See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/89/>
[...truncated 10430 lines...]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.785 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.341 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.455 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.272 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.331 s]
[INFO] Main Module ........................................ SUCCESS [02:29 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.097 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 59.857 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:54 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.840 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.939 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.667 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.046 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:13 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.969 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.858 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.664 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 13.332 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.340 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.230 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.139 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:25 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:16 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.868 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.058 s]
[INFO] Printing Module .................................... SUCCESS [ 13.843 s]
[INFO] Community Space .................................... SUCCESS [ 0.060 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.048 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.116 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.921 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.644 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.170 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.532 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.283 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.310 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.886 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.552 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.341 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.065 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.027 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.877 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.037 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.785 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.168 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.661 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.436 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.549 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.187 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.002 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.191 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.885 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.093 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.541 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.818 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.099 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.773 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.089 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.500 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.096 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.703 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.117 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.749 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.032 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.554 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.606 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.053 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.476 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.759 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.037 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.651 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.599 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.247 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.119 s]
[INFO] Importer Core Module ............................... SUCCESS [ 49.416 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 41.789 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.283 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.346 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.492 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.619 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.695 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:26 min (Wall Clock)
[INFO] Finished at: 2016-11-23T13:57:57+00:00
[INFO] Final Memory: 111M/305M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
