerPersisterTest and the build
[maurobartolomeoli] GEOS-6550: updated printing plugin dependency to mapfish print-lib 2.1.0, that includes many bugfixes
[planablediglet] GEOS-6394 import can fail on windows
[git] Must be WFS instead of WMS
[jdeolive] Calling findFile rather than findDataFile when looking up wps temp resource.
[jdeolive] Using a custom class object stream to deserialize during cloning, GEOS-6560
[andrea.aime] [GEOS-4149] Make continuous wrapping for raster layers work like it does for vector layers (and general projection handling improvements)
[jdeolive] Using sqljdbc4 artifact in driver profile since it's required on java 7.
[jdeolive] Fixing outdated remote ows tests
[jdeolive] Swapping out wfs for wfs-ng
[richardfuch] Fix a typo in overview.rst
[planablediglet] importer - ensure layer has projection policy
[maurobartolomeoli] GEOS-6245: implemented dynamic width and height calculation for Style LegendURL in WMS Capabilities
[maurobartolomeoli] GEOS-6245: little fix to size calculation
[maurobartolomeoli] GEOS-6567: reimplemented AuthenticationCache using Guava library
[christian.mueller] GEOS-6528 Change master password using REST API
[rob] support booleans in MapJSONFormat
[maurobartolomeoli] GEOS-6567: added explicit entry expiration check
[maurobartolomeoli] GEOS-6245: switched using local storage in data_dir for cached samples
[maurobartolomeoli] GEOS-6245: fixed some tests randomly failing
[andrea.aime] [GEOS-6385] Rendering-based GetFeatureInfo does not work properly against polygons stroked but not filled and [GEOS-6502] stroke-Dasharray style partially breaks WMS getfeatureinfo
[jared.erickson] Move the scripting web ui into a new sub module.
[damianofds] add more documentation to connection pool parameters
[jody.garnett] remove catalog listener on dispose
[maurobartolomeoli] GEOS-6245: fixed missing samples folder creation
[maurobartolomeoli] GEOS-5318: fix xss vulnerability in OpenLayersMapOutputFormat
[jody.garnett] GWC Endpoint Documentation (GEOS-3719)
[jody.garnett] Clarify GeoServer Version / Java Version in docs (GEOS-5670)
[jody.garnett] Switch to Java 7
[Ben.Caradoc-Davies] Updated app-schema online tests to expect improved curve encoding
[daniele.romagnoli] [GEOS-6564]:WCS Granule stack duplicated entries + unit test for multi dimensional output
[christian.mueller] Rename XML/JSON elements for GEOS-6528 Change master password using REST
[daniele.romagnoli] GEOS-4834: original patch to fix transparency in animaged gif + tests
[daniele.romagnoli] GEOS-6476: Fixing NPE on animate requests on WMS-EO plugin
[fgdrf] Initial Turkish properties files : Thanks to Eren CON and Team
[lago.88] [GEOS-6576] Modify gs-grib module after moving coverage-multidim
[daniele.romagnoli] GEOS-6577: Updating documentation, referring the proper imageio-ext version
[andrea.aime] [GEOS-2935] Support for Oracle curve geometries
[andrea.aime] Fixing first trivial build issue, one more problem in app-schema remains
[damianofds] [GEOS-6579] Wrong kvp parser for interpolation for WCS version 1.0.0
[andrea.aime] Compile fix, and test fix, when you ask for a Curve, you should get one, not a LineString
[damianofds] [GEOS-6580] OWS Dispatcher log could be improved
[jdeolive] GSIP 117 - Pluggable styles, GEOS-6581. Fixes #645
[andrea.aime] [GEOS-6582] GeoServer fails to report the current process task in the status response
[planablediglet] jdbcconfig - prevent stacktraces in tests
[planablediglet] jdbcconfig - enable spring transactions in tests
[planablediglet] jdbcconfig - better db test support
[planablediglet] jdbcconfig - fix oracle backend support
[jody.garnett] Additional Java 7 notices and config.py paths (GEOS-6574)
[andrea.aime] Make sure we indent output when running on jdk 7, right now we're getting a flat result
[andrea.aime] [GEOS-6508] WFS 2.0 three way join fails with a NPE
[jody.garnett] Fix javadocs for JDK 1.7
[andrea.aime] Adding documentation for curved geometries
[andrea.aime] Make sure we use java 7 also in tests
[andrea.aime] Removing un-needed dependency towards commons-digester
[andrea.aime] Removing some unused dependencies
[andrea.aime] Removing gt-validation from web modules, not used there either
[andrea.aime] Moving validation module to community
[andrea.aime] Reverting pom.xml assembly modification inadvertedly pushed to github
[andrea.aime] [GEOS-6519] WPS not enabling in workspace
[fgdrf] updated Turkish properties files
[jody.garnett] Check params before clearing dataStoreCache (GEOS-6575)
[jody.garnett] javadoc and log clarification of DataStoreCache use (GEOS-6575)
[jdeolive] Avoiding full namespace scan on GetFeature request, GEOS-6597.
