[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #305
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/305/&gt;
[...truncated 14300 lines...]
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.831 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.987 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.188 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.237 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.634 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.102 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.780 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:13 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.949 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.476 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.910 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 56.703 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:30 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.174 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:24 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.317 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:18 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.087 s]
[INFO] Core UI Module ..................................... SUCCESS [01:25 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.064 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.920 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.408 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.596 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.193 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.977 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.421 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.110 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:24 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.124 s]
[INFO] Printing Module .................................... SUCCESS [ 13.677 s]
[INFO] Community Space .................................... SUCCESS [ 0.052 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.041 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.653 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.914 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.979 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.078 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.449 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.285 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.664 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.634 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.032 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.342 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.044 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.215 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.090 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.034 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 14.754 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.581 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.249 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.498 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.713 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.289 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.332 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.123 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.399 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.048 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.088 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.888 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.083 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.593 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.806 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.057 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.899 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.482 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 44.610 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.610 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.068 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.371 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.044 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.864 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.103 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.436 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 43.297 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 25.346 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.358 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.741 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.628 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.585 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:46 min (Wall Clock)
[INFO] Finished at: 2017-05-26T20:49:38+00:00
[INFO] Final Memory: 125M/518M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/306/&gt;
[...truncated 14243 lines...]
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.808 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.075 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.271 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.837 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.140 s]
[INFO] Main Module ........................................ SUCCESS [02:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.097 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 59.719 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:09 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.633 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.842 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.768 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 51.382 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:28 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.185 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:22 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.203 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.047 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.810 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.871 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.850 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.585 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.203 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.078 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.082 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:23 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:09 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.123 s]
[INFO] Printing Module .................................... SUCCESS [ 14.072 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.882 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.689 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.100 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.127 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.428 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.275 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.232 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.148 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.676 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.311 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.995 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.949 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.378 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.495 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.154 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.397 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.073 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.060 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.045 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.815 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.283 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.053 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.906 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.603 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.545 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.080 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.646 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.259 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.275 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.171 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.029 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.196 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.064 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.058 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.344 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 43.001 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 24.353 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.962 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.626 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.071 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.792 s]
[INFO] Total time: 20:20 min (Wall Clock)
[INFO] Finished at: 2017-05-26T23:00:17+00:00
[INFO] Final Memory: 125M/625M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/307/&gt;
