[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x-nightly #29
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/29/changes&gt;
Changes:
[afabiani] - Backup & Restore Plugin Assembly Dependencies
[...truncated 3387 lines...]
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-mbtiles ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-mbtiles ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-mbtiles ---
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/dependency/gwc-core-1.10-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/dependency/gt-api-16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-mbtiles ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.10-SNAPSHOT/gs-mbtiles-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.10-SNAPSHOT/gs-mbtiles-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.10-SNAPSHOT/gs-mbtiles-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.10-SNAPSHOT/gs-mbtiles-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.10-SNAPSHOT/gs-mbtiles-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer GeoPackage Extension 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-geopkg ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geopkg ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geopkg ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geopkg ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geopkg ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geopkg ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geopkg ---
[INFO] Compiling 5 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/geopkg/src/test/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormatTest.java&gt;:\[64,25\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.444 s]
[INFO] Core Platform Module ............................... SUCCESS [ 6.587 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.056 s]
[INFO] Main Module ........................................ SUCCESS [ 28.338 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.110 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.133 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.730 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.581 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 6.158 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.592 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 9.769 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 11.911 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 15.944 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 6.726 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 10.975 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.717 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.568 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.043 s]
[INFO] Core UI Module ..................................... SUCCESS [ 13.884 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 7.555 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.483 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.320 s]
[INFO] Demos Module ....................................... SUCCESS [ 6.081 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.133 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.078 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.734 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 5.285 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.857 s]
[INFO] REST UI Module ..................................... SUCCESS [ 4.040 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.318 s]
[INFO] Community Space .................................... SUCCESS [ 0.037 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 21.268 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 20.078 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.548 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.594 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.597 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.068 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.044 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.659 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.110 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.502 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.678 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.754 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 23.596 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.320 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.026 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.201 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.972 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.218 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.345 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.661 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 5.202 s]
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:13 min
[INFO] Finished at: 2016-11-08T05:57:00+00:00
[INFO] Final Memory: 178M/490M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geopkg: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/30/changes&gt;
Changes:
[...truncated 2978 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] 1 error
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.875 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.570 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.994 s]
[INFO] Main Module ........................................ SUCCESS [ 22.996 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.068 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.094 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.551 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.512 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.659 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.634 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.666 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 11.128 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 13.568 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.324 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.061 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.713 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 8.647 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.046 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.351 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.154 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.404 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.195 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.764 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.913 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.064 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.001 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.352 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.655 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.820 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.425 s]
[INFO] Community Space .................................... SUCCESS [ 0.923 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 15.211 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 4.560 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 3.409 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.587 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 5.063 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 9.307 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.061 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.646 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.521 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.611 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 12.579 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.318 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.020 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.227 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.657 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.338 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.730 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.697 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 4.988 s]
[INFO] Total time: 05:15 min
[INFO] Finished at: 2016-11-08T11:54:30+00:00
[INFO] Final Memory: 175M/428M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/31/changes&gt;
