See <https://build.geoserver.org/job/geoserver-2.15.x/448/display/redirect?page=changes>
Changes:
[gabriel.roldan] Fix data/minimal/styles/generic.xml pointing at generic.sld instead of
[...truncated 1.29 MB...]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/surefire-reports>
T E S T S
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.936 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.641 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[debug] Using AOSP style
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [94/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src>
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 56.256 sec
Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.668 sec
Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.31 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-bdb ---
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.802 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.235 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.425 s]
[INFO] Main Module ........................................ SUCCESS [ 55.074 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:20 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.265 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.726 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.599 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.123 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.519 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.646 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:03 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:37 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.336 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.845 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:22 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:22 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.488 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.981 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.515 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.061 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.721 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 50.659 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 5.862 s]
[INFO] Demos Module ....................................... SUCCESS [02:25 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.419 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.037 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.718 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.758 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 6.551 s]
[INFO] Community Space .................................... SUCCESS [ 0.024 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:29 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.454 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.937 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.066 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.848 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.810 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.316 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.303 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.078 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.474 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.339 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.082 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.269 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.289 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.037 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:10 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.922 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.251 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.522 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.462 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.576 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.344 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.676 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 21.300 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.164 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.477 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.056 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.520 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.303 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.253 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.155 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.146 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.157 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:56 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.976 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.069 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.518 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.501 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.043 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.866 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 37.477 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.314 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.039 s]
[INFO] Importer Core Module ............................... SUCCESS [ 31.703 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.724 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [01:01 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.241 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.249 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [02:26 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 49.244 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.438 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.638 s]
[INFO] REST SLD service ................................... SUCCESS [01:48 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 56.084 s]
[INFO] GeoFence Server .................................... SUCCESS [ 38.017 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:14 min (Wall Clock)
[INFO] Finished at: 2019-06-13T18:59:39Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user gabriel.roldan@anonymised.com