[andrea.aime] [GEOS-6502] stroke-Dasharray style partially breaks WMS getfeatureinfo
[andrea.aime] [GEOS-6572] WMS GetFeatureInfo Request Returns Too Many Features
[andrea.aime] [GEOS-6599] Do not log all SerializableRenderedImage misguided attempts to connect to a server
[riniangreani] Make all online tests pass with paging changes.
[lago.88] [GEOS-6379] Unable to add new default gridsets
[andrea.aime] [GEOS-6600] Allow clients to decide whether to use the OGC simplified scale computation, or an accurate one
[jody.garnett] Always reset DataAccess if sql_views used, or if last feature type deleted
[riniangreani] More test cases
[riniangreani] Paging documentation update for app-schema.
[damianofds] [GEOS-6603] Add a button for disabling native warp
[jared.erickson] Improve style editor browser detection and handle browsers that don't support codemirror
[jody.garnett] Edit GenericUnWrapper with test (GEOS-6578)
[jody.garnett] Guard against NPE in ResourcePool.FeatureTypeCache.dispose(...)
[jody.garnett] Fix handling of NPE in AdvancedDispatchFilter (GEOS-6529)
[andrea.aime] [GEOS-6604] WMS GetFeatureInfo using 'vendorParams: propertyName' does not working after upgrade to 2.5.x
[jdeolive] Updated repository settings for new boundless maven repo.
[jdeolive] Allowing multiplexing password encoder to encode passwords.
[jdeolive] Removing dead bean definition.
[ksmith] Use correct CRS representation and axis order for WFS GeoJSON
[ksmith] Document GEOSERVER_GEOJSON_LEGACY_CRS
[jdeolive] Including required compress jar in jdbcconfig assembly
[jody.garnett] Flush ContentState during FeatureType DELETE (GEOS-6616)
[andrea.aime] Some windows running/installer fixes
[andrea.aime] [GEOS-6619] Rendering based feature info will return just one geometry of the group that falls into the same pixel
[jdeolive] Fixing links to old website
[jared.erickson] Fix style editor tests
[jdeolive] Updating OSX installer for Oracle JVM, fixes GEOS-6588
[Tom] added wfserviceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618
[Tom] added wcs100ServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618
[Tom] added wcs111ServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618
[Tom] added cswServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618
[Tom] added wpsServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618
[andrea.aime] [GEOS-6622] Add support for WCS 2.0 requests crossing the dateline
[jdeolive] Updating version numbers to 2.7-SNAPSHOT
[ksmith] Check for nulls when generating GeoJSON
[riniangreani] Update gt version to 13-SNAPSHOT
[damianofds] Upgrade GWC dependency to 1.7-SNAPSHOT
[damianofds] [GEOS-6627]GWC causes a wrong handling of the ImageIO and ImageIO-Ext plugins
[lago.88] [GEOS-6628] NullPointerException when setting empty ParameterFilter
[maurobartolomeoli] GEOS-6245: fixed OnlineResource GetLegendGraphic width and height parameters
[daniele.romagnoli] [PGRaster] - Community module
[daniele.romagnoli] GEOS-6338: Fixing DescribeEOCoverageSet against coverageView
[jdeolive] Updated OpenLayers output format to include OL3.
