[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #207
See <https://build.geoserver.org/job/geoserver-2.12.x/207/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8634] Import objects cannot be deleted when in COMPLETE state
[Andrea Aime] [GEOS-8165] Layer groups not queryable when members are not advertised
[...truncated 4.64 MB...]
Apr 27, 2018 6:43:02 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Apr 27, 2018 6:43:02 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Apr 27, 2018 6:43:02 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Apr 27, 2018 6:43:02 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Apr 27, 2018 6:43:02 PM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5012 this
Members [2] {
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.819 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.12-SNAPSHOT/gs-dxf-wps-2.12-SNAPSHOT-test-sources.jar
Apr 27, 2018 6:43:03 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Apr 27, 2018 6:43:03 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Apr 27, 2018 6:43:03 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Apr 27, 2018 6:43:08 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Apr 27, 2018 6:43:08 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Apr 27, 2018 6:43:08 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Apr 27, 2018 6:43:08 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 20 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 8 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.915 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.12-SNAPSHOT/gs-wps-cluster-hazelcast-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.750 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.308 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.560 s]
[INFO] Main Module ........................................ SUCCESS [02:11 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.080 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.935 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.482 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.724 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.113 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.434 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 41.409 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:38 min]
[INFO] Web Map Service Module ............................. FAILURE [ 8.039 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 17.679 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.091 s]
[INFO] Core UI Module ..................................... SUCCESS [01:14 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 13.980 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.055 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.065 s]
[INFO] Printing Module .................................... SUCCESS [ 15.876 s]
[INFO] Community Space .................................... SUCCESS [ 0.080 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.036 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.636 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.929 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.951 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.387 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.262 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.268 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.034 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.257 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.783 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.759 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 9.724 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.581 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.453 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.253 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.503 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 12.418 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.395 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 14.340 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.714 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.053 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.148 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.344 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.869 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.866 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 12.706 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.900 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.133 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.493 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.596 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:51 min (Wall Clock)
[INFO] Finished at: 2018-04-27T18:43:08+00:00
[INFO] Final Memory: 123M/1110M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wms/src/main/java/org/geoserver/wms/WMS.java&gt;:\[64,28\] error: package org.geotools.decorate does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wms/src/main/java/org/geoserver/wms/WMS.java&gt;:\[1067,41\] error: cannot find symbol
[ERROR] class WMS
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wms/src/main/java/org/geoserver/wms/WMS.java&gt;:\[1069,12\] error: cannot find symbol
[ERROR] class WMS
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wms/src/main/java/org/geoserver/wms/WMS.java&gt;:\[1069,31\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-2.12.x/208/display/redirect?page=changes&gt;
