See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/14/changes>
Changes:
[Stefano Costa] [GEOT-5526] SQL Encoding of Filters on Nested Attributes
[alessio.fabiani] JIRA GEOS-7802 - Add a URL Mangler injecting Bearer type access tokens
[...truncated 380 lines...]
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Build Order:
[INFO]
[INFO] Community Space
[INFO] Application Schema Integration Test
[INFO]
[INFO] Building Community Space 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ community ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ community ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ community ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ community ---
[INFO] Building jar: <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ community ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ community ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ community ---
[INFO] Installing <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT.pom
[INFO] Installing <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Application Schema Integration Test 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-test ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-test ---
[INFO] skip non existing resourceDirectory <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-test ---
[INFO] Copying 141 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-test ---
[INFO] Compiling 130 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/target/test-classes>
[WARNING] COMPILATION WARNING :
[WARNING] class AbstractAppSchemaTestSupport
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[26,21\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[159,11\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[165,12\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[165,39\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO] 4 warnings
[ERROR] COMPILATION ERROR :
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[51,24\] error: cannot find symbol
[ERROR] package org.geotools.jdbc
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[693,14\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>:\[27,24\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[23,24\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[24,24\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[34,24\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[23,24\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[677,44\] error: cannot find symbol
[ERROR] class AppSchemaDataAccessConfigurator
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,8\] error: cannot find symbol
[ERROR] class AbstractAppSchemaTestSupport
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,50\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>:\[258,19\] error: cannot find symbol
[ERROR] class SRSReprojectionTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[118,8\] error: cannot find symbol
[ERROR] class NestedIdSupportTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[145,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[419,8\] error: cannot find symbol
[ERROR] class SimpleAttributeFeatureChainWfsTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[444,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[477,20\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[504,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[531,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[565,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1405,8\] error: cannot find symbol
[ERROR] class FeatureChainingWfsTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1434,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1460,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1478,47\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1480,55\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1491,12\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1515,23\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1521,51\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[759,19\] error: cannot find symbol
[ERROR] class PolymorphismWfsTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[784,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[809,19\] error: cannot find symbol
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[811,8\] error: cannot find symbol
[INFO] 31 errors
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.712 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 7.415 s]
[INFO] BUILD FAILURE
[INFO] Total time: 22.622 s
[INFO] Finished at: 2016-10-25T19:02:32+02:00
[INFO] Final Memory: 122M/507M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure: Compilation failure:
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[693,14\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[23,24\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[24,24\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[34,24\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[23,24\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[677,44\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,8\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/AbstractAppSchemaTestSupport.java>:\[711,50\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[118,8\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[145,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[419,8\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[444,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[477,20\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[504,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[531,19\] error: cannot find symbol
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/pom.xml> to org.geoserver.extension/gs-app-schema-test/2.10-SNAPSHOT/gs-app-schema-test-2.10-SNAPSHOT.pom
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[565,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1405,8\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1434,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1460,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1478,47\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1480,55\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1491,12\] error: cannot find symbol
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/pom.xml> to org.geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/community/target/community-2.10-SNAPSHOT-tests.jar> to org.geoserver/community/2.10-SNAPSHOT/community-2.10-SNAPSHOT-tests.jar
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1515,23\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1521,51\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[759,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[784,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[809,19\] error: cannot find symbol
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.10.x-OpenJDK8/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/PolymorphismWfsTest.java>:\[811,8\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
channel stopped