[jdeolive] Documenting ENABLE_OL3 toggle for OpenLayers output format
[andrea.aime] Add file choosers for netcdf and grib files
[Ben.Caradoc-Davies] [GEOS-6632] Cross-site scripting vulnerability in WMS exceptions
[daniele.romagnoli] GEOS-6641
[daniele.romagnoli] GEOS-6642: NetCDF ouput on Coverage Views may throws exceptions when dealing with input bands coming from different input files
[Ben.Caradoc-Davies] Revert "added wfserviceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618"
[Ben.Caradoc-Davies] Revert "added wcs100ServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618"
[Ben.Caradoc-Davies] Revert "added wcs111ServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618"
[Ben.Caradoc-Davies] Revert "added wpsServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618"
[Ben.Caradoc-Davies] Revert "added cswServiceInterceptor* wildcard to proxy list in applicationContext for GEOS-6618"
[Ben.Caradoc-Davies] Bundled commons-digester jar in app-schema plugin [GEOS-6589]
[damianofds] [GEOS-6645] NPE when trying to reload bands with empty range
[gabriel.roldan] Make GWCLifeCycleHandler behave correctly on application shutdown.
[gabriel.roldan] Revert "Make GWCLifeCycleHandler behave correctly on application shutdown."
[jody.garnett] c) 2014 Open Source Geospatial Foundation (GSIP-118)
[jody.garnett] Missed a few (GSIP-118)
[jody.garnett] Change instructions for OSGeo license, headers and use of GitHub for docs
[gabriel.roldan] Restore "Make GWCLifeCycleHandler behave correctly on application shutdown."
[jody.garnett] A few more references to openplans
[unknown] - A GPX PPIO for WPS
[unknown] - A KML PPIO for WPS
[simone.giannecchini] fixing community release
[simone.giannecchini] addin kml to community release
[strk] Update postgis website to postgis.net
[ksmith] Update JDBCConfig documentation to warn of security risks
[daniele.romagnoli] GEOS-6648: Report proper uom, nilValue, ranges on GML GetCoverage requests
[damianofds] GEOS-6658 and a minor fix on the bound generator
[damianofds] [GEOS-6695] GeoPackageProcess should support the configuration of an external file
[daniele.romagnoli] [GEOS-6407]: Inspire plugin initializer fix
[parker] Renamed aus_dem.tif to aus_dem.tiff. Top level pom file lists *.tiff
[bradh] Minor docfixes in python extension.
[bradh] Trivial spello and whitespace fixes in CONTRIBUTING.md
[maurobartolomeoli] GEOS-5994: added missing namespace from wcs 1.1 schemaLocation
[jared.erickson] Fix failing RestConfig StyleTest due to file locking issues on Windows
[jared.erickson] OWS FilePublisherTest fails on Windows due to file encoding issues
[parker] Fixed (most) of the failing tests in the BIL module. Changed test to
[jody.garnett] docs update for gt-render improvements in code sprint
[jody.garnett] update install instructions
[ivanfm] Update pointsymbols.rst
[ivanfm] update css stylemarks with windbarbs information
[ivanfm] Update styledmarks.rst
[parker] Corrected error in user manual. WMS Basics section incorrectly specifies
[mike] Update pointsymbols.rst
[mike] update css stylemarks with windbarbs information
[mike] windbarbs example files
[bmmpxf] Update CONTRIBUTING.md
[jdeolive] Updating css demo to handle case of style natively being stored in css.
[martins.linde] added scripting web UI docs, added docs for WFS TX and Filter Function hooks
[Ben.Caradoc-Davies] Revert "GEOS-6648: Report proper uom, nilValue, ranges on GML GetCoverage requests"
[volayaf] Some small changes in certificates tutorial
[lago.88] [GEOS-6673] AbstractTilesGetMapOutputFormat should perform cleanup continuously
[jdeolive] Removing manual formatChoice procesing during validation. Fixes GEOS-6666.
[maurobartolomeoli] GEOS-6675: workaround fix for wfs 1.1 cite tests failures
[jared.erickson] The Scripting app resource throws null pointer exception is main script isn't found.
