[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #71
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/71/changes&gt;
Changes:
[tbarsballe] [GEOS-7840] Consistently use java-vector-tile:1.0.9
[...truncated 16487 lines...]
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO]
[INFO] Building GeoServer 2.10-SNAPSHOT
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-api/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/library/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/modules/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/geotools/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-referencing:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-referencing:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-referencing:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-metadata:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-metadata:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-metadata:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-opengis:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-opengis:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-opengis:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-main/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-main:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/target/geoserver-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.10-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.10-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 6.801 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10.379 s
[INFO] Finished at: 2016-11-08T22:00:32+00:00
[INFO] Final Memory: 130M/433M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.10-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.10-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
This looks to be being caused by issues with the certificate on repo.boundlessgeo.com. Currently looking into it.
Torben
On Tue, Nov 8, 2016 at 2:00 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/71/changes>
Changes:
[…truncated 16487 lines…]
[INFO] DXF WPS PPIO
[INFO]
[WARNING] Failure to transfer org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-referencing:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-referencing:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-metadata:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-metadata:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-opengis:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-opengis:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-main:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ geoserver —
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ geoserver —
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ geoserver —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/target/geoserver-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.10-SNAPSHOT/geoserver-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] — maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver —
[INFO]
[INFO] GeoServer … FAILURE [ 6.801 s]
[INFO] Core Platform Module … SKIPPED
[INFO] Open Web Service Module … SKIPPED
[INFO] Main Module … SKIPPED
[INFO] GeoServer Security Modules … SKIPPED
[INFO] GeoServer JDBC Security Module … SKIPPED
[INFO] GeoServer LDAP Security Module … SKIPPED
[INFO] Web Coverage Service Module … SKIPPED
[INFO] Web Coverage Service 1.0 Module … SKIPPED
[INFO] Web Coverage Service 1.1 Module … SKIPPED
[INFO] Web Coverage Service 2.0 Module … SKIPPED
[INFO] Web Feature Service Module … SKIPPED
[INFO] Web Map Service Module … SKIPPED
[INFO] KML support for GeoServer … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] REST Support Module … SKIPPED
[INFO] REST Configuration Service Module … SKIPPED
[INFO] GeoServer Web Modules … SKIPPED
[INFO] Core UI Module … SKIPPED
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SKIPPED
[INFO] Demos Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SKIPPED
[INFO] Security UI Core Module … SKIPPED
[INFO] Security UI JDBC Module … SKIPPED
[INFO] Security UI LDAP Module … SKIPPED
[INFO] REST UI Module … SKIPPED
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SKIPPED
[INFO] Authentication by unique url key … SKIPPED
[INFO] WorldWind Format Module … SKIPPED
[INFO] SpatiaLite Extension … SKIPPED
[INFO] GeoServer JDBC KV Catalog … SKIPPED
[INFO] Aggregating Data Store … SKIPPED
[INFO] GeoServer Extensions … SKIPPED
[INFO] Web Processing Service parent … SKIPPED
[INFO] Web Processing Service Module … SKIPPED
[INFO] GeoServer Scripting Extensions … SKIPPED
[INFO] Core Scripting Extension … SKIPPED
[INFO] Web UI Scripting Extension … SKIPPED
[INFO] BeanShell Scripting Extension … SKIPPED
[INFO] Groovy Scripting Extension … SKIPPED
[INFO] H2 DataStore Extension … SKIPPED
[INFO] Python Scripting Extension … SKIPPED
[INFO] JavaScript Scripting Extension … SKIPPED
[INFO] Ruby Scripting Extension … SKIPPED
[INFO] WMS-EO … SKIPPED
[INFO] ColorMap … SKIPPED
[INFO] GeoServer mbtiles Extension … SKIPPED
[INFO] GeoServer GeoPackage Extension … SKIPPED
[INFO] Dynamic WMS dimension value defaults … SKIPPED
[INFO] REST plugin community module … SKIPPED
[INFO] GPX PPIO for WPS … SKIPPED
[INFO] KML PPIO for WPS … SKIPPED
[INFO] DownloadProcess … SKIPPED
[INFO] GeoServer JMS based clustering modules … SKIPPED
[INFO] ActiveMQ … SKIPPED
[INFO] GeoServer JMS clustering Commons module … SKIPPED
[INFO] GeoServer JMS clustering module … SKIPPED
[INFO] GeoServer Hazelcast Clustering Module … SKIPPED
[INFO] Solr Module … SKIPPED
[INFO] Resumable REST Upload module … SKIPPED
[INFO] GeoFence security integration … SKIPPED
[INFO] GeoFence Server … SKIPPED
[INFO] REST SLD service … SKIPPED
[INFO] Parameters Extractor … SKIPPED
[INFO] Vector Tiles … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] WPS cluster on jdbc datastores … SKIPPED
[INFO] ncWMS compatibility extension … SKIPPED
[INFO] GWC Distributed Caching Plugin … SKIPPED
[INFO] GeoWebCache S3 … SKIPPED
[INFO] OGR parent … SKIPPED
[INFO] OGR CORE … SKIPPED
[INFO] GDAL translate parent … SKIPPED
[INFO] GDAL translate WCS … SKIPPED
[INFO] GDAL translate WPS … SKIPPED
[INFO] Ysld GeoServer Plugin … SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store … SKIPPED
[INFO] GeoWebCache SQLite … SKIPPED
[INFO] GeoGig GeoServer integration … SKIPPED
[INFO] GeoServer Config Backup And Restore … SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module … SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module … SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions … SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module … SKIPPED
[INFO] WMTS Multi Dimensional … SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module … SKIPPED
[INFO] GeoServer Community Release Module … SKIPPED
[INFO] GeoServer Resource Browser … SKIPPED
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] Importer REST Api Module … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.10-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.10-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target → [Help 1]
[ERROR]
[ERROR]
Build step ‘Invoke top-level Maven targets’ marked build as failure
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/72/&gt;