[leigh] SQL Server extension installation
[damianofds] [GEOS-6672] Creation of a WPS Process for mbtiles generation
[daniele.romagnoli] [GEOS-6679]: WCS20 GetCoverage multipart does encoding 2 times
[lago.88] [GEOS-6680]Creation of a new wps process for downloading vector and raster data as zip
[juha.hyvarinen] c) 2014 Open Source Geospatial Foundation (GSIP-118)
[maurobartolomeoli] GEOS-6675: generalized fix to be applied always, not only for cite-tests and restricted to HTTP GET
[Ben.Caradoc-Davies] Updated geopkg GeoPackageGetMapOutputFormat to use continuous cleaning as in mbtiles AbstractTilesGetMapOutputFormat
[lago.88] Minor fix on a test for wps-download module
[lago.88] [GEOS-6681] New REST parameter for disabling exception logging
[bradh] Update README.md
[andrea.aime] [GEOS-6647] Failure to generate WMS capabilities document when cascading a WMS server that does not advertise GetFeatureInfo
[jared.erickson] Add docs for the scripting community module's rest api
[daniele.romagnoli] [GEOS-6684]: Fixing WPSInfo Title management
[jared.erickson] Add warning about changing the default admin password to get the scripting rest api to work
[damianofds] [GEOS-6685] WrappedSampleDimension sets NoData category as qualitative
[alex3305] [GEOS-6654] Refer to right Xlink XSD in WFS
[jdeolive] Removing reference to Info.plist, no longer needed with new mac installer
[andrea.aime] [GEOS-5312] CSV WFS output format doesn't deal with Windows newlines
[andrea.aime] [GEOS-5034] Non-advertised layers should appear in the layer-specific virtual service GetCapabilities document
[jdeolive] Using ResponseUtils.appendPath to build urls for demo request page.
[andrea.aime] Adding docs for the 'partials' labelling vendor option
[lago.88] [GEOS-6686] MBTiles and GeoPkg are not correctly shown in LayerPreview
[dwinslow] Render LinearRings in WPS WKT output as LineStrings
[dwinslow] Enable geojson geometry output in WPS
[jdeolive] Handling multi part form upload to the dispatcher.
[andrea.aime] [GEOS-6697] Avoid adding null messages in exception reports
[andrea.aime] [GEOS-6699] Add a FeatureTypeCallback extension point to allow creation/flush of configured feature types in stores
[andrea.aime] [GEOS-6700] Add GUI integration for the SOLR data store
[andrea.aime] [GEOS-6701] Provide better error messages when wfs sortby attribute does not exists
[andrea.aime] Qualify which feature type the property is not part of
[bradh] Fix broken CCLA link
[jdeolive] Creating zip entry for directories.
[andrea.aime] [GEOS-6705] JMS based clustering module
[andrea.aime] Some initial docs for the clustering extension
[andrea.aime] Adding LICENSE.txt to the root, just like our headers say
[andrea.aime] GEOS-6692 do not assume that the subset envelope is using WGS84 lat lon
[andrea.aime] Adding missing pom file
[parker] Changed expected content length for application/bil test to match
[Ben.Caradoc-Davies] Fixed jms-cluster artifactId and removed inconsistent property activation
[jdeolive] Allow StyleGenerator to create style inside of a workspace.
[jdeolive] Added DataStoreFactoryInitializer for GeoPkg. Fixes GEOS-6708.
[Ben.Caradoc-Davies] [GEOS-6707] SortBy property name validation breaks app-schema
[Ben.Caradoc-Davies] Fixed jms-cluster artifactId in community release pom
[andrea.aime] Fixing some issues reported by Mark Jansen during a pull request review
[maurobartolomeoli] GEOS-6711: improvements for the authkey module, by mapper parameters and
[maurobartolomeoli] GEOS-6711: added some documentation for the improvements
[simone.giannecchini] GEOS-6716, Add SolR plugin to the community release
[andrea.aime] Adding SOLR data store docs
[andrea.aime] [GEOS-6717] Improve store param hover labels
[andrea.aime] [GEOS-6718] Allow the admin to specify which SOLR geometry attribute should be the default one
[andrea.aime] Document choosing default geometry field
[andrea.aime] Document SOLR f and fq viewparams
[andrea.aime] Make sure this clustering sub-title does not appear in the community index page
[...truncated 3774 lines...]
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Make sure this clustering sub-title does not appear in the community index page
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.10.2014 @ 09:31:54 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Oct-2014 21:27
[INFO] [GitCommitIdMojo] build.build.time = 11.10.2014 @ 21:32:18 UTC
[INFO] [GitCommitIdMojo] build.branch = 0bf32f88cf6f56be8c35cbed3b98665a664232b4
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0bf32f8
[INFO] [GitCommitIdMojo] build.commit.id = 0bf32f88cf6f56be8c35cbed3b98665a664232b4
[INFO] [GitCommitIdMojo] build.commit.message.full = Make sure this clustering sub-title does not appear in the community index page
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ community <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ community ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ community >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ community ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/.git’> repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ community <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ community ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ community ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/2.7-SNAPSHOT/community-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/community-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/2.7-SNAPSHOT/community-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer Extensions 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ extension ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/extension/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ extension ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ extension ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/extension/target/extension-2.7-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ extension >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ extension <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ extension ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ extension >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ extension <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ extension ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ extension ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.7-SNAPSHOT/extension-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/extension/target/extension-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.7-SNAPSHOT/extension-2.7-SNAPSHOT-tests.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.086s]
[INFO] Core Platform Module .............................. SUCCESS [7.587s]
[INFO] Open Web Service Module ........................... SUCCESS [8.057s]
[INFO] Main Module ....................................... SUCCESS [32.567s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.224s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [6.540s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.390s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.824s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [7.491s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [10.440s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.936s]
[INFO] Web Feature Service Module ........................ SUCCESS [17.172s]
[INFO] Web Map Service Module ............................ SUCCESS [18.101s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.397s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.042s]
[INFO] REST Support Module ............................... SUCCESS [5.500s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.515s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.078s]
[INFO] Core UI Module .................................... SUCCESS [16.508s]
[INFO] WMS UI Module ..................................... SUCCESS [6.888s]
[INFO] GWC UI Module ..................................... SUCCESS [8.861s]
[INFO] WFS UI Module ..................................... SUCCESS [5.391s]
[INFO] Demoes Module ..................................... SUCCESS [7.692s]
[INFO] WCS UI Module ..................................... SUCCESS [6.802s]
[INFO] Security UI Modules ............................... SUCCESS [0.132s]
[INFO] Security UI Core Module ........................... SUCCESS [13.034s]
[INFO] Security UI JDBC Module ........................... SUCCESS [6.856s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.609s]
[INFO] REST UI Module .................................... SUCCESS [5.538s]
[INFO] GeoServer Web Application ......................... SUCCESS [5.836s]
[INFO] Community Space ................................... SUCCESS [0.117s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.143s]
[INFO] BUILD SUCCESS
[INFO] Total time: 4:23.640s
[INFO] Finished at: Sat Oct 11 21:32:19 UTC 2014
[INFO] Final Memory: 43M/121M
[geoserver-master] $ /opt/apache-maven-3.0.4/bin/mvn -f src/community/pom.xml assembly:attached
[INFO] Scanning for projects...
[INFO]
[INFO] Building Community Space 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-assembly-plugin:2.1:attached (default-cli) @ community ---
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-authkey-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-ftp-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-python-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-groovy-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-javascript-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-spatialite-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-jdbcconfig-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-simpleFeatureService-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-dds-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-aggregate-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-wms-eo-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-netcdf-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-netcdf-out-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-colormap-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-mbtiles-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-geopkg-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-grib-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-pgraster.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-dyndimension-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-rest-ext.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-kmlppio-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-gpx-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-wps-download-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-jms-cluster-plugin.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-activeMQ-broker.zip>
[INFO] Building zip: <http://ares.opengeo.org/jenkins/job/geofence-master-nightly/ws/src/community/target/release/geoserver-2.7-SNAPSHOT-solr-plugin.zip>
[INFO] Total time: 43.698s
[INFO] Finished at: Sat Oct 11 21:33:05 UTC 2014
[INFO] Final Memory: 11M/181M
[geoserver-master] $ /bin/sh -xe /tmp/hudson8845780386567378638.sh
+ ver=master
+ dist=/var/www/geofence/master
+ date +%Y-%m-%d
+ datestamp=2014-10-11
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ cp gui/web/target/geofence.war /var/www/geofence/master/geofence-master-2014-10-11-war.zip
cp: cannot create regular file `/var/www/geofence/master/geofence-master-2014-10-11-war.zip': No such file or directory
Build step 'Execute shell' marked build as failure
